Worth adding a 3rd Sub? - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 3 Post By iceatola
  • 1 Post By deano86
  • 1 Post By BryceDH
post #1 of 18 Old 05-14-2019, 04:54 PM - Thread Starter
flyers10's Avatar
Quoted: 86 Post(s)
Liked: 40
I'm running 2 PSA v1510df's located up front. I have an old Klipsch KSW-12 sub and was debating on adding it as a nearfield sub located between right surround and sofa. I'm aware of REW, miniDSP and a UMIK microphone but don't own them nor have any experience with them. Thoughts on if this is a good idea to get some additional TR or would be too difficult or a bad fit to integrate in? (plus the extra cost of the mic and dsp)
flyers10 is online now
post #2 of 18 Old 05-14-2019, 05:51 PM
darthray's Avatar
Quoted: 1993 Post(s)
Liked: 2802
Integrating different subs are much harder to do, also if your run an Auto Calibration like Audyssey and others.
The calibration system will set level to match the weaker sub.
Many have been in the same boat, as you are. And once they remove the weaker sub, the superior sub came Alive even with only one sub instead of two (after a new calibration).
Therefore, my suggestion is to remove the Klipsch KSW-12. And enjoy your two PSA
And if still not happy about your TR presence, you could save money to get one more PSA v1510.
That said, if your room is over a concrete foundation.
I would look into this option instead, since Bass sound do not produce much TR over a concrete floor;
Shakers - Simple/Cheap Hookup - Visual Guide
Darth
darthray is offline
post #3 of 18 Old 05-14-2019, 07:02 PM
Kini62's Avatar
Quoted: 2624 Post(s)
Liked: 2386
Try it and give it a listen. If it sounds better or makes a noticeable improvement then you're golden. If not you're only out a little time.
My two subs aren't nearly as different in capabilities but they are different and running both makes a noticeable improvement over just the more powerful one.
Def Tech SC8000
Onkyo RZ820
Roku Ultra, Apple TV, Sharp 70" Quattron
Kini62 is offline
post #4 of 18 Old 05-15-2019, 08:02 AM
iceatola's Avatar
Quoted: 245 Post(s)
Liked: 227
Just add some transducers/bass shakers and then you will be good to go
Video: Epson HC 1060 projector - Elite Screens Manual Grande Series - 128inch
Receiver: Emotiva Fusion 8100 / Amps: Emotiva XPA-3, UPA-700
Polk Signature Series - S20 for L/R, S35 Center, S15 Surrounds
Subwoofer PSA 2xV1801
Roku 4, Nvidia Shield, Darbee Darblet 5000
iceatola is offline
post #5 of 18 Old 05-15-2019, 10:50 AM - Thread Starter
flyers10's Avatar
Quoted: 86 Post(s)
Liked: 40
Room is on a concrete slab foundation. Bass shakers might need to be the way to go to get more TR. Not sure how the wife will feel about cutting the bottom of the sectional. LOL.
Maybe I'll hook up the ksw12 via a splitter and see if notice anything positive. If so then I'll look to pick up a mic and miniDSP to maximize the 3.
post #6 of 18 Old 05-15-2019, 11:01 AM
deano86's Avatar
Quoted: 596 Post(s)
Liked: 297
deano86 is offline
post #7 of 18 Old 05-15-2019, 11:01 AM
Quoted: 73 Post(s)
Liked: 45
That is what I did. I have 3 different subs and got a Umik (I have DSP iNukes) and spent some time integrating them. I think it turned out pretty well (mini-marty for ULF, J112 for mid-bass, DIY 15" to smooth over any gaps between the two).
JediMindTrick is offline
post #8 of 18 Old 05-15-2019, 11:05 AM
BryceDH's Avatar
Quoted: 134 Post(s)
Liked: 88
I would highly recommend taking a look at @trhought "The Hideaway Theater" thread and look at a BOSS build on a mini riser. I just built one myself and it works amazingly well. I've got 2 18" VBSS subs nearfield and the BOSS gives 10x the tactile response. It's very inexpensive too. It is a DIY project, but a very easy one.
I'll try to post the link to that thread, but it never seems to come up right.
https://r.tapatalk.com/shareLink?url...3&share_type=t
Sent from my SM-N960U using Tapatalk
Equipment: Yamaha 3050, Oppo 103d, PSA mt 110s (L,C,R), Polk tsi200 (SR/L), 2 VBSS, FullMarty, 4 driver BOSS build, umik-1, Epson 3700
BryceDH is offline
post #9 of 18 Old 05-15-2019, 11:06 AM
KidHorn's Avatar
Quoted: 1772 Post(s)
Liked: 1207
Optimally, you want all your subs to have similar capabilities, but many have had multiple subs with varying capabilities and were happy.
KidHorn is offline
post #10 of 18 Old 05-15-2019, 11:54 AM
GunmetalR56's Avatar
Quoted: 268 Post(s)
Liked: 393
I would also recommend considering bass shakers. One of the best upgrades I've done for my room
Ascend Sierra Towers w/RAAL, Ascend Horizon Center w/RAAL, Ascend Sierra 2 surrounds, PSB Imagine XA Atmos modules (x4), SVS PB13 Ultras (x2)
Denon X6500H / Emotiva Mini-X a-100
Panasonic DP-UB820 / PS4 Pro / XBOX 1X
Sony XBR75Z9D, LG OLED65B7A
GunmetalR56 is offline
post #11 of 18 Old 05-15-2019, 03:07 PM - Thread Starter
flyers10's Avatar
Quoted: 86 Post(s)
Liked: 40
Originally Posted by deano86 View Post
Interesting idea. Wife would never allow that (even if carpeted) as this is in our open living room. 😔 But maybe traditional bass shakers might get approval or at least not physically noticed.
post #12 of 18 Old 05-15-2019, 03:18 PM
BryceDH's Avatar
Quoted: 134 Post(s)
Liked: 88
If you do it right, it will hardly be noticable
Soulburner likes this.
BryceDH is offline
post #13 of 18 Old 05-15-2019, 04:10 PM
darthray's Avatar
Liked: 2802
Your floor foundation is the main culprit for your TR problem.
Also may TT options are not very big, so no need to cut the sectional.
Only attach to the frame, and Do require a separate source of Amplification and not from your AVR.
While you could still try your Klipsch KSW-12, near field to see if you have what you are looking for.
I know my self, I would remove it for having the best performance from your dual PSA v1510.
Since I use two TT, even with dual SVS PB13 on my concrete floor cover by heavy carpet.
Darth
darthray is offline
post #14 of 18 Old 05-15-2019, 07:47 PM - Thread Starter
flyers10's Avatar
Quoted: 86 Post(s)
Liked: 40
BryceDH thanks for the pic. That's helpful.
Darth, I may have to do same as you did to get what I want.
Any particular brand recommendations? Buttkicker?
post #15 of 18 Old 05-16-2019, 10:59 AM
Alan P's Avatar
Quoted: 6125 Post(s)
Liked: 5330
The cream of the crop are Crowsons...but, by all reports, the BOSS comes very, very close to the effect the Crowsons give at a small fraction of the price.
Buttkickers are a distant 2nd (for ULF at least).
Alan P is offline
post #16 of 18 Old 05-16-2019, 11:22 AM
WOKNROX's Avatar
Quoted: 246 Post(s)
Liked: 181
Yes..Earthquake Sound's Mini quakes.
Don't forget you're going to need an amplifier to drive them or any shaker you decide on.
WOKNROX is offline
post #17 of 18 Old 05-18-2019, 02:41 PM
scraejtp's Avatar
Quoted: 49 Post(s)
Liked: 29
I think it is a good idea. I have 4 subwoofers and my Receiver (Pioneer SC-95) has two separate subwoofer outputs with their own calibration curves.
The "main" subwoofers are two Klipsch R-115SW up front and then two near-field units right behind the main seating, Elemental Designs A2-300.
scraejtp is offline
post #18 of 18 Old 05-20-2019, 09:37 AM
Alan P's Avatar
Liked: 5330
Just to clarify...MCACC Pro does not EQ each sub separately. It will set separate levels and distances, but both subs are EQ'ed "as one".
EQ'ing subs separately is not usually recommended and is best done only via software (i.e. MSO).
Alan P is offline
