ULS-15 MK2 or L22 or F12-300 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By Gyroscopics
post #1 of 10 Old 08-31-2018, 12:23 PM - Thread Starter
Gyroscopics's Avatar
Quoted: 202 Post(s)
Liked: 264
Looking to replace ~15 yr old subs, in a dual sub configuration, for 30/70 movie/music duty. The subs need to fit under the cofee tables on each side of the sofa (MLP), hence the limited choices. Room has 30 feet cathedral ceiling and opens to another room to the left (with 15ft ceiling). Need AVS advice.
Gyroscopics is offline
post #2 of 10 Old 08-31-2018, 01:13 PM
Kini62's Avatar
Quoted: 2722 Post(s)
Liked: 2536
The HSUs are probably the best of those options. Just saw the movie music ratio. So if max output is not the priority a pair of the L22s would be the best of both worlds. In between the other two in output with the musicality of Rythmik's servo tech.
Def Tech SC8000
Onkyo RZ820
Roku Ultra, Apple TV, Sharp 70" Quattron
Kini62 is offline
post #3 of 10 Old 08-31-2018, 01:36 PM - Thread Starter
Quoted: 202 Post(s)
Liked: 264
Is the ULS-15MK2 louder than the L22? I know the L22 is louder than the F12 per Rythmic's website...
post #4 of 10 Old 08-31-2018, 02:14 PM
Kini62's Avatar
Liked: 2536
Based on Rythmik's data the HSU would likely have a little more output. It should be similar to Rythmik's 15 sealed subs. Based on your preference for music IMO the L22 is the best compromise.
Def Tech SC8000
Onkyo RZ820
Kini62 is offline
post #5 of 10 Old 08-31-2018, 05:13 PM - Thread Starter
Quoted: 202 Post(s)
Liked: 264
I asked on the Rythmik thread if there's any harm laying the L22 on its side - no response. I'm gonna order the HSU. Thanks for the input.
post #6 of 10 Old 08-31-2018, 05:30 PM
Kini62's Avatar
Liked: 2536
It's ok to lay the subs on their sides even if there are heat sinks that run vertically. They won't get hot enough to really make a difference.
I'm sure you'll be satisfied with the HSUs though.
Def Tech SC8000
Onkyo RZ820
Kini62 is offline
post #7 of 10 Old 08-31-2018, 05:46 PM - Thread Starter
Quoted: 202 Post(s)
Liked: 264
Thanks, I also sent an inquiry to Rythmik if they give discount for direct pick-up from their warehouse. I realize I will be charged tax if I order from Rythmik, but not from HSU.
post #8 of 10 Old 09-01-2018, 09:15 PM - Thread Starter
Quoted: 202 Post(s)
Liked: 264
Can the L22 be placed on its side without degrading performance or adding risk of overheating? I'm considering the L22 but have limited placement options...
@enricoclaudio can correct me if I'm wrong, but I believe there should be no degradation. My recollection is this same question has been answered earlier in this thread. Of course, the feet are the on the bottom and you'd need to consider how you're going to decouple the sub from whatever you place it on.
Thanks for all the input. I got the twin L22's setup at my house today. Thanks to Brian and @enricoclaudio for the quick response and smooth transaction (received the L22s less than 24 hours from first inquiry). Big step-up from my 15 yr old ported HSU. Still tuning the L22s but so far so good. Very tight and musical.
gajCA and BluesDaddy56 like this.
post #9 of 10 Old 09-02-2018, 05:08 AM
BluesDaddy56's Avatar
Quoted: 566 Post(s)
Liked: 789
Congratulations. I love mine. They fit well in my room, are unobtrusive in their locations, and have "integrated" just fine with two radically different pair of fronts (Magnepan MMGs first and now Philharmonic BMRs). With them in the mix for 2 channel music they had the right impact and weight of deep bass without calling attention to themselves. It just seems like my FR have more extension.
Display: Vizio P55-E1l Pre-pro: Marantz 7703; Amps: Emotiva XPA-2 Gen 2, Emotiva XPA-3 Gen 1, H/K AVR 520 (direct in to amps); Sources: Sony UBP-X700; X-box 1 S; Technics 1200 Mk II; Win10 PC for digital; Phono Preamp: Emotiva XPS-1; Speakers - LR: Philharmonic BMR LR; Center: Selah Audio BMR-CC; Surrounds: Wharfedale Reva-2; Rear Surrounds: Wharfedale Diamond 220; Atmos: TF - Monoprice Alpha 8; TR - BIC VI-38; Subwoofers: dual Rythmik L22s
BluesDaddy56 is offline
post #10 of 10 Old 09-02-2018, 10:05 AM
gajCA's Avatar
Quoted: 9082 Post(s)
Liked: 6223
I love sealed servo subs for the reasons you describe.
Congratulations.
Geoff A. J., California
gajCA is online now
