SW behind TV OK? - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By AmerCa
  • 1 Post By jedi1982
  • 1 Post By prsman
post #1 of 17 Old 04-09-2019, 01:47 PM - Thread Starter
prsman's Avatar
Quoted: 149 Post(s)
SW behind TV OK?
My TV is in the corner and there is a large void back there. Room enough for a subwoofer.
Id have to put the subwoofer on a platform so that its bottom sits at the same height as the legs of the TV.
the face of the subwoofer would be about 1st behind the TV. Its a new 65" LED TV.
Any issues you can offer for placing the subwoofer there? thanks you for any tips!
the SW is a Definitive PF1500, a vintage unit now but works good.
prsman is offline
post #2 of 17 Old 04-09-2019, 03:29 PM
AmerCa's Avatar
Quoted: 676 Post(s)
Liked: 1397
Do you mean 1 feet? If so, I wouldn't be comfortable with the sub facing so close to the TV. I'd try to put it further away (maybe facing the wall), or below the TV.
However, the critical factor about sub placement is how good it sounds at a given spot. If it sounds good behind your TV, then so be it. Unfortunately subwoofers don't care for what's more convenient to us.
darthray likes this.
Vizio 43" D Series 2017 || Onkyo TX383 7.2ch || Fronts: Sony SS-CS5 || Center: Pioneer SP-C22 || Sub: Polk HTS 12 || Surrounds: Micca MB42
AmerCa is offline
post #3 of 17 Old 04-09-2019, 04:03 PM - Thread Starter
prsman's Avatar
Quoted: 149 Post(s)
thanks for that. Yes I meant 1ft.
prsman is offline
post #4 of 17 Old 04-09-2019, 06:41 PM
jedi1982's Avatar
Quoted: 242 Post(s)
Liked: 515
I had a similar setup in our first house, however, the sub was a down-firing sub. You could turn the woofer portion towards one of the cornering walls and see how it sounds. If you have some sort of room correcting program, that would further help.
jedi1982 is offline
post #5 of 17 Old 04-09-2019, 06:56 PM - Thread Starter
prsman's Avatar
Quoted: 149 Post(s)
I did put the SW back there pointed at the TV. After receivers AccuEQ, the SW was set to minimum level. I had to turn it down, it was too thumpy. Ill play with your suggestion and turn it toward a wall and re AccuEQ. Do you have a suggestion on a way to EQ just the SW? Its a big room and there are several peaks and valleys over its bandwidth. Thanks again!
prsman is offline
post #6 of 17 Old 04-10-2019, 04:52 AM
Leon!'s Avatar
Quoted: 283 Post(s)
Liked: 136
That's where mine is, behind tv, facing not directly toward the back of the panel, but angled off to the side.
Works out great like this, here. Guess it varies per room.
Leon! is offline
post #7 of 17 Old 04-10-2019, 05:53 AM
confinoj's Avatar
Quoted: 1190 Post(s)
Liked: 996
As long as the TV is stable when the sub is pushed to high levels and the screen is not annoyingly shaking while watching the much more important issue is if the sub sounds good in that particular location.
LG OLED65C7P (Chad B Calibrated) | Denon X4300H | Tivo Roamio OTA | Nvidia Shield | ATV 4K | Oppo UDP-203 | Plex server
5.2.4 | Front Klipsch RP-160M x2 | Center Klipsch RP-450C | Surrounds Klipsch RP-150M x2 | Atmos Klipsch RP-140SA x 4 | Subs SVS PC-4000 x 2
confinoj is online now
post #8 of 17 Old 04-16-2019, 07:49 AM - Thread Starter
prsman's Avatar
Quoted: 149 Post(s)
Thank you for the encouragment. I went ahead and did it. Seems fine. Sounds the same to me. However I notice that I have to turn the sub input way down. To get the sub in the range of the room EQ I have to turn the sub volume know down about 1/4 turn. So I get being in the corner makes it more efficient
prsman is offline
post #9 of 17 Old 04-16-2019, 07:59 AM
Squirrel!'s Avatar
Quoted: 788 Post(s)
Liked: 466
The sub being in the corner will produce heavier bass than being out in the open. You will be turning it down. I have had one of my subs in the back nether regions of the TV for years and years now. The BEST thing i did was to add a second sub in the back of the room, seriously smoothed out the bass. But there really is no real reason to not utilize the space you have.
ID:	2553700   Click image for larger version
Main: Mitsubishi 73736|OTA|fireTV|Sony BDP-S1100|Denon AVR4311CI|MartinLogan Preface|Phantom|MartinLogan Encore TF|2 - DIY 12" Subs|Behringer KM750|2 Bass Shaker|APC H15 Power Conditioner|Harmony Hub|Sennheiser RS 160|SMSL B1 BT Rx|Linksys SE2500
MBR: Vizio VF550M|OTA|fireTV3|Sony BDP-S1100|Denon AVR-X1000|Chane A1rx-c|Dayton SAT-BK|MartinLogan Dynamo 300|Belkin Bridge|Belkin PF30|Harmony 550
Squirrel! is offline
post #10 of 17 Old 04-17-2019, 04:18 PM - Thread Starter
prsman's Avatar
Quoted: 149 Post(s)
Thanks for confirming. Yes. I think the next thiing will be a 2nd subwoofer. My receiver has only a single SW preamp output. Can one "T" the coax to get a cable to each subwoofer.?
Squirrel! likes this.
prsman is offline
post #11 of 17 Old 04-17-2019, 05:35 PM
darthray's Avatar
Quoted: 2034 Post(s)
Liked: 2885
Normal, it is call corner loading and re-enforcing the lower frequencies.
Yes a single Y-splitter, with the single end from your AVR to each sub. Just make sure to get the proper ends for the AVR and the Subs.
But once done, you need to figure out manually the volume level and phase control on the second sub. This will correct the distance to be relative to each sub.
Get a Sound Pressure Level measurer, do some reading of various test tone. For the first Sub with the second sub Off. And write those value for the first sub.
With something like that;
https://www.amazon.ca/Decibel-Mengsh...8&s=hi&sr=1-21
Once you got your readings on paper, for the first sub. Turn-it Off and turn your second sub On.
Repeat the same frequencies level result, and slowly adjust your volume level to match your first sub. Than slowly adjust the phase level. Until all results come closely to the first sub.
Then put both subs On, and do your calibration.
Just for info.
An AVR/AVP that can do two subs, just do-it on the first sweep to find out the volume and distance (in your case, playing with the phase do the same thing) for each sub. Than the calibration will be done as one sub. Just making the whole process easier
Ray
darthray is offline
post #12 of 17 Old 04-17-2019, 06:39 PM - Thread Starter
prsman's Avatar
Quoted: 149 Post(s)
Just for info.
Ray
Nice. Thanks very much. Ill print this out while I figure out what SW to buy. thanks again!
prsman is offline
post #13 of 17 Old 04-18-2019, 10:24 AM - Thread Starter
prsman's Avatar
Quoted: 149 Post(s)
Just for info.
Ray
Hi Ray. A couple of questions:
1) What do you listen for when adjusting the phase knob on the back of the 2nd SW? The meter doesnt do phase. that parts confusing for me.
2) Are there downloadable test files to sweep the subwoofer output and set it at specified frequency?
prsman is offline
post #14 of 17 Old 04-18-2019, 06:10 PM
darthray's Avatar
Liked: 2885
For question 1), I do not listen to any thing I just look at my results from the first sub. From a test CD, been many years since I did-it this way (three AVP ago, over 10 years).
And just look at the numbers of the results, for every frequencies. Than when doing the second sub, try to match those number closely (some will have higher [dip] and lower ones [null], just need to find a nice average).
And hope your calibration from your AVR, will take care of smoothing everything out.
If doing by hear, I still suggest to use a Sound Pressure Measuring tool for the volume.
Than have some play with the phase control, (using a song or movie with lots of bass, just not very accurate) to find out where your level is the highest and go back down. And fine tune from there.
For question 2), I use to have a real CD, but unfortunately cannot find a link for you.
But did find this on line version from a You Tube video;
All my previous instructions are not the easy to do, without some understanding of bass and equalisation knowledge.
And therefore just gave some basics step. That said, my suggestion to you would be buying an AVR with two subs output. Before buying a second sub
This will remedy lots of problems for you, just do-it one step at the time. Enjoy your first sub for now.
Ray
darthray is offline
post #15 of 17 Old 04-18-2019, 07:10 PM - Thread Starter
prsman's Avatar
Quoted: 149 Post(s)
https://www.youtube.com/watch?v=u7A_SEE0_nc
Ray
Yes thanks. I already have a sound pressure meter that has an interface to a PC so I can capture the frequecy response if I could sweep. But how is changing the phase is detected. I can adjust level or volume knob on the 2nd SW to match the reference readings of the 1st SW. What am I looking for when I adjust the phase at each test frequency?.
prsman is offline
post #16 of 17 Old 04-19-2019, 03:54 PM
darthray's Avatar
Liked: 2885
Ray
No just an overall idea of what frequencies to try when playing with phase. To see if the measurement go up.
As I said previously, not an easy task to do for some who know what they are doing.
In your case, I strongly suggest you got an AVR with Audyssey XT32.
Then get a second sub, one piece at the time.
Ray
darthray is offline
post #17 of 17 Old 04-19-2019, 05:49 PM - Thread Starter
prsman's Avatar
Quoted: 149 Post(s)
Ray
Hi Ray: Attached is a room characteristic. Note the deep null of 20db at 72hz. I spoke with Audessey about ability to correct. here is their response: "Yes, MultEQ will correct to create a flat frequency response. No, it likely won't completely resolve the 20 dB drop at 71 Hz. MultEQ will apply up 9dB of boost and 24dB of cut, and does so in a way that keeps the channel level aligned with MultEQ on and off. Moving the subwoofer or adding acoustic treatment may help change the response for extreme dips, a acoustician is needed to make recommendations specific to your room."
So Ill take your suggestion and see if the phase can at least help the null to getter closer to something Audessey can handle. And while I have little flexibility to move the sub, I can point it differently and see if that helps.
Name:	SW Sweep.jpg
prsman is offline
