What would match an SVS PB12-NSD? - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 1 Post By gajCA
  • 2 Post By Leon!
  • 1 Post By gajCA
post #1 of 21 Old 05-16-2019, 01:46 PM - Thread Starter
tonybradley's Avatar
Quoted: 511 Post(s)
Liked: 191
For a few years, I've ran just one SVS PB12-NSD. It sounded fine. I've since upgraded my room with a bigger screen, etc. I had to move my PB12-NSD from my front left corner to the area between my left and center speaker. I have also added a 16-46 CS Plus. Per Ed Mullen, the 16-46 CS Plus would work with the PB12-NSD. Since I have a Denon X3400H receiver with dual LFE outputs, I wanted to take advantage of that since I had the 16-46 CS in another room I could use.
I'm not happy with my LFE at all. Maybe adding the 16-46 CS Plus along with the PB12-NSD doesn't match so well. I probably should run Audyssey with just the PB12 and then again just with the 16-46 CS Plus to to hear the difference. The Cylinder Sub is so much harder to place due to size, so it's on the right side wall.
I don't think I've seen the PB12-NSD for sale on SVS any longer, but if I wanted to add another sub up front, between the center and right speaker, what would be a better match?
Tony
tonybradley is offline
post #2 of 21 Old 05-16-2019, 02:05 PM
gajCA's Avatar
Quoted: 8461 Post(s)
Liked: 5644
Well, they were made available again this past December so might be available again this coming December.
drh3b likes this.
Geoff A. J., California
gajCA is offline
post #3 of 21 Old 05-16-2019, 02:07 PM - Thread Starter
Quoted: 511 Post(s)
Liked: 191
Interesting. Any idea the reasoning they made them available again for a short time?
Tony
post #4 of 21 Old 05-16-2019, 02:11 PM
gajCA's Avatar
Liked: 5644
For the last several Black Fridays the SB12s have been made again despite being a "discontinued" subwoofer.
But this past Black Friday both the SB12 and PB12 were made available and IIRC the PB12 was $400.
So a holiday "loss leader" perhaps???
gajCA is offline
post #5 of 21 Old 05-16-2019, 02:58 PM
Leon!'s Avatar
Quoted: 283 Post(s)
Liked: 136
Yep. As recently as Feb of this year, and lately expanding the resellers who have them at even lower prices.
I'd hold off, if you can stand it. The PB12 looks like one of the best performance values this side of monolith sales, since you already have one I'd be going multiples of those.
gajCA and tonybradley like this.
Leon! is offline
post #6 of 21 Old 05-16-2019, 03:53 PM
dpc716's Avatar
Quoted: 99 Post(s)
Liked: 145
I'd be inclined to think your problem is less the sub pairing and more about moving your sub(s) from a more optimal to a less optimal position. I wouldn't give up on your pair just yet.
I can tell you that in my room mid wall (or near it) on both front and sides are "black holes" for bass when the driver faces into the room. Try the sub crawl method and see if you can find any better placement alternatives, or even try facing the PB driver in another direction in its current location.
Your idea of running Audyssey with the PB12 alone in it's new spot is a good idea - you can compare output against what you were getting before. If it doesn't match up, you have a starting point to dig into things.
dpc716 is offline
post #7 of 21 Old 05-16-2019, 06:47 PM - Thread Starter
Quoted: 511 Post(s)
Liked: 191
Yeah, if around $400, that's ridiculous. I purchased mine B-Stock around 2009 for more than that. I'll keep my eye out for when/if SVS adds them back to their site at some point.
Tony
post #8 of 21 Old 05-16-2019, 06:55 PM - Thread Starter
Quoted: 511 Post(s)
Liked: 191
Back around 2009, I downloaded an Excel File with Correction Values built into their equations from HomeTheaterShack for the Radio Shack SPL meter that SVS used to provide with a purchase of their Subs. I also downloaded Frequency files from 10Hz to 100Hz from the same site. I then tried my Sub in a few different places and entered the dB for each frequency recorded on my SPL meter into that Spreadsheet. It then plot a curve so you could see the Peaks and Dips. That is how I learned that the front left corner had the flattest curve in my room. I was going to use REW with the SPL Meter and the loop back with the sound card but never got around to it. I see now it's much easier with a USB Mic as there isn't much calibration to do, mainly plug and play it appears. But, that's almost $100.
Has anyone here used that old HomeTheaterShack Spreadsheet with correction values for the old Radio Shack SPL meter and know if it's close enough to use to find the best subwoofer location? Although it takes a little longer than REW, it's much cheaper given I have the SPL meter and the Spreadsheet.
Also, with the Subwoofer Crawl, I know how to do that with one sub. Easy enough. However, how do you do that with two subwoofers?
Tony
post #9 of 21 Old 05-16-2019, 11:22 PM
jamiebosco's Avatar
Quoted: 619 Post(s)
Liked: 1426
Honestly, $100 for the umik-1 (plus the free REW download) will be the best VFM you ever get when trying to setup your home theater, especially when trying to integrate 2 or more subs.
TV: Panasonic P65ST60 AVR: Denon 4311ci Speakers: PSA MTM-210C (Centre), PSA MTM-210 (Left & Right), PSA MT-110 (Surrounds) Subwoofers: Dual Seaton SubMersives
jamiebosco is online now
post #10 of 21 Old 05-16-2019, 11:49 PM
drh3b's Avatar
Quoted: 1745 Post(s)
Liked: 3141
My guess is that it's not actually a loss leader, but just not as large a margin as their other subwoofers. All the design etc has long been paid for, so I think they very simply make a run of the SB and PB each year at the time of year it's going to sell best, make some money, and hope that people will like it enough to upgrade to one of their more expensive ones. One large run a year, some profit, several small runs a year, no profit. YMMV of course. I've moved on to bigger and better, but I have no problem recommending the SB12-NSD for a small sealed room. Sounded great to me, I just wanted more SPL than they could provide, and I think my room is a little too big for a small sealed subwoofer. or 4 of them, as I ended up with before going with my current Rythmiks. Even my Rythmiks aren't quite enough, at some point, I plan on doubling up on them, but finances.
Denon AVR-X4300H (2nd try), Emotiva XPA-3 Gen3, A-5175
Klipsch RP-280f LR & SR, RP-450c, RP-260f SB, pending Velodyne Deco Atmos
Rythmik F18 x 2
OPPO UDP-203, HTPC, TiVo Roamio, Adequate Samsung 4k
Turn Down For What!?
drh3b is offline
post #11 of 21 Old 05-17-2019, 04:55 AM
dpc716's Avatar
Quoted: 99 Post(s)
Liked: 145
It's the same process. Ideally you want to find spots that compliment each other. If your trying to optimize one seat, use one seat. If across a seating area, you can use two representative locations. My room is a family room (not a dedicated theater) with seating along the back wall. I found front corner placement resulted in peaky output in the opposite back corner, but two subs in each front corner resulted in fairly even output across the whole seating area. When I tried moving them away from the corners (nearer the TV in the middle of the front wall) the bass just disappeared. There was a lot of trial and error involved in the process.
dpc716 is offline
post #12 of 21 Old 05-17-2019, 06:44 AM
Leon!'s Avatar
Quoted: 283 Post(s)
Liked: 136
Almost, PB12 was $440 at Rakuten last time, SB12 as low as $350!
Ofc SVS "bill of rights" limited through 3rd party.
Leon! is offline
post #13 of 21 Old 05-17-2019, 08:27 AM
gajCA's Avatar
Liked: 5644
There is a "wild card" this year of course and that is the Tariff nonsense which could affect availability or pricing.
gajCA is offline
post #14 of 21 Old 05-19-2019, 04:18 AM - Thread Starter
Quoted: 511 Post(s)
Liked: 191
I've not been around for a few days due to my lousy Cable Internet Provider and issues they are having.
I found out my friend owns the Dayton Audio UMM-6 Mic that he was using to calibrate his car stereo system as he competes. I watched an Audioholics Youtube video on REW and he used that mic. I was able to borrow it, download the Calibration File and install REW. From what I've seen online, the UMIK-1 has two calibration files, with one being for 90 degrees. The UMM-6 only had one.
My Cylinder Sub location is really the only place it can go, so I left it there and moved the PB12 between L/C and then R/C. I took measurements with just that sub and with the Cylinder. I turned the PB12 so the speaker and port faced the room, faced front wall, faced left, faced right, pulled it further out from wall and closer to the wall. No matter what I did, I had a HUGE Null at around 65Hz up to 100Hz.
I then played around with the phase of one sub, little at a time. I found that I was able to get a "better" response for the 65-100Hz, but doesn't look great, but I have a small dip from 30-40Hz now. Subs are set 180 degrees out of phase now. After about 2 hours, I was a little tired of measuring. But wow.....this makes it so easy to see where the problems area.
I've attached the graph of the best graph I was able to obtain last night. I still have the option of placing the cylinder on my riser in the back, but it's filled with insulation and now sound.....so not sure that will be a good idea. I still plan to try.
Tony
post #15 of 21 Old 05-19-2019, 06:14 AM
dpc716's Avatar
Quoted: 99 Post(s)
Liked: 145
Sounds like your on the right track. You can also try adjusting the distance settings, try increasing one or both and see if it helps.
dpc716 is offline
post #16 of 21 Old 05-19-2019, 11:48 AM - Thread Starter
Quoted: 511 Post(s)
Liked: 191
That's a good idea. That's one of the Bass Hacks that Subwoofer 101 discusses on Youtube. If memory serves me, he recommends increasing it by about 4'. I'll play around with it. I am also going to try the Cylinder Sub in a few places on my riser and see how the graphs look. But if movies tend to cause some echo or rattle due to not being filled with Sand, I'll need to move.
So question. I turned off Audyssey when I ran my measurements as I wanted to know what it was like with no EQ to get the best natural spot I could in my Room. Once I do, I plan on running Audyssey. Is that what most people do, then run REW again and see how the graph looks after Audyssey does it's thing? I have the X3400H so it's the MultiEQ XT32.
Tony
post #17 of 21 Old 05-19-2019, 12:38 PM
raceredmustang's Avatar
Quoted: 131 Post(s)
Liked: 70
It is a longshot, but you might call Electronics Expo in NJ. It's possible they have some in their warehouse, but not on their website. I found an SB-12 NSD that way. Good luck.
2 channel : Anthem Integrated 225, Bluesound Node 2i, Monitor Audio Silver 8, PSA S1500, Marantz SA8005,
HT: Yamaha RX-A1060, Klipsch RP-260, Polk RTIA1 rears, RP-450C, PSA V1500, Onkyo C-S5VL
Office: Yamaha A-S701, Bluesound Node 2, Monitor Audio Silver 2, SVS SB12-NSD, Marantz CD6006
raceredmustang is offline
post #18 of 21 Old 05-19-2019, 04:44 PM
dpc716's Avatar
Quoted: 99 Post(s)
Liked: 145
My guess is most people don't have REW, so they just a find a good spot via sub crawl or other method, run Audyssey, and if it sounds good /measures well fine, otherwise try again.
That said, since taking measurements is easy for you what you're doing is not a bad idea. As you probably know you want to find a spot with as few dips/nulls as possible so Audyssey's main task will be to cut peaks and not boost. If a couple of dips are unavoidable hopefully your second sub can address those.
dpc716 is offline
post #19 of 21 Old 05-20-2019, 08:07 PM - Thread Starter
Quoted: 511 Post(s)
Liked: 191
I was thinking of moving my cylinder sub up front, on the other side of the center speaker from PB12-NSD. It can't stay there due to the height, but would like to run REW to see the response of two subs up front. If that's a much better graph, I'll look into picking up a PB12-NSD either used or a black Friday sale if there is one. If the Response is not much better than what I'm getting now, then I probably won't bother and stick with the Cylinder and try a few locations up on the Riser.
Tony
post #20 of 21 Old 05-22-2019, 01:25 PM
gajCA's Avatar
Liked: 5644
Hurry Tony, several PBNSDs at the SVS Memorial Day Outlet blowout sale!
https://www.svsound.com/collections/...Blow-out+Event!
MIX_MASTER_ICE likes this.
gajCA is offline
post #21 of 21 Old 05-22-2019, 07:20 PM - Thread Starter
Quoted: 511 Post(s)
Liked: 191
Thanks. Was just looking at one. I think I'm going to hold off for now. I've spent so many evenings moving the two subs, changing crossovers, distances, phases and I can't get rid of the dip around 65Hz. I did find two locations where I was able to smooth out the dip around 30Hz though, but it gave me some bigger dips around 80Hz. Not sure purchasing another PB12 will gain me anything unless adding a third sub would improve things. I think I have a lousy room for LFE.
Anyone know which LFE frequencies are more common than others in movies? If I had to sacrifice dips between 30-40Hz vs 65-80, which would would be the choice?
Tony
