Raise subwoofer off ground 24"? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By eljaycanuck
post #1 of 7 Old 03-12-2019, 09:45 AM - Thread Starter
todd1010's Avatar
Quoted: 117 Post(s)
I want to buy some solid sturdy foam to make a platform to raise my subwoofer off the ground.
What kind of foam would I be looking for?
Receiver : Pioneer Elite SC-LX701
Main & Center Speakers : Phase Technology PC 3.5, & Surrounds
Amplifiers : Emotiva UPA-1 Monoblocks, SVS SB3000 Subwoofer
MonsterPower HTS5100, Harmony Elite Remote
TV & Sources: Sony 75” 900F, Bluesound Node 2, Xbox One & Apple TV4K
todd1010 is offline
post #2 of 7 Old 03-12-2019, 10:35 AM
eljaycanuck's Avatar
Quoted: 1892 Post(s)
Liked: 2657
Sturdy? My guess is you'd want to look at something like EPS (Expanded Polystyrene) foam. Personally, if I were building a 24"-high platform for a subwoofer, I'd make it out of wood.
Madmax67 likes this.
eljaycanuck is offline
post #3 of 7 Old 03-12-2019, 10:48 AM
Alan P's Avatar
Quoted: 6393 Post(s)
Liked: 5707
Why? Aesthetics, or something else?
Alan P is online now
post #4 of 7 Old 03-12-2019, 10:54 AM - Thread Starter
todd1010's Avatar
Quoted: 117 Post(s)
Sort of. I just can't think of anything that wouldn't stand out or look like its bring attention to the sub. I just want it to do its job.
I'm not opposed to something else, I just haven't seen or can't think of anything. I've looked at the ISOacoustic sub stand but its only a few inches off the ground.
todd1010 is offline
post #5 of 7 Old 03-12-2019, 10:59 AM
DonH50's Avatar
Quoted: 3275 Post(s)
Liked: 3362
Are you planning in using the space beneath the sub? If so, you need a pretty solid platform... If not, I'd suggest picking up some concrete blocks (cinder blocks) from a hardware store and some cheap cloth or sheet in whatever color you choose. Set up the blocks (two high = 16", or stand on end to get 16" high from just four blocks) space appropriately to support the sub, then drape the cloth over them and pull tight for a clean look. Stick the sub on them, done.
https://www.homedepot.com/p/Oldcastl...1345/100350252
HTH - Don
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #6 of 7 Old 03-12-2019, 11:00 AM - Thread Starter
todd1010's Avatar
Quoted: 117 Post(s)
I was thinking that if I could find some solid foam, that would also help isolate the sub.
todd1010 is offline
post #7 of 7 Old 03-12-2019, 11:44 AM
Quoted: 166 Post(s)
Liked: 151
I have my subwoofer off the ground by around 12 inches or so using a modular rack system by VTI. You could stack a couple of them to reach 24 inches and have some usable shelves underneath and a clean modern look.
Not sure how big and heavy your sub is, but mine is a Rythmik G25HP which isn’t exactly tiny.
ianrozzano is offline
