HELP: Not Sure What Settings - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By eljaycanuck
post #1 of 3 Old 12-20-2018, 08:37 PM - Thread Starter
Brian206's Avatar
Quoted: 24 Post(s)
Hey all,
I am not sure what settings to use. I am not using the sub in a 2-channel setup, it is in a 7.1 setup. However, the cable that came with the sub (Martin Logan 700W) is a Left and Right cable which I have plugged into the sub, but the other end is into an adapter that converts it to a single that attaches to the receiver (Yamaha RX V679) I currently have it set to the LFE setting, but I'm not sure if that is correct. (Image attached of instruction manual) Do I have it correct, or is there something I need to change?
Brian206 is offline
post #2 of 3 Old 12-21-2018, 09:07 AM
eljaycanuck's Avatar
Quoted: 1927 Post(s)
Liked: 2714
Run a single RCA-to-RCA connection:
- from the receiver's "SUBWOOFER" output;
- to the subwoofer's "LFE" input.
(See Figure 4 in that manual.)
Blacklightning and Rgarc like this.
eljaycanuck is offline
post #3 of 3 Old 12-21-2018, 10:38 AM
Blacklightning's Avatar
Quoted: 999 Post(s)
Liked: 856
Yes just use the Red LFE connector. No point in using a y-splitter. Using one may target the Low pass filter and you don't want that.
EDIT: I now see that your sub has a LFE switch. Make sure you use that
Blacklightning is offline
