Help me with Epik sub repair / amp panel replacement - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 44 Old 08-06-2019, 07:12 AM
Juiced46's Avatar
Quoted: 448 Post(s)
Liked: 149
Originally Posted by snookfisher View Post
Originally Posted by Juiced46 View Post
You can always run it in Bridge mode
Then I would need 2 of them..in which case im looking at almost the cost of a new sub
Why would you need 2 of them? Isnt the Phoenix a single 18? Are they 8 or 4 ohm drivers? Can you send me the full specs on those subs? Im having trouble finding info. I dont see why you cant run them both. Or you can always go with a 6000D. But I think the 3000 will be sufficient depending on those subs specs
Juiced46 is offline
post #32 of 44 Old 08-06-2019, 07:29 AM
snookfisher's Avatar
Quoted: 146 Post(s)
Liked: 34
Well...the inuke is a 2 channel amp I have two subs...
snookfisher is offline
post #33 of 44 Old 08-06-2019, 07:31 AM
Juiced46's Avatar
Quoted: 448 Post(s)
Liked: 149
My Behringer is a 2 channel and I run 6 subs, I run 4 off of ONE channel...... I edited my post. Can you list me the specs on those Phoenixs?
Juiced46 is offline
post #34 of 44 Old 08-06-2019, 07:36 AM
Quoted: 146 Post(s)
Liked: 34
Its a single 18 inch driver 4 ohm original amp was 600RMS and 1500peak.
post #35 of 44 Old 08-06-2019, 07:48 AM
Juiced46's Avatar
Quoted: 448 Post(s)
Liked: 149
Is the driver a single voice coil or DVC? If its a single 4 ohm. You run the amp in bridged mode and wire the 2 speakers in series/parallel which will give a 4ohm load and 3000 watts peak power
Juiced46 is offline
post #36 of 44 Old 08-06-2019, 07:59 AM
Quoted: 146 Post(s)
Liked: 34
I was thinking of running each sub off each channel ..my receiver has duel sub output
post #37 of 44 Old 08-06-2019, 08:13 AM
Juiced46's Avatar
Quoted: 448 Post(s)
Liked: 149
Then run 1 per channel @ 4 ohms. It will be enough. If you dont like it, return, or buy a 6000D
Juiced46 is offline
post #38 of 44 Old 08-06-2019, 08:25 AM
Quoted: 146 Post(s)
Liked: 34
I will...thank you for the help
post #39 of 44 Old 08-14-2019, 03:06 PM - Thread Starter
Vladyxa's Avatar
You will need an RCA to XLR adapter to connect the Receiver to the AMP. No cutting required.
From the AMP to the speakers you will just need a Speakon connector.
It goes like this.
RCA out of receiver > cable to convert RCA to XLR> connect XLR to INPUT of Amp. This gets the sub signal from the receiver to the AMP.
From there, its a Speakon connector out to the sub with speaker wire. At that point you can do what I did and add another speakon terminal at the back of the Epik.
All you need to make all of this work is an RCA to XLR cable like this-
https://www.amazon.com/Monoprice-XLR...gateway&sr=8-6
You will not have to cut any wires at all. Then you will need the SpeakOn connectors to go from Amp to sub.
Got little derailed, ordering parts now:
- speakon connector for the back of the sub. Did you have to break out the old connector from Epik? I looked and it looks like I might have to break off peace of the amp board.
- 2 x speakon connectors for speaker wire (should have some 14ga wire left from running speakers)
- XLR to RCA cable
I already got the amp, yay!
Should get it next week and will update.
Vladyxa is offline
post #40 of 44 Old 08-14-2019, 03:19 PM
Juiced46's Avatar
Quoted: 448 Post(s)
Liked: 149
- XLR to RCA cable
I unscrewed it from the plate amp and clipped the wires where it goes to the circuit board I believe. I forget what it looked like exactly at the moment.
I did it neatly but to be honest, the plate amp is junk, so you can technically break it off if you wanted to. Post a picture if you can and hopefully it will refresh my memory lol
Juiced46 is offline
post #41 of 44 Old 08-26-2019, 09:11 AM - Thread Starter
Vladyxa's Avatar
Finally got to work on the sub. Got everything connected and now struggling with the amp setup.
When I turn the amp on, the sub starts making a buzzing (not static) noise, which changes when I start or pause a movie.
The noise goes away if I turn the play around with settings, but I have not figured out how to set up the settings.
The manual for the amp's setup was less than user-friendly.
So, right now, there isn't much bass coming from the sub. But the good news - it seems to be working. lol
Can you share the setting you use for the sub?
Did you have any issues connecting to your amp?
Vladyxa is offline
post #42 of 44 Old 08-26-2019, 09:18 AM
Juiced46's Avatar
Quoted: 448 Post(s)
Liked: 149
Buzzing is due to poor grounding in your electrical of your home. I will PM you tonight
Juiced46 is offline
post #43 of 44 Old 08-26-2019, 09:23 AM - Thread Starter
Vladyxa's Avatar
Thank you! Just to clarify, the buzzing sound doesn't start until I turn on my receiver.
When I turn the amp on, and the receiver is off, there is no sound.
Vladyxa is offline
post #44 of 44 Old 08-26-2019, 03:21 PM
Juiced46's Avatar
Quoted: 448 Post(s)
Liked: 149
Then it may be interference with your Sub cable to XLR or something connected to the AVR causing noise to pass through the AVR to the AMP. I am going to PM you now....
Juiced46 is offline
