Hardly any bass with music.. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-21-2019, 04:02 PM - Thread Starter
Matthew Wiechert's Avatar
Quoted: 81 Post(s)
Liked: 25
Not sure what the deal is.. using 2 monolith 12s movies shake my room.. I switch to Spotify the subs won't barely move not sure what's going on... I stream from built in Spotify on my reciever not sure what in setting it could be.. My bics I used to have played fine.. Play some bass I love you and they don't even move..
Matthew Wiechert is offline
post #2 of 2 Old 05-21-2019, 05:12 PM
clownaphobia's Avatar
I know that my receiver can change settings depending on the input selected. Perhaps yours is changing into stereo mode and running your mains full range, which would bypass your subs?
While on spotify...make sure your speakers are still set as small, with an appropriate crossover (usually 80hz) as a starting point. Just a suggestion. 🙂
clownaphobia is offline
