XTZ 1x12 occasional noise. Is this a failure? - AVS Forum | Home Theater Discussions And Reviews
 8Likes
  • 2 Post By indebtbassfreak
  • 2 Post By jamiebosco
  • 3 Post By MIX_MASTER_ICE
  • 1 Post By MIX_MASTER_ICE
post #1 of 16 Old 09-15-2018, 04:12 PM - Thread Starter
Liked: 1
I have xtz 1x12 since one month ago.
In some scenes of movies with strong bass, the sub makes a little noise. It sounds like "POK" more or less.
It sounds one "POK" and nothing more. It is not continuous. If you hear the scene going down the volume of the bass, it doesn´t sound that noise.
Is this a failure? Or is it simply a mechanic noise of the driver in its maximum extension?
The new model 12.17 EDGE has DSP and the amp has the total control of the woofer. But the 1x12 no. May be is the cause, I don´t know. What is your opinion?
subwoofer40 is offline
post #2 of 16 Old 09-15-2018, 04:19 PM
indebtbassfreak's Avatar
Quoted: 1346 Post(s)
Liked: 2543
Without a video,,,, cant be 100% sure but it sounds like the driver is been pushed beyond its mechanical limit probably in very low frequency moments.
subwoofer40 and darthray like this.
-Marantz SR-8012
-Yamaha BD-A1060
-Funk 21.0LX Master/Slave combo 4800 watts RMS/9600watts (peak)-
-Chane A-2.4 L/C/R
-Chane A-1.4 side/rear surrounds.
indebtbassfreak is offline
post #3 of 16 Old 09-15-2018, 06:31 PM
MIX_MASTER_ICE's Avatar
Quoted: 2593 Post(s)
Liked: 2418
I have no clue what a "glock" noise sounds like. I have pushed my 1X12 to the point where it will make port noise, but I've never heard any type of mechanical noise or anything like that.
Subs>RBH I-12e/I-12. HSU VTF-15H mk2. Monolith THX 12(x2)/THX 10(x2). XTZ 1X12. SVS PB-1000(x2). Speakers>JBL 270/235c/230/225c, Arena 130/125c. Jamo S807/S803. Infinity P363/163. Sony CS3/CS8/CS5. QA 3020i/3090Ci, 2020i/2000c. Monolith Cinema 5 bs. Polk RTiA1/CsiA4. Other Audio>Sony MDR-Z7m2, WH-XB700, XB32, XB31. Sennheiser HD58X, HD4.50, PC37X. SIVGA SV004. HyperX Cloud PS4 HS. Plantronics RIG500 Pro HS. LG FH6,RK8,RK7,PK5. UE Boom3.
MIX_MASTER_ICE is online now
post #4 of 16 Old 09-15-2018, 07:13 PM
jamiebosco's Avatar
Quoted: 670 Post(s)
Liked: 1562
"glock" sounds like you may be bottoming out the woofer
..and yes , a video showing it would help
TV: Panasonic P65ST60 AVR: Denon 4311ci Speakers: PSA MTM-210C (Centre), PSA MTM-210 (Left & Right), PSA MT-110 (Surrounds) Subwoofers: Dual Seaton SubMersives
jamiebosco is online now
post #5 of 16 Old 09-20-2018, 12:45 PM - Thread Starter
Liked: 1
post #6 of 16 Old 09-20-2018, 01:40 PM
Liked: 2418
Originally Posted by subwoofer40 View Post
The video is here.
The noise is in the second 7.
What is that?
http://www.youtube.com/watch?v=f8ijz6XpydQ&feature=youtu.be
Sounds like clipping. What do you have the sub level set to on your receiver? Where do you have the gain set on the sub? Did you run your receiver auto-calibration set up? Do you have anything like dynamic EQ, dynamic volume, boosts enabled.
This sounds very reminiscent of how the Rythmik LV12R I had performed during this same Underworld Awakening scene. I was only running the LV12R a few dB's hot over Audyssey calibration, however. No dynamic EQ, volume or any other enhancements. Video clip> https://sendvid.com/oh6u05z5
post #7 of 16 Old 09-20-2018, 01:53 PM - Thread Starter
Liked: 1
Gain sub is 2 oclock in that video,and AVR level +6. With +4 the noise is the same (with autocalibration the Level is 0). But I normally set the volume louder.
post #8 of 16 Old 09-20-2018, 02:24 PM
Liked: 2543
Both video samples sound like the same issue to me. I dont know if the video's are minimizing the appearance of driver excursion, but it doesn't look like there is enough to cause that noise. Almost sounds like some form of mechanical friction.
Also your settings seem very aggressive. If your over driving the sub,those settings would explain this, you should try different sub placement and recalibrate until your post calibration has your trim well into the (-).
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
post #9 of 16 Old 09-20-2018, 02:43 PM
Liked: 2418
What brand receiver are you using? Running the sub level in the + region in the receiver settings is highly discouraged. Depends on the receiver, but you want to run the auto-calibration so that the result is somewhere in the -6 to -9 region. From there you can bump it up if you want more output, but you don't want to go past 0 into the + numbers. Also, disable any audio "enhancers" like dynamic EQ.
darthray likes this.
post #10 of 16 Old 09-20-2018, 06:31 PM
jamiebosco's Avatar
Quoted: 670 Post(s)
Liked: 1562
Sub gain at 2 o'clock and it came back with a sub trim of 0dB? how large is your room?
Agreed with MMI, it's best not to run the AVR sub trim into the positives as you will almost certainly be clipping the signal in a movie like Underworld:Awakening
post #11 of 16 Old 09-21-2018, 06:09 AM
darthray's Avatar
Quoted: 2098 Post(s)
Liked: 2990
Also positive, this is what that sound description is.
subwoofer40
Like many said in the previous posts, running your sub level on the AVR, in the minus would help, just need to raise the gain on the sub itself to achieve that.
Also, if you have the DEQ engage, turn it Off, it can play havoc when playing at level under reference (since The DEQ will try to bring the bass to reference level), reference is very loud. Even with my two PB13-Ultra, once engage, there was way too much bass, I now have it Off, and sound much better, even during those very low frequencies and loud moment.
Ray
darthray is offline
post #12 of 16 Old 09-24-2018, 05:54 AM - Thread Starter
Liked: 1
The brand receiver is Yamaha rxv465. That AVR hasn´t dynamic EQ.
My room is 13 m2. Little-medium.
Bass level in sub is almost three oclock. In the scene of video, the level of receiver was +4db. (With autocalibration the level is 0 db, right in the middle).
If I would want negative numbers with autocalibration, I had to set the bass level louder.
I think it´ll be the woofer bottoming out. The coil hitting in the back plate, I don´t know. But with PB1000 and Polk dsw550, I hadn´t that problem. And I set the same volume.
post #13 of 16 Old 09-24-2018, 08:48 AM
xcjago's Avatar
Quoted: 54 Post(s)
Liked: 53
The video is here.
What is that?
What movie is that from?
xcjago is online now
post #14 of 16 Old 09-24-2018, 12:51 PM
DaBateman's Avatar
Quoted: 721 Post(s)
Liked: 517
Turn your gain to 4 o’clock, put your trim level at ~-5dB
Then go under
Options -> Subwoofer/Bass -> Subwoofer trim -> +6dB
Options -> Subwoofer/Bass -> Extra Bass -> OFF
Options -> Tone control -> Bass -> +3-6dB
This should stop the clipping and also bring your bass levels up.
| Eqmt | Vizio 4K M50-E1 | Yamaha RX-V681 | iNUKE 3kdsp x2 | Emotiva BasX A-100 | miniDSP UMIK-1 | Monolith M1060 | Monolith USB DAC |
| Sub | Trilithon | Stonehenge Variant Subwoofer - 18” - 9ft³ - 19Hz | Marty | Microcube 390HO - 22Hz | Monolith THX Ultra 12 | Monolith THX Select 10 |
| Spkrs | HSU CCB8 x3 | SVS Prime Elevation x2 | Polk S15 |
DaBateman is offline
post #15 of 16 Old 09-25-2018, 08:51 AM - Thread Starter
Liked: 1
Nothing. That method doesn´t work.
For example, Resident Evil 5. Alice and the ship. Minute 1:42.
With bass almost 3 oclock and AVR LEVEL +6, noise "pok". (with autocalibration was 0 dB). When I set +4, the noise dissapears.
I try your method.
I turn the gain 4 oclock (Autocalibration is -4dB here)
So I turn up 6 db in the AVR, because I want the same volume. I put +2 in the AVR level.
The noise is the same. If I turn down, the noise dissapears.
post #16 of 16 Old 10-04-2018, 12:13 AM
Sdroid's Avatar
Quoted: 125 Post(s)
Liked: 25
Sdroid is offline
