SUB Decision!!!! - AVS Forum | Home Theater Discussions And Reviews
 55Likes
post #1 of 53 Old 03-16-2019, 03:50 AM - Thread Starter
Quoted: 82 Post(s)
Liked: 1
SUB Decision!!!!
Ok I need help making a decision on a sub i was going to go with a klipsch sub but i have got some poor feed back on them. So i been reading that the rythmik, vtf-2 mk5, svs sb-2000 and monolith are good sub in my price rang (700.00) I will be using it for movies more than music. my room size is 13x24. i will be running a 9.2.4 what do you guys think?
quentinnw2 is offline
post #2 of 53 Old 03-16-2019, 05:02 AM
jamiebosco's Avatar
Quoted: 712 Post(s)
Liked: 1699
I know this gets said almost every time, but if at all possible - extend your budget and grab the HSU VTF3 mk5
TV: Panasonic P65ST60 AVR: Denon 4311ci Speakers: PSA MTM-210C (Centre), PSA MTM-210 (Left & Right), PSA MT-110 (Surrounds) Subwoofers: Dual Seaton SubMersives
jamiebosco is offline
post #3 of 53 Old 03-16-2019, 05:18 AM
eljaycanuck's Avatar
Quoted: 1866 Post(s)
Liked: 2619
13' x 24' x ~8' = ~2,500 cu.ft. Not a huge room, but not a small one, either.
If you can stretch your budget, the VTF-3 MK5 HP is the best value (bang-for-buck) option.
But a pair of Monoprice Monolith 12" for $1,500, shipped, is pretty hard to argue with, IMO.
tackhouse1 likes this.
eljaycanuck is offline
post #4 of 53 Old 03-16-2019, 05:39 AM
Buy once,cry once. You can't have too much sub.
m0j0, Todd G., pjp and 4 others like this.
Grappler1911 is offline
post #5 of 53 Old 03-16-2019, 05:44 AM
m0j0's Avatar
Quoted: 512 Post(s)
Liked: 456
Great suggestions! He could even start with a single Monolith 12 and buy the 2nd later to complete the setup.
m0j0 is online now
post #6 of 53 Old 03-16-2019, 05:57 AM - Thread Starter
Quoted: 82 Post(s)
Liked: 1
could my Denon avr-x4500h run these subs?
post #7 of 53 Old 03-16-2019, 06:02 AM
Spewdom's Avatar
Quoted: 192 Post(s)
Liked: 174
Of course. That's a great AVR. I'd choose the ported Monolith subs in your price range.
Spewdom is online now
post #8 of 53 Old 03-16-2019, 07:52 AM
Todd G.'s Avatar
Quoted: 162 Post(s)
Liked: 374
Lots of good advice here. I like Grappler's take--"buy once, cry once". That's what I did for our main floor living room (VTF-3 Mk5 HP) and the basement media room (twin Power Sound Audio V1811 subs). What's most important is that your preferences, goals, and budget are your own...and your room will not be like anyone else's. But buy from any of the internet-direct manufacturers (Hsu, Monoprice Monolith, SVS, PSA, Rythmik, JTR, etc.) and you really can't go wrong.
Best of luck with your decision!
iceatola likes this.
Basement bat cave: JVC RS2000, 100" 16:9 Stewart StudioTek 130, Denon AVR-X4400H, Oppo UDP-203, Polk RTi A7 towers/CSi A6 center/65RT in-wall side surrounds (2)/70RT in-ceiling Atmos (4), dual PSA V1811 subwoofers
Todd G. is offline
post #9 of 53 Old 03-16-2019, 08:25 AM - Thread Starter
Quoted: 82 Post(s)
Liked: 1
OK I HAVE IT DOWN TO TWO SUB NEED YOUR INPUT ONE MORE TIME.....rythmik LVX12 Direct OR VTF-2 MK5 12 WHAT DO YOU THINK.
post #10 of 53 Old 03-16-2019, 09:38 AM
badboi's Avatar
Location: East of the Sun, West of the Moon (Home Farm, Emme
Quoted: 126 Post(s)
Liked: 130
HSU. I've had good results with them.
badboi is offline
post #11 of 53 Old 03-16-2019, 11:12 AM - Thread Starter
Quoted: 82 Post(s)
Liked: 1
HAS ANYONE USE emotiva SUB?
post #12 of 53 Old 03-16-2019, 11:38 AM
gajCA's Avatar
Quoted: 8795 Post(s)
Liked: 5972
Not a great value anymore now that the BasX line of subs has been discontinued.
PORTED SUBWOOFERS $600 AND BELOW, DELIVERED
NOTE:
*THE LARGER PORTED SUBS DELIVER AT LEAST 40% MORE SOUND PRESSURE LEVEL
THAN THE SAME BRAND'S SEALED VERSION WITH SAME SIZE WOOFER AND AMP
*IF LOOKING AT LARGER/MORE EXPENSIVE SUBWOOFERS ADD PSA TO THE LIST OF BRANDS
*IF YOU ARE NOT AN ACTION MOVIE FAN A SUBWOOFER WITH 22-30HZ EXTENSION WOULD BE FINE
*FOR MUSIC A 30HZ SUB IS A FINE CHOICE
*BEFORE BUYING MAKE A CARDBOARD CUTOUT OF THE SIZE OF THE SUB TO MAKE SURE IT IS NOT TOO LARGE FOR YOU
Specs are from the manufacturer unless noted otherwise.
120watts =13w15h16d= 29 lbs 10" [29hz] $250 MARTIN LOGAN DYNAMO 500, limited time offer
200watts =13w14h15d= 27 lbs 8" [29hz] $270 KEF C4 Accessories 4 Less Price
350watts =15w16h17d= 40 lbs 10" [30hz] $399 RSL SPEEDWOOFER 10S, (extension from Sound & Vision review)
200watts =14w15h15d= 32 lbs 10" [25hz] $450 ELAC DEBUT 2.0 SUB3010, (extension from Sound & Vision review)
NOTE: THIS SUB HAS PHONE APP EQ FOR THE SUB
250watts =15w19h17d= 42 lbs 10" [25hz] $455 HSU VTF 1 MK3 (extension from Audioholics review)
300watts =15w19h20d= 46 lbs 10" [18hz] $499 SVS PB1000, (extension from Sound & Vision Review)
500watts =15w19h20d= 72 lbs 10" [20hz] $500 MONOPRICE MONOLITH THX 10"
300watts =16w22h21d= 69 lbs* 12" [19hz] $569 RHYTHMIK LV12F
350watts =15w21h22d= 62 lbs 12" [18hz] $607 HSU VTF2 MK5, (extension from Audioholics review)
* = shipping weight
B3ntwooki3 and d-rail34 like this.
Geoff A. J., California
gajCA is online now
post #13 of 53 Old 03-16-2019, 11:42 AM
Liked: 2619
OK I HAVE IT DOWN TO TWO SUB ... rythmik LVX12 ... OR VTF-2 MK5 ...
Outlaw Ultra-X12. On sale, it tends to run about $650, shipped. A pair for $1,300 would be pretty sweet.
post #14 of 53 Old 03-16-2019, 11:47 AM
spyboy's Avatar
Quoted: 212 Post(s)
Liked: 155
Second the HSU.
Todd G. likes this.
spyboy is offline
post #15 of 53 Old 03-16-2019, 12:12 PM
MIX_MASTER_ICE's Avatar
Quoted: 2636 Post(s)
Liked: 2453
I would sit tight until the next ebay discount code to get $100 off or monoprice run another 20% off the Monolith THX Ultra 12. That would put the sub at your $700 budget or less. Best 12" sub I've ever experienced.
Todd G. likes this.
MIX_MASTER_ICE is offline
post #16 of 53 Old 03-16-2019, 12:15 PM
d-rail34's Avatar
Quoted: 396 Post(s)
Liked: 742
The Denon's have dual sub outs and Audyssee has the ability to EQ the subs as well, so you're good to go.
Note: Any AVR that has sub outs can run a powered subwoofer.
As for which sub to get...
Get the biggest, best sub you can within your allocated budget. Even if it's just a single now, as you can always add another one later. I say this merely due to the fact that at some point most people want MORE. This will help eleminate the "upgraditis" & "what ifs", and it will save you a lot more money in the grand scheme of things.
With that said, the Hsu VTF3 MK5 that was mentioned at the beginning of your thread would be worth extending your budget a little to get. You'll be much happier with the results of having the larger cone. Hence, most people eventually upgrading to the 15"-18" drivers.
Hope this helps,
Darrell
darthray, Todd G. and iceatola like this.
"Sticking feathers up your butt does not make you a chicken." - Tyler Durden
Living Room - Denon AVR-X2400H/MiniDSP 2X4HD/Hsu Research HB-1 Bookshelfs (4)/HC-1 Center/SVS PB12 Plus (1)/Samsung UN65H7150/Sony UBP-X800/PC Built by D-Rail/XBox One S
d-rail34 is online now
post #17 of 53 Old 03-16-2019, 12:17 PM
Kini62's Avatar
Quoted: 2702 Post(s)
Liked: 2506
2 different price points. Overall the LVX12 is the better sub.
d-rail34 likes this.
Def Tech SC8000
Onkyo RZ820
Roku Ultra, Apple TV, Sharp 70" Quattron
Kini62 is offline
post #18 of 53 Old 03-16-2019, 12:52 PM
Billy p's Avatar
Quoted: 372 Post(s)
Liked: 740
Iirc....you had the predecessor Rythmik unit and have owned several subs... Seen folks here often shy away from recommending the monolith....citing extenuating circumstances which for argument sake are duly noted....but from what I've seen and read the monolith are tremendous performers and now appear they're releasing "new" sealed units....they must be doing something right...I reckon.
Ascend Acoustics: Towers, STC w RAAL & 200 SE in espresso,
54" of Panny Bliss, Anthem MRX 300, Oppo 103D,
Sub: Funk Audio 18: (Santos Rosewood)
Indian proverb: We don't inherit the earth from our ancestors but we borrow it from our children!
Billy p is online now
post #19 of 53 Old 03-16-2019, 01:35 PM
Liked: 2453
Originally Posted by Billy p View Post
Iirc....you had the predecessor Rythmik unit and have owned several subs... Seen folks here often shy away from recommending the monolith....citing extenuating circumstances which for argument sake are duly noted....but from what I've seen and read the monolith are tremendous preformers and now appear their releasing "new" sealed units....they must be doing something right...I reckon.
The only Rythmik sub I've owned was the LV12R and I wasn't too impressed with it. I own or have owned several quality 12" subs, but none of them impressed me nearly as much as the Monolith THX Ultra 12. Claridy did a great job with the Monolith subs and when on sale they are really tough to beat.
Subs>RBH I-12e, I-12. HSU VTF-15H mk2. Monolith THX 12(x2)/THX 10(x2). XTZ 1X12. SVS PB-1000(x2). Speakers>JBL Studio 270/235c/230/225c, Arena 130/125c. Sony CS3/CS8/CS5. QA 3020i/3090Ci, 2020i/2000c. Monolith Cinema 5bs. Polk RTiA1/CSiA4. Other Audio>Sony MDR-Z7m2, XB900n, MDR-V6, XB700, XB32, XB31, XB22. Sennheiser HD58X, HD4.50, PC37X. SIVGA SV004. HyperX Cloud PS4. TB Stealth300. LG FH6, RK8, RK7, PK5, PH4. HK Onyx Studio4(x2).
post #20 of 53 Old 03-16-2019, 03:19 PM
Todd G.'s Avatar
Quoted: 162 Post(s)
Liked: 374
...at some point most people want MORE. This will help eleminate the "upgraditis" & "what ifs", and it will save you a lot more money in the grand scheme of things.
Precisely why I bought the PSA V1811s for my basement.
If you can expand your budget some and decide you would like the Hsu VTF-3, look on the Hsu clearance page or email Kevin to see if you can snag a B-stock unit when one comes available--it typically has been enough of a discount that shipping winds up essentially free. That's how I got mine for a decent discount, so it was even more of a bargain.
alwaller and d-rail34 like this.
Todd G. is offline
post #21 of 53 Old 03-16-2019, 05:29 PM
d-rail34's Avatar
Quoted: 396 Post(s)
Liked: 742
I was actually looking into building a pair sonotube subs with 18' drivers (24" x 6').
Todd G. likes this.
post #22 of 53 Old 03-16-2019, 06:30 PM
darthray's Avatar
Quoted: 2143 Post(s)
Liked: 3069
While you have only 20 posts, I can see that you have done lots of reading around here (or had lots of previous experience, and new around here)
I got to remember this line, it is so perfect in few little words. And so true
Ray
darthray is offline
post #23 of 53 Old 03-16-2019, 06:59 PM
darthray's Avatar
Liked: 3069
@d-rail34
Darrell
This is the first time, I notice in your Signature;
Bedroom - Blose: Cinemate II GS 2.1
Love-it!!!
That did put a big smile on my face
Most folks do not understand why, I walk away from some vehicle due to the fact they use Bose.
Instead I got lots of this And reply's that they sound so good and play loud.
Sorry in advance to derail this thead a little, and now back to the subject at hand
Ray
d-rail34, B3ntwooki3 and rjmcinnis like this.
darthray is offline
post #24 of 53 Old 03-16-2019, 09:27 PM
bobknavs's Avatar
Quoted: 2213 Post(s)
Liked: 1576
You're up to 9.2.4 now? Is that correct? Receivers that can process 13 channels are much more expensive than those that can do 11. Example: Denon AVR-X8500H. $4k list, not a lot less on the street.
You'd do better to stay with a 7.2.4 system and spend the extra on the subs.
Rysa4 and darthray like this.
bobknavs is offline
post #25 of 53 Old 03-17-2019, 12:52 AM
TommyDeVito's Avatar
Quoted: 144 Post(s)
Liked: 143
Ray
That line is how I live my entire life. Extend it past HT, and apply towards vehicles, appliances, anything. I tend to wait, buy, and keep what I buy. Upgrayedd thusly spelled with two D’s, for a double dose of this pimpin’, doesn’t get me much. But some people are fidgety or must have new new all the time.
d-rail34 and darthray like this.
TommyDeVito is offline
post #26 of 53 Old 03-17-2019, 07:15 AM
Quoted: 31 Post(s)
I run dual HSU VTF2 MK5's in a room with similar cubic feet as yours and never have they felt inadequate. Would two 15's sound even better lower, hell yeah, but a room of that size it might just be overkill outside of some very selected movie tracks that would take advantage of lets say below 18hz. Two subs like that will outperform one 15" also without working that hard. But overall if the sub can hit a cleaner 22hz or so your covered a very large majority of the time. So with HSU VTF2 MK5's hitting 18hz your pretty much covered and it does an excellent job of being clean sounding on its way down and that is what makes a great sub and what you pay for.
I run them with with one vent plugged and they hit hard and rumble great. In that room I'm only running them at about volume level 2.5 on the back of them and I think I set my receiver is giving them a 1.5 or 2 db bump. I could crank them up so much more but they completely fill that room with all the bass 99% of people would ever want and you can feel it when it hits and rumbles.
I'd highly recommend them or the Rhythmik. Both have a great reputation and if you ever wanted to go bigger down the road in a few years you'd probably be able to recoup a good chunk of your money. But in a room of your size and what those subs are capable of I'm not sure you'd hear much benefit for big part of your listening experience with larger subs.
skylolow is offline
post #27 of 53 Old 03-17-2019, 09:28 AM
I have two PSA 1800 also. Two SVS sealed 12s also in a Duplex. I started Home Theater in the mid 80s.
Had a subwoofer before subwoofers were cool. Power Amp too.
post #28 of 53 Old 03-17-2019, 09:34 AM
Same here. I sells guns and train people for a living. Everyone regrets going half way. End up losing way more than they saved upgrading/trading in, in the first place.You only live once, you could die tomorrow. Get what you want.
post #29 of 53 Old 03-17-2019, 11:25 AM
bobknavs's Avatar
Liked: 1576
I suppose that no one has starved or frozen to death because they spent too much on guns or AV gear.
Maybe a mortgage foreclosure or early demise due to being unable to pay for medical care, but...
bobknavs is offline
post #30 of 53 Old 03-17-2019, 01:10 PM - Thread Starter
Quoted: 82 Post(s)
Liked: 1
Sub choice and why
Klipsch R-115SW Subwoofer Or the HSU VTF-3 MK5 HP I will be running Klipsch 7.1.4 set RP-8000f towers and with (4)RP-250S surrounds and RP-450C I have heard some mix reviews on the Klipsch subwoofer...Thanks
