Subwoofer comparisons and impressions - Page 54 - AVS Forum | Home Theater Discussions And Reviews
 2580Likes
post #1591 of 1930 Old 05-22-2019, 01:34 PM
MKtheater's Avatar
Quoted: 2761 Post(s)
Liked: 3209
You can also apply a LT to a sealed sub which brings up the low end even more, creating that TR a ported sub has.
Building the room, speakers, and subs.
MKtheater is online now
post #1592 of 1930 Old 05-22-2019, 02:15 PM
chucks0's Avatar
Quoted: 611 Post(s)
Liked: 1578
Dude I am going to need a demo of the TV36 when you get it if you'll have me down. @Archaea will also be thrilled that I could also demo your BOSS platform, as I have been quite outspoken about agreeing with the concept. Not denying it, just not agreeing that I find it "True to the source"
Sounds like a plan. I was very skeptical of the whole BOSS concept, but I have been amazed with how well it integrates. Hard to deny the value.
Electronics: Denon X4400, Vizio M65
Sub: Rythmik FV18-PC x 2
Speakers: 3 x Chane A2.4 LCR, DIYSG Volt-6 Surrounds
chucks0 is online now
post #1593 of 1930 Old 05-22-2019, 04:59 PM
Gorilla Killa's Avatar
Quoted: 1631 Post(s)
Liked: 2447
[quote=beastaudio;58085284
Back to the Irene 7hz chopper scene. With more displacement than essentially all but maybe 4 members on this site, applying a 15hz HPF and playing that scene back to back then full range with no HPF, the effect was less than negligible.[/QUOTE]
I was as skeptical as anyone on here about the BOSS platform. Even the low cost aside its a great upgrade. Pairing it up with some PA drivers is a home run. I've stumbled upon a bunch of movie scenes with ULF wobble that were never apparent to me until building one. The wobble in BHD is continuous besides Irene that I wasn't aware since they are subtle.
I would say you'll be impressed at what it does, even more because of the simplicity of it.
Getting TR at low volumes at 2am when the house is sleeping is just icing
8hz ULF TR for the masses and the Cashless. Like a BOSS
If you can't stand behind our troops stand in front of them
Gorilla Killa is online now
post #1594 of 1930 Old 05-22-2019, 05:09 PM
zeus33's Avatar
Quoted: 2004 Post(s)
Liked: 2295
It's filtered out yes, but not completely gone (in most cases, there are definitely some bad eggs out there, ST:B, Atomic Blonde, etc.). If there is absolutely no effect, there is nothing BEQ can do to make one. Filtered movies at 30hz slope down from the filter into the teens but looking at the graphs you can see if specific effects still take place, BEQ just brings them up out of the lower dB dredges so they are more potent. It doesn't magically create effects that never existed before.
Have you looked at the BEQ thread ba? I just glanced at a few and there is substantial output down to 10 hz and some in the single digits on the few that I saw. And these aren't "bass" movies either. Avengers sloped off pretty heavily before BEQ. Here's Atomic Blonde too.
CallingMrBenzo likes this.
zeus33 is offline
post #1595 of 1930 Old 05-22-2019, 06:12 PM
darthray's Avatar
Quoted: 2703 Post(s)
Liked: 4585
Originally Posted by Marc Alexander View Post
Dual FV15HPs should be more than enough. @enricoclaudio what say you?
Originally Posted by jamiebosco View Post
From memory @darthray already has dual PB13U's in there (correct me if I'm wrong darth?) Would moving to FV15HP's be that much of an upgrade given his listening level? ( I am discounting SQ gains, which between these two, would largely come down to personal preference)
You are correct
@enricoclaudio told me, that moving to the FV15 compare to my present PB13. Would be a lateral move, therefore the reason I got my mind set on the FV18.
Got love honest answers, and thank you both for your reply.
Darth
jamiebosco likes this.
darthray is offline
post #1596 of 1930 Old 05-22-2019, 06:35 PM
Writer & Reviewer
JimWilson's Avatar
Quoted: 2530 Post(s)
Liked: 4091
Originally Posted by GatoGoat View Post
What I do think is that we are about to experience some pretty awesome new options from some of our favorite ID brands. PSA and I think Seaton and maybe Rythmik possibly entering the 12" sub game , dual opposed 10" subs etc etc.
Did you mean 21" by chance? Rythmik has half a dozen 12" models already, probably the most of any company.
If you take yourself too seriously expect me to do the exact opposite.
BTW, did you really need to quote the entire post?
JimWilson is offline
post #1597 of 1930 Old 05-22-2019, 09:38 PM
basshead81's Avatar
Quoted: 382 Post(s)
Liked: 10985
Originally Posted by imureh View Post
Nor sure I follow. BEQ is boosting the filtered frequencies mostly below 20hz.
It's still the same amount of ULF on the disk....So no BEQ doesn't increase the amount of ULF but it does increase the depth/extension of the ULF on the disk. So the percentage is the same.
basshead81 is offline
post #1598 of 1930 Old 05-22-2019, 10:05 PM
drh3b's Avatar
Quoted: 2491 Post(s)
Liked: 5554
It depends how you define "increase the amount." Louder is also more. Amount of ULF db is definitely up.
drh3b is offline
post #1599 of 1930 Old 05-23-2019, 05:25 AM
AVS ***** Member
mthomas47's Avatar
Quoted: 6032 Post(s)
Liked: 12405
The BEQ conversation increasingly seems like a tomato/tomahto discussion to me, since people are using the term "more ULF" in different ways. Perhaps it helps a bit to frame the discussion in the following way. It is very hard to hear frequencies below about 20Hz, in conjunction with other bass sounds, until the volume of the ULF sounds approaches about 100Hz. That number probably varies depending on the noise floor of the room, the overall volume level, the specific hearing of the individual, etc. But, 100db is a pretty good number to use for discussion purposes.
So, if there is ULF content in a movie that is significantly lower than 100Hz, when the volume of the rest of the bass track is played at about 100Hz or higher, then for all practical purposes, the <20Hz content simply isn't there. Perhaps it adds a little almost imperceptible bass weight to the audible bass content, and perhaps it adds a little low-bass TR (which may take less SPL to be perceptible) but if the volume of the ULF content is very low, then the ULF is pretty much not there at all.
If, on the other hand, we raise the volume level of the ULF content, which is rolled-off either deliberately or otherwise, while keeping the other bass levels about the same, something interesting happens. At about 30Hz and below, approximately a 5db increase in volume is perceived as a doubling in loudness, so an increase in very low-bass SPL immediately makes it more noticeable than it was. Our attention is drawn to it more, compared to when it was virtually (or completely) imperceptible.
That may be a good thing or a bad thing, depending on the individual, but it is definitely a thing. As a somewhat neutral observer to the discussion, I think that everyone is right. How's that for a cop-out?
BEQ doesn't create ULF that never existed in a soundtrack to start with, but it also doesn't simply increase the loudness of that ULF content. In many cases, it may change the ULF from non-existent, by reason of inaudibility, to perceptible, thereby enhancing the overall special effects. So, it doesn't add to the overall percentage of ULF in a movie, but it may absolutely add to the overall audibility of ULF in a movie.
Just thought I would throw that distinction out there, for what it's worth.
Mike
Edit: There is something else that I think may be worth noting. People who are already implementing a significant low-bass house curve may be doing the equivalent of Bass EQ for all of their movies. If they are lifting their <30Hz or <20Hz frequencies, relative to the other frequencies, then they are probably accomplishing the same thing that BEQ does, but on a broad-stroke basis.
BEQ is more movie-specific, but the net effect effect may be very similar with either BEQ or a global low-bass house curve. In fact, the person with the global low-bass house curve may end-up with more ULF, in general, because he is lifting the low-frequencies even in movies that are not rolling-off the ULF.
audiofan1 and drh3b like this.
GUIDE TO SUBWOOFER CALIBRATION AND BASS PREFERENCES
* The Guide linked above is a comprehensive guide to Audio & HT systems, including:
Speaker placements & Room treatments; HT calibration & Room EQ; Room gain; Bass
Preferences; Subwoofer Buyer's Guide: Sealed/ported; ID subs; Subwoofer placement.
mthomas47 is online now
post #1600 of 1930 Old 05-23-2019, 06:34 AM
basshead81's Avatar
Quoted: 382 Post(s)
Liked: 10985
all the scenes are the same length or duration of time going by the time stamps. So BEQ doesn't add any more ULF scenes to the track which is what Beast was saying. ULF is defined as the frequencies below 25hz. BEQ changes the roll off so the extension and level increases, not the amount of ULF. So if there was 5% ULF content on the disk before BEQ, then there still is 5% after BEQ. The 5% range has been altered to extend deeper is all.
post #1601 of 1930 Old 05-23-2019, 07:51 AM
Mark Seaton's Avatar
Quoted: 932 Post(s)
Liked: 2607
Mike
I recently experimented with this on Art Sonneborn's Trinnov. This was instigated from Art being a big fan of NASA movies and documentaries, and as many know, First Man was pretty much castrated in the lowest frequencies. I saw the posted info on the BEQ thread, and found I could implement some curves with the PEQ already available in the Trinnov using different presets. First Man really is a worst case example. We listened first with the typical system setup, and then engaged the boost which was very significant below 35-40Hz. While I ultimately dialed back the boost 3-5dB from what was suggested on the thread, it instantly transformed the launch sequences, especially where they were getting set and buttoned up in the pod. Without BEQ it was anemic and sounded like a TV recording, while the bass boost suddenly made all of the VLF punctuation of footsteps walking through different spaces, doors closing and rumblings in the background. As recorded on the BluRay these effects were so far down from audibility that for practical purposes, it was bringing back content previously not realizable.
I would point out that the vast majority of the EQ curves are MUCH steeper than any house curve. As anyone who's been around while I'm calibrating has witnessed, I'm pretty quick to audibly identify what I like as a good balance in a system of the content below 25Hz vs above. Too much below 25Hz or even in the 25-45Hz range will quickly muddy the detail and sound un-natural, and usually benefits more from overall more level vs added tilt to the response. It was plainly obvious in listening when the gain was in the ballpark of bringing the VLF content up to appropriate levels corresponding to the rest of the range. I ended up leaving 3 BEQ settings in separate presets to hit some curves I found more typical, with corners roughly around 20Hz, 30Hz, and 40Hz (for First Man). I do think the recommended filters are rather inefficient vs 1-3 shelf filters and 1-2 correctly set PEQs, but the net effect is impressive, beneficial, and plenty safe for a film that's been analyzed and with subwoofers that have appropriate protections in case you accidentally send a signal 10-30dB past the comfortable limits.
Mark Seaton
Seaton Sound, Inc.
"Make no little plans; they have no magic to stir men's blood..." Daniel H. Burnham
Mark Seaton is offline
post #1602 of 1930 Old 05-23-2019, 09:09 AM
Quoted: 281 Post(s)
Liked: 870
It must be Seaton coming out with the 12" models then. Just goes to show how many new options we will have soon to choose from , from a 21" Rythmik , a 12" Seaton , possibly dual 10" from PSA and a mystery 'Big" sub. Plus all of the great choices we currently have!
CallingMrBenzo and iceatola like this.
GatoGoat is offline
post #1603 of 1930 Old 05-23-2019, 09:21 AM
3ll3d00d's Avatar
Quoted: 2699 Post(s)
Liked: 3139
This distinction doesn't make any sense. beq changes the spectral balance of the track so there is literally more "useable" ulf
i.e. in this example, previously there was basically 0% of the track with useable ulf (content that you can hear or feel) and now there is 5% (the scenes which had rolled off content on disc) of the track.
3ll3d00d is offline
post #1604 of 1930 Old 05-23-2019, 09:34 AM
jsc79's Avatar
Quoted: 574 Post(s)
Liked: 851
21” Rythmik? Never heard any mention of that anywhere.
jsc79 is online now
post #1605 of 1930 Old 05-23-2019, 09:36 AM
David Charles's Avatar
Quoted: 1109 Post(s)
Liked: 1888
There is not one, that is why
jsc79 likes this.
David Charles is offline
post #1606 of 1930 Old 05-23-2019, 10:06 AM - Thread Starter
imureh's Avatar
Quoted: 3591 Post(s)
Liked: 4916
Hi Mark, thanks for sharing, do you by any chance recall the exact freq, db, and Q values you used as I would love to compare to the one we have on the BEQ thread
SuperFist likes this.
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser, 2 BK LFE
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is online now
post #1607 of 1930 Old 05-23-2019, 10:49 AM
Writer & Reviewer
JimWilson's Avatar
Liked: 4091
Mark does indeed have the JS12. I didn't recall Brian mentioning he had a 21" driver in the works, but you never know anymore.
post #1608 of 1930 Old 05-23-2019, 10:52 AM - Thread Starter
imureh's Avatar
Liked: 4916
I have not heard any mention at all about a 21 inch. I think he would likely get a G28 and FV28 done first before he ever thought about a 21 inch
post #1609 of 1930 Old 05-23-2019, 11:51 AM
beastaudio's Avatar
Quoted: 5810 Post(s)
Liked: 5669
Sure have although I don't frequent it since I do just as Mike is describing below VVVV
I run an adjustable series of low shelves like this where I can go flat should I choose to for the big bass movies, but have a global house curve that usually stays in place. If i don't adjust it down at all for the 5 star films, it is completely overpowering and almost violent, but, that's why I am rewatching the 5 star bass movie in the first place so why not? It's super fun.
beastaudio is offline
post #1610 of 1930 Old 05-23-2019, 12:25 PM
Quoted: 281 Post(s)
Liked: 870
My post got all screwed up , I dont know who is making what or if ANYONE is making a new 21" sub...lol....Seems like we are on the forefront of an arms race of subs between ID brands!!
GatoGoat is offline
post #1611 of 1930 Old 05-24-2019, 07:57 AM
basshead81's Avatar
Quoted: 382 Post(s)
Liked: 10985
More useable ULF in the areas where Low Frequency content is already encoded. It doesn't transform the entire sound track.
First Man for example is extremely neutered in LF content. BEQ helps this sound track a lot, but it's still just adding more low frequency content to specific scenes. It's not like you are going to turn on BEQ and the movie suddenly has ULF start to finish. The same areas of the sound track that had bass pre BEQ will now have more presence and weight post BEQ.
I have had Anti-mode dual core and Mini DSP devices in the past. I use to play with house curves and low shelf filters. I found that most tracks sound the best left alone or slightly boosted(+3db) house curve or it sounds artificial and muddy. Just because the graph looks better doesn't mean it will actually sound better. Some rooms sound better by not significantly boosting low frequencies due to room resonances and vibrations.
Fwiw I am not implying BEQ is not worthwhile. I think it's a great supplement to gain useable extension with all of these filtered movies...especially for those with the right rooms to do it.
post #1612 of 1930 Old 05-24-2019, 09:08 AM
Quoted: 932 Post(s)
Liked: 2607
The issue with First Man is there was almost NO low frequency effects anywhere in the soundtrack, and the recording analysis confirms that. This difference is more akin to listening on a system with vented sub that dives off a cliff at 35Hz to a large array of sealed woofers with <10Hz extension and plenty of output.
While I agree most sound better with some level of house curve, I find that to be very dependent on room acoustics and comfortable playback levels of the system. The intent and use of BEQ is dramatically sharper than we would ever do in a house curve. It was slightly un-nerving to apply the filters, even knowing how well my own subs are protected, but looking multiple times at the measured soundtrack content and a first listen eventually put me at ease with it.
jamiebosco and SuperFist like this.
Mark Seaton
Seaton Sound, Inc.
post #1613 of 1930 Old 05-24-2019, 09:26 AM
beastaudio's Avatar
Liked: 5669
I about lost my lunch the first time I saw the amount of LT boosting that was taking place on a few of the very first BEQ's. To the point I almost somehow smelled burning voicecoils just sitting there at my work desk. Bosso probably WOULD lose it looking at some of those filter layerings.
Ricci likes this.
post #1614 of 1930 Old 05-24-2019, 09:28 AM
Liked: 1888
Im the wierdo here.. I do not use BEQ and probably will never.. but maybe because I am mainly a music dude.
audiofan1 and AudioFan810 like this.
post #1615 of 1930 Old 05-24-2019, 09:36 AM
beastaudio's Avatar
Liked: 5669
I dont either. a 15-20dB house curve down to 10hz suffices just fine for me
audiofan1 likes this.
post #1616 of 1930 Old 05-24-2019, 10:56 AM
3ll3d00d's Avatar
Liked: 3139
seems like talking at cross purposes here as this is what I wrote above, probably it's just semantics (of transform or amount) though as a filter does literally transform the entire track (aka waveform), I mean that's what a filter does
imureh likes this.
3ll3d00d is offline
post #1617 of 1930 Old 05-24-2019, 11:04 AM - Thread Starter
imureh's Avatar
Liked: 4916
This conversation started as I made a comment here that with BEQ there was more ULF content available. I still believe that statement is true as many movies had below 20hz content that had been filtered out and BEQ is unlocking it. Now how that statement is spun or interpreted is up to the individual. The fact that BEQ helps with filtered movies is a fact.
post #1618 of 1930 Old 05-24-2019, 11:46 AM
basshead81's Avatar
Quoted: 382 Post(s)
Liked: 10985
^ Agreed. If you have the room and subs for the deep stuff then BEQ away.
imureh likes this.
post #1619 of 1930 Old 05-24-2019, 11:46 AM
beastaudio's Avatar
Liked: 5669
Sure! The discussion was, assuming 5% of the LFE track is below 20hz, Using BEQ doesn't change that, it just enhances that 5%. Use the Hulk cop car smash as an example and for a second let's pretend it has a similar rolloff to the MCU movies. When that 5hz note hits you wont get that floor wobble effect if the track had have been filtered, BUT the sound effect was still embedded in the audio track, IT WAS STILL THERE. Then you apply BEQ to drag that effect up into the range that you will actually experience the effect. The point it, the sound effect had to be there in the first place for BEQ to find it. The semantics argument could be that my statement that only 5% of a soundtrack is below 20hz is meaning anything and everything encoded to the soundtrack below 20hz regardless of level. Your system may only be able to play 50% of that 5%. OR the movie is filtered so you are only able to really experience 50% of that 5%, doesn't matter, it's still there and only 5% of the soundtrack. Now in the latter example you can use BEQ to now experience 100% of the 5%.
Stick a fork in this convo, it's done
Faviann and Spidacat like this.
post #1620 of 1930 Old 05-24-2019, 12:04 PM
tvuong's Avatar
Quoted: 3008 Post(s)
Liked: 3095
And there is a thread for those of us who appreciate what Beq brings. After spending $$$$ on subs, some with MAs/Boss, to get the extension down to 20hz or even to a single digit hz, it is up to an individual to decide playing 20 or higher hz filtered contents on his/her system. I know that I play my subs to their fullest potential making my investment worthwhile
tvuong is online now
