? re: cable to connect powered sub to preamp - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By eljaycanuck
  • 1 Post By enricoclaudio
  • 1 Post By vld
post #1 of 10 Old 06-25-2019, 04:45 PM - Thread Starter
Liked: 2
I'm feeling a bit confused about how to select the appropriate type/class of cables (L/R) to connect a powered sub-woofer to my 2Ch pre-amplifier. I am rearranging the listening area and will potentially need 25 ft. of cable. RCA connections of both ends. I presume I need shielded cable, if that is correct how does one discern the 'quality' of the cable and it's shielding characteristics?
Info appreciated!
Thanks/Bill
Wgosma is offline
post #2 of 10 Old 06-25-2019, 04:59 PM
eljaycanuck's Avatar
Quoted: 1865 Post(s)
Liked: 2614
Quality product + a reasonable price = bluejeanscable.com
purplerain likes this.
eljaycanuck is offline
post #3 of 10 Old 06-25-2019, 06:04 PM
vld
vld's Avatar
Quoted: 112 Post(s)
Liked: 87
Also, look into a shielded COAX cable with F-type to RCA connectors, it may be a hair cheaper at 25'.
vld is offline
post #4 of 10 Old 06-25-2019, 07:47 PM - Thread Starter
Liked: 2
Thanks, I'm not very knowledgeable about cables...are you speaking of say 'RG-6' coax cable? Like this https://www.homedepot.com/p/Commerci...4062/203726228 and then simply affixing adapters to get my RCA connection?
This would be appealing from price standpoint- compared to say the Blue Jeans cables mentioned above it's a very significant price difference.
Thanks/Bill
Wgosma is offline
post #5 of 10 Old 06-25-2019, 08:18 PM
enricoclaudio's Avatar
Quoted: 3651 Post(s)
Liked: 4380
Media Bridge ULTRA Series Subwoofer cables from Amazon. Cheap and very well made. I have a pair of those and they work the same as my expensive Blue Jeans cables and AudioQuest interconnects.
https://www.amazon.com/Mediabridge-U...s%2C155&sr=8-3
darthray likes this.
Enrico Castagnetti @ Rythmik Audio - Dialing In Rythmik Audio Subwoofers - REW for macOS
Media Room: Sierra Towers w/RAAL, Horizon w/RAAL, Sierra 2s & Lunas | Rythmik F12SE(x2) + FV25HP | Denon X6500H | Panny 820 + ATV 4K | Bluesound Node 2 | 92" Stewart ST100 | Sony VW295ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac| Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz SR6013 | Sony X700 + ATV 4K | Sony XBR-65Z9D |
enricoclaudio is offline
post #6 of 10 Old 06-25-2019, 08:24 PM
vld
vld's Avatar
Quoted: 112 Post(s)
Liked: 87
Thanks/Bill
Yes, but you will still need connectors like;
https://www.homedepot.com/p/Paladin-...0046/202534283
OR
https://www.amazon.com/Conwork-6-Pac.../dp/B01DRQF8RS
The only drawback to using COAX is the size and stiffness of COAX does limit hiding of the cable a bit.
vld is offline
post #7 of 10 Old 06-25-2019, 08:31 PM - Thread Starter
Liked: 2
Geez, now those cables are quite inexpensive indeed; maybe worth a go, little to lose.
Thanks/Bill
Wgosma is offline
post #8 of 10 Old 06-25-2019, 08:33 PM - Thread Starter
Liked: 2
Thanks/Bill
OR
In my configuration not a big issue; only need to turn one 90 deg corner and 70% of cable run is hidden by furniture.
Wgosma is offline
post #9 of 10 Old 06-25-2019, 10:29 PM
bobknavs's Avatar
Quoted: 2128 Post(s)
Liked: 1506
I'm using the same cable (25') as well. I get no audible noise pickup.
It's also available in white, should you prefer that.
I take it that Wgosma is using a source with no single LFE output? How about a crossover? (It's good to avoid sending low frequencies to the main speakers, if only to cut the power load for their amps.)
bobknavs is online now
post #10 of 10 Old 06-27-2019, 11:39 AM - Thread Starter
Liked: 2
I ordered the cable via Amazon, as usual quick delivery - they sound great. I have two cables connected to L/R line level outputs on my NAD preamp (and into SVS sub), cannot discern any humm or extraneous noise, darn cost-effective solution.
Thanks guys!
Bill
Wgosma is offline
