SVS PC-2000 or Monolith 12 - AVS Forum | Home Theater Discussions And Reviews
 18Likes
post #1 of 32 Old 05-21-2019, 10:11 AM - Thread Starter
monteplus3's Avatar
Quoted: 12 Post(s)
Not sure if anyone has the answer really, but thought I'd share my fence-sitting quandary here to get some opinions.
I was planning on buying the SVS PC-2000, hopefully during a sale sometime down the road rather than paying the full price of $800. However, now I see that the Monoprice Monolith 12 is available for $650, so I am thinking of abandoning my plans with the PC-2000 and going for that option instead.
With my set-up, eventually I could add another PC-2000 (space works) but not a second Monolith 12.
Room is about 2,000 sq ft, fronts are Mirage OMD 28s, Yamaha RX-3070 receiver.
Any thoughts? Thanks.
monteplus3 is offline
post #2 of 32 Old 05-21-2019, 10:50 AM
confinoj's Avatar
Quoted: 1194 Post(s)
Liked: 998
You can't go wrong with either. They are both in the same ballpark in terms of overall performance. Forum members who have heard both give the performance edge to the Monolith making it a great deal at its current price. With the SVS you will the get the great CS as well as easy upgrades within 1 year. The once nice thing about the PC subs is that if you moved up to the PC-4000 at some point the footprint is identical, just taller. That being said duals of either the mono 12 or PC-2000 should be very good in that sized space. Having the option to go duals is very advantageous in most spaces and typically that works best with matching subs. If you really think you will never be able to make enough room for a second mono 12 I may give the edge to the PC-2000 to make the dual upgrade path easier. If within a year you would get a $100 discount on the second. If you think duals are rather unlikely for you or you can figure out a way to move things around to get a second mono 12 in then that's the better deal.
drh3b likes this.
LG OLED65C7P (Chad B Calibrated) | Denon X4300H | Tivo Roamio OTA | Nvidia Shield | ATV 4K | Oppo UDP-203 | Plex server
5.2.4 | Front Klipsch RP-160M x2 | Center Klipsch RP-450C | Surrounds Klipsch RP-150M x2 | Atmos Klipsch RP-140SA x 4 | Subs SVS PC-4000 x 2
confinoj is offline
post #3 of 32 Old 05-21-2019, 11:28 AM - Thread Starter
monteplus3's Avatar
Quoted: 12 Post(s)
Originally Posted by confinoj View Post
You can't go wrong with either. They are both in the same ballpark in terms of overall performance. Forum members who have heard both give the performance edge to the Monolith making it a great deal at it's current price. With the SVS you will the get the great CS as well as easy upgrades within 1 year. The once nice thing about the PC subs is that if you moved up to the PC-4000 at some point the footprint is identical, just taller. That being said duals of either the mono 12 or PC-2000 should be very good in that sized space. Having the option to go duals is very advantageous in most spaces and typically that works best with matching subs. If you really think you will never be able to make enough room for a second mono 12 I may give the edge to the PC-2000 to make the dual upgrade path easier. If within a year you would get a $100 discount on the second. If you think duals are rather unlikely for you or you can figure out a way to move things around to get a second mono 12 in then that's the better deal.
Very logically put and makes good sense, thanks for the advice....much appreciated.
post #4 of 32 Old 05-21-2019, 11:31 AM
Kini62's Avatar
Quoted: 2662 Post(s)
Liked: 2448
If your plans include a second sub then you've answered your own question.
Is the room 2000 SQUARE feet or CUBIC feet? Big, big difference. If the latter a single of either would be good if you can get a good response across the seating area. 2 subs really do help in making the bass response better. It's not really about more bass but better bass.
2 PC2000s would be my choice.
Def Tech SC8000
Onkyo RZ820
Roku Ultra, Apple TV, Sharp 70" Quattron
Kini62 is offline
post #5 of 32 Old 05-21-2019, 11:50 AM - Thread Starter
monteplus3's Avatar
Quoted: 12 Post(s)
Yes, I think you have a point there....I think the two PC-2000s are my best option eventually, I just hate to pass up such a good deal on the Monolith 12, but best to plan for the long haul. My viewing/listening area is really about 15X15X10, so a little over 2,000 cubic feet, but it opens up into the kitchen area as well. Will pay a little extra and go for the PC-2000 with the intention to double on down the road. Thanks for the input.
post #6 of 32 Old 05-21-2019, 12:43 PM
Leon!'s Avatar
Quoted: 283 Post(s)
Liked: 138
Would have said M12 given the sale & value to performance, but if not possible for two of them ever, easy choice. Dual PC's are just cool.
Now I missed what cu. ft. your HT is, re:PC2k vs. PC4k
Leon! is offline
post #7 of 32 Old 05-21-2019, 01:34 PM
MIX_MASTER_ICE's Avatar
Quoted: 2560 Post(s)
Liked: 2398
I have a pair of the Monolith 12's and used to own the PC-2000. For the current $660 the Monolith would be the easy choice. However, your situation being limited in space to run duals definitely changes the mindset. Dual subs are a big advantage over a single, so I would go with the PC-2000. You might hold off a bit buying one, as SVS will likely have a Memorital Day sale this weekend. SVS doesn't ever discount new model PC-2000's, at least that I'm not aware of. They do offer discounts in the outlet for customer returns/used in like new condition or scratch and dent units. The everyday discounts in the outlet are increased during holiday sales.
One other option for the PC-2000 is IQ Home Entertainment, a licensed SVS seller, currently has the PC-2000 open box for $649 via amazon.com. You lose some of the perks like 1 year upgrade buying from a 3rd party instead of directly from SVS, but you still retain the full 5 year warranty. I have provided the link below.
https://www.amazon.com/gp/offer-list...&condition=all
Subs>RBH I-12e/I-12. HSU VTF-15H mk2. Monolith THX 12(x2)/THX 10(x2). XTZ 1X12. SVS PB-1000(x2). Speakers>JBL 270/235c/230/225c, Arena 130/125c. Jamo S807/S803. Infinity P363/163. Pioneer FS52/BS22A/C22. Sony CS3/CS8/CS5. QA 3020i/3090Ci, 2020i/2000c. Monolith AM Cinema 5 bs. Polk RTiA1/CsiA4. Other Audio>Sony MDR-Z7m2, WH-XB700, XB32, XB31.JBL Live500bt. Logitech GPro HS. Plantronics RIG 500 Pro HS. LG FH6,RK8,PK5,PH4. UE Boom3.
MIX_MASTER_ICE is offline
post #8 of 32 Old 05-21-2019, 02:51 PM - Thread Starter
monteplus3's Avatar
Quoted: 12 Post(s)
Thanks, I forgot all about the discounted "like new" option on Amazon. I decided to take a deep breath and go for it. The seller is highly rated, it's a good price, plus I get it in two days.
It's a significant benefit to know the day it will be arriving so I can try to get it inside and connected before my wife gets home....much less chance of getting a plate thrown at my head when she sees it in play as opposed to seeing a mega-box at our front door.
I'll let some time pass and then go for the second one. Thanks for the input....my fingers are crossed.
MIX_MASTER_ICE likes this.
post #9 of 32 Old 05-21-2019, 04:28 PM
confinoj's Avatar
Liked: 998
Congrats. You will love them. I know you already ordered and this may not be an option but don’t underestimate the utility of the 1 year trade up policy from SVS if you buy from them directly. Many folks find they want more subwoofer or better extension once they get a taste of quality subs so having that option is nice.
There is an outlet pc-2000 for $80 off and again you would get a discount with a second sub. I know not as good a deal as what you got and don’t even know if you could cancel but just something to consider.
confinoj is offline
post #10 of 32 Old 05-21-2019, 05:36 PM
Liked: 2398
SVS doesn't offer multi-sub discounts for outlet units.
post #11 of 32 Old 05-22-2019, 10:09 AM
confinoj's Avatar
Liked: 998
Forgot about that. Interestingly enough for the just announced memorial day sale PC-2000s in outlet with no damage are listed for $699 plus they are offering 5% off for duals including from the outlet (just for memorial day). Lots of other really good deals too.
Edit - well those are gone already. But still others with minor cosmetic issues.
confinoj is offline
post #12 of 32 Old 05-22-2019, 10:28 AM - Thread Starter
monteplus3's Avatar
Quoted: 12 Post(s)
I see one still available for $100 off with no damage, but I am still happy with my Amazon "like new" purchase for basically $150 off, which I will get on Friday. Hopefully it really will be like new, we'll see. I don't see me trading up within a year. I've had my paltry Polk 505 for over ten years, so I'm pretty certain I will be keeping this one, and maybe a twin later on.
I know I won't get the great customer service that SVS offers with their return policy, etc.....but no regrets.
I appreciate everyone's comments and advice.
post #13 of 32 Old 05-22-2019, 01:50 PM
Liked: 2398
Even though you didn't buy the PC-2000 directly from SVS, they will still be happy to help you with any issues or questions you have.
post #14 of 32 Old 05-25-2019, 01:11 PM
Liked: 2
Ive purchased two subs from the outlet and I swear they go out of their way with lighting to make it look worse than it is. The last purchase I thought I was going to have some deep scratches in the piano finish and when I got it unboxed I needed my iPhone flashlight and the right angle to find them.
jfinne13 is offline
post #15 of 32 Old 05-25-2019, 05:19 PM
confinoj's Avatar
Liked: 998
So how do you like it?
confinoj is offline
post #16 of 32 Old 05-26-2019, 08:03 AM - Thread Starter
monteplus3's Avatar
Quoted: 12 Post(s)
Got it yesterday....weather troubles around the nation delayed the delivery by day, no big deal....worked out even better because the wife was at work when it arrived!
I was pleasantly surprised when I unpacked it, because the item was described as "like new" on Amazon, when, in fact, as best I can tell it is actually new instead of "like new". It looked factory packed and untouched.
I went through the YPAO calibration process with my AVR, based off the guidelines here at AVSForum. I decided to go ahead and keep my old sub, the Polk 505, in play as well to have a two sub configuration....not sure if that hurts or helps me, but thought I would run it this way for a while then change it later and try it with only the PC-2000.
It sounds impressive but honestly it hasn't blown me away like I was expecting, but I am not sure if I have if set up to its best configuration. I will continue to tweak it over the next few days.
Yesterday, after calibrating it, I flipped through a few channels and played portions of the first Jurassic Park through it, then an Avengers movie, then a Harry Potter, and then a Star Wars. I could tell a pronounced difference, but quite honestly it wasn't giving me quite the boom I was expecting. Again though, I think this is because I haven't yet found its optimal setting. Interestingly, I seem to notice a bigger difference with music than with what I have heard from movies. There is definitely an overall difference though....in the short time I have had it my wife has asked me to turn the volume down twice!
Have put my Polk up for sale, and once sold, I will probably go for a second PC-2000.
Kini62 likes this.
post #17 of 32 Old 05-26-2019, 08:38 AM
Kini62's Avatar
Liked: 2448
Sometimes it takes a little while to adjust to the distortion free linear output of subs like the SVS. It's output in the 40-60hz range is probably about only about 2-3db more that your polk. The polk has a built in hump in its output in that range (typical for subs in that price range) that tend to make them seem louder than they really are. You might need to up the gain on the sub and or AVR to get more of the low end that you were missing. Experiment and have fun with it.
drh3b likes this.
Def Tech SC8000
Onkyo RZ820
Kini62 is offline
post #18 of 32 Old 05-26-2019, 08:44 AM
confinoj's Avatar
Liked: 998
I would definitely try running through calibration without the Polk. It’s so much less capable in all respects that it may be limiting the performance of the pc-2000 especially at the low end for movies. Most wouldn’t recommend running them together unless you found it clearly added to the experience only after trying pc-2000 on it’s own.
sigpig and drh3b like this.
confinoj is offline
post #19 of 32 Old 05-26-2019, 09:12 AM - Thread Starter
monteplus3's Avatar
Quoted: 12 Post(s)
Noted.....will definitely try it in that manner. I take it a second PC-2000 would be a different (positive) scenario though?
post #20 of 32 Old 05-26-2019, 09:42 AM
Kini62's Avatar
Liked: 2448
Set up your system with just the SVS, then try and add the polk in to see if it helps. My 2 subs are quite different in capabilities but adding the lesser sub in a near field position really made a nice overall improvement.
Def Tech SC8000
Onkyo RZ820
Kini62 is offline
post #21 of 32 Old 05-26-2019, 11:49 AM - Thread Starter
monteplus3's Avatar
Quoted: 12 Post(s)
Thanks, I adjusted the crossover for all speakers to 80Hz or less, changed every speaker to a small setting, including the fronts, and slightly increased the volume on the PC-2000.
That made a world of difference. Definitely have the thunder/rumble I was looking for now. I've noticed that it has to be set just right for music so as to fully complement what's playing without dominating it, which with this sub is very easy to do.
I'll continue to experiment with the settings, but I am very pleased with it now....I can definitely hear the difference from what I had, and it's really remarkable. I'm already talking myself into getting a second one.
pase22 likes this.
post #22 of 32 Old 05-26-2019, 01:16 PM
pase22's Avatar
Quoted: 3014 Post(s)
Liked: 2503
Once you've experienced what a good sub can, it can get addictive.
Kef Q100 FL/FR,SL/SR, Q200C, SVS SB-2000, Denon AVR-X3400H, , Panasonic 50" Plasma, Xbox One.
Bedroom: JBL Loft 50 , Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is online now
post #23 of 32 Old 05-26-2019, 03:35 PM - Thread Starter
monteplus3's Avatar
Quoted: 12 Post(s)
I believe it. What I've found pretty amazing since I reconfigured the settings is that not only the lower bass tones sound significantly better, but even the mids and highs from music are greatly improved....more distinct and better separated. I'm hearing detailed sounds that I never heard before in music that I have listened to many times before.
Biggest problem I have now is that I want to keep listening to it and do little else.
post #24 of 32 Old 05-26-2019, 04:37 PM
confinoj's Avatar
Liked: 998
Yup. Surgeon General’s Warning: Good deep bass is highly addictive and hazardous to your credit card and significant other relationship.
doni01 and drh3b like this.
confinoj is offline
post #25 of 32 Old 05-26-2019, 05:02 PM
Quoted: 111 Post(s)
Liked: 67
Lol very true!! I keep telling my wife, this is the last thing I am getting, I promise. Unfortunately that promise keeps getting broken Should have never come on here
drh3b and MIX_MASTER_ICE like this.
doni01 is offline
post #26 of 32 Old 05-26-2019, 05:17 PM
Liked: 2398
Between AVS and Slickdeals, my wallet is always under constant assault. My wife hates subs and home theater equipment. She would rather just listen to the TV speakers. My wife actually gets angered when I say this is the last sub I'm going to buy, because she has heard that quite a few times and it never holds true.
doni01 likes this.
post #27 of 32 Old 05-26-2019, 05:39 PM
confinoj's Avatar
Liked: 998
You have certainly amassed quite the sub collection over the years. Just curious what you do with them? Do you have multiple setups or are they unused? I know I’m terrible about getting rid of older electronic equipment. My wife always asks me to sell what I’m replacing but it never seems to happen. Like you and many others it seems my wife also would be perfectly happy listening from a tiny mono tv speaker and finds the subs “uncomfortable” because she can feel it. Fortunately she has tolerated my HT escapades but doesn’t get it at all.
doni01 likes this.
confinoj is offline
post #28 of 32 Old 05-26-2019, 05:46 PM
Liked: 2398
I have sold some subs over the years, otherwise I would be knee deep in them. The Monolith subs may end up here long term due to them being so awesome. We moved last fall to a larger house and I do have multiple set ups, but still have more speakers than I can use. I'm actually more over-run with speakers than subs. I sometimes swap out speakers in one of the set ups with some on deck, sorta like getting new speakers without buying them at that time. It's hard to pass up a good deal when they come along. My wife calls me an electronics hoarder.
post #29 of 32 Old 05-27-2019, 05:07 AM
Quoted: 111 Post(s)
Liked: 67
Haha mine just rolls her eyes and says you sure this time ?? You really sure ?? And I go with my regular line. I promise babe
doni01 is offline
post #30 of 32 Old 05-27-2019, 04:55 PM
Liked: 2398
I use the "on my word as a gentleman" line. She tells me I'm no gentleman.
doni01 likes this.
