SVS PB-2000 - Measurements- Testing - Review - AVS Forum | Home Theater Discussions And Reviews
 9Likes
  • 6 Post By DaBateman
  • 1 Post By Ben Tan
  • 1 Post By DaBateman
  • 1 Post By jamiebosco
post #1 of 6 Old 09-18-2018, 08:48 PM - Thread Starter
DaBateman's Avatar
Quoted: 721 Post(s)
Liked: 517
SVS PB-2000
There’s plenty of reviews for the SVS PB-2000 but, nevertheless while it was still in my possession I figured I would take some measurements and post them for other readers.
To be honest when I first came into contact with the PB2K we did not get along, at all. Unfortunately to properly get it outputting all she could it took two furniture rearrangements and a week’s worth of time..so I was not a fan of this particular transducer at first but, I have came around after a couple of months of usage to be a big fan of what SVS has accomplished with a single 12” driver.
Speaking of I’m sure most people here know SVS uses a single customer 12” driver by Peerless featuring a cast aluminum basket, dual ferrite magnets, FEA optimized motor, dual shorting rings, extended pole, 2” diameter voice coil, Nomex spider design, tinsel leads, aluminum cone material with a polypropylene dust cap, & rubber long throw surround.
In combination with the customer 12” Peerless driver is a 500Wrms/1.1kWpk STA-500D sledge plate amplifier including on-board proprietary DSP featuring limiter with attack/release function. The plate amplifier also includes a 12v trigger, stereo line level input & outputs with an input impedance of 47 kΩ (unbalanced line level RCA). Continuously variable phase control (0-180), continuously variable (50-160 Hz) 12 dB/octave low pass filter frequency with disable/LFE setting, & fixed 80 Hz 12 dB/octave high pass filter on line level outputs.
The enclosure is a reflex design with an internal volume of 3.84924^3 including a single 4” flared port tuned to 19Hz with an F3 of 17Hz.
Per my subjective opinion just based solely on what my ear is hearing, the SVS PB-2000 has an extremely flat frequency response with more usable bass < 160Hz than is necessarily required in an ID subwoofer. Also for a single 12” reflex design there is sufficient tactile sensations especially if placed in a nearfield location.
This subwoofer in my opinion excels in a home-theater application more so than primarily music as per the sound signature, again; completely subjective and my personal opinion.
Here is the specs for the SVS PB-2000
Spoiler!
MEASUREMENTS
*note* all measurements are taken via Ground Plane 2m or nearfield.
SPL & Phase
SPL
Distortion
Impulse Response
Filtered IR
Envelope ETC
Group Delay
Clarity
Spectral Decay
Waterfall
Spectrogram
References
Sound & Vision
Audioholics
| Eqmt | Vizio 4K M50-E1 | Yamaha RX-V681 | iNUKE 3kdsp x2 | Emotiva BasX A-100 | miniDSP UMIK-1 | Monolith M1060 | Monolith USB DAC |
| Sub | Trilithon | Stonehenge Variant Subwoofer - 18” - 9ft³ - 19Hz | Marty | Microcube 390HO - 22Hz | Monolith THX Ultra 12 | Monolith THX Select 10 |
| Spkrs | HSU CCB8 x3 | SVS Prime Elevation x2 | Polk S15 |
DaBateman is offline
post #2 of 6 Old 09-19-2018, 02:41 AM
Quoted: 146 Post(s)
Liked: 151
Originally Posted by DaBateman View Post
SVS PB-2000
When you say "customer driver", do you mean that it's an off-the-shelf driver? Or do you mean "custom"? Also, I'd like to point out a small error. You mean >160Hz, not <160Hz
Ferrari_1996 is online now
post #3 of 6 Old 09-19-2018, 03:20 AM
Ben Tan's Avatar
Quoted: 519 Post(s)
Liked: 504
^ It's a custom Peerless XXLS 12" driver, made specifically per SVS requirements. You can't get the exact same model "off the shelf".
DaBateman likes this.
SVS Ultra Bookshelf + SVS Ultra Center
Prime Bookshelf Surround with Prime Elevation Heights
Dual Rythmik FV15HP
Yamaha RX-A3060 + Parasound Halo A31 + Emotiva A500
Ben Tan is offline
post #4 of 6 Old 09-23-2018, 08:04 PM
AmerCa's Avatar
Quoted: 685 Post(s)
Liked: 1442
Excellent job!
Enviado desde mi SM-G318ML mediante Tapatalk
Vizio 43" D Series 2017 || Onkyo TX383 7.2ch || Fronts: Sony SS-CS5 || Center: Pioneer SP-C22 || Sub: Polk HTS 12 || Surrounds: Micca MB42
AmerCa is online now
post #5 of 6 Old 09-23-2018, 09:09 PM - Thread Starter
DaBateman's Avatar
Quoted: 721 Post(s)
Liked: 517
Originally Posted by AmerCa View Post
Excellent job!
Thanks! I’ve grown quite fond of the PB2K. I’d put it right below the Monolith 12” as far as the top tier ID 12’s.
AmerCa likes this.
post #6 of 6 Old 09-23-2018, 09:52 PM
jamiebosco's Avatar
Quoted: 651 Post(s)
Liked: 1543
Yes agreed, great review mate, well done.
TV: Panasonic P65ST60 AVR: Denon 4311ci Speakers: PSA MTM-210C (Centre), PSA MTM-210 (Left & Right), PSA MT-110 (Surrounds) Subwoofers: Dual Seaton SubMersives
jamiebosco is online now
PB-2000 , Review , subwoofer , Svs , svs pb-2000
