Polk Audio PSW505 power cord? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Tom Vodhanel
post #1 of 3 Old 03-20-2019, 06:43 PM - Thread Starter
iamjason's Avatar
Quoted: 32 Post(s)
Hello! My home theater had been lacking a sub for too long....I was recently gifted a used Polk Audio PSW505 12" Powered Subwoofer and am stoked to put it to use. I just need to order the cable and power cord as they had misplaced it - is there a certain plug I should be buy for the sub? just want to make sure there is not something specific i should have to power the sub - here is the link to the one I have -
Sub link to amazon
I appreciate the assistance - would prefer to order from amazon if possible - thanks!
iamjason is offline
post #2 of 3 Old 03-20-2019, 06:50 PM
Tom Vodhanel's Avatar
Quoted: 3034 Post(s)
Liked: 10320
Sub link to amazon
That looks like a standard iec. Any spare PC or pc printer power cord you might have in a box will work.
https://www.amazon.com/TNP-Universal...ronics&sr=1-14
Just ifnd something cheap(same for the sub cable )
Don't worry about the 3 prong versus two prong. Either one will work for you and the three prong tend to be less expensive.
Tom V.
Power Sound Audio
sk373 likes this.
The woods are lovely, dark and deep, But I have promises to keep,
Tom Vodhanel is offline
post #3 of 3 Old 03-21-2019, 07:04 AM - Thread Starter
iamjason's Avatar
Quoted: 32 Post(s)
Tom V.
Power Sound Audio
great thanks! I was not sure if there was a special cable! I appreciate the info!
iamjason is offline
