Buttkicker Amp Low Pass Ineffective - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-15-2018, 05:09 PM - Thread Starter
Quoted: 159 Post(s)
Liked: 248
I purchased a buttkicker lfe today, and the seller threw in a buttkicker amp. The serial number does not match any of the recalled units. The transducer responds to all frequencies despite the high cutoff set to 40Hz. I performed a slow 1Hz to 100Hz sweep. If I turn off the high cutoff the transducer responds even more, so the cutoff is doing something, it's just not 100% effective.
Is this typical behavior of the amp?
lmidgitd is offline
post #2 of 6 Old 10-16-2018, 02:10 AM
brettus's Avatar
Quoted: 44 Post(s)
Liked: 30
Do you mean a Low Pass filter set to <40hz or a High Pass set to 40hz>? I'd be setting a 40-60hz low pass for your Buttkicker if thats what you're after....
In either case though the slope of the filter may only be shallow at 6db (unless it's adjustable) but the filter isn't a brick wall so you will still get frequencies outside of your 40hz crossover.
Google is your friend!
brettus is offline
post #3 of 6 Old 10-16-2018, 02:21 AM
keeper's Avatar
Quoted: 601 Post(s)
Liked: 247
I have mine set to 50. I think it does a good job. I never feel voices or anything like that.
keeper is online now
post #4 of 6 Old 10-16-2018, 02:54 AM - Thread Starter
Quoted: 159 Post(s)
Liked: 248
I had the low pass (labeled on the amp as "high cutoff") set to 40Hz. The buttkicker responded as high as 100Hz whether the cutoff was turned on or off. I tried googling so I figured I'd ask here in case somebody could verify that their's does the same.
lmidgitd is offline
post #5 of 6 Old 10-16-2018, 03:46 AM
markmon1's Avatar
Quoted: 4639 Post(s)
Liked: 2943
Originally Posted by lmidgitd View Post
I had the low pass (labeled on the amp as "high cutoff") set to 40Hz. The buttkicker responded as high as 100Hz whether the cutoff was turned on or off. I tried googling so I figured I'd ask here in case somebody could verify that there's does the same.
The high pass is a crossover that runs (I think) 6db per octave but it may be 12db per octave. Each octave is doubling in frequency. So if you set it to 40hz and play a tone, at 40hz it will be N DB. At 80hz it will be N-6 DB, at 160hz N-12DB etc.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #6 of 6 Old 10-16-2018, 04:37 AM - Thread Starter
Quoted: 159 Post(s)
Liked: 248
I guess I should have looked up the octave separations. -6dB at 80Hz sounds about right for what I was feeling between the low pass being enabled or not. Excuse my ignorance and thank you all for your help.
lmidgitd is offline
