2nd sub need be matching? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-22-2019, 09:50 AM - Thread Starter
prsman's Avatar
Quoted: 149 Post(s)
Would I experience a significant movie surround improvement if I add a 2nd sub?
I currently have a single Definitive Technology 15" sub, 250watts, probably about 20 years old that still works fine.
Should I add a 2nd 12" or 15".....I can get the Klipsch reasonably (with wireless)....or do I need to get matching subs?
I use the single sub, a DT PF1500, in a 7.1.2 setup with a Denon x4500h. see attached for Sub performance.
The room is large, vaulted ceilings with large level deviations below 120hz with a huge null or cancellation at about 74hz.
Have you gone through a similar experience you could share? Thanks!
Name:	REW compares.jpg
prsman is offline
post #2 of 3 Old 05-22-2019, 10:11 AM
phatfreeza's Avatar
Quoted: 50 Post(s)
can give you general advice, duals will only perform as well as your lowest performing sub. I've had mismatched subs for awhile and its fine for HT use for me. I didn't really notice anything off.
My HT: 7.3.4 Denon x4300h + denon stereo amp, Hsu HB1-MK2(6), HC1-MK2, Pioneer SP-T22A-LR(4), dual Rythmik fv25hp, b1200d, 65" LG OLEDB7A, xbone s, ps4 pro.
Classroom HT: 7.2.2 Onkyo TX-NR747, JBL L5 (LR), HSU HC-1 MK2(C), Pioneer SP-T22A-LR(2), Pioneer SP-C22 (2-Surrounds), svs pb12+/2, svs pc13, Epson Powerlite 99WH
phatfreeza is offline
post #3 of 3 Old 05-25-2019, 08:35 PM
Quoted: 70 Post(s)
Liked: 24
Itn some cases it could be beneficial. If you can eq them individually you could darn close to equality. Its just bass so i wouldn't sweat it too bad if they are different.
miketofani is offline
