Sub cutting out at mid to high volumes? - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 2 Post By RayGuy
  • 1 Post By rufunky
  • 1 Post By RayGuy
post #1 of 4 Old 05-21-2019, 05:14 PM - Thread Starter
rufunky's Avatar
Quoted: 47 Post(s)
Question Sub cutting out at mid to high volumes?
I am trying to enjoy my newly put together ATMOS 5.1.2 system but midway through action scenes, my sub keeps cutting out and I have to turn it off then on again to reset it. Even at as low as 3 ( it goes up to 10 and is 75 watt )
Receiver: Onkyo TX-NR575
Sub: Cambridge Soundworks BassCube 10
It's an old sub so its probably time for a new one but not really in the budget right this moment. I'm hoping someone can give me some suggestions.
rufunky is offline
post #2 of 4 Old 05-23-2019, 10:59 AM
RayGuy's Avatar
Quoted: 2516 Post(s)
Liked: 2263
You are exceeding the capabilities of that sub. At 75 watts, it's more suited for near-field computer usage, than full blown HT. In the interim, turn it down. Then experiment with near-field placement (as a side table or just behind your seating position).
indebtbassfreak and rufunky like this.
It's a VIRTUAL channel unless stated otherwise.
RayGuy is offline
post #3 of 4 Old 05-24-2019, 08:42 AM - Thread Starter
rufunky's Avatar
Quoted: 47 Post(s)
Thanks Ray. I guess its served its time.
I ordered a refurbished JBL 250p for $117 as a filler until I have more of a budget.
RayGuy likes this.
rufunky is offline
post #4 of 4 Old 05-24-2019, 10:27 AM
RayGuy's Avatar
Liked: 2263
rufunky likes this.
RayGuy is offline
