subwoofer upgrade - AVS Forum | Home Theater Discussions And Reviews
 10Likes
post #1 of 43 Old 01-26-2019, 08:03 AM - Thread Starter
wadennis's Avatar
Quoted: 111 Post(s)
Adding Polk HTS 12 opinions
My current setup is listed below. I am thinking of replacing the subwoofer with Polk HTS 12. I am looking for opinions or suggestions? Is the Polk HTS 12 much better than my current subwoofer or am I putting too much emphasis on keeping everything Polk? Thanks
Denon 4300
Front RTIA5
Centre CSIA6
Rear RTIA3
Side FXIA6
Subwoofer NXG NX-BAS-500
wadennis is offline
post #2 of 43 Old 01-28-2019, 08:17 AM
Quoted: 160 Post(s)
Liked: 144
The Polk HTS 12 is an excellent sub for the money.
Obviously there are way better subs for more money, but this is a good value sub. This thread covers it all:
https://www.avsforum.com/forum/113-s...er-review.html
AmerCa likes this.
LG OLED65B7, LG UP970, Yamaha RXA770, Polk S55's, Polk S35, Polk S15's, KEF Ci160ER's, Dual SVS PB-1000's
Sask HT is offline
post #3 of 43 Old 01-28-2019, 08:56 AM
AmerCa's Avatar
Quoted: 781 Post(s)
Liked: 1650
Sask is spot on. If the Polk is at the end range of your budget, it's a pretty good option, if not the best. If you have more money ($500+), there are better options. I have a Polk HTS 12, (Sask also had one), and I'm pretty satisfied with it, but I'd be the first one to tell you, if you have the budget, buy something higher in the sub echelon.
Sask HT likes this.
Vizio 43" D Series 2017 || Onkyo TX383 7.2ch || Fronts: Sony SS-CS5 || Center: Pioneer SP-C22 || Sub: Polk HTS 12 || Surrounds: Micca MB42
AmerCa is online now
post #4 of 43 Old 02-01-2019, 05:37 AM - Thread Starter
wadennis's Avatar
Quoted: 111 Post(s)
What other subs would you recommend? Our options in Canada are not many. I was looking at the polk because of the rest of my setup being polk.
wadennis is offline
post #5 of 43 Old 02-01-2019, 05:39 AM - Thread Starter
wadennis's Avatar
Quoted: 111 Post(s)
Thanks for the info. I could spend more but at $348 I think this is a great price.
wadennis is offline
post #6 of 43 Old 02-01-2019, 12:20 PM
Kini62's Avatar
Quoted: 2716 Post(s)
Liked: 2526
Denon 4300
Front RTIA5
Centre CSIA6
Rear RTIA3
Side FXIA6
Seems more of a lateral move, as long as your current sub is still working fine. I'd skip it or run the two together.
https://www.soundandvision.com/conte...-500-subwoofer
MIX_MASTER_ICE likes this.
Def Tech SC8000
Onkyo RZ820
Roku Ultra, Apple TV, Sharp 70" Quattron
Kini62 is offline
post #7 of 43 Old 02-01-2019, 01:36 PM
MIX_MASTER_ICE's Avatar
Quoted: 2665 Post(s)
Liked: 2470
Matching sub brand to speaker brand isn't important at all. Good to see you have a NX-BAS-500 that is still kicking. The amp on those proved to be unreliable. I haven't heard the Polk HTS12, but that NXG sub is a really good performing budget sub. I had two at one time and was very impressed with them compared to some of the usual suspects from Polk, Bic and Klipsch. If anything, adding the Polk to the NXG might be an option, but I really see no real upgrade in replacing the NXG with the Polk. Or you could sell the NXG and get the Polk. It's likely that the amp will die on the NXG and they went belly up as a company.
Subs>RBH I-12e, I-12. HSU VTF-15H mk2. Monolith THX 12(x2), THX 10(x2). XTZ 1X12. SVS PB-1000(x2). Speakers>JBL Studio 270/235c/230/225c, Arena 130/125c. Sony CS3/CS8/CS5. QA 3020i/3090Ci, 2020i/2000c. Monolith Cinema 5bs. Polk RTiA1/CSiA4. Other Audio>Sony MDR-Z7m2, MDR-V6, XB900n, XB700, XB32, XB31. Sennheiser HD58X, HD4.50, PC37X. Philips SHP9500. SIVGA SV004. HyperX Cloud PS4. TB Stealth300. LG FH6,RK8,RK7,PK5. HK Onyx Studio4(x2).
MIX_MASTER_ICE is offline
post #8 of 43 Old 02-01-2019, 03:32 PM
AmerCa's Avatar
Quoted: 781 Post(s)
Liked: 1650
Like others have implied, you may want your next upgrade to be more significant. We could be talking about in the PB2000 price range, which is possible to get in Canada, Sask can tell you more about it. A Polk HTS12, PB 1000, and particularly the Monolith THX10 would be nice upgrades, but, if possible, saving a little more for a better sub would be advisable.
If you're not interested in spending that much money or care much a about deeper extension and you'd rather stay on a smaller budget, it's either between the Polk or a SVS PB 1000, whichever fits better your budget. That is just my opinion. Here's a thread from a guy that's also in Canada, and is also evaluating his options. He has a slightly bigger budget, but you can see other options: https://www.avsforum.com/forum/113-s...monoprice.html
Sask HT likes this.
post #9 of 43 Old 02-01-2019, 04:09 PM
eljaycanuck's Avatar
Quoted: 1873 Post(s)
Liked: 2632
Sticking +/- to the OP's budget, I'd take a look at the open-box (w/ full warranty) Polk Audio DSW PRO 660wi at Gibby's for $350. Double the power, greater overall output, better extension.
AmerCa and iceatola like this.
eljaycanuck is offline
post #10 of 43 Old 02-01-2019, 04:55 PM
m0j0's Avatar
Quoted: 538 Post(s)
Liked: 501
SVS PB-2000 or SB-2000 would be a good choice, or an HSU perhaps, if you are willing to spend a bit more. I upgraded from an older 12inch Polk sub to the SB-2000 and have not looked back.
m0j0 is offline
post #11 of 43 Old 02-02-2019, 06:24 AM - Thread Starter
wadennis's Avatar
Quoted: 111 Post(s)
I am not sure it is still kicking? I only get minimal bass out of it. It has been minimal since the day I purchased it. I always thought it sure perform better than it has. Returning it was a problem because I purchased it in US & live in Canada. I am hoping to get better results from the Polk if not I will return it. I have ordered it from Visions & is on back order so will be a while until I find out
wadennis is offline
post #12 of 43 Old 02-02-2019, 06:30 AM - Thread Starter
wadennis's Avatar
Quoted: 111 Post(s)
I am not sure my current sub is working well or ever has. I am a little concerned that if I upgrade to a better sub then my next step will be changing out my entire system to some thing higher end. My current setup is only about a year old. Thanks for the info
wadennis is offline
post #13 of 43 Old 02-02-2019, 02:43 PM - Thread Starter
wadennis's Avatar
Quoted: 111 Post(s)
Which polk 12 inch sub did you upgrade from? What does the rest of your setup consist of? Did the sub upgrade make a huge difference? Do you play much music with your setup? If so did sub improve the music listening much? I am considering biting the bullet for a higher end sub but am wondering if almost 3 times the price is worth the cost. All opinions appreciated
wadennis is offline
post #14 of 43 Old 02-02-2019, 03:12 PM - Thread Starter
wadennis's Avatar
Quoted: 111 Post(s)
subwoofer upgrade
Here is my current setup
Denon 4300
Front RTIA5
Centre CSIA6
Rear RTIA3
Side FXIA6
I would like to upgrade the subwoofer & am looking for suggestions. I would say in the $1000 & under range. I am in Canada so options are limited.
wadennis is offline
post #15 of 43 Old 02-02-2019, 03:14 PM - Thread Starter
wadennis's Avatar
Quoted: 111 Post(s)
subwoofer upgrade
Denon 4300
Front RTIA5
Centre CSIA6
Rear RTIA3
Side FXIA6
I would like to upgrade the subwoofer. Budget approx $1000. I am in Canada so limited choices
wadennis is offline
post #16 of 43 Old 02-02-2019, 03:37 PM
Liked: 2470
You can get SVS subs in Canada. The PC-2000 is $1079/shipped at electronicsforless.ca
post #17 of 43 Old 02-02-2019, 03:40 PM
m0j0's Avatar
Quoted: 538 Post(s)
Liked: 501
I don't recall the model. Thinking about it, it may have been a 10 inch Polk. It was a few years ago. But yes, the SVS-PB2000 was a dramatic upgrade. I don't play much music with it, mostly use it for movies, but I do have some FLAC audio files and occasionally will put on some music. In particular, the kids love Infected Mushroom, which has lots of bass, so in that case, it does make quite a difference, but as far as I am concerned, I use it mostly for movies. I have the sub close to my seating position and it feels like I have one of those bass shakers in my couch. The impact is insane compared to my older sub. I had a friend over and his wife was startled several times by the impact from the bass, so it makes quite a difference. It's like saying (with the old sub) I hear bass and acknowledge that there is bass to (with the SVS sub) man, did you feel that?!?!
m0j0 is offline
post #18 of 43 Old 02-02-2019, 03:40 PM
Liked: 2470
You might make sure you have it set up properly. If the NXG is putting out "minimal bass", then that sounds like a set up issue. That sub has quite a bit of output in it's wheel-house frequency range. One thing that jumps out at me with you stating this is to make sure you have your speakers set to small and a crossover in the 70-100Hz range, depending on your speakers. Having the speakers set to large will REALLY decrease the output to the sub.
post #19 of 43 Old 02-02-2019, 03:54 PM
Liked: 2470
SVS is available in Canada. PC-2000 is $1079/shipped at electronicsforless.ca
darthray and eljaycanuck like this.
post #20 of 43 Old 02-02-2019, 06:27 PM
darthray's Avatar
Quoted: 2199 Post(s)
Liked: 3164
@wadennis
+1 on the quote above
And free shipping to boot
https://www.electronicsforless.ca/sv...-oak-3912.html
Ray
darthray is online now
post #21 of 43 Old 02-02-2019, 06:33 PM
pase22's Avatar
Quoted: 3292 Post(s)
Liked: 2737
Denon 4300
Front RTIA5
Centre CSIA6
Rear RTIA3
Side FXIA6
How much sub you need is dependent on:
1) How big is the room? including open areas and adjacent rooms.
2) Listening habits? moderate, loud, very loud.
3) Desired output? Do you want that kick in chest thump or smooth even bass?
4) Is the system used more for TV/HT or music?
Kef LS50,Q200C, Q100, SVS SB-2000, Denon AVR-X3400H, NAD 216, Panasonic 50" Plasma, Xbox One.
Bedroom: JBL Loft 50 , Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #22 of 43 Old 02-03-2019, 06:19 AM - Thread Starter
wadennis's Avatar
Quoted: 111 Post(s)
The room is an enclosed 12 x 24 feet. I would say my listening is moderate to loud. I would say a smooth even bass. I mainly listen to tv & music. Music more so at loud.
wadennis is offline
post #23 of 43 Old 02-03-2019, 06:22 AM
KenM10759's Avatar
Quoted: 3395 Post(s)
Liked: 1876
KEF Kube 12b. Great in smaller rooms as the unit's DSP (digital sound processor) can do wonders for situations of constrained placement. Very smooth, very responsive.
KEF R500, R200C, R100, R50, SVS SB2000 sub, NAD T758v3 AVR, LG UP875 4K BlueRay, Samsung UN55JU6500F 4K LED TV, KEF M500 headphones, Sony CDP-CE500 CD changer. Office: NAD M10, KEF LS50, KEF Kube 10b, Pro-Ject RPM1 TT w/ Ortofon 2M Red. Guest room: Hafler 300 L-R, KEF Reference Model 100 center, KEF iQ10 surrounds, modded M&K V-90 sub, Bluesound Vault 2.
KenM10759 is online now
post #24 of 43 Old 02-03-2019, 08:15 AM
Justin Andrew Parks's Avatar
Quoted: 60 Post(s)
Liked: 38
A PC2000 for that price is going to be hard to beat in Canada. Just remember if you are purchasing from anyone other than SVS directly I don't believe you are eligible for the upgrade program
Receiver: Marantz 5012 Power: Emotiva XPA-5 Gen 1
Towers: Klipsch RF83 Center: Klipsch RP450C
Surrounds: Klipsch RS42II
Subs: Dual Rythmik FV15HP
Justin Andrew Parks is offline
post #25 of 43 Old 02-03-2019, 11:49 AM
pase22's Avatar
Liked: 2737
Your room is on the larger side. Since you mostly listen to TV/movies, dual SVS PB-1000's would be the way to go. Dual subs would minimize nulls and give you even smooth bass throughout the room. If you can only do a single sub, the SVS PB-3000 would be a good choice or at a minimum the PB-2000 if you can't go over budget. Anything smaller would struggle to fill that space, especially at higher volume. Unfortunately good sub options are limited in Canada.
https://www.sonicboomaudio.com/box-s...377q5394mhooo0
https://www.summithifi.com/collectio...3000-subwoofer
pase22 is offline
post #26 of 43 Old 02-03-2019, 11:51 AM
Quoted: 832 Post(s)
Liked: 671
sigpig is offline
post #27 of 43 Old 02-04-2019, 04:26 AM - Thread Starter
wadennis's Avatar
Quoted: 111 Post(s)
Polk Sub
Which subwoofer is better the HTS12 or PSW505 12" powered?
My room is 12 x 24. I am 50/50 for music & movies.
I would appreciate all opinions and/or other suggestions.
wadennis is offline
post #28 of 43 Old 02-04-2019, 04:34 AM
Liked: 2632
IMO the best value right now is the open-box (w/ full warranty) Polk DSW PRO 660wi for $349.99 at Gibby's:
- 12" driver
- 400W (RMS/continuous) amp
- 25-125Hz +/-3dB
post #29 of 43 Old 02-04-2019, 05:30 AM - Thread Starter
wadennis's Avatar
Quoted: 111 Post(s)
SVS Subs
What is the differences other than size between the SVS SB-2000 & PB-2000? The SB model I can order for a minimal amount cheaper(only about $100) What is the performance differences? My room is 12 x 24. I am about 50/50 listening between music & movies.
wadennis is offline
post #30 of 43 Old 02-04-2019, 05:35 AM
imureh's Avatar
Quoted: 2812 Post(s)
Liked: 3508
You can look at the details on the SVS website but main difference is that SB is sealed and PB is ported. In your room size I would lean towards a ported sub as it will more output around port tune and will fill the room better than a sealed.
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser, 2 BK LFE
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is online now
