AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Subwoofers, Bass, and Transducers (https://www.avsforum.com/forum/113-subwoofers-bass-transducers/)
-   -   Velodyne F-1500B for $250 or 2 Martin Logan Dynamo 700 for $165? (https://www.avsforum.com/forum/113-subwoofers-bass-transducers/3073600-velodyne-f-1500b-250-2-martin-logan-dynamo-700-165-a.html)
edzyy 06-15-2019 09:49 PM
Setup:
Klipsch RB-81 II Bookshelves
klipsch KSB 1.1 Surrounds
Klipsch KSC C1 Center
Martin Logan Dynamo 300 sub
Yamaha V379 receiver
Saw these 2 on craigslist within walking distance of home, so figured that was a good enough excuse to upgrade my sub.
My room is small, but the ML 300 doesn't do much. I ended up moving it to my bedroom 2.0 set up. Sounds a lot better there.
Anyway...
I've been running 5.0 for a while, and though the RB -81's are bassy, they don't get low enough to scratch my itch for bass.
Of the 2 options above, what would be a better buy?
I know the Velodyne will get a lot lower since it's a 15, but dual subs are usually better.....usually. I've been scratching my head for 2 days. Help me decide?
50% movies 50% music
sk373 06-16-2019 05:45 AM
I wouldn’t feel too comfortable getting the Velodyne. That model is 20 yrs old. Dual ML Dynamo 700’s seem pretty solid for $165.
eljaycanuck 06-18-2019 03:21 AM
+1 to the pair of Dynamo 700.
gajCA 06-19-2019 09:20 AM
I've owned Velodynes since 1986 and loved them but with your choices, the MLs are the way to go.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
