Buttkicker LFE Mini Question - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By dwander
post #1 of 5 Old 05-20-2019, 07:49 AM - Thread Starter
Quoted: 14 Post(s)
Liked: 1
Ultimately will have 3 LFE mini transducers. The current amp thats coming today is the BKA-130 which will give out 45 watts at 4 ohms to two transducers. So, once i add the third id have to get another one of these amps to power the third one. Is there a reason to scrap this plan and get a single amp like the BKA-300 to power all 3?
dwander is online now
post #2 of 5 Old 05-20-2019, 08:18 AM
Sekosche's Avatar
Quoted: 1370 Post(s)
Liked: 3352
Since the BK mini-LFE are 4ohm and 50W RMS, if you go with only three, you’ll have to wire them in series for a 12ohm impedance and will be drastically short on power from either of these amps.
I’d recommend getting a fourth BK mini and wiring them in series/parallel for the same 4ohm load and the BKA-300 amp will power them all nicely; an odd number of transducers never works well for wiring in this case. If you want to stick with just two and wire them in parallel, the BK-130 amp will be fine.
Speakers: PSA MTM-210T x2, MTM-210C, MT-110SR x2; Atmos-SVS Satellite x2, DIY Volt-10 x2
Subs: PSA V1801 x2, DIY: 18" RSS460HO, 15" RSS390HO x2, BOSS w/JBL CX1200 x6
MA’s: Crowson Tech x2
Processing: Denon X4200, NU6KDSP, 3KDSP
Video: Epson 3700; Screen: Silver Ticket 106" High Contrast
Sekosche is offline
post #3 of 5 Old 05-20-2019, 08:30 AM - Thread Starter
Quoted: 14 Post(s)
Liked: 1
Originally Posted by Sekosche View Post
Since the BK mini-LFE are 4ohm and 50W RMS, if you go with only, three you’ll have to wire them in series for a 12ohm impedance and will be drastically short on power from either of these amps.
I wasnt going to wire them in a series. Was going to wire the two parallel and the third will have its own amp. So based on that im trying to see if theres a good reason to go with the single BKA-300 amp versus the two BKA-130 amp
post #4 of 5 Old 05-20-2019, 09:32 AM
Sekosche's Avatar
Liked: 3352
Ah, well in that case then no. Just get another 130 amp, save the money, and call it a day; you can always add a 4th BK down the road should the need arise. The BK130 does technically leave them 10% short on max RMS power handling, but it‘d be an insignificant amount of output lost.
Sekosche is offline
post #5 of 5 Old 05-20-2019, 09:47 AM - Thread Starter
Quoted: 14 Post(s)
Liked: 1
That what i was looking for. Thanks a lot.
Sekosche likes this.
