AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Subwoofers, Bass, and Transducers (https://www.avsforum.com/forum/113-subwoofers-bass-transducers/)
-   -   HSU amp replacement (https://www.avsforum.com/forum/113-subwoofers-bass-transducers/3068934-hsu-amp-replacement.html)
melvin long 05-22-2019 11:14 AM
HSU amp replacement
Picking up a free dead HSU VTF 3 MK2 tomorrow. I'm assuming it's just a dead amplifier but won't know til I get it in hand. My understanding is the Dayton SPA250 is a near drop-in replacement (with some extra wood to mount it?) and then I'll have a great extra sub. Has anyone done this already - any pointers on the wiring?
The real questions are:
- would this pair up nicely with my Paradigm Servo 15 v1, DefTech STL w built in subs and Anthem MRX700 amp assuming I can get phase/volume lined up ok.
- alternatives to the spa250 amp? I have an old NAD amp that could be connected directly to the driver via an old x30 active crossover (would that even be needed if using the Anthem crossover?) - crazy talk? I'm way undereducated on what makes a good subwoofer plate amp vs a standard stereo integrated amp - the old NAD is only about 40 wpc if memory serves.
- mounting the subs into a riser for rear theater seats - If I laid the HSU on it's side, and built a box around it and the Servo to put seats on, would there be anything to consider in the design to optimize output or just rely on ARC once level/phase checked?
Thanks all!
deano86 05-22-2019 11:19 AM
Why not just call HSU and see what the proper replacement amp costs?
melvin long 05-22-2019 11:48 AM
I'll definitely do that but initial research has people getting the v4 model amp at about twice the price of the Dayton and the sub loses oomph (subjectively).
deano86 05-22-2019 11:58 AM
Subjectively indeed... I am sure...I would call HSU just for the heck of it and see what they recommend for your fix 'r upper project and then see if your Dayton option will be the way to go....
melvin long 07-07-2019 02:59 PM
Update - pulled apart the sub finally. Definitely the amp is toast. Luckily, hooking up another amp, driver performs beautifully! Talked with HSU, they can either repair the amp or can send a mk4 to replace, latter a bit more expensive. I'm up in Canada so a bit of a pain to ship/pickup/customs paperwork (I assume no duties as it's a repair). The Dayton SPA-250 I can get in Canada for about the same as from US with exchange/gas to pickup across border. Am likely going with the Dayton based on reviews and ease of purchase. I did however see an inuke 6000 come up on craigslist for about 400 Cdn (about 150 more than the Dayton). Would that be way overkill for the HSU or would it possibly eek out more performance? Would definitely allow me to make a giant sub out of my second row riser - thinking about 3ftx8ftx15inches - would a huge box like that work well with the 12" hsu driver or is it just begging for an 18" or 2?
Zarkoff500 07-07-2019 09:20 PM
How about this one? https://www.parts-express.com/hsu-re...fier--299-4036
melvin long 07-08-2019 06:45 AM
Originally Posted by Zarkoff500 (Post 58270110)
Whoa - thanks! Did not see that searching for plate amps on parts express. Wonder if these are refurbs? Doesn't say which version it is mk 3 up is 350 watts so guessing an actual mk 2? Regardless, biting the bullet on it and will try it out and report back.
Zarkoff500 07-08-2019 07:36 AM
1 Attachment(s)
Hope it works out. I purchased one of these https://www.parts-express.com/hsu-re...ofer--299-4020 and I am very impressed with the performance in a 3.5 cft cab at 20 hz.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
