Bass EQ for Filtered Movies - Page 464 - AVS Forum | Home Theater Discussions And Reviews
 32941Likes
post #13891 of 13966 Old 05-22-2020, 12:25 PM
Quoted: 3684 Post(s)
Liked: 15426
BassEQ Justice League Dark: Apokolips War (2020) DTS-HD MA 5.1
tbass2k, SBuger, galonzo and 7 others like this.
Take the Red Pill (BassEQ) BassEQ Demo Clips TR Curves
Video: Sony 85" X900F @ 80" eyes-to-screen (49.4° viewing angle)
Audio: Denon AVR-X4400H 7.2.4 Atmos
Mains: Fusion-15 LR, Fusion-8 Center, Ported Volt-10 Surrounds, Custom 45°/45° Double-Angled Ported Volt-6 Atmos
Subs: The Two Towers (HT18 32cf 11.5Hz x 2), UM18 4cf x 2, Crowson MAs x 4
aron7awol is offline
post #13892 of 13966 Old 05-22-2020, 02:25 PM
Liked: 15426
Still good through episode 7...
Originally Posted by aron7awol View Post
BassEQ Defending Jacob (2020) Season 1 Apple TV+ DD+ Atmos
Episodes 1-7 Only
Spoiler!
CallingMrBenzo likes this.
post #13893 of 13966 Old 05-22-2020, 02:38 PM
Liked: 15426
BassEQ Homecoming (2018) Season 2 Amazon DD+
The one really hot hit is at the very beginning of the first episode, so if you're concerned about that peak around 18Hz, just don't increase MV by the 3.5dB until after that hit.
CallingMrBenzo and djdanny like this.
post #13894 of 13966 Old 05-22-2020, 03:10 PM
Daniel Chaves's Avatar
Quoted: 701 Post(s)
Liked: 592
BassEQ Days of Thunder (1990) TrueHD 5.1
Spoiler!
Fighting with the noise but this should still be a big improvement.
THANK YOU!!!!
I will give it another listen this weekend! ^_^
aron7awol likes this.
Projector: BenQ w1500 + ES Sable 135" 16:9 Screen AVR: Marantz SR6011 ATMOS/DTSX + Pyle 2ch Amp + Darbee 5000s + miniDSP 2x4HD (for Subs) Speakers: Polk Audio TSX550t (FL/FR), CS2 Series II (C), FXiA6 (SL/SR), Monitor40 Series II (RL/RR), TSx110B (Ceiling FL/FR RL/RR) LFE: (2) Dayton 15" Subs + (2) ButtKicker LFE Arrangement: 7.1.4 Source: OPPO UDP-203 4k Bluray Player, HTPC, nVidia Shield TV Pro, Hauppauge OTA DVR
Daniel Chaves is offline
post #13895 of 13966 Old 05-22-2020, 04:06 PM
Hopinater's Avatar
Quoted: 3845 Post(s)
Liked: 12948
Heads up if you load Underwater using the BEQ designer, the last filter should be PEQ but it loads as Low Shelf.
CallingMrBenzo and aron7awol like this.
Subwoofers: PSA TV36 iPal X2 ...Speakers: PSA MTM-210T L/R - PSA MTM-210C Center- PSA MT110SR's Surrounds - RSL C34E Atmos... Motion Actuators: Crowson Shadow 8 - X2
Video: Samsung UN65KS9000 4K SUHD - Oppo UDP-203... AVR:Denon X4400... Gaming: XBOX ONE S
Guide to Subwoofer Calibration and Bass Preferences
Hopinater is online now
post #13896 of 13966 Old 05-22-2020, 10:17 PM
DesertDog's Avatar
Quoted: 1111 Post(s)
Liked: 2909
Fixed
Hopinater and aron7awol like this.
#IHateNalleh
The struggle is real for Generation Xplain Digital to the Analog and Analog to the Digital.
Klipsch RF-7III, RC-64III
SI HS-24mkIII BOSS-Sac
Sony 85X900F, Denon 8500, nVidia Shield, Apple TV
DesertDog is online now
post #13897 of 13966 Old 05-22-2020, 11:57 PM
richsto's Avatar
Quoted: 80 Post(s)
Liked: 142
Anyone using the MiniDSP 2x4 HD ever have one of the output channels stop outputting a signal? I am running dual subs seeing equal signal on the input side for both (linked) then when switching to the outputs I’m not seeing any output on Output 1 -Output 2 is fine. Essentially no output from the MiniDSP for subwoofer 1 in Configuration 1.
What is odd is that this only occurs in Configuration #1 - I get equal output (both output channels) on all the other Configurations. The settings are the same on all Configurations - I’ve triple checked unless I’m missing something. Is is possible for one of the outputs to go bad for a single Configuration?!?
richsto is offline
post #13898 of 13966 Old 05-23-2020, 06:22 AM
Quoted: 104 Post(s)
Liked: 49
If it works in the other configurations then it’s something with config1. Most likely a HP filter that isn’t bypassed.
Sent from my iPhone using Tapatalk Pro
My HT Build
Marantz SR6011 + Yamaha RX-V671. JVC RS-420 - 92" Elite Screens Cinetension 2 electric screen, Panasonic 65" plasma
7.3.4 Atmos setup - Definitive Technology - BP8 (2), CLR2500, Supercube II (2), Supercube 3 (1), BPX1.2x (2), BPX2 (2), DI 5.5 (4)
chrisnack is offline
post #13899 of 13966 Old 05-23-2020, 11:09 AM
ccarzoo's Avatar
Quoted: 57 Post(s)
Originally Posted by fatherom View Post
Couple basic questions from a noob who has a MiniDSP on order:
1) I don't HAVE to use BEQ designer, right? I can load a movie XML into the minidsp plugin software, load that profile into the minidsp (using my laptop), and then I can watch that movie, right?
2) Is there a particular movie (or better yet a scene), that is easy for A/B testing so when I get this set up, I can ensure it's working?
3) I have a modest setup...just one subwoofer...I'm presuming I can still reap the benefits of BEQ?
Chris
the dark knight rises opening scene in the plane.. the pressurization that it adds is legendary...
fatherom, SuperFist and aron7awol like this.
"Go Blue"
ccarzoo is offline
post #13900 of 13966 Old 05-23-2020, 11:14 AM
BigCoolJesus's Avatar
Quoted: 2643 Post(s)
Liked: 2026
So, got the Wifi adapter up and working and everything seems good to go. Quick question: is there a way to assign a Static IP to the Wifi adapter?
BigCoolJesus is offline
post #13901 of 13966 Old 05-23-2020, 11:15 AM
CallingMrBenzo's Avatar
Quoted: 781 Post(s)
Liked: 1950
I meant to ask if you ever got it!
Marantz 7011- Panasonic UB-820- Xbox One X - JVC RS4910 (FOR THE TIME BEING) * - Elite Screen's 2:35:1 AT 115' - PSA MTM 110's L/C/R - Mixed Surrounds - SVS Elevations Atmos X2 - Dual PSA TV36 B&C Neo's *MiniDSP HD* Took the Red Pill BEQ *HOVER BOSS*
CallingMrBenzo is offline
post #13902 of 13966 Old 05-23-2020, 11:18 AM
Liked: 2026
I forgot to send a message. Yup! Works perfectly. Just want to try and lock in a Static IP as I have found it way easier to manually enter the IP address when using the app or computer software rather than Auto (that can be hit or miss).
post #13903 of 13966 Old 05-23-2020, 01:22 PM
DesertDog's Avatar
Liked: 2909
Yes, I have one assigned to mine. It's a function of your router though and not the adapter. So how to do it is going to vary based on your router.
SuperFist and richardsim7 like this.
#IHateNalleh
post #13904 of 13966 Old 05-23-2020, 01:32 PM
shepP's Avatar
Quoted: 60 Post(s)
Liked: 26
For those using the IR remote is their a way to get it to receive commands while the USB cable is still plugged in? I need the USB cable to be plugged into the Wi-DG to load up a movie but I wanted to set a macro on my remote so when I start up my theatre system and shut it down, it automatically switches to config 1 which I save for non BEQ. I figured it would be a fool proof method to make sure I never left the minidsp with a BEQ for the wrong movie if I could get it to work.
shepP is offline
post #13905 of 13966 Old 05-23-2020, 03:54 PM
richardsim7's Avatar
Quoted: 1627 Post(s)
Liked: 2204
richardsim7 is offline
post #13906 of 13966 Old 05-23-2020, 07:34 PM
Liked: 15426
BassEQ Ashfall (2019) Korean TrueHD 5.1 / DTS-HD MA 5.1
Spoiler!
Good movie, solid bass/TR, good surround usage. Worth a watch!
SBuger and CallingMrBenzo like this.
post #13907 of 13966 Old 05-23-2020, 09:18 PM
Geronimo.USMC's Avatar
Quoted: 389 Post(s)
Liked: 260
If using merge in the BEQDESIGNER app, upgrade to the latest version, and rebuild the XML files.
- AUDIO: (7.1.4 ATMOS) Denon AVR-X3600H | McIntosh MC-8207 + CROWN XLS 2502, 1502 | KEF LS50, SVS Prime Elevations, RYTHMIK G25HP
- VIDEO: SONY OLED 65A9G | Panasonic UB820 | 44TB Synology DS1815+ | Dune Solo 4K | XBOX ONE X SCORPIO | PS4 PRO | Apple TV 4K | HTPC/Gaming Rig (Ryzen 3700X, GIGABYTE X570 I AORUS PRO WIFI, 16GB, STRIX OC 1080TI, Auzen HDMI XFi)
Geronimo.USMC is online now
post #13908 of 13966 Old 05-23-2020, 09:31 PM
Quoted: 104 Post(s)
Liked: 49
Ok Batman vs Superman in iTunes was insanely hot. I had to turn off my Crowson as it was overheating and my subs were struggling too. I initially had BEQ on but turned it off and it was still hot.
First time I’ve had any issues with anything.
My HT Build
post #13909 of 13966 Old 05-24-2020, 09:05 AM
phatfreeza's Avatar
Quoted: 97 Post(s)
Liked: 141
Cross posting from the Ultimate Bass in movies thread -
Hi folks,
Here's my thoughts on the Atmos vs DTS-HD version of War of the Worlds. I've included some RTA graphs(with BEQ) of some of the scenes so you can see what it's doing in my room.
TLDR - The Atmos track is definitely filtered under 30hz and does indeed affect rumble down under. Surprisingly, I feel the upper bass is a bit more nuanced and defined in the Atmos mix. The overhead effects stand out more in the Atmos mix. Still, that under 30hz stuff is the fun stuff! BEQ helps but still doesn't reach the levels of the DTS-HD track.
My HT: 7.3.4 Denon x4300h + denon stereo amp, Hsu HB1-MK2(6), HC1-MK2, Pioneer SP-T22A-LR(4), dual Rythmik fv25hp, b1200d, 65" LG OLEDB7A, xbone s, ps4 pro.
Classroom HT: 7.2.4 Onkyo TX-NR747, JBL L5 (LR), HSU HC-1 MK2(C), Pioneer SP-T22A-LR(4), Pioneer SP-C22 (2-Surrounds), monoprice 6.5" towers (2-Rear surrounds), svs pb12+/2, svs pc13, Epson Powerlite 99WH
phatfreeza is online now
post #13910 of 13966 Old 05-24-2020, 09:31 AM
ratm's Avatar
Quoted: 296 Post(s)
Liked: 120
This is such a great thread. But I can't find the answer to my most fundamental question. Can I use this somehow without a MiniDSP and input the data into my NX6000D's software?
ratm is offline
post #13911 of 13966 Old 05-24-2020, 02:14 PM
sirjaymz's Avatar
Quoted: 514 Post(s)
Liked: 625
Short Answer - No.
Long answer - Spend the $205 and enjoy the hard work that has already been done by the entire team, especially @aron7awol .
EDIT: actually it will be a little more than $205, as you need some of these cables and these.
HT1.0 | HT2.05 | Bass EQ for Filtered Movies
JVC RS-2000 / Seymour AV Center Stage 130"diag, 2.35 / nVidia Shield
11.2(22).6 Atmos / Denon 7200WA / Denon 6300 / 2x miniDSP2x4HD / DIY treatments
2x NU6000DSP / 2x NU3000DSP / 2x Klipsch R-112SW / 4x UM18-22 / 4x PA-460 / 12x JBL 12"
Klipsch RF-82II/RC-64II/RS-42II/RS-41II/RB-61II/CDT3800-C-II
sirjaymz is offline
post #13912 of 13966 Old 05-24-2020, 04:14 PM
Liked: 15426
Keep in mind that the iTunes streaming track is not necessarily the same as the lossless Atmos track (for the Extended Cut in this case) from the disc, which is the track I actually BEQed.
post #13913 of 13966 Old 05-25-2020, 07:00 AM
Quoted: 104 Post(s)
Liked: 49
Yup I figured. Regardless the mix was all messed up. Will have to check another movie or two. I had been mostly watching 4K/Blu-ray but I have a ton of movies in iTunes as well.
My HT Build
post #13914 of 13966 Old 05-25-2020, 10:07 AM
Nalleh's Avatar
Quoted: 3183 Post(s)
Liked: 4821
BassEQ Star Wars: Episode II - Attack of the Clones (2002)
Atmos / DTS-HD MA 6.1 / Disney+ DD+ Atmos
BTW, just wanted to report that that sub-5hz !!!! peak at ~1:51 run time is REAL!! And AWSOOOOME !! It show on both graphs, and i wondered if it was dangerous, but instead it was some of the coolest ULF effect i have experienced It comes during the Jedi fight at the area when a plasma cannon or something like that is fired. Man when it hit, the whole couch was in waves of motion, LOL absolutely over the top cool!! Had to play it a few times, LOL.
Otherwise, i have watched the 5 first ones of the Skywalker Saga, and i have to say the ULF has been off the charts!!!!!!!!
Either the BEQ’s are totally restoring all of them to demo glory, OR it is my new Fat Tube HB’s that is just crushing it, because i actually had to turn DOWN the LFE on most of them, which is unheard of for me, LOL.
Anyone else experience this?
BTW2: a bit dissapointed about the Atmos tracks, CLEARLY mixed in a 7.1.2 config, because they ALL have height effects in the top middle placement ONLY !!!! And a lot of speach also comes from the TM. Very strange and un-natural
BTW3: HOWEVER: i am enjoying the heck out of rewatching all of them
Such a cool revisit
m0j0, carp, phatfreeza and 5 others like this.
Dual AVR 13.1.8 SWAtmos - Atmos 13.1.8/DTS X 9.1.8/Auro 3D 13.1 - Denon AVCX8500H+AVRX7200WA - Klipsch+KEF - 4xSI18" - 12x12" w/6xSLAPS M12 VNF - 4x12"HB+2x18"CLHB - 6x Crowsons - 4xBK-LFE - 2x12"BB - 2x "4DX" fans- 6xNU6K - Minidsp 10x10HD - Oppo UDP203 - XB1X - ATV4K - JVC RS600 Dreamscreen V2 120"- Samsung QE82Q60.
>>>>Nalleh’s HT<<<<
Nalleh is offline
post #13915 of 13966 Old 05-25-2020, 06:14 PM
m0j0's Avatar
Quoted: 1312 Post(s)
Liked: 1962
Such a cool revisit
Yeah, attack of the clones has ridiculous ulf! I too had to turn mine down! I love the scene where they are in the arena fighting the big green preying mantis!
Nalleh likes this.
m0j0 is offline
post #13916 of 13966 Old 05-25-2020, 06:17 PM
m0j0's Avatar
Liked: 1962
Hi folks,
https://www.youtube.com/watch?v=XFPicBnYmkY
We watched the 4K version with BEQ and really enjoyed it. I was getting plenty of good TR with my setup so no complaints at all here.
m0j0 is offline
post #13917 of 13966 Old 05-25-2020, 06:20 PM
phatfreeza's Avatar
Quoted: 97 Post(s)
Liked: 141
Such a cool revisit
I want to say there are very few of us, even on here that can feel that sub 5hz spike. Must be bananas
Nalleh likes this.
post #13918 of 13966 Old 05-25-2020, 06:21 PM
phatfreeza's Avatar
Quoted: 97 Post(s)
Liked: 141
Nice! Did you do the -4MV adjustment? I might try watching it at -2MV and see how it feels.
post #13919 of 13966 Old 05-25-2020, 06:33 PM
Nalleh's Avatar
Liked: 4821
Agreed
I just wanted to confirm that in this case it was actually real content, not just some DC noise, or an artifact. And that if it was safe to run on my setup, it is defenitely safe to use for anyone with a lesser setup
And just to test: i tried that clip afterwards without BEQ, and that spike was barely noticable in my setup, but still cool, actually
>>>>Nalleh’s HT<<<<
Nalleh is offline
post #13920 of 13966 Old 05-25-2020, 06:47 PM
Nalleh's Avatar
Liked: 4821
That is the scene that has this effect !
It is after all the jedis come to help, Anakin and Obi gets their lightsabers, and there is a huge massive cannon fired at them.
Check it out at 1:51;20.
m0j0 and SuperFist like this.
>>>>Nalleh’s HT<<<<
Nalleh is offline
