TBI Subwoofers?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 05-19-2019, 11:45 AM - Thread Starter
(insert witty title)
disturbedfuel15's Avatar
Quoted: 31 Post(s)
Liked: 9
TBI Subwoofers??
Hey All,
I've tried to search up and down this forum and cannot find anything on TBI Audio Systems. I have an opportunity to grab a local "TBI Emperor DPM-8 Passive Subwoofer" and I had never heard of the company before. The company claims this subwoofer is one of the "fastest" subwoofers available in the world. Apparently it is able to dig deep and fast, but was not made for high SPL applications. It was made to blend in with the rest of your audio system. I really don't care about SPL, I am only concerned with the quality of the tones reproduced as the artist intended. Does anybody have any idea about this company, or more specifically, this subwoofer? Here is the documentation:
http://tbisound.com/_pdf/EMPEROR%20DPM.pdf
EMPEROR DPM-8
The subwoofer as it is known today has been a rather disconcerting
product for the high-end audio community. The very word conjures rather
unpleasant thoughts of out of place boom that we audiophiles put up
with in our video system. Well the controversy over what a subwoofer
should do is over. Size is important so we are starting this series
small in dimensions but wonderful as low frequency support for any
audio-video system.
The new Emperor DPM 8 represents an audio technological tour de force
for bass reproduction. It is a small .84 cu ft internal volume cube
subwoofer that efficiently produces bass frequencies from below 20Hz to
above 200Hz. The driver used is low mass aluminum operating in a
balanced pressure environment with 5mm maximum required travel. It
typically requires less than 10 w for the DPM-8 to support full range
material operating at 90db room SPL.
While the EMP-8 may look somewhat familiar it is based on totally new
subwoofer design principles. DPM (Direct Port Modulation) is the first
departure from introducing the driver diaphragm energy directly into
the enclosure volume. The DPM-8 puts the ports ahead of the box to not
only eliminate boxy sound but also allow all bass frequencies to be
output with equal efficiency and low distortion.
An internal manifold maintains the port first in the pressure sequence
then allows the box to do its magic. An internal acoustic transmission
line maintains the standing waves at the port throat. It is an acoustic
engine, which incorporates clever turbo bass extension and capable of
launching broadband output as stable standing waves. There is no static
frequency dominating the enclosures internal pressure. The ports launch
critically damped standing waves with the drivers’ motion minimal
throughout its bandwidth. The room is ignored as a source of signal
modulation as the Acoustic Intake Regulator (AIR) isolates the driver.
This serves to both isolate the room while dynamically adjusting the
drivers' acoustic impedance to comply with its ambient environment.
The DPM-8 doesn't unload quickly in the infrasonic range and will load
the room in this range when information is present making ambience an
important contributor to realism when its there. (request graphs)
There are a few secrets here as well as patented generic acoustic
processes that are now available in the Emperor DPM-8. The Emperor
series of audiophile subwoofer promises to bring joy when you turn your
system on and play your music or settle for something on the videophile
side of your system. The DPM-8 really shows its capability reproducing
effects naturally without boom (unless its in the source) at levels you
will love.
Patents issued and pending
*(DP8-P amplified version also available see info below)
Specifications: DPM-8
Alignment– Direct Port Modulation/w AIR (Driver- Aluminum 8" low mass)
Frequency response- 20/200 Hz (-9db/oct below 25Hz)
Impedance- 8 ohms nominal
Power Handling-250W program
Maximum SPL - [email protected] (typical 90db room levels <10w required)
Sensitivity-87db @1w (35-200Hz) [25-200Hz with room gain]
Connection- Gold Plated 5-way binding posts- .75” spacing.
Dimensions-12.5”d x 12.5”w x 13.75”h)
Included required spikes adds 1.75” to height
Weight- 25lbs (shipping wt-30lbs)
AVR: Denon AVR-X4400H Front L/R: Def Tech BP2000TL Center: Def Tech CLR 3000 Surrounds: Def Tech DI 5.5BPS
Ceiling Atmos: RSL C34E x4 Subs: Monoprice Monolith 12" THX Ultra, Dayton Audio BST-1 Bass Shakers x2 (APA150 Amp)
disturbedfuel15 is online now
