Bass EQ for Filtered Games - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 57Likes
post #61 of 77 Old 01-28-2020, 06:52 AM
Lonewolf7002's Avatar
Quoted: 540 Post(s)
Liked: 628
Originally Posted by peniku8 View Post
Sure. The more the better, basically. I'd recommend hitting record, then going through all the menus quickly to pick up those sounds. In the same recording you can try out as many different weapons as you can find, similar to what I described in the first post. Add some general gample and maybe cutscenes etc. Should be a few hours of material for best results. Extract the audio with mkvtoolnix and send it to me via mega or something
Sounds good, I should hopefully get a few hours of play in this week so I'll record everything I do, focusing on as many sounds and making things go boom as much as possible! The game is in Atmos on PC and already sounds fantastic, this would give those explosions the bit of grunt they are missing!
peniku8 likes this.
Samsung KS8000, Denon AVR-X3300W, Xbox One X, Samsung UBD-K8500 4K bluray player, Himedia Q5 Pro android box
Lonewolf7002 is offline
post #62 of 77 Old 02-10-2020, 10:28 AM - Thread Starter
peniku8's Avatar
Quoted: 381 Post(s)
Liked: 386
Need for Speed: Heat
Audio Profile: Home Cinema; SFX Volume -1; Music Volume -1 (to give the speech +1, shouldn't affect the bass)
Matt Fowler likes this.
A Star Is Born - Lady Gaga goes Rock Audio&Video by Ocean Studios (me)
SKHorn Build
Samsung KS7500 - Marantz NR1504 - Klipsch R-26F - Klipsch R-25C - Klipsch R-15M - SKHorn - BOSS
Bass EQ for Filtered Video Games
peniku8 is offline
post #63 of 77 Old 02-11-2020, 07:20 AM
Quoted: 159 Post(s)
Liked: 196
Borderlands 3
Man these levels are super loud, any headroom concerns? Comparing to movies I see few BEQs go over -15dbfs peaks. Coming close to 0db peaks for BL3.
Do you tend to play at a low MV?
TCL 65R615/Denon X4400H/EMOTIVA A-300/CHANE 2.4A LRC/HSU HB1-MK2 Surrounds/CHANE 1.4 Rear Surrounds/4x RSL C34E Atmos/2x SVS PB 16 Ultras/GIK Accoustics 8 244s 4 tri traps/2x Crowson MAs/MiniDSP 2x4HD
Matt Fowler is offline
post #64 of 77 Old 02-11-2020, 12:29 PM - Thread Starter
peniku8's Avatar
Quoted: 381 Post(s)
Liked: 386
Since you should have enough headroom in the miniDsp/hardwareEQ of your choice (if it's properly set up), you won't run into issues with the BEQ. Crysis 3 had the hottest audio of any game I've ever recorded (see the peaks at around -2db in the un-BEQ'd graph) and you could hear clipping at times. That's just how the game was coded then. I played the game at -20MV, while I watch movies usually at -10 and louder, depending on the movie.
I tried lowering the overall game volume of Crysis 3 but that somehow threw off the entire balance and I didn't bother to investigate any further, so I left it at full.
If you're using something like equalizerAPO for BEQ, I'd suggest including a negative input gain of -10db to prevent digital clipping.
I play BL3 and NFSH at -10MV for example.
Althou the games' graphs might be hotter than those of movies, the bass peaks during movie playback will be much louder. Probably because of the fact that movies have a higher channel count, which send a hotter signal to the sub after bass management and maybe because of how I handle the recorded audio. Borderlands might look very loud on the graph, but the sub will have less work at the same MV compared to watching a random movie.
SKHorn Build
peniku8 is offline
post #65 of 77 Old 02-15-2020, 03:42 PM - Thread Starter
peniku8's Avatar
Quoted: 381 Post(s)
Liked: 386
Nfs Heat BEQ has been updated. Very minor adjustments. Overall, the BEQ doesn't add too much, but I think the fact that the sub 20Hz content is almost exclusively car-crash related makes TR pretty neat for this one. It's not too excessive overall, so you might feel like boosting that region to taste.
SKHorn Build
peniku8 is offline
post #66 of 77 Old 02-21-2020, 10:45 AM
jbarteli's Avatar
Quoted: 331 Post(s)
Liked: 120
Is it possible that anyone can make a BEQ for Destiny 2?
jbarteli is offline
post #67 of 77 Old 03-04-2020, 02:10 PM
Quoted: 540 Post(s)
Liked: 628
My apologies for the delay in getting a recording of Division 2 off to you. peniku8, I sent you a pm.
post #68 of 77 Old 03-13-2020, 04:30 PM - Thread Starter
peniku8's Avatar
Quoted: 381 Post(s)
Liked: 386
The Division 2
Audio provided by @Lonewolf7002
Lonewolf7002 likes this.
SKHorn Build
peniku8 is offline
post #69 of 77 Old 03-20-2020, 01:25 PM - Thread Starter
peniku8's Avatar
Quoted: 381 Post(s)
Liked: 386
Doom Eternal
SKHorn Build
peniku8 is offline
post #70 of 77 Old 04-08-2020, 05:41 AM - Thread Starter
peniku8's Avatar
Quoted: 381 Post(s)
Liked: 386
Division 2 updated!
Doom updated too. Don't forget to switch to the new BEQ or the old one will bring hell to your subwoofer..!
SKHorn Build
peniku8 is offline
post #71 of 77 Old 04-09-2020, 10:00 AM
Quoted: 540 Post(s)
Liked: 628
Thanks for the update! Did Div2 change much from the old settings? I'll check these out tomorrow!
post #72 of 77 Old 04-09-2020, 01:19 PM - Thread Starter
peniku8's Avatar
Quoted: 381 Post(s)
Liked: 386
It's a little more balanced between mid-bass and sub-bass. Not much of a difference overall
SKHorn Build
peniku8 is offline
post #73 of 77 Old 04-20-2020, 09:56 AM - Thread Starter
peniku8's Avatar
Quoted: 381 Post(s)
Liked: 386
Sniper Ghost Warrior Contracts
SKHorn Build
peniku8 is offline
post #74 of 77 Old 04-26-2020, 06:03 PM
Quoted: 540 Post(s)
Liked: 628
Originally Posted by TheBoom89 View Post
Hey Pen, loved your BEQ for Prey.
Do you think you could do one for No Man's Sky? The in game audio and bass is already pretty good, was wondering if the bass could be improved though.
peniku8, I have five and a half hours of No Man's Sky recorded if you are interested.
peniku8 likes this.
post #75 of 77 Old 05-02-2020, 08:06 AM - Thread Starter
peniku8's Avatar
Quoted: 381 Post(s)
Liked: 386
Sorry for the late reply, but sure, send it my way and I'll have a look at it
SKHorn Build
peniku8 is offline
post #76 of 77 Old 05-22-2020, 08:45 AM - Thread Starter
peniku8's Avatar
Quoted: 381 Post(s)
Liked: 386
No Man's Sky
Audio provided and BEQ approved by @Lonewolf7002
SKHorn Build
peniku8 is offline
post #77 of 77 Old 05-22-2020, 08:50 AM - Thread Starter
peniku8's Avatar
Quoted: 381 Post(s)
Liked: 386
Ghost Recon Wildlands
SKHorn Build
peniku8 is offline
