upgrade single pb1000 to single pb2000 ? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 16Likes
post #31 of 40 Old 05-30-2019, 06:29 AM - Thread Starter
wadennis's Avatar
Quoted: 111 Post(s)
Originally Posted by Jeparisoe View Post
Probably 80% movies and 20% music. I have only turned on some music just for a little bit of testing. Sounds great, but I am not sure what you are looking for. Specifically what type of music? I just turned on some hard hitting rap songs and it by far exceeded my PB1K with how hard it was hitting.
I am more a rock/alternative music listener. Both old & new music. I am about 50/50 music to movies but listen to music at louder volumes.
wadennis is offline
post #32 of 40 Old 05-30-2019, 06:39 AM
Quoted: 31 Post(s)
Liked: 5
I'll have to get back to you on that. Once I get off work, I'll go home and turn on some rock.
Jeparisoe is offline
post #33 of 40 Old 05-30-2019, 02:07 PM
MIX_MASTER_ICE's Avatar
Quoted: 2665 Post(s)
Liked: 2470
Thanks. So you would say a single pb2000 is a decent upgrade from the single pb1000. My dealer in Canada is telling me that I wouldn't notice much difference?
How large is your room? The PB-1000 has less output across the board compared to the PB-2000, as well as slightly less extension. The output difference is more pronounced lower in range than higher in range. Did you ask your dealer what he is basing this on?
Subs>RBH I-12e, I-12. HSU VTF-15H mk2. Monolith THX 12(x2), THX 10(x2). XTZ 1X12. SVS PB-1000(x2). Speakers>JBL Studio 270/235c/230/225c, Arena 130/125c. Sony CS3/CS8/CS5. QA 3020i/3090Ci, 2020i/2000c. Monolith Cinema 5bs. Polk RTiA1/CSiA4. Other Audio>Sony MDR-Z7m2, MDR-V6, XB900n, XB700, XB32, XB31. Sennheiser HD58X, HD4.50, PC37X. Philips SHP9500. SIVGA SV004. HyperX Cloud PS4. TB Stealth300. LG FH6,RK8,RK7,PK5. HK Onyx Studio4(x2).
MIX_MASTER_ICE is offline
post #34 of 40 Old 05-30-2019, 02:43 PM - Thread Starter
wadennis's Avatar
Quoted: 111 Post(s)
My room is about 12 x 19. But my sitting position is about 10 ft from subwoofer. My dealer never explained why this wouldn't be a worthwhile upgrade other than it wouldn't be a noticeable upgrade. I will add that I am not interested in more volume but interested in better clarity. I am only interested in music being played louder.
wadennis is offline
post #35 of 40 Old 05-30-2019, 03:09 PM
Liked: 2470
The larger driver and enclosure of the PB-2000 will allow it to play more effortlessly at higher volume levels, also with less distortion compared to the PB-1000. Sounds like you are pretty set on a single sub instead of duals, so I would personally move up to the PB-2000 if the PB-1000 isn't getting the job done well enough.
post #36 of 40 Old 05-30-2019, 03:23 PM - Thread Starter
wadennis's Avatar
Quoted: 111 Post(s)
I wouldn't say the pb1000 isn't getting the job done but curious how much better the pb2000 would be? I originally thought I would get dual pb1000 but I am having a hard time grasping how this will be much of an improvement in my single seat setup. I keep reading how it fills all seating positions but not a concern for me. SVS does recommend 2 1000's over a single 2000. I also don't like the space requirements of 2 subs
wadennis is offline
post #37 of 40 Old 05-30-2019, 06:45 PM
confinoj's Avatar
Quoted: 1243 Post(s)
Liked: 1060
Definitely go for single PB-2000 over dual PB-1000. If you find down the road you need a better frequency response at MLP you can add a second. Otherwise you’ll notice the better extension, higher and cleaner output.
LG OLED65C7P (Chad B Calibrated) | Denon X4300H | Tivo Roamio OTA | Nvidia Shield | ATV 4K | Oppo UDP-203 | Plex server
5.2.4 | Front Klipsch RP-160M x2 | Center Klipsch RP-450C | Surrounds Klipsch RP-150M x2 | Atmos Klipsch RP-140SA x 4 | Subs SVS PC-4000 x 2
confinoj is online now
post #38 of 40 Old 06-01-2019, 01:14 PM
Quoted: 31 Post(s)
Liked: 5
Sorry I took a while to respond. I listened to some Metallica, Rage Against the Machine, and Shinedown. All sounded great, not overpowering, but very smooth and tight. Still managed some window shaking on some songs, but overall it sounded great.
I'm not sure I would buy this for music alone, though it does sound good. I'm also probably not the best judge of musicality.
post #39 of 40 Old 06-01-2019, 01:52 PM - Thread Starter
wadennis's Avatar
Quoted: 111 Post(s)
Thanks for the update. Sounds like you don't recommend the pb3000 if music is my main concern. I may have to stay with my pb1000 or at the best maybe upgrade to pb2000.
wadennis is offline
post #40 of 40 Old 09-09-2019, 06:07 AM - Thread Starter
wadennis's Avatar
Quoted: 111 Post(s)
I am now also considering the sb3000 to satisfy my music needs but wondering if I will lose something on the movie side? I am quite happy with my pb1000 for movies
wadennis is offline
