Help identifying older Velodyne sub - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-17-2019, 10:58 AM - Thread Starter
niccolo's Avatar
Quoted: 256 Post(s)
Liked: 63
A friend recently moved and his older Velodyne sub was damaged, likely to the point of non-repairability, by the movers. He's trying to identify the model for insurance purposes, and Velodyne is being surprisingly unhelpful. I believe the sub has a modestly-sized 10" driver but a beast of an amplifier rated at 1250 watts RMS. Any suggestions on how to identify the model and its present-day equivalent? Much appreciated.
P.S. I'm not sure why the site is turning correctly oriented photos on their side.
ID:	2591926   Click image for larger version
ID:	2591928   Click image for larger version
ID:	2591930   Click image for larger version
Benq W1070 projector w/ Chief RSM mount with custom interface bracket
119" Da-Lite Cinema Contour with High-Contrast (gray) Da-Mat screen
Denon X2000 receiver fed by Panasonic DMP-BDT210 Bluray player
Focal Chorus 700-series towers and center, JMLab Tantal 500-series bookshelf rears
Rythmik FV15HP sub
niccolo is offline
post #2 of 8 Old 07-17-2019, 11:03 AM
eljaycanuck's Avatar
Quoted: 1867 Post(s)
Liked: 2621
A quick google of "velodyne tandem 3" push-pull" suggests it may be an HGS-10:
- manual
- review
-- Edit --
Reviewing the links, the HGS-10 has a 1000W amp while the HGS-12 has a 1250W amp. Are you sure it's a 10" driver (measured to the outer edges of the metal basket)?
-- Edit #2 --
Going by this pic from an ad on CAM, it's definitely the HGS-12.
eljaycanuck is offline
post #3 of 8 Old 07-17-2019, 11:14 AM - Thread Starter
niccolo's Avatar
Quoted: 256 Post(s)
Liked: 63
- manual
- review
-- Edit --
-- Edit #2 --
I think you're right and he was mismeasuring the driver, Velodyne HGS-12 seems to fit the bill.
The Velodyne website doesn't seem to be functional enough to try to locate its present-day equivalent.
Rythmik FV15HP sub
niccolo is offline
post #4 of 8 Old 07-17-2019, 11:39 AM
torii's Avatar
Quoted: 3436 Post(s)
Liked: 1910
I own that sub, hgs 12 under my desk with some little audioengine a2+ desktop speakers. I got that sub to hit 110db's in a wide open room, I dont think I will ever try that again as this sub has had some warranty issues with amp....knock on wood mine has not.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS
Subs: Rythmik FV25HP, Rythmik FV15HP
torii is online now
post #5 of 8 Old 07-17-2019, 11:44 AM
torii's Avatar
Liked: 1910
that sub was retail 2 grand when it came out 20 yrs ago or so. think I paid 1200 on clearance. an equal would be any top line 12 inch sealed sub w/piano finish.
torii is online now
post #6 of 8 Old 07-17-2019, 01:25 PM - Thread Starter
niccolo's Avatar
Quoted: 256 Post(s)
Liked: 63
Wow, that's about $3000 in 2019 dollars! It'll be interesting to see what the insurance company is willing to cover for my friend, depreciated value (probably not much) versus replacement cost (a lot).
Rythmik FV15HP sub
niccolo is offline
post #7 of 8 Old 07-17-2019, 01:59 PM
b curry's Avatar
Quoted: 995 Post(s)
Liked: 632
It's a Velodyne HGS-12. The box dimensions are 14" x 14.5" x 14".
Here's a link to the Velodyne product manual for the HGS-10 & 12:
http://velodyneacoustics.com/pdf/hgs...riesManual.pdf
Here's a link for a review of the product that verifies the MSRP of $1995:
https://hometheaterhifi.com/volume_5...dynehgs12.html
The Velodyne HGS-12 is a 20 plus year old unit so good luck with the insurance company as they are going to want to depreciate the value considerably. I would suggest that your friend leverage the insurance company for a JL Audio E-Sub, e112. It's very similar in size, has a 12" driver and a 1500 watt amplifier. MSRP for the JL Audio is $2300 in piano black gloss finish and $2100 in black ash finish.
b curry is offline
post #8 of 8 Old 07-17-2019, 02:04 PM - Thread Starter
niccolo's Avatar
Quoted: 256 Post(s)
Liked: 63
Agreed that the insurance company is likely to depreciate the value a lot. That JL Audio seems like a strong replacement contender. Another option I'd recommend based on my own good experiences is a Rythmik sub, or possibly a Salk build of a Rythmik sub if he wants a really high-end finish.
Rythmik FV15HP sub
niccolo is offline
