Subwoofer Low pass filter - LFE setting? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-13-2019, 05:47 PM - Thread Starter
Liked: 0
Hi there,
My subwoofer has the LPF (low pass filter) knob with 40hz to 120hz and currently the dial is turned all the way on "LFE" this was the default when I got it.
Should I be leaving it on LFE? Or turning it back to 80hz for example.
I'm confused what exactly the difference is between the 2?
What does it mean if I leave it on LFE?
mraussieav is offline
post #2 of 3 Old 05-13-2019, 06:21 PM
eljaycanuck's Avatar
Quoted: 1865 Post(s)
Liked: 2617
The owner's manual will likely indicate that setting the LPF control on the sub to "LFE" means the control is bypassed. If your AVR handles bass management (and any newer AVR will), generally-speaking you do want to bypass the sub's LPF.
If, for example, your AVR sends all bass content below 80Hz to the sub and you set the sub's LPF to:
- 80Hz you're (arguably) unnecessarily adding a second 80Hz filter to the content;
- higher than 80Hz, nothing happens (all content below the LPF setting - which is all the content the sub received - gets played by it);
- lower than 80Hz, you're filtering out content between 80Hz and whatever you set the LPF to.
eljaycanuck is offline
post #3 of 3 Old 05-13-2019, 06:52 PM
darthray's Avatar
Quoted: 2135 Post(s)
Liked: 3057
Originally Posted by mraussieav View Post
Hi there,
Here's a good read for you;
III-C: Cascading Crossovers:
From this Guide;
Guide to Subwoofer Calibration and Bass Preferences
Darth
darthray is offline
