Bass EQ for Filtered Movies - Page 60 - AVS Forum | Home Theater Discussions And Reviews
 25347Likes
post #1771 of 10441 Old 10-22-2018, 06:45 PM
Quoted: 27 Post(s)
Liked: 78
Originally Posted by aron7awol View Post
Your cautiousness is warranted, and I really cannot recommend applying a BEQ from a known mix onto an unknown mix. Short of using BEQ Designer to check it yourself, you can post a request in here, and I might be able to help you.
Your normal sub EQ can stay in place while using BEQ. Remember, BEQ is really only making the mix something closer to full-bandwidth. As long as your system is properly set up to handle the elite full-bandwidth flicks like The Incredible Hulk and The Hurricane Heist, to name a couple examples, then it should be able to handle BEQ just the same.
Thank you for your response!
That makes sense, I did a quick search at start of thread, looks like there are instructions to try BEQ designer at the bottom of post #4 .
I will definitely be trying that, I love experimenting!
Thanks again
Paulo Franco is offline
post #1772 of 10441 Old 10-22-2018, 07:30 PM
Nalleh's Avatar
Quoted: 2562 Post(s)
Liked: 3451
I can't commit to that just yet! ~340 movies is a TON to go back through. I'll probably work my way through them as they pop up in the thread, my mind, or my watch list. That's kind of what's been happening with the older style posts that I have been updating here and there in a similar fashion, while staying up to date with the new stuff as it comes out.
Speaking of which, Daredevil Season 3 needs some love from me!
Understood and no worries After all, the BEQ data is already there, the spectrum is just a visual aid
Do you have to do them all over or will opening your BEQ projects in the newest version make them "fall into place" ?
Dual Atmos Receivers - Atmos 13.1.8/DTS X 9.1.8/Auro 3D 13.1 - Denon AVCX8500H+AVRX7200WA - Klipsch+KEF - 6xSI18" - 12xJBL 12" w/6xSLAPS M12 downfiring VNF - 3x2 stacked Crowson MA - 4xBK-LFE - 6xNU6K(fan&trig mod) - Minidsp 10x10HD - Oppo UDP203 - XBox OneX - Apple TV4K - JVC RS600 Dreamscreen V2 120"- Philips 65OLED873.
Nalleh’s HT
Nalleh is offline
post #1773 of 10441 Old 10-22-2018, 07:30 PM
Quoted: 2794 Post(s)
Liked: 11928
Here's a major update:
BEQ Oblivion (2013) Atmos
Take the Red Pill (BassEQ) BassEQ Demo Clips
Video: Sony 85" X900F @ 80" eyes-to-screen (49.4° viewing angle)
Audio: Denon AVR-X4400H 7.2.4 Atmos
Mains: Fusion-15 LR, Custom Tapered Ported Volt-6 Center, Ported Volt-10 Surrounds, Custom 45°/45° Double-Angled Ported Volt-6 Atmos
Subs: The Two Towers (HT18 32cf 11.5Hz x 2), UM18 4cf x 2, Crowson MAs x 4
aron7awol is online now
post #1774 of 10441 Old 10-22-2018, 07:44 PM
Liked: 11928
BEQ Charlotte's Web (2006) DTS-HD MA 5.1
SuperFist, Nalleh and biga6761 like this.
post #1775 of 10441 Old 10-22-2018, 08:05 PM
Liked: 11928
BEQ The Foreigner (2017) DTS-HD MA 7.1
post #1776 of 10441 Old 10-22-2018, 08:08 PM
Nalleh's Avatar
Liked: 3451
^^ The spectrums look awsome now, Aron. Very easy to see the difference, even though these aren’t extreme BEQ’s
And not only BEQ/noBEQ, but also between movies. Just these three last ones are very different in the spectrum.
aron7awol and biga6761 like this.
Nalleh’s HT
Nalleh is offline
post #1777 of 10441 Old 10-22-2018, 08:24 PM
Liked: 11928
I agree. I tweaked the aspect ratio a bit, and I'm really happy with that particular style with the 1-40 range and that marker size.
post #1778 of 10441 Old 10-23-2018, 04:08 AM
NM20's Avatar
Quoted: 14 Post(s)
This is an amazing thread, thanks to all who have contributed.
I want to use my iNuke DSP to do something similar, but I am struggling to understand where to enter the info.
Taking Avengers Infinity War as an example
LS 19Hz Q0.9 3.8dB x 4 (15.2dB total)
Does this mean apply a Low Shelf at 19hz with a Q rating of 0.9 and a +3.8db gain?
What I am not sure about is the iNuke can do a LS6 or an LS12, which do I use?
Also I don't understand the X4. The inuke can apply 8 filters per channel in the PEQ and 2 in the DEQ. I assume I use the PEQ and not the DEQ. But how do I do the X4? Do I set 4 of the filters on 19hz and apply 3.8 to each one?
NM20 is offline
post #1779 of 10441 Old 10-23-2018, 04:34 AM
3ll3d00d's Avatar
Quoted: 2476 Post(s)
Liked: 2688
The inuke does not support variable Q LS filters so you would have to manually work out (through trial and error) an approximation using the available LS and PEQ filters. IIRC an LS6 in the inuke equates to a low shelf with S=1 and LS12 equates to a low shelf with S=2, I might be misremembering this though so it would be something to double check. MSO supports the inuke via its filters so one could create that filter in MSO and compare to the equivalent filter in BEQD to be sure.
if it says x4 then it means enter the same filter 4 times.
3ll3d00d is offline
post #1780 of 10441 Old 10-23-2018, 06:29 AM
Spidacat's Avatar
Quoted: 282 Post(s)
Liked: 383
I did hear back from the folks at miniDSP. The variable color LED obviously still isn't implemented, but it is on their to-do list. People have been asking about it on their forum since January, so it must not be a big priority.
aron7awol and Nalleh like this.
Spidacat is offline
post #1781 of 10441 Old 10-23-2018, 06:48 AM
NM20's Avatar
Quoted: 14 Post(s)
So to be crystal clear, I would put the same filter on 4 times for Avengers Infinity war. So LS12, 19hz Q0.9, gain 3.8 and repeat three more times? Couldn't I just put a gain of 7 twice?
NM20 is offline
post #1782 of 10441 Old 10-23-2018, 07:15 AM
3ll3d00d's Avatar
Liked: 2688
I think you've missed my point, the inuke does not support variable Q LS filters and it also does not allow entry of filters below 20Hz. This means you will have to experiment to find out how to replicate this filter with the filters you have avaiable.
probably the FAQ posts in the thread need an explanation for this one, simple answer is the total filter shape will change if you do that.
biga6761 likes this.
3ll3d00d is offline
post #1783 of 10441 Old 10-23-2018, 07:40 AM
NM20's Avatar
Quoted: 14 Post(s)
Thanks for taking the time to respond. I may just be better buying a used MiniDSP if I see one come up.
NM20 is offline
post #1784 of 10441 Old 10-23-2018, 08:25 AM
biga6761's Avatar
Quoted: 219 Post(s)
Liked: 833
Hey brother Aron did Goosebumps(Atmos) ever receive your magic BEQ touch? I can't find it anywhere if it did and a search didn't turn up anything.
If it hasn't I would like to formally request it please. TIA.
aron7awol likes this.
Epson 5040UB-125" Silver Ticket 2.35:1-Xbox One S- HTPC JRiver MC24
Marantz av7702 - Crestron CNAMPX-12x60 Fully Bridged to 6x220 - 2_Crown Xls 2000's
Crown Xls 1500 - Qsc RMX 1450 - Qsc RMX 850 - 2_Inuke 3kDSP's - Inuke 6kDSP
Speakers}7.4.4 Atmos DIYSoundGroup HTM-12's, Volt-8's
Subs}8 SI HT-18 v.2's SBA 11hz Ported IB-Nr Fld 2_PA460 MBM's-UM18 FMarty-2_Buttkicker's
biga6761 is offline
post #1785 of 10441 Old 10-23-2018, 12:51 PM
Quoted: 259 Post(s)
Liked: 130
Is the normal MiniDSP 2x4 okay for my situation running dual subs only? Does the power output important in my small room to go with the HD version?
Paopawdecarabao is online now
post #1786 of 10441 Old 10-23-2018, 01:08 PM
nsiret's Avatar
Quoted: 26 Post(s)
PEQ Filter Question
First off, many thanks to aron7awol, PioManiac, 3ll3d00d for making this thread one of the best on AVSforum. Really appreciate the time and effort the 3 of you put into helping everyone with Bass EQ.
I have not visited this thread for a while and recently noticed on some movies, there is a final filter with a type of PEQ. Sorry if this seem obvious, but I can't figure out how to add this last filter using the 2x4 HD plug-in. I do not see PEQ in the filter type dropdown.
Also, any chance of getting the BEQ for "3:10 to Yuma"?
Thanks again!
Nick
nsiret is offline
post #1787 of 10441 Old 10-23-2018, 01:09 PM
Liked: 11928
I added to the BEQ FAQ with the question about smaller filters. Can anyone think of any other FAQs I've answered in the past and should add to it?
The BEQ FAQ
1. Is BEQ dangerous?
I totally understand the fear of asking a sub to do too much and blowing it up. I also understand people thinking, "OMGZ, 20-30dB boost down into the teens and single digits! My sub is now a smoke machine!" Those boosts do look really scary, without the proper context.
I think the important thing is not to look at it like we're boosting our subs by 20-30dB. We're really not. We're boosting super-low level content within the mix by 20-30dB to bring it back up to normal levels that exist in content that is readily available and played on those same subs every day without batting an eye. That goes for huge subs, tiny subs, ported subs, sealed subs, subs of all shapes and sizes. Even the guy with the 10" sub should be able to BEQ without any fear of breaking his sub. Granted, he won't get much benefit if his sub only digs down to 25Hz, and that might be a reason for him not to bother with BEQ, but danger should not be.
Now, all that being said, if you do something ignorant/stupid/forgetful and leave the shelves enabled and play War of the Worlds, that's another story. But that's not any more irresponsible than running your 10" sub 20dB hot with a house curve and no HPF. Any full-bandwidth content will be doing the same kind of damage at that point. So for the newbies, tread carefully, study up, read the FAQ that doesn't exist yet, make sure you know what you're doing, and then there's nothing to be afraid of. Jump in with two feet. The water's warm. Actually, it's blistering hot, because if you're reading this thread, that's how you like your bass!
2. Why do you use multiple small filters instead of one big one?
The reason for using multiple smaller filters is twofold:
1. You can achieve a steeper slope with lower Q, and thus less overshoot.
2. A lower frequency, a higher Q, and a higher gain will all push the biquad coefficients closer to the limitations of their precision. Using multiple smaller filters will help with a lower Q and lower gain, giving those biquad coefficients more "headroom" as far as their precision limitations. This can be especially important with the MiniDSP 2x4HD, because it uses 96kHz sample rate which eats into that headroom. Running into the precision limitations would manifest itself as "error" in the implementation of the filters in the DSP. In other words, the actual result of the filter would differ from the expected result.
post #1788 of 10441 Old 10-23-2018, 01:09 PM - Thread Starter
PioManiac's Avatar
Quoted: 3338 Post(s)
Liked: 8434
Thanks again!
Nick
When Aron puts PEQ = Peak Filter
brahman12 and biga6761 like this.
The Unfinished Basement Theater & Whisky Guitar Lounge | Bass EQ for Filtered Movies
JVC DLA X750 4K Projector | 120" Powered Drop Screen | 65" LG 65B6P OLED | Panasonic DMP UB900 | Oppo UDP 203 | HDFury Vertex
Yamaha RX-A3070 | 7.4.4.4 | Mission M3i x11 | Funk Audio 18.0 x2 | Velodyne DLS 5000R x2 | Crowson LvL3 MA x4 | miniDSP 2x4HD
PioManiac is offline
post #1789 of 10441 Old 10-23-2018, 01:15 PM
Liked: 11928
If you are buying one, I think it's worth the extra money for the HD version.
The PEQ is a Peak EQ filter. You should see Peak in your list.
FYI, if you see a last small filter like that, it will either be a LS or a Peak, but in either case, it is to counter the overshoot of the other LS filters with higher Q. I use a LS if I have the headroom to do so, otherwise I use a Peak.
I'm pretty sure I did a BEQ for 3:10 to Yuma, but I'm not seeing one, so I'll have to do one tonight along with Goosebumps.
post #1790 of 10441 Old 10-23-2018, 01:22 PM
nsiret's Avatar
Quoted: 26 Post(s)
Thanks to both you and aron7awol for the quick response! Appreciate it.
Nick
nsiret is offline
post #1791 of 10441 Old 10-23-2018, 01:42 PM - Thread Starter
PioManiac's Avatar
Liked: 8434
Both models are 2 inputs x 4 outputs ....so the number of Subs (or sub power) is no different.
The HD model has a boat load of features, options, twice as many filters, compatible with other devices via IR and USB, But perhaps more importantly ...
10x the processing power (96kHz sample rate) So it's much less likely to experience distortion or clipping.
I had the regular 2x4 first but sold it and upgraded to the HD model before I even loaded my first BEQ.
If you already have a 2x4, you are certainly free to try it out.
But like Aron said, if you are buying new now, spend the extra $90 and never second guess.
SuperFist and biga6761 like this.
post #1792 of 10441 Old 10-23-2018, 03:15 PM
Liked: 11928
BEQ Goosebumps (2015) Atmos
Note: The DTS-HD MA 5.1 track has been validated as safe to use with this BEQ by @paulst :
Spoiler!
brahman12, SuperFist and biga6761 like this.
post #1793 of 10441 Old 10-23-2018, 03:19 PM
Liked: 11928
BEQ 3:10 to Yuma (2007) DTS:X
post #1794 of 10441 Old 10-23-2018, 03:50 PM
Liked: 11928
Updated...has anyone else tried this one yet?!? It is EPIC!
BEQ Unbroken (2014) Atmos
If you want to feel the flak like a real man, this BEQ is for you.
post #1795 of 10441 Old 10-23-2018, 03:59 PM
richardsim7's Avatar
Quoted: 1392 Post(s)
Liked: 1820
Still need to try that one
richardsim7 is offline
post #1796 of 10441 Old 10-23-2018, 04:00 PM
3ll3d00d's Avatar
Liked: 2688
a sneak preview for @aron7awol
elliptic markers
also user selection of the time vs freq tradeoff & some traditional spectrogram rendering options too
(build to follow tomorrow at some point)
aron7awol, Nalleh and biga6761 like this.
3ll3d00d is offline
post #1797 of 10441 Old 10-23-2018, 04:49 PM
Nalleh's Avatar
Liked: 3451
Maybe this
Like: what is the PEQ and what does it do?
And :
And maybe a note about the "antiboomy" filter like on AB.
The HPF filter if the house shakes mentioned earlier.
Nalleh’s HT
Nalleh is offline
post #1798 of 10441 Old 10-23-2018, 06:47 PM
Liked: 11928
BEQ The Spy Who Dumped Me (2018) Atmos
post #1799 of 10441 Old 10-23-2018, 07:27 PM
Liked: 11928
BEQ Daredevil Season 3 (2018) DD+ Atmos
brahman12, SuperFist, femi and 1 others like this.
post #1800 of 10441 Old 10-23-2018, 07:48 PM
Liked: 11928
BEQ Radius (2017) DTS-HD MA 5.1
