AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Subwoofers, Bass, and Transducers (https://www.avsforum.com/forum/113-subwoofers-bass-transducers/)
-   -   NX3000D Behringer not working (https://www.avsforum.com/forum/113-subwoofers-bass-transducers/3081398-nx3000d-behringer-not-working.html)
Monstrosity 07-29-2019 06:44 PM
I posted my concern in another thread. I thought maybe I should just start a new so I can get this figured this out as soon as possible.
I have two 10" subs wired up to the 3000 but I am unable to get Channel B to output more than 10% SPL of what I get out of Channel A. I swapped every wire to make sure it wasn't one of my 2 sub outs from my STR-1070 or one of the wires. Both subs work fine by themselves but when I try to run the NX3000D in Dual with same settings B outputs very little SPL.
Secondly, I have a $10 Nobsound 100W TPA3116D2 Amp with a 60W power supply. With the gains maxed out on both the NX3000D and Nobsound, the Nobsound is a little louder than the NX3000D. Maybe the NX3000D is a cleaner sound but does this sound right, should a 60w $10 amp beat out the 3000 on SPL?
Monstrosity 08-06-2019 09:30 PM
I returned the amp and got a replacement and i am still seeing the same problem. No output on channel B... back to the drawing board, maybe i have a wire mixed up.
Monstrosity 08-09-2019 04:10 PM
As one last attempt to get this working I maxed out the gain on the filter/crossover which doesn't seem to do much but then I also maxed out the Parametric EQ to 15dB at multiple frequencies throughout to 30-200hz and that 15dB on the EQ more than did it. I didn't think I needed to increase the gain on that to get the output I was looking for. I set my voltage limiter to keep it under 400w for my 400wRMS rated sub and just one or two ticks of the knob and it was limiting the output and I think the SPL was desirable... now I need a bigger sub, maybe UM18-22 :)
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
