SVS PB13 Ultras just set up-- not overly impressed, What am I Missing? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 147Likes
post #61 of 168 Old 08-09-2018, 03:56 PM - Thread Starter
Quoted: 1383 Post(s)
Liked: 1588
Called SVS, we went thru AVR to make sure settings ok
the only change was LPF to LFE from 80hz where I had to increase to 120hz
they saying possible damage to amps? Both of them?? Seems nearly unthinkable but I guess its possible....
Going to take @Montucky suggestion and turn off one Sub
Set up #1 Speakers LR: Tekton Enzo XL ; Center: Tekton Pendragon Subs (2) 2019 JTR 118HTs
Set up #2 : QA3020i LR, Center: Emotiva C1 Subs (2) HSU VTF2 MK5,
mpk1970 is offline
post #62 of 168 Old 08-09-2018, 03:56 PM
madhuski's Avatar
Quoted: 1656 Post(s)
Liked: 1118
Originally Posted by mpk1970 View Post
Dont disagree, but they should be substantially better than petty HSU VTF2s
i may have missed it earlier but are you using RCA or XLR cables?
sounds like a pre-out voltage issue if your not hearing any output
madhuski is online now
post #63 of 168 Old 08-09-2018, 04:02 PM
farsider3000's Avatar
Quoted: 1719 Post(s)
Liked: 1097
After PB13 Ultra's delivered on Monday, had to wait for my son to help when he got to house yesterday.
Finally, set them up and started to play with them. I had the HSU VTF2 MK5s. These subs do create some difficulty now in my configuration with the Emotiva T2 towers due to their size.
(See pics)
Before I could fit the HSU and EMotiva's in the corner, now I cant rather have to put the T2s in the front of cabinet
But, I am not seeing that big of a difference in sound vs. HSU's
. A little bit yes, but not dramatic enought for the $3K cost for duals. I'm going to play with them a little more but now I'm thinking about ordering the Monolith 15s while I have the SVS PB 13Ultra's here to do a head to head. Is there something I'm not doing right? My florida room also is a nightmare with all the glass but HSUs just seem to be more efficient.
I had the SVS volume at 0, and now calibrated to -10 but haven't played them since changing -10 as I will this weekend.
Also have all crossovers at 80, lpf>lfe at 80
Option 1, just return the SVS subs and keep the HSU's be happy with those subs as they do make the room less crowded and aesthetically more pleasing.
Option 2, order Monolith 15s do head to heard (little worried in Mono's not better now have to pay $300+ for shipping back)
I didnt want to spend more than 3K on subs because its not worth it with the little bit of HT usage per month....but I do want that awesome experience when I do.
Im not a big user of subs, maybe 4-6x per month for movies...that's about it.
I'm asking for any suggestions?? Help? Opinions....
NOTE: Pics 1st is back of Florida room which is like 35-40 length, 14 feet wide
2nd pic- up closer to see configuration
There are a lot of things to look at here but if your receiver set the subs to -10 it’s very likely you will want them about 3-8 dB higher than that to have any fun at all.
For a room that size the smaller diameter woofers in the PB will not be able to produce that Thor’s hammer effect when explosions hit, monster footsteps etc depending on where your bass nulls are located.
Room placement makes a huge difference as well. Manual EQ can help smooth out the response and I generally find I do not like the way my subs sound letting Audyssey or other “auto” room correction algorithm EQ them.
Anyway for now I would suggest looking at JTR subs for your room. The 18” Captivator S1 are quite small for an 18” woofer”. Other great brands with very high performance are Seaton sound, Funk Audio and Power Sound Audio.
If space is your primary concern, dual JL Audio F113 are awesome but very pricey ($6,000 each?).
Sent from my iPhone using Tapatalk Pro
mpk1970 likes this.
7.4.6 system: Processors:Marantz 8805 || Xilica XP4080 Amps: Parasound A31 and ATI AT528NC & AT526NC n-core ||Speakers: Procella P8 LCR, Procella P5/P5 in-wall
Subs: JTR Captivator subs: One S2, Two RS2, One S1
Screen: 2.40:1 Seymour XD Acoustically Transparent, 128" diagonal / 118" wide || Projector: JVC X570/RS420
farsider3000 is offline
post #64 of 168 Old 08-09-2018, 04:03 PM - Thread Starter
Liked: 1588
Welp, that didnt work either. 1 sub off still produces mediocre performance from the one sub on.
mpk1970 is offline
post #65 of 168 Old 08-09-2018, 04:05 PM - Thread Starter
Liked: 1588
I have some output, just not at a decent level, rather mediocre.
mpk1970 is offline
post #66 of 168 Old 08-09-2018, 04:09 PM
Kini62's Avatar
Quoted: 2948 Post(s)
Liked: 2824
Try just one of the subs. Up the trim in your AVR to about -4db, go to youtube and play some of the bassotronic or bassmekanik stuff or even the EOT intro. Walk around the room to see if there is any difference. Maybe move that one sub into the middle of your front wall in front of your stand just for the heck of it.
If still no joy then return them. Too bad there are no PC13Us in the outlet. They would have fit in the same spot as your HSUs.
Maybe get another pair of the VTF2s and place them on top of your currents VTFs. You'd get a really nice overall gain above 20hz for just another $1200.
mpk1970 likes this.
Def Tech SC8000
Onkyo RZ820
Roku Ultra, Apple TV, Sharp 70" Quattron
Kini62 is offline
post #67 of 168 Old 08-09-2018, 04:10 PM
torii's Avatar
Quoted: 4416 Post(s)
Liked: 2595
if all settings in avr correct...double check sub cable connections and/or try different inputs like lfe in or line input...otherwise I guess send em back....do the hsu subs still work?
mpk1970 likes this.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300 LG oled c9 77
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS, Audioengine A2+
Subs: Rythmik FV25HP, Rythmik FV15HP, Velodyne HGS 12, Velodyne VA1512
torii is online now
post #68 of 168 Old 08-09-2018, 04:13 PM - Thread Starter
Liked: 1588
Yes no probs with HSU subs. Prob hook those back up.
mpk1970 is offline
post #69 of 168 Old 08-09-2018, 04:14 PM
Liked: 1097
You can look at data-bass.com in the measurement section and compare response graphs of many, but not all subs. You will notice how well JTR perform. I think the Captivator S1 is $2,400 plus shipping.
mpk1970 likes this.
post #70 of 168 Old 08-09-2018, 04:14 PM - Thread Starter
Liked: 1588
That might be good idea. Go with 4 VTF2s. These VTF2s hardly used only like 2 mos total.
mpk1970 is offline
post #71 of 168 Old 08-09-2018, 04:15 PM
Liked: 1097
Did you try cranking the sub level in your receiver ? Are you sure you don’t have dynamic range reduction on or any other processing in your receiver that could tame the bass output?
post #72 of 168 Old 08-09-2018, 04:18 PM
madhuski's Avatar
Liked: 1118
that’s why i think it sounds like a preout voltagebissue.
do you have the input selector switch to the right cable type (xlr/rca)?
post #73 of 168 Old 08-09-2018, 05:14 PM - Thread Starter
Liked: 1588
@madhuski yes I have the right cable, input from sub pre out, to the left input on sub
Anyhow, its all done!! Something was wrong with both subs, they were outlet specials so who knows?? I literally just plugged in the HSU VTF2s, the whole room shaking and AC vent in ceiling next shaking.
I definitely should've heard that minimum with PB 13s
We packed up the PB13 Ultras, I'll call SVS tomorrow to pick up.
I've decided what I will do is get 2 more HSU VTF2s and stack them. This will actually work best because I can fit the towers and VTF2s in the corner and not have to worry about the Emotiva T2s placement.
This was a total pain in the ass, but I just want to thank everybody for trying to help me. Trust me it is greatly appreciated.
mpk1970 is offline
post #74 of 168 Old 08-09-2018, 05:20 PM
ratbuddy's Avatar
Quoted: 946 Post(s)
Liked: 1389
If you would, please update with any feedback from SVS regarding whether the subs were defective or not.
mpk1970 likes this.
ratbuddy is offline
post #75 of 168 Old 08-09-2018, 05:24 PM
MIX_MASTER_ICE's Avatar
Quoted: 2678 Post(s)
Liked: 2493
Sorry to hear nothing remedied the situation. Still think something wasn't set correctly. I believe those outlet PB13's were new stock close-outs. The chances of getting two of them that exhibited the same amp issue are probably slightly better odds than getting struck by lightning.
torii and mpk1970 like this.
Subs>RBH I-12e. HSU VTF-15H mk2. Monolith THX 12(x2), THX 10(x2). XTZ 1X12. SVS PB-1000(x2). Speakers>JBL Studio 270/235c/230/225c. Sony CS3/CS8/CS5. QA 3020i/3090Ci, 2020i/2000c. Monolith Cinema 5bs. Polk RTiA1/CSiA4. Other Audio>Sony MDR-Z7m2,V6, XB900n,700,XB72,XB32. Sennheiser HD58X,HD4.50,PC37X. HiFiMAN HE4XX. Philips SHP9500. JBL PartyBox100(x2), Xtreme2,Charge4,Link300. Sivga SV004. LG FH6,RK8,RK7,PK7,PK5. HK Onyx Studio4(x2)
MIX_MASTER_ICE is offline
post #76 of 168 Old 08-09-2018, 05:27 PM
Gob Bluth's Avatar
Quoted: 249 Post(s)
Liked: 505
I’ve had a similar problem. When I got my first PSA V1500 the performance was incredibly underwhelming. My 20 year old 12” velodyne smoked it. For days I went through every setting there was, ran Audyssey a dozen times, moved the sub all over the room. It just wasn’t working properly. I got all the same advice you’re getting now like “your subs are canceling each other out”. Out of pure frustration I started flipping through listening modes on my AVR (stereo, Dolby, dts). When I flipped it to DTS X Neural the 15” roared to life and never had an issue like that again. There was something funky about the signal my AVR was sending to the sub - to this day I really don’t get it.
If / when you get your subs dialed in I would strongly recommend putting them nearfield behind the couch. That room looks like a place that bass goes to die. I have an even larger and more open floor plan so I can relate. I resisted nearfield placement for a while but in a room like that, it’s the way to go. Leaving the subs up front and putting the HSU subs behind your couch would also be a good option.
The comment a few pages back about the cone material being to blame is AVS comedy gold, btw.
Good luck. Try not to get overly frustrated by this. It’s a minor setback that you’ll get past. If you do end up returning the SVS for whatever reason I’d strongly recommend looking at some 18” subs for that room. You have the budget for some serious firepower from a smaller ID company.
Denon AVR-X3300W | Samsung UN65KS8000 | i7 6700K / GTX 1080 Ti HTPC
Front L/R: Klipsch RF-7 II | Center: Klipsch RP-250C | Surrounds: Klipsch RP-280F
Subwoofers: PSA V3601 | (2) PSA V1500 | Velodyne CT-120
Gob Bluth is offline
post #77 of 168 Old 08-09-2018, 05:37 PM
Liked: 1097
I agree. It is extremely unlikely that both subs are not working properly and I bet it is a setting in the AVR.
mpk1970 likes this.
post #78 of 168 Old 08-09-2018, 05:40 PM
madhuski's Avatar
Liked: 1118
sorry, not to belabor it, but you had the right input selected on the selctor switch on th seldge amp? ("normal" iirc)
mpk1970 likes this.
post #79 of 168 Old 08-09-2018, 06:01 PM
indebtbassfreak's Avatar
Quoted: 1637 Post(s)
Liked: 3070
Curious if you can confirm good driver movement in both SVS's?? If there is then amps are probably just fine and its some sort of set up issue going on. If little driver movement, that would explain lack of performance. Hard to believe two bad amps, but hey anything is possible.
-Marantz SR-8012
-Yamaha BD-A1060
-Funk 21.0LX Master/Slave combo 4800 watts RMS/9600watts (peak)-
-Chane A-2.4 L/C/R
-Chane A-1.4 side/rear surrounds.
indebtbassfreak is offline
post #80 of 168 Old 08-09-2018, 06:11 PM - Thread Starter
Liked: 1588
Minor driver movement. I could feel vibration but no noticeable driver movement.
mpk1970 is offline
post #81 of 168 Old 08-09-2018, 06:13 PM - Thread Starter
Liked: 1588
yes I did ....I went thru everything like 5x on both the subs and AVR
As I just answered, I thought it was weird drivers weren't really moving but very minor....could see vibrations but nothing when I put the VTF2s back up...those drivers were movin good
mpk1970 is offline
post #82 of 168 Old 08-09-2018, 06:16 PM - Thread Starter
Liked: 1588
Actually, the VTFs that I put back in place after packing the PB 13s, were rocking. I basically put volume at 75% vs. 50% what I normally had. I was in my bathroom and those things were shaking the house.
They actually work pretty good. I"m considering adding two more VTF2s now and stack them.....??
mpk1970 is offline
post #83 of 168 Old 08-09-2018, 06:19 PM - Thread Starter
Liked: 1588
I dont think I did because the minute I put the HSU's back in place, everything was fine??? I'll never know at this point what problem was unless when SVS gets the return they say it was AMP problem
mpk1970 is offline
post #84 of 168 Old 08-09-2018, 06:22 PM
torii's Avatar
Liked: 2595
all I know is I would be pissed if got 2 hvy subs I need to return...with my handicap status I would have to pay some to ship em back
Marc Alexander, mpk1970 and AmerCa like this.
torii is online now
post #85 of 168 Old 08-09-2018, 06:32 PM - Thread Starter
Liked: 1588
Not fun believe me.
mpk1970 is offline
post #86 of 168 Old 08-09-2018, 06:34 PM
Liked: 3070
Ok as rare as it would be with aggressive gain and no driver movement on both subs and then the HSU's pounding,,,, i guess it is what it is,,,, sounds like bad amps. That sucks man sorry you had to go through that.
mthomas47 and mpk1970 like this.
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
post #87 of 168 Old 08-10-2018, 05:58 AM
Montucky's Avatar
Quoted: 789 Post(s)
Liked: 781
That's a bummer. Sorry you had to go through all that nonsense if it ended up just being some bad amps. The odds are astronomical to end up with two bad amps, but I suppose that could be what it is. Wish I was in your locale to help you! We could've physically tested the amp board. Way easier than packing those beasts back up and getting shipped back out.
Actually that does remind me. If you're willing to do the work, SVS will gladly send you a new amp for you to swap if that's what they determined it most likely is. Would you be willing to try that? It's super easy actually. Just a handful of screws and a couple of wires to unplug/plug back in. You could do it in like 10 minutes tops. Might be worth a shot if you're willing to give SVS one last chance. If it were me, I'd go that route first before lugging those things out.
Montucky is offline
post #88 of 168 Old 08-10-2018, 06:34 AM - Thread Starter
Liked: 1588
Thank you for the help
SVS was great offered
1) new amps I replace
2) send back subs and they replace amps
3) send back subs they send new subs
Ultimately, with all that I went thru I'm going to just send back....I broke these thin pavers I have at front door step, chipped my door, just so many things went wrong I'm just kinda mentally done with this experiment for now.
I've already packed them up with help from my son helping me lift these things on to the styrofoam...
Now, I'm even scared to order new subs lol
But these HSUs are doing a dam good job with the towers
AmerCa likes this.
mpk1970 is offline
post #89 of 168 Old 08-10-2018, 06:47 AM
DaBateman's Avatar
Quoted: 722 Post(s)
Liked: 521
Not fun believe me.
I don’t believe that the issue here is the amplifier or the sub for that matter.
Last month when I ordered my Monolith 12” all of my subs favorite place was a front corner beside my TV stand, no matter if it was my BIC PL-200 II, Polk PSW505, Monolith 10”, or Monolith 12” they all loved that front corner.
My buddy has a SVS PB-2000, I took him my Monolith 12” & took his PB2K in the meantime and threw it in that front corner...nothing. Absolutely nothing. I called him and made sure he didn’t make me haul this 80lb 12” around for no reason but a giggle but he assured me it shook his room. Remember my room is 9x15 so it should be breaking drywall. It didn’t matter if I had the gain maxed out & the AVR trim at +5 w/ a master volume of 0 it wasn’t doing ****!
I ended up throwing that beast all around my room, different corners, halfway on side walls, middle of the room, anywhere there was open floor space. I pm’d mthomas as well, made a thread, etc. I received the same suggestions you have, something is not right.
After two days I totally rearranged my room, flipped the furniture, moved my seating, throw my TV & setup on the other side of the room & wallah; output! Between my placement & seating I was in a massive null bringing the output down 27dB...27dB!
My point being, every sub I’ve owned loved that one corner until the SVS PB2K didn’t, it created a bass black hole, sucking all output down the abyss. This sounds exactly what you are experiencing. It sounds like you spent more time packing & unpacking than you did trying to integrate the PB13’s. Just because your HSU’s like that front wall doesn’t mean every sub is going to. Also you didn’t even adjust the gain according to your post so I’m curious if you wanted the PB13’s to work in the first place...
You can buy every brand of subwoofer available in the world but, if you don’t find the correct placement, make sure polarity is correct, make sure there’s not phase issues, address nulls & modes, & take the time to properly adjust your system settings, you’re just wasting money whether it be shipping or purchasing them, wasting your time, etc.
It would have been much simpler & easier to find a remedy to your placement issues than packaging both of those big subwoofers. I’m not trying to upset you or sound cynical but, there’s no point in experimenting with other subs if you aren’t willing to accommodate their best placement/settings needs. Yes it is a need. If you expect tremendous output & extension, you’ll have to experiment with different gain settings, different PEQ settings, different phase settings, different phase settings, different AVR settings, & most importantly different placement.
It seems between your front wall & your seating you are experiencing nulls &/or standing waves. Even moving your seating forward or backwards 6”-1’ can fix these issues.
I’d recommend getting these running right, stop worrying about aesthetics so much for now, then once you figure out what the best setup is, go from there.
Anyway I’d be willing to help if you’d want to unpack them but, I don’t see buying a different brand would remedy your room issues.
AmerCa likes this.
| Eqmt | Vizio 4K M50-E1 | Yamaha RX-V681 | iNUKE 3kdsp x2 | Emotiva BasX A-100 | miniDSP UMIK-1 | Monolith M1060 | Monolith USB DAC |
| Sub | Trilithon | Stonehenge Variant Subwoofer - 18” - 9ft³ - 19Hz | Marty | Microcube 390HO - 22Hz | Monolith THX Ultra 12 | Monolith THX Select 10 |
| Spkrs | HSU CCB8 x3 | SVS Prime Elevation x2 | Polk S15 |
DaBateman is offline
post #90 of 168 Old 08-10-2018, 07:02 AM
Liked: 3070
In most cases i would agree with your statement. With aggressive gain on both subs,,, there was no cone movement For subs known for good driver excursion,,,,,, this was not a location issue imo. No driver movement/high gain and avr trim= bad amp when all other trouble shooting remedies had been explored.
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
