Velodyne sub won't power after connecting 12v trigger to remote input - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-11-2018, 02:07 PM - Thread Starter
Breddy's Avatar
Quoted: 21 Post(s)
I got the brilliant idea to auto trigger my Velodyne HGS-15 with my receiver's (Yamaha AV-R2050) remote trigger out. It didn't work and now my (aging, but otherwise perfect) sub doesn't power on. Did I fry something by doing this? It would be an incredible coincidence that it suddenly failed after several years of second-hand ownership right at the very moment I plug up a trigger cable that I now know isn't the right way to go.
Thanks for your collective help...
Breddy is offline
post #2 of 6 Old 08-11-2018, 07:37 PM - Thread Starter
Breddy's Avatar
Quoted: 21 Post(s)
I've posted this question to the official Velodyne support thread. I don't see a way to delete this but mods are welcome to do so.
Breddy is offline
post #3 of 6 Old 08-13-2018, 12:19 PM
DonH50's Avatar
Quoted: 3305 Post(s)
Liked: 3407
I do not see a trigger input in the HGS-15 manual, just a remote IR input. What did you plug the trigger line into?
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #4 of 6 Old 08-13-2018, 12:22 PM - Thread Starter
Breddy's Avatar
Quoted: 21 Post(s)
Thanks for the reply.
Plugged it into that, not realizing what it was for. Definitely my mistake. I'm sending it out to EBC which I found by perusing the big Velodyne thread in this forum.
Breddy is offline
post #5 of 6 Old 08-13-2018, 12:30 PM
DonH50's Avatar
Liked: 3407
OK, hope it all works out.
I might have expected the IR circuit to have fried, but would not have expected it to take out the rest of the circuits. Maybe it is along the way and by taking out the IR remote sensor it disrupted the main turn-on path.
DonH50 is offline
post #6 of 6 Old 08-13-2018, 01:55 PM - Thread Starter
Breddy's Avatar
Quoted: 21 Post(s)
I was also scratching my head about why that would cause the whole thing to crap the bed, but alas. I should have it back in a week or so!
Breddy is offline
