Replacing Velodyne - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By PioManiac
post #1 of 13 Old 04-12-2019, 01:25 PM - Thread Starter
Liked: 0
Replacing Velodyne
Hi,
I have a Velodyne DLS 5000R that I use both for music and movies. It is old and its cabinet rattles when I play loud music.
The music setup has:
Klipsch La scala's, Dyanco ST 70 and Dynaco PAS 3X, Technics 1500MK2
Movie setup has:
B&W CM10's
Peachtree 220SE
Any recommendations as to what can I use to replace it.
Thanks in advance
Fahad
fsyed13 is offline
post #2 of 13 Old 04-12-2019, 02:27 PM
PioManiac's Avatar
Quoted: 3403 Post(s)
Liked: 8689
Originally Posted by fsyed13 View Post
Hi,
Movie setup has:
B&W CM10's
Peachtree 220SE
Thanks in advance
Fahad
What's your budget?
I still have my 10 y/o Velo DLS5000R's sitting behind my MLP (for rear near field duty)
Funk Audio 18.0's up Front
iceatola likes this.
The Unfinished Basement Theater & Whisky Guitar Lounge | Bass EQ for Filtered Movies
JVC DLA X750 4K Projector | 120" Powered Drop Screen | 65" LG 65B6P OLED | Panasonic DMP UB900 | Oppo UDP 203 | HDFury Vertex
Yamaha RX-A3070 | 7.4.4.4 | Mission M3i x11 | Funk Audio 18.0 x2 | Velodyne DLS 5000R x2 | Crowson LvL3 MA x4 | miniDSP 2x4HD
PioManiac is offline
post #3 of 13 Old 04-12-2019, 02:30 PM - Thread Starter
Liked: 0
Wow That is a very cool setup!
about $1500. Looked into the FV15HP and Monolith 15" THX. Any thoughts?
fsyed13 is offline
post #4 of 13 Old 04-12-2019, 02:35 PM
PioManiac's Avatar
Liked: 8689
Both Solid choices!
Rythmik supposed to be excellent for music
drh3b likes this.
post #5 of 13 Old 04-17-2019, 05:52 AM
DonH50's Avatar
Quoted: 3375 Post(s)
Liked: 3538
I went Rythmik after auditioning Velodyne and others but not a Monolith.
Have you looked at what about the Velodyne's cabinet is rattling? May be cheaper to fix it.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #6 of 13 Old 04-17-2019, 06:14 AM
humbland's Avatar
Quoted: 1141 Post(s)
Liked: 335
+1 on the "fix the Velodyne"
We have a Velodyne DLS 5000R. It's an oldie but a goodie...The build quality is off the charts. Plus it's beautiful to look at. Velodyne was high end in it's day.
The other subs you are considering are all good, but if the amp and cone are intact and working, then the DLS 5000R can hold it's own. FWIW, it's "easy" to remove the amp and see what's rattling. I can not imagine that it would be difficult to secure something loose in the cabinet.
However, if the $ is burning a hole in your pocket, or you just want to upgrade (I know the feeling well), my recommendation would to consider HSU. As far as build quality and "bang for the buck", they bring a lot to the table. However, looks wise, they are a little bit of "plain Jane".
My $.02.
humbland is online now
post #7 of 13 Old 04-17-2019, 10:47 AM
iceatola's Avatar
Quoted: 265 Post(s)
Liked: 235
If you are music first then my vote would be Rythmik FV15HP.
If you only watch movies then no question I would go with Monolith 15 instead
Video: BenQ HT3550 4K Projector - Elite Screens Manual Grande Series - 128inch
Pre Amp: Marantz 7705/ Power Amplifiers: Emotiva XPA-3, UPA-700
JBL - Stage A190 Towers L/R , Stage A135 Center , Stage A190 surrounds , Atmos Klipsch rp-500sa
Subwoofer PSA 2xV1801 / Xbox One X, Nvidia Shield, Darbee Darblet 5000
iceatola is offline
post #8 of 13 Old 04-18-2019, 05:57 AM - Thread Starter
Liked: 0
Thanks guys! I take your advice and will try to fix the Velodyne. It is indeed a nice sub.
fsyed13 is offline
post #9 of 13 Old 04-19-2019, 11:03 AM
gajCA's Avatar
Quoted: 9774 Post(s)
Liked: 6786
These guys do a lot of Velodyne repairs if you need a repair shop:
https://www.ebcelectronics.com/velodyne-repair.php
Geoff A. J., California
gajCA is offline
post #10 of 13 Old 04-29-2019, 12:25 PM - Thread Starter
Liked: 0
Thanks, Any recommendations on where the filter cut off should be?
fsyed13 is offline
post #11 of 13 Old 04-29-2019, 12:26 PM - Thread Starter
Liked: 0
Will look into them
fsyed13 is offline
post #12 of 13 Old 04-29-2019, 12:26 PM - Thread Starter
Liked: 0
Do listen to alot of music
fsyed13 is offline
post #13 of 13 Old 04-29-2019, 02:09 PM
iceatola's Avatar
Quoted: 265 Post(s)
Liked: 235
Then go with the Rythmik FV15HP and don't look back
iceatola is offline
