The Tactile Response Thread for BASS :)) - Page 79 - AVS Forum | Home Theater Discussions And Reviews
 3466Likes
post #2341 of 2478 Old 03-26-2020, 10:39 AM
m0j0's Avatar
Quoted: 1184 Post(s)
Liked: 1746
Originally Posted by markmon1 View Post
I have 2 BKA1000N's - I've had them since 2010 and they're still going strong so they must be the models that don't smoke
Will be interesting to see what m0j0's experience is on this regarding the input gain levels.
So, to follow-up, here's my experience so far:
I had a BKA-1000N that I was using to power 2 x BK's in an MBK configuration (ButtKickers mounted to the back of the seat just below the Boss Back JBL). It was pretty wicked and was really enjoying it so ordered 2 more BK's to mount to the outside seats, but before I could get everything setup across the board, my BKA amp went bad.
I ordered the NX3000 and have set it up in bridged mode running all 4 BK's in a series/parallel setup (with pos to +1 and neg to +2 on the neutrik connector going into Channel A on the NX).
I had started with some testing where I was running the BK's flat to 90Hz with no PEQ other than amp rolloff, and I have the volume turned up about 3/4 of the way (about 4 clicks from max). Sounded and felt decent, but felt like there was a little bit missing in the few demo clips I was running at the time. However, started watching the latest Star Wars and the BK's were going nuts, just bottoming out hard, so I began to dial back until just below the 1/2 mark. This seems to be all the power that I need right now, so no concerns with gain levels!
I did eventually switch my BK's over in the mDSP 2x4HD to use some PEQ (same PEQ as I am using with the cantilevered BK's now) and it was much better in terms of the feel/impact using the previously tested demo clips. I am very pleased with the feel of the MBK's now with the current amp gain levels at 1/2 and the PEQ settings on the mDSP (which includes a +4 gain in the mDSP). I wasn't sure if the NX would be able to push the BK's with the same level of intensity as the BKA amp, but so far, I am more than pleased with it and definitely consider it a good option if you have a BKA amp and it goes bad.
Here are the BK settings I am using currently (which I more or less took from how @SBuger was running his cantilevered BK's before):
LS 15Hz, +7.0, Q0.8
LS 12Hz, +6.0, Q0.9
Negative HS 12Hz, -5.0, Q0.9
Negative HS 10 Hz, -3.0, Q0.9
Peak 10Hz, +2.0, Q1.0
m0j0 is offline
post #2342 of 2478 Old 03-26-2020, 11:16 AM
Quoted: 3438 Post(s)
Liked: 14412
So one thing I noticed while digging into the amp testing, and that might be relevant to the differences in BK bottoming you guys are seeing, is that maybe the DSP and non-DSP models have slightly different rolloff and that is the difference?
Are the guys noticing their BKs bottoming sooner in the singles running non-DSP amps, and the guys (Nalleh?) who don't are running DSP models?
I'm going to analyze the rolloff that notnyt measured on the NU4-6000 and design a rolloff comp filter for that. It might be a bit better for you guys with non-DSP models.
Edit: Just finished. It turns out I settled on the same exact shelf as the mDSP rolloff comp: LS 10Hz 2.3dB Q0.5, which makes the response +/- 0.5dB down to 4Hz!
So I don't know if that maybe partially explains the difference, considering it's only a 2.1dB difference in shelf.
Take the Red Pill (BassEQ) BassEQ Demo Clips TR Curves
Video: Sony 85" X900F @ 80" eyes-to-screen (49.4° viewing angle)
Audio: Denon AVR-X4400H 7.2.4 Atmos
Mains: Fusion-15 LR, Fusion-8 Center, Ported Volt-10 Surrounds, Custom 45°/45° Double-Angled Ported Volt-6 Atmos
Subs: The Two Towers (HT18 32cf 11.5Hz x 2), UM18 4cf x 2, Crowson MAs x 4
aron7awol is offline
post #2343 of 2478 Old 03-26-2020, 01:43 PM
Nalleh's Avatar
Quoted: 3047 Post(s)
Liked: 4401
^^ My BK’s are on a non-DSP NU6K.
aron7awol likes this.
Dual AVR 13.1.8 SWAtmos - Atmos 13.1.8/DTS X 9.1.8/Auro 3D 13.1 - Denon AVCX8500H+AVRX7200WA - Klipsch+KEF - 4xSI18" - 12x12" w/6xSLAPS M12 VNF - 4x12"HB+2x18"CLHB - 3x2 stacked Crowson MA - 4xBK-LFE - 6xNU6K(fan&trig mod) - Minidsp 10x10HD - Oppo UDP203 - XB1X - ATV4K - JVC RS600 Dreamscreen V2 120"- Samsung QE82Q60.
>>>>Nalleh’s HT<<<<
Nalleh is offline
post #2344 of 2478 Old 03-26-2020, 06:13 PM
gpmbc's Avatar
Quoted: 445 Post(s)
Liked: 346
Very close to some good vibrations.
ID:	2702058   Click image for larger version
ID:	2702060   Click image for larger version
gpmbc is offline
post #2345 of 2478 Old 03-26-2020, 07:39 PM
m0j0's Avatar
Liked: 1746
Getting ready to test Monster BOSS version 2.0, GBE (Garbage Bag Edition)! Let out some air to lower ride height and added a super sophisticated sealing system (aka garbage bag). Going to give it a go tonight and see how it performs!
ID:	2702114   Click image for larger version
ID:	2702116   Click image for larger version
ID:	2702118   Click image for larger version
ID:	2702120   Click image for larger version
SBuger, BP1Fanatic, Nalleh and 2 others like this.
m0j0 is offline
post #2346 of 2478 Old 03-26-2020, 08:20 PM
markmon1's Avatar
Quoted: 6184 Post(s)
Liked: 4233
LS 15Hz, +7.0, Q0.8
LS 12Hz, +6.0, Q0.9
Awesome. Glad you didnt take my advice or need to
m0j0 likes this.
Video: JVC RS4500 135" ST130 G4 screen in batcave, htpc nvidia 1080ti madVR.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, Infinite Baffle Subs 4x15 fi audio running on behringer ep4000 + 2x12 fi audio mounted in main chair firing into back.
markmon1 is online now
post #2347 of 2478 Old 03-27-2020, 12:51 AM
Nalleh's Avatar
Liked: 4401
Holy crunk, is that 4 !!! Si18’s in Cantilever HoverBoss???
That should work, LOL!! Awsome job
m0j0, SBuger, BP1Fanatic and 1 others like this.
>>>>Nalleh’s HT<<<<
Nalleh is offline
post #2348 of 2478 Old 03-27-2020, 12:56 AM
Nalleh's Avatar
Liked: 4401
Just a heads up: using thin plastic can make a flapping sound from all the air movement(think plastic in the wind outside). That is why thicker plastic like builders plastic is better. Also using some kind of fabric underneath the plastic helps with the flapping
However you are on carpet, so that helps too
>>>>Nalleh’s HT<<<<
Nalleh is offline
post #2349 of 2478 Old 03-27-2020, 05:09 AM
m0j0's Avatar
Liked: 1746
Yeah, I was worried about that, but so far, I have heard nothing whatsoever, so carpet must be helping.
Nalleh likes this.
m0j0 is offline
post #2350 of 2478 Old 03-27-2020, 06:59 AM
gpmbc's Avatar
Quoted: 445 Post(s)
Liked: 346
Yep! I’ll be wiring them up today. For power, I don’t want to overdrive them, but I want to give them enough. What should I be lookin in terms of wattage?
Also, the platform is definitely sealed in a resting position. If I push on the cone from the backside it barely wants to move like it’s stuck. If I lift the platform to let air underneath the bottom of tubes (I used an adhesive on the top) then the cone moves freely. Is that normal?
Nalleh likes this.
gpmbc is offline
post #2351 of 2478 Old 03-27-2020, 07:04 AM
gpmbc's Avatar
Quoted: 445 Post(s)
Liked: 346
Here’s what I used to seal the tubes. Double sided tape, at least the kind that I tried just didn’t wanna stick. This adhesive worked perfect. There was some excess on the side of the wood and I could scrape it off with my fingernail so it’s secure but not permanent and it has some give unlike glue.
ID:	2702300   Click image for larger version
SBuger and Nalleh like this.
gpmbc is offline
post #2352 of 2478 Old 03-27-2020, 07:17 AM
Quoted: 93 Post(s)
Liked: 237
I'm not sure what the RMS rating is on those but I'm giving both my UM18's a full NX6k channel each
Video: Epson TW9400 - DIY frame 126.5" DreamScreen Ultraweave V6 - Panasonic DP-UB820
Audio: Klipsch 7.1.4 - Denon X4400H - Emotiva BasX A-500 - 2xMiniDSP 2x4HD - 4xNX6000
Subs/TR: 3xSealed UM18's - 2xSVS PB4000 / 2xBK-LFE - 8x12"HB+2x18"CLHB+3x12"BB
Magly is offline
post #2353 of 2478 Old 03-27-2020, 07:23 AM
gpmbc's Avatar
Quoted: 445 Post(s)
Liked: 346
@Magly Thanks, my first plan was to wire all of them together for a 4 ohm load and send power with one channel of a clone FP10k so around 500 watts each.
Nalleh and Magly like this.
gpmbc is offline
post #2354 of 2478 Old 03-27-2020, 07:41 AM
Quoted: 93 Post(s)
Liked: 237
That should work pretty good
Magly is offline
post #2355 of 2478 Old 03-27-2020, 07:44 AM
Nalleh's Avatar
Liked: 4401
That sounds great and all normal
Can’t wait to hear your impressions of this bad boy
>>>>Nalleh’s HT<<<<
Nalleh is offline
post #2356 of 2478 Old 03-27-2020, 08:33 AM
tvuong's Avatar
Quoted: 2865 Post(s)
Liked: 2819
Holy Greg. Do you still have/use your Crowsons on top of this BOSS?
tvuong is offline
post #2357 of 2478 Old 03-27-2020, 09:14 AM
gpmbc's Avatar
Quoted: 445 Post(s)
Liked: 346
@tvuong Hey bud! No Crowsons in use at this time. I wanna get this sealed CLHB in effect and then go from there. From all reports, sealed BOSS kills it in the single digits which is what I was missing with my previous regular BOSS. I liked everything else about it. I also have a few Buttkickers. All the discussion about the x, y and z axis had me curious about maybe mounting the BKs mounted sideways directly to the couch frame to engage those axis in a different way?
gpmbc is offline
post #2358 of 2478 Old 03-27-2020, 01:01 PM
DesertDog's Avatar
Quoted: 1038 Post(s)
Liked: 2697
I might have to break quarantine this weekend...
#IHateNalleh
The struggle is real for Generation Xplain Digital to the Analog and Analog to the Digital.
Klipsch RF-7III, RC-64III
SI HS-24mkIII BOSS-Sac
Sony 85X900F, Denon 8500, nVidia Shield, Apple TV
DesertDog is online now
post #2359 of 2478 Old 03-27-2020, 01:07 PM
gpmbc's Avatar
Quoted: 445 Post(s)
Liked: 346
gpmbc is offline
post #2360 of 2478 Old 03-27-2020, 02:04 PM
DesertDog's Avatar
Liked: 2697
I've been trying to catch up on this thread from the last week or so. Boy is it dense. It got me thinking though that we should do a summary of the filters, amps, etc. that have been discussed to have as an easy reference for new people or people getting up to speed. Would anyone be interested in working on it? The BEQ repo on GitHub has a wiki feature that I can give anyone interested write access to for it. Then we have something to point people to and a reference for ourselves. I was thinking maybe have a master page that's a baseline of everything and then Magly, Aron, Nalleh, or anyone can have their own branch off of it to document their set-up and config.
#IHateNalleh
post #2361 of 2478 Old 03-27-2020, 02:06 PM
Liked: 14412
^^^ Most of it should already be in the "TR Curves" post I put together. I've been adding to it pretty regularly, and I'm definitely not done yet. If you take a look at the post and have any suggestions of what else to add, I'd love to get that sort of input.
post #2362 of 2478 Old 03-28-2020, 06:11 AM
m0j0's Avatar
Liked: 1746
Monster BOSS v3, or MB3 as I call it, is alive...
https://www.avsforum.com/forum/19-de...l#post59420202
SBuger, aron7awol and Nalleh like this.
m0j0 is offline
post #2363 of 2478 Old 03-28-2020, 06:41 AM
markmon1's Avatar
Liked: 4233
I cant remember where I read it, but I believe buttkicker says you need to mount their devices vertically to avoid damaging them. They can be upright or upside down but not sideways.
post #2364 of 2478 Old 03-28-2020, 07:43 AM
m0j0's Avatar
Liked: 1746
Just got around to updating my TR Gear thread in case anyone is interested...
https://www.avsforum.com/forum/113-s...l#post59260592
m0j0 is offline
post #2365 of 2478 Old 03-28-2020, 08:05 AM - Thread Starter
SBuger's Avatar
Quoted: 1591 Post(s)
Liked: 5344
So glad to hear you're loving the MHB latest version!!! Super cool!!! Thanks for the update on that and the settings and well I'm sure your system just KILLS and is a ton of fun!!!! Fantastic job my friend
Dude, those 4x 18's CLHB are gonna BRING IT!!!!!! . I think you're gonna freak over what it can dish out in the single digit area (other areas too!!). Great job and looks awesome!!!!
m0j0 and aron7awol like this.
My 'Blacked Out' Home Theater | Tactile Response for BASS | BassEQ for Filtered Movies
1400cuft Sealed Room | SY Triple Black Velvet Blackout | GIK Treatments | Denon AVR-X6300H - 7.7.4 Atmos | KEF Q Series Speakers | Epson 5040UB | 120" 16:9 AT Seymour Screen | Oppo 203 | XB1X | ATV4K | 3x 18" Sealed Subs | MEGA HoverBOSS w/6x JBL-12s + 3x 18s | BossBack w/ 1x JBL-12 + 1x BK LFE | 6x Crowson MAs | 4x BK LFEs | MiniDSP 10x10HD
SBuger is offline
post #2366 of 2478 Old 03-28-2020, 08:19 AM
m0j0's Avatar
Liked: 1746
@SBuger thanks for the reply. Yes, I can honestly say that I am blown away with my setup at this point! Every TR component is bringing their individual strengths, or that something special that only they can do, and perfectly combining it together into a cohesive, unified TR experience! It's somewhat of a Holy Grail type feeling. I know I am perhaps missing out on the CLHB component but don't have the space in my room to accomodate that aspect. Otherwise though, couldn't be happier!
SBuger and aron7awol like this.
m0j0 is offline
post #2367 of 2478 Old 03-28-2020, 09:12 AM - Thread Starter
SBuger's Avatar
Liked: 5344
Awesome!! Yep it’s an amazing feeling to be where you want to be with the system for sure!!
As far as missing out on the CLHB ….you’re probably not missing that much without CLHB, especially with your bigger tubes and all that you are running now. I loved mine so much that I almost didn’t even mess with the CLHB addition. I do love the CLHB, but I could be pretty much just as happy with out it I think, since these HB's seem to be able to take whatever boost you through at it if want more on the low end. For me what I especially love is the overall feel when I switched to the bigger tubes. Still not as big as your monster tubes, but a lot bigger than the norm and made one heck of a difference for me in feel for the better. Almost an undescribable magical type feel and something that I KNOW you’re getting with those monster tubes you are using now.
Enjoy!!! I know that’s what I’m gonna start doing again. I had to take about 4 days off from the HT and TR’ing. I kind of pulled a lower ab muscle dunking a basketball and messing around (thinking I’m still young or something I guess LOL). It didn’t feel so good on the ab setting in the HT seat getting blasted by TR, as it makes me tense up my core area a lot of times and works the abs kind of like me an Aron were talking about the other day. So I just took a handful of days off from it. But it’s doing better now and got in a session last night with some more Altered Carbon 2 and a few of my favorite demos. Pure Joy it was!!!! So thankful to be able to enjoy it again and about went into serious withdraw without it!!! Gonna have to be more careful, cause nut’n more important than TR’n Hahahaha
m0j0 likes this.
SBuger is offline
post #2368 of 2478 Old 03-28-2020, 09:20 AM
m0j0's Avatar
Liked: 1746
Need a theater sign that says “when the TR’s Rockin’, don’t come Knockin’”
SBuger likes this.
m0j0 is offline
post #2369 of 2478 Old 03-28-2020, 09:24 AM
imureh's Avatar
Quoted: 3307 Post(s)
Liked: 4381
I remember reading your change to the thicker tubes. I am using the 16 inch Goodyear ones from Walmart which I think were thicker than most FB begin with. Looks like the ones you are using are even thicker? Having any height issues now? Think you reduced the air to compensate for it? You don’t have any isolators anymore right? So the platform is just on the tubes now?
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser, 2 BK LFE
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is offline
post #2370 of 2478 Old 03-28-2020, 09:49 AM
m0j0's Avatar
Liked: 1746
In version 1, I was at about 3 1/4 inches ride height, or a bit more perhaps. I also didn't have both tubes evenly pumped so one side had a bit more air than the other, but I figured it was okay for testing (also no seal with version 1). I let out a lot of air in version 2 and dropped the ride height down to about 2 inches (or maybe 2 1/4), but that didn't feel right with these tubes. In version 3, ride height is at 2 3/4 inches and feels "just right". For comparison, my other platform with 16" tubes has a ride height just a bit under 2 inches.
The Monster BOSS doesn't have any iso's, just the two big tubes up front and the three smaller wheelbarrow tubes in the back.
m0j0 is offline
