Bass EQ for Filtered Movies - Page 484 - AVS Forum | Home Theater Discussions And Reviews
 34429Likes
post #14491 of 14746 Old 06-30-2020, 07:14 AM
BigCoolJesus's Avatar
Quoted: 2764 Post(s)
Liked: 2104
With more people now purchasing the HTP-1, I figure I'd do a quick and dirty walkthrough with screenshots as a fellow HTP-1/BEQ user. I know the BEQ guide discusses using the HTP-1 feature, but I was hoping this might be a little more cut and dry for those who want an easy visual guide.
Step 1: Access the HTP-1 option under Tools in BEQ
Step 2: Type in your HTP-1 IP address (leave the :80 at the end) and press the check mark box. A pop-up will then ask if your current version of HTP-1 supports shelf filters...assuming you are up to date say yes
Step 3 and 4: Choose the subwoofer EQ channel and then load your BEQ file directly from the repository folder you have saved on your computer (no alterations need to be made to the XML files/no merge process necessary)
Step 5: Press Add Filter. This will then show how many PEQ slots will be occupied (loading of filters always starts at PEQ slot 16 on the HTP-1) along with how a visual graph of the EQ response of those filters
Step 6: Press Sync to HTP-1. A small green check mark will appear once synced.
The next two screens show what two of the applied filters look like on the EQ screen of the HTP-1. Note: Any EQ under 20Hz has a red box around it as the Web GUI doesn't support going below 20Hz, however using the backdoor that BEQ Designer does allows filters down to 10Hz
Step 7 and 8: To clear the applied filters, press Remove Filter and then press the garbage can icon. This will clear out the EQ slots where filters were applied (the green box). Make sure to press Sync to HTP-1. If you go back into the EQ menu of the Web GUI interface, these slots will now be back to default.
That's it for a quick and dirty.
AFAIK, for those who want to add their own house curve, as long as you use EQ slots that will never be touched when BEQ loads filters (so start at Slot 1), they will never be touched/zeroed out when adding or removing BEQ specific filters.
Additionally: you can use the community made Preset Recorder program in the HTP-1 thread to add the ability to turn the HTP-1's PEQ on and off from a remote so that once done watching a movie you can simply have PEQ turn off (much like switching to an empty Config slot on the MiniDSP) with the click of a button.
Name:	Step 7 and 8.jpg
ID:	2751122   Click image for larger version
ID:	2751124   Click image for larger version
ID:	2751126   Click image for larger version
Name:	Step 3 and 4.jpg
ID:	2751128   Click image for larger version
ID:	2751132   Click image for larger version
Name:	HTP screen2.jpg
ID:	2751134   Click image for larger version
Name:	HTP screen1.jpg
BigCoolJesus is offline
post #14492 of 14746 Old 06-30-2020, 07:25 AM
Quoted: 3991 Post(s)
Liked: 16463
BassEQ Jeon Woochi (2009) Korean DTS-HD MA 5.1
I didn't want to force it on anyone by baking it into the BEQ, but I'd personally bump the subs by 5dB as well for this one.
Take the Red Pill (BassEQ) BassEQ Demo Clips TR Curves
Video: Sony 85" X900F @ 80" eyes-to-screen (49.4° viewing angle)
Audio: Denon AVR-X4400H 7.2.4 Atmos
Mains: Fusion-15 LR, Fusion-8 Center, Ported Volt-10 Surrounds, Custom 45°/45° Double-Angled Ported Volt-6 Atmos
Subs: The Two Towers (HT18 32cf 11.5Hz x 2), UM18 4cf x 2, Crowson MAs x 4
aron7awol is offline
post #14493 of 14746 Old 06-30-2020, 07:40 AM
d-rail34's Avatar
Quoted: 685 Post(s)
Liked: 1500
Originally Posted by aron7awol View Post
BassEQ Stardust (2007) DTS-HD MA 5.1
Spoiler!
Awesome! Thanks brutha!
I wasn’t sure how much content this one would have, but it looks like it could be pretty decent.
"Sticking feathers up your butt does not make you a chicken." - Tyler Durden
Living Room - Denon AVR-X2400H/MiniDSP 2X4HD/Hsu Research HB-1 Bookshelf (4) w/HC-1 Center/SVS PB12 Plus (1)/Samsung UN65H7150/Sony UBP-X800/PC Built by D-Rail/XBox One S/Rythmik T-Shirt (1)
d-rail34 is offline
post #14494 of 14746 Old 06-30-2020, 09:37 AM
mitchlampert's Avatar
Quoted: 187 Post(s)
Liked: 85
Maybe this can be added to the setup guide for easier reference?
mitchlampert is offline
post #14495 of 14746 Old 06-30-2020, 09:39 AM
peniku8's Avatar
Quoted: 445 Post(s)
Liked: 439
Originally Posted by phatfreeza View Post
the navy ship firing from that movie scared the crap out of me the first time i watched it. The whole movie up till that point was super quiet and then BAM. What'd you think?
How loud do you listen?? The only time I was scared was when I watched Godzilla with the sub some 30db hot (hint: not my usual setup).
I watched Hacksaw ridge with the EQ below, which includes the BEQ and my house curve. The super low stuff was great and I had some nice wind effects (port wind directly firing at my seat from 4' away), but the artillery could've had a bit more slam. Maybe I should adjust my house curve in the movie preset?
Edit: it just dawned on me that my longing for midbass may never be satisfied due to room issues. I have quite a nasty hole from 50 to 80Hz.
A Star Is Born - Lady Gaga goes Rock Audio&Video by Ocean Studios (me)
SKHorn Build
Samsung KS7500 - Marantz NR1504 - Klipsch R-26F - Klipsch R-25C - Klipsch R-15M - SKHorn - BOSS
Bass EQ for Filtered Video Games
peniku8 is offline
post #14496 of 14746 Old 06-30-2020, 10:04 AM
cdx47's Avatar
Quoted: 35 Post(s)
First thanks. Much appreciated.
Second. I don't know exactly what is happening in my room. One day I might go through REW but I experimented with a 6dB pseudo house curve on my outputs kind courtesy of someone on a different forum. I hoped the boost would help and it does. I wasn't hearing much difference on audio when using BEQ. I'll let you know what happens
Conrad Nash likes this.
cdx47 is online now
post #14497 of 14746 Old 06-30-2020, 10:05 AM
3ll3d00d's Avatar
Quoted: 2699 Post(s)
Liked: 3139
. A pop-up will then ask if your current version of HTP-1 supports shelf filters...assuming you are up to date say yes.
What version of the htp1 firmware are you on?
3ll3d00d is offline
post #14498 of 14746 Old 06-30-2020, 10:35 AM
Liked: 2104
Originally Posted by 3ll3d00d View Post
what version of the htp1 firmware are you on?
v 1.5.1
post #14499 of 14746 Old 06-30-2020, 10:54 AM
cdx47's Avatar
Quoted: 35 Post(s)
Wow this film really is bass light. I would rather not increase the sub volume so how would I bake this into my local BEQ config?
cdx47 is online now
post #14500 of 14746 Old 06-30-2020, 10:56 AM
Liked: 16463
Just put the input gain in your mDSP to +5. That's what I meant by bumping the subs up 5dB.
cdx47 and magicj1 like this.
post #14501 of 14746 Old 06-30-2020, 12:48 PM
Liked: 16463
BassEQ Flash Gordon (1980) DTS-HD MA 5.1
corwiniii and SuperFist like this.
post #14502 of 14746 Old 06-30-2020, 02:38 PM
Liked: 16463
BassEQ The Legend of Hercules (2014) Atmos
SuperFist likes this.
post #14503 of 14746 Old 06-30-2020, 03:22 PM
3ll3d00d's Avatar
Liked: 3139
v 1.5.1
Would you mind showing a pic of the dialog that pops up? The one that says "Reported software version is"
3ll3d00d is offline
post #14504 of 14746 Old 06-30-2020, 03:40 PM
Liked: 2104
Here ya go
post #14505 of 14746 Old 06-30-2020, 03:51 PM
3ll3d00d's Avatar
Liked: 3139
Here ya go
Ta. Now I see they made the v upper case, it is meant to be lower case! I will fix it to be case insensitive so then you don't get the dialog box any more.
shepP likes this.
3ll3d00d is offline
post #14506 of 14746 Old 06-30-2020, 04:37 PM
Liked: 2104
Awesome. Thanks!
post #14507 of 14746 Old 06-30-2020, 06:42 PM
d-rail34's Avatar
Quoted: 685 Post(s)
Liked: 1500
Spoiler!
Okay, this was surprisingly a really good movie. Not a great deal of ULF as you can see from the heatmap, but it does have a couple of pretty good wobble moments that's worth noting.
Thanks again for another great BEQ Aron!
Darrell
aron7awol likes this.
d-rail34 is offline
post #14508 of 14746 Old 06-30-2020, 06:47 PM
Geronimo.USMC's Avatar
Quoted: 391 Post(s)
Liked: 265
Why do I keep getting errors merging with BEQ Designer? Yesterday was one, but today there are 6! See below....
bmiller_miniDSPBEQ - Movie BEQs - Flash Gordon (1980) (-0.5 gain) BEQ DTS-HD MA 5.1.xml - Different input filters found in C:\Users\G\.beq\bmiller_miniDSPBEQ\Movie BEQs\Flash Gordon (1980) (-0.5 gain) BEQ DTS-HD MA 5.1.xml - Input 1: {'1': {'freq': '120', 'q': '1', 'boost': '0.3', 'type': 'PK', 'bypass': '0'}, '6': {'freq': '38', 'q': '0.8', 'boost': '7.5', 'type': 'SL', 'bypass': '0'}, '7': {'freq': '38', 'q': '0.8', 'boost': '7.5', 'type': 'SL', 'bypass': '0'}, '8': {'freq': '38', 'q': '0.8', 'boost': '7.5', 'type': 'SL', 'bypass': '0'}, '9': {'freq': '38', 'q': '0.8', 'boost': '7.5', 'type': 'SL', 'bypass': '0'}, '10': {'freq': '10', 'q': '0.9', 'boost': '-6', 'type': 'SL', 'bypass': '0'}} - Input 2: {'1': {'freq': '35', 'q': '1', 'boost': '0.4', 'type': 'PK', 'bypass': '0'}, '9': {'freq': '11', 'q': '0.9', 'boost': '5', 'type': 'SL', 'bypass': '0'}, '10': {'freq': '11', 'q': '0.9', 'boost': '5', 'type': 'SL', 'bypass': '0'}}
bmiller_miniDSPBEQ - Movie BEQs - Hell or High Water (2016) (+5.5 gain) BEQ DTS-HD MA 5.1.xml - Different input filters found in C:\Users\G\.beq\bmiller_miniDSPBEQ\Movie BEQs\Hell or High Water (2016) (+5.5 gain) BEQ DTS-HD MA 5.1.xml - Input 1: {'1': {'freq': '80', 'q': '1', 'boost': '0.6', 'type': 'PK', 'bypass': '0'}, '6': {'freq': '35', 'q': '0.9', 'boost': '6.6', 'type': 'SL', 'bypass': '0'}, '7': {'freq': '35', 'q': '0.9', 'boost': '6.6', 'type': 'SL', 'bypass': '0'}, '8': {'freq': '11', 'q': '0.9', 'boost': '5', 'type': 'SL', 'bypass': '0'}, '9': {'freq': '11', 'q': '0.9', 'boost': '5', 'type': 'SL', 'bypass': '0'}, '10': {'freq': '11', 'q': '0.9', 'boost': '5', 'type': 'SL', 'bypass': '0'}} - Input 2: {'1': {'freq': '35', 'q': '1', 'boost': '0.4', 'type': 'PK', 'bypass': '0'}, '9': {'freq': '11', 'q': '0.9', 'boost': '5', 'type': 'SL', 'bypass': '0'}, '10': {'freq': '11', 'q': '0.9', 'boost': '5', 'type': 'SL', 'bypass': '0'}}
bmiller_miniDSPBEQ - Movie BEQs - Jeon Woochi (2009) (Korean) (+3.5 gain) BEQ DTS-HD MA 5.1.xml - Different input filters found in C:\Users\G\.beq\bmiller_miniDSPBEQ\Movie BEQs\Jeon Woochi (2009) (Korean) (+3.5 gain) BEQ DTS-HD MA 5.1.xml - Input 1: {'10': {'freq': '20', 'q': '0.7', 'boost': '5', 'type': 'SL', 'bypass': '0'}} - Input 2: {'1': {'freq': '35', 'q': '1', 'boost': '0.4', 'type': 'PK', 'bypass': '0'}, '9': {'freq': '11', 'q': '0.9', 'boost': '5', 'type': 'SL', 'bypass': '0'}, '10': {'freq': '11', 'q': '0.9', 'boost': '5', 'type': 'SL', 'bypass': '0'}}
bmiller_miniDSPBEQ - Movie BEQs - Stardust (2007) (-0.5 gain) BEQ DTS-HD MA 5.1.xml - Different input filters found in C:\Users\G\.beq\bmiller_miniDSPBEQ\Movie BEQs\Stardust (2007) (-0.5 gain) BEQ DTS-HD MA 5.1.xml - Input 1: {'1': {'freq': '52', 'q': '1', 'boost': '0.5', 'type': 'PK', 'bypass': '0'}, '2': {'freq': '10', 'q': '5', 'boost': '-14', 'type': 'PK', 'bypass': '0'}, '8': {'freq': '23', 'q': '0.9', 'boost': '5', 'type': 'SL', 'bypass': '0'}, '9': {'freq': '23', 'q': '0.9', 'boost': '5', 'type': 'SL', 'bypass': '0'}, '10': {'freq': '10', 'q': '0.9', 'boost': '6', 'type': 'SL', 'bypass': '0'}} - Input 2: {'1': {'freq': '35', 'q': '1', 'boost': '0.4', 'type': 'PK', 'bypass': '0'}, '9': {'freq': '11', 'q': '0.9', 'boost': '5', 'type': 'SL', 'bypass': '0'}, '10': {'freq': '11', 'q': '0.9', 'boost': '5', 'type': 'SL', 'bypass': '0'}}
bmiller_miniDSPBEQ - Movie BEQs - The Legend of Hercules (2014) (-2.5 gain) BEQ Atmos.xml - Different input filters found in C:\Users\G\.beq\bmiller_miniDSPBEQ\Movie BEQs\The Legend of Hercules (2014) (-2.5 gain) BEQ Atmos.xml - Input 1: {'1': {'freq': '50', 'q': '1', 'boost': '0.5', 'type': 'PK', 'bypass': '0'}, '8': {'freq': '22', 'q': '0.9', 'boost': '5.3', 'type': 'SL', 'bypass': '0'}, '9': {'freq': '22', 'q': '0.9', 'boost': '5.3', 'type': 'SL', 'bypass': '0'}, '10': {'freq': '10', 'q': '0.9', 'boost': '5', 'type': 'SL', 'bypass': '0'}} - Input 2: {'1': {'freq': '35', 'q': '1', 'boost': '0.4', 'type': 'PK', 'bypass': '0'}, '9': {'freq': '11', 'q': '0.9', 'boost': '5', 'type': 'SL', 'bypass': '0'}, '10': {'freq': '11', 'q': '0.9', 'boost': '5', 'type': 'SL', 'bypass': '0'}}
bmiller_miniDSPBEQ - TV Shows BEQ - Penny Dreadful City of Angels (2020) (Season 1) (Amazon) (+5.5 gain) BEQ DD+.xml - Different input filters found in C:\Users\G\.beq\bmiller_miniDSPBEQ\TV Shows BEQ\Penny Dreadful City of Angels (2020) (Season 1) (Amazon) (+5.5 gain) BEQ DD+.xml - Input 1: {'1': {'freq': '50', 'q': '1', 'boost': '0.5', 'type': 'PK', 'bypass': '0'}, '8': {'freq': '25', 'q': '1', 'boost': '5.5', 'type': 'SL', 'bypass': '0'}, '9': {'freq': '11', 'q': '0.9', 'boost': '4.3', 'type': 'SL', 'bypass': '0'}, '10': {'freq': '11', 'q': '0.9', 'boost': '4.3', 'type': 'SL', 'bypass': '0'}} - Input 2: {'1': {'freq': '35', 'q': '1', 'boost': '0.4', 'type': 'PK', 'bypass': '0'}, '9': {'freq': '11', 'q': '0.9', 'boost': '5', 'type': 'SL', 'bypass': '0'}, '10': {'freq': '11', 'q': '0.9', 'boost': '5', 'type': 'SL', 'bypass': '0'}}
- AUDIO: (7.1.4 ATMOS) Denon AVR-X3600H | McIntosh MC-8207 + CROWN XLS 2502+1502 | KEF LS50, SVS Prime Elevations, RYTHMIK G25HP
- VIDEO: SONY OLED 65A9G | Panasonic UB820 | 44TB Synology DS1815+ | Dune Solo 4K | XBOX ONE X SCORPIO | PS4 PRO | Apple TV 4K | HTPC/Gaming Rig (Ryzen 3900XT, ASUS ROG Strix X570-I, 32GB, 2080TI FE, Auzen HDMI XFi)
Geronimo.USMC is offline
post #14509 of 14746 Old 06-30-2020, 06:52 PM
Quoted: 391 Post(s)
Liked: 265
the message means the filters in the config file has a different filter in input 1 vs input 2, merge process expects them to be the same or only one slot to have any (non bypassed, boost > 0) filters in it
in this case, input 2 has fewer active filters (peq 1, 9, 10 vs 1, 6, 7, 8, 9, 10)
i.e. file in repo needs a fix
post #14510 of 14746 Old 06-30-2020, 11:01 PM
3ll3d00d's Avatar
Liked: 3139
Because new files are added with the same problem
Geronimo.USMC likes this.
3ll3d00d is offline
post #14511 of 14746 Old 06-30-2020, 11:34 PM
TimoJ's Avatar
Quoted: 475 Post(s)
Liked: 264
With the Preset Recorder you can also make a remote control preset to zero all upper slot dB values instead of turning the PEQ fully off. (In case you want to use first PEQ slots for your own permanent corrections.)
shepP likes this.
TimoJ is online now
post #14512 of 14746 Old 07-01-2020, 12:36 AM
Quoted: 391 Post(s)
Liked: 265
Yes. These are the movies with the problematic files.
Flash Gordon
Hell or High Water
Jeon Woochi
Stardust
post #14513 of 14746 Old 07-01-2020, 02:19 AM
corwiniii's Avatar
Quoted: 102 Post(s)
Liked: 254
THANK YOU! Looks like you really were able to dig out some LFE from this anemic sounding movie. I cannot wait to re-watch what is widely considered by critics and viewers alike to be the greatest movie ever written, acted, and directed!
At least the soundtrack is solid.
Klipsch RP-8000F L/R | Klipsch RP-504C C | Klipsch RP-500SA atmos | elemental Designs A6-6T6 MTM surrounds | Rythmik FV18 Rev2 Paper Cone Black Matte + Elemental Designs A5-350 Restored! | Denon AVR-S920W | Vizio P75-C1
corwiniii is offline
post #14514 of 14746 Old 07-01-2020, 07:08 AM
peniku8's Avatar
Quoted: 445 Post(s)
Liked: 439
@3ll3d00d I just wondered why BEQd can't export biquad txt files for miniDsp. Sounds like a convenient way for me to load BEQs than via the XML. Is it a cross-compatibility thing? Could you possibly add that feature?
SKHorn Build
peniku8 is offline
post #14515 of 14746 Old 07-01-2020, 07:28 AM
richardsim7's Avatar
Quoted: 1674 Post(s)
Liked: 2256
https://beqdesigner.readthedocs.io/e...xport_biquads/
peniku8 likes this.
richardsim7 is offline
post #14516 of 14746 Old 07-01-2020, 07:47 AM
3ll3d00d's Avatar
Liked: 3139
As Richard notes, it can do this already though I don't know how that is more convenient than the merge tool (I don't use a minidsp though ....)
3ll3d00d is offline
post #14517 of 14746 Old 07-01-2020, 08:27 AM
Nalleh's Avatar
Quoted: 3296 Post(s)
Liked: 5133
^^^ I still use the save as biquads for my 10x10HD exlusively ! It is two seconds work before each movie i watch, but it loads INSTANT to the mDSP, while the merge way takes forever to load each file to the mDSP.
I know, i am quirky 😂😂
m0j0 likes this.
Dual AVR 13.1.8 SWAtmos - Atmos 13.1.8/DTS X 9.1.8/Auro 3D 13.1 - Denon AVCX8500H+AVRX7200WA - Klipsch+KEF - 4xSI18" - 12x12" w/6xSLAPS M12 VNF - 4x12"HB+2x18"CLHB - 6x Crowsons - 4xBK-LFE - 2x12"BB - 2x "4DX" fans- 6xNU6K - Minidsp 10x10HD-Vertex2-Oppo UDP203-XB1X-ATV4K-JVC RS600-Dreamscreen V2 120"-Samsung QE82Q60.
>>>>Nalleh’s HT<<<<
Nalleh is offline
post #14518 of 14746 Old 07-01-2020, 08:38 AM
peniku8's Avatar
Quoted: 445 Post(s)
Liked: 439
Could've sworn I searched everything..! It convenient for me as I do my own BEQs on the fly for the German movies I watch. I have not used the merge tool and I have not looked at that yet, but exporting the biquads is really everything I need for maximum convenience. I change my miniDsp config a lot, so the XML files would quickly become outdated.
SKHorn Build
peniku8 is offline
post #14519 of 14746 Old 07-01-2020, 04:20 PM
DesertDog's Avatar
Quoted: 1160 Post(s)
Liked: 3081
Flash Gordon
Hell or High Water
Jeon Woochi
Stardust
I don't know what's causing this is to happen. I'll take a look at them when I can but it's probably not going to be for a few days at least. I've been down sick with covid since the 20th and my head isn't 100% here for digging through data sets. So once my head's up to it I'll take a look.
#IHateNalleh
The struggle is real for Generation Xplain Digital to the Analog and Analog to the Digital.
Klipsch RF-7III, RC-64III
SI HS-24mkIII BOSS-Sac
Sony 85X900F, Denon 8500, nVidia Shield, Apple TV
DesertDog is online now
post #14520 of 14746 Old 07-01-2020, 04:49 PM
subacabra's Avatar
Quoted: 1980 Post(s)
Liked: 5809
Hope you feel better soon! What kind of symptoms etc are you experiencing if you don't mind me asking?
DesertDog likes this.
subacabra is offline
