Velodyne DLS-4000R vs. BIC America F-12 - straight trade - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By Spewdom
  • 1 Post By B3ntwooki3
post #1 of 10 Old 02-17-2019, 12:42 AM - Thread Starter
Saitac's Avatar
Quoted: 12 Post(s)
Hey you awesome geniuses...
Just upgraded some speakers. I've got a nice to me 5.1 with Energy speakers - Connoisseur series towers for R/L and there larger center. I'm currently running a Bic America F-12. Works pretty well I think but I have the option of doing a straight across swap with a Velodyne DLS-4000R. I get to keep 1 of the 2 subs.
They both seem like pretty decent subs. I know Velo has a long pedigree. Room is mid sized. ~14'x18'. 9 ft ceilings.
For movies. Does anyone have any thoughts here?
BIC F12
Price (MSRP): $449/Each
Design: Front-firing 12" 475-watt peak powered subwoofer
Frequency Response: 25Hz - 200Hz
Sensitivity: 90dB
Drivers: 12" Injection molded woofer with heavy duty surround
Magnetic Shielding: YES
Gold-Plated Terminals:YES
Recommended Power: Built-in Amplifier Power: 475 watts Dynamic Peak, 150 watts RMS continuous
Impedance: 8 ohms
Velodyne DLS-4000R
Price: $560
Configuration Extended Excursion Slot-Loaded Bass-Reflex
Driver 12" forward firing (9-7/8" piston diameter) with vented pole piece
Frequency Response 25-120 Hz +/-3 dB
Phase 0, 90, 180, 270 degrees
Presets Movies; R&B-Rock; Jazz-Classical; Games
Magnet 2.5 lbs
Voice Coil 2" 4-layer copper
Power Requirements: 117V, 60 Hz
Continuous Power: 200 watts
Dynamic Power: 400 watts
Saitac is offline
post #2 of 10 Old 02-17-2019, 01:31 AM
Quoted: 91 Post(s)
Liked: 82
The Velodyne DLS-4000R is an ancient model by electronics standards. My $0.02 is that performance seems to be pretty comparable but with a much older amp possibly nearing the end of its life.
B3ntwooki3 is offline
post #3 of 10 Old 02-17-2019, 05:44 AM
Spewdom's Avatar
Quoted: 185 Post(s)
Liked: 168
BIC F12
Sensitivity: 90dB
Impedance: 8 ohms
Velodyne DLS-4000R
Price: $560
Magnet 2.5 lbs
I would keep what you have and just save up for a better performing sub if you're wanting a change.
iceatola likes this.
Spewdom is online now
post #4 of 10 Old 02-19-2019, 01:01 PM
Photokid1970's Avatar
Quoted: 67 Post(s)
Liked: 50
I have an Onkyo 809 with Klipsch LCRs and Surrounds, and I've been reading through the Speaker and Receiver forums trying to decide what to do in order to upgrade to Atmos. I've moved speaker positions, re-run Audyssey calibration using new techniques, and have improved the sound overall without having spent any money (except for banana plugs, mounts, etc). I've been trying to save my budget for a new Atmos Onkyo, because I'm generally pleased with the speakers I have. Some have recommended a higher model center for my setup, but no one has said anything to make me worry about upgrading anything besides my AVR at this point.
Until now! I have a Velo DLS-4000R sub that I received in 2011. It may be old technology, but I really enjoy it. Now that I have it calibrated better, it really does add life to both music and movies. I really was looking forward to upgrading my AVR and hearing Atmos. But NOW that you have told me that the Velo is old technology, I will need to upgrade! Since you said it on the Internet, it has to be true, right? Ugh. Now it's time to start finding new excuses to feed to my wife as to why I need to upgrade more than one big ticket item in the HT...
Photokid1970 is offline
post #5 of 10 Old 02-19-2019, 01:22 PM
Quoted: 91 Post(s)
Liked: 82
Did you even bother reading the OP's question to establish context before injecting your sarcasm into a friendly thread?
I never implied that the Velo was a bad sub. The OP asked he he should do a straight trade with a presumably new BIC F12 for an older Velo DLS-4000R.
The statement that the Velo was "ancient" was a reference to how electronics don't improve with age like a fine wine. The Velo has no CEA-2010 specs therefore it is impossible to know exactly how it compares with the F12 but the specs infer that they are comparable with the Velo having the disadvantage of having aged electronic components.
As far as your whatever your wife has to say about anything or whatever you choose to upgrade or not upgrade is none of my business and I really don't care as I was not replying to you or your situation.
Edit:
I also never made a single reference to how the Velo was old technology even though it just might be as it is struggling to keep up with a budget under $200 subwoofer such as a BIC F12. I only mentioned that the electronics had some mileage on it.
post #6 of 10 Old 02-19-2019, 01:28 PM
Quoted: 67 Post(s)
Liked: 50
Yes I did... I did not mean to offend - my apologies. He's looking to see if he should trade or not, and I wasn't trying to encourage or discourage that at all. I am just making the point that I thought the Velo was pretty good, and now it seems that it may be old technology, and perhaps I should add something new to my shopping list! I find that to be a bit exciting, as I haven't been sub shopping in a while.
Again, I apologize if my sarcasm caused your fur to raise. Not my intent.
post #7 of 10 Old 02-19-2019, 01:39 PM
Quoted: 91 Post(s)
Liked: 82
Perhaps my social skills our out of touch with today's internet speak but the statements like you made which is quoted above would absolutely solicit a response in my opinion. Response has been given and I am moving on.
post #8 of 10 Old 02-19-2019, 01:43 PM
Quoted: 67 Post(s)
Liked: 50
Understood. I meant no disrespect. Again my apologies if I came across as rude.
In regards to the OP, I can tell you I am very pleased with my sub. Good luck to whatever choice you make!
post #9 of 10 Old 03-06-2019, 01:26 PM
Quoted: 17 Post(s)
Liked: 4
Very civil of you gents, good to see not everyone will drag down the thread with back-and-forth bickering.
I've had the Velodyne DLS-4000R for close to a decade now, as an audio novice it has performed well for my needs.
I do have a bass drop in my main seating area where the room opens up but that's primarily a layout issue.
I'm no expert so I'm not sure what new subs bring to the table but unless you're noticing a major audio issue it is probably best to wait it out.
No harm in asking for a trial if you can swing it.
kozege is offline
post #10 of 10 Old 03-08-2019, 11:46 AM
iceatola's Avatar
Quoted: 250 Post(s)
Liked: 227
BIC F12
Sensitivity: 90dB
Impedance: 8 ohms
Velodyne DLS-4000R
Price: $560
Magnet 2.5 lbs
If I were you I would save up a little more money and go bigger because the F12 might have a little bit more bass but it will not be as clear as the DLS-4000R sub.
Just my 2cents
Video: Optoma HD143X projector - Elite Screens Manual Grande Series - 128inch
Receiver: Emotiva Fusion 8100 / Amps: Emotiva XPA-3, UPA-700
Polk Signature Series - S60 Towers for L/R, S35 Center, S15 Surrounds
Subwoofer PSA 2xV1801
Roku 4, Nvidia Shield, Xiaomi Mi Box S, Darbee Darblet 5000
iceatola is offline
