This post #2 will be used to cover most of the important information throughout this TR thread, without you having to search through lots of pages to find it, as this thread has grown to be pretty good sized. Of course, there will also be links to posts within the thread for more detailed information whenever need be, for it to be more complete.
** Quick / Easy Accessible Links***
HoverEze Guide Longeze's Guide to setting up your HeZe
After your HeZe is built, follow these guides on how to get the most out of it with tuning...
Mechanical Tuning Part 1 &
Part 2 - Reduce ringing and increase efficiency with proper spring rate and damping on your Heze
Full Range Hz Tuning Learn how to make sure you are experiencing the full range of frequencies in movies from your HeZe
If you want to take your TR with HeZe to the next step (with the latest AVRs) with Directional TR, then take a look at how Nalleh did it ...
Dircitional Bass / TR , as well as
HERE and
HERE . If you are interested in Directional Bass / TR, then check out these great posts & pointers from Nalleh. He is the first to get this going on his HeZe rig with the new Denon AVRs and his insights and methods might be helpful for anyone wanting to set their rig up for this.
The post will be divided up into sections that include (in order):
-Frequently Asked Questions
-TR Curves - Gear and Settings used by various members of the thread
-TR Journey / Story Links from various members from the thread
-Useful Links - Tape and Tubes for HoverEZe, HoverEZe Drivers, Buttkicker Mods, etc.
-Subwoofer Positioning and TR Devices Overview
-Movie Clip "Time Stamps" - For some Killer BASS and TR scenes
I hope this post turns out to be a helpful resource for newcomers, as well as the regulars of the thread, if they need it
. This section is still a work in progress, and I'll continue to add to it as we go. As always, suggestions are welcomed on things to include and how to make it better
Frequently Asked Questions:
Here’s a list of questions that get asked frequently in this thread and have been covered in detail all along the way, but is spread out pretty good and is sometimes hard to find since the thread is starting to get pretty long. Rather than having to dig like crazy or even ask a question that has maybe been asked again and again, these may help answer your question(s) quickly and easily. But if you still need to ask for more detail or specifics for whatever the reason, feel free. But, this should cover a LOT of what is asked about on a pretty continuous basis. I tried to give short (but hopefully decently complete) answers on most of them, and / or also created links to where the topic was discussed in full detail within the thread (or even elsewhere if need be). I hope this helps. Please feel free to add questions and answers to the list, or suggestions in general to help make it better. Thanks!
First let's start with …..What is a HoverEZe exactly and how does it work?
HoverEZe - Currently the
BEST TR device ever developed for TR lovers of all levels, by none other than our very own AVS forum member and TR lover himself, Longeze!!!!
If you are still new to a HoverEZe and wonder what it is exactly, it's when you put tubes around the drivers in a platform / riser (that the seating sits on) and creates a seal between the baffle that the driver is mounted to and the other side (floor, plywood, disc, etc), creating a very small “Hover Column” that pressurizes and “moves” the seating (and you) in amazing, super realistic, and natural ways. The better the seal, the better it works, as it's basically creating an air pump within the Hover Column, with the tubes acting as the springs, to create the TR from the source signal.
Here's a few videos of the HoverEZe in action from various members of the thread for a visual of the kind of TR that it's capable of dleivering:
m0j0’s HoverEZe on a clip from Avengers Endgame, showing some pretty crazy TR:
Nalleh’s HoverEZe on a clip from Wonder Woman Bell Tower, showing some insane 3.5hz TR at about the 14 second mark:
SBuger’s HoverEZe on a clip from Jumanji: Welcome to the Jungle, showing some pretty fun TR:
Magly’s HoverEZe showing some insane ULF TR from the song Infrasonic Death that goes down to 1hz, from his DIY seat, with enough force to even launch a laptop completely airborne from the seat surface from super low hz:
Ok, so if that wasn't enough TR video clips for you guys on what the HoverEZe can do, here is one more from m0j0 again ( ...cuz his TR is just so awesome that he gets not just one video, but two
), because it's so intense here that the TR makes his cheeks shake like mad in this clip from Batman vs Superman, at about the 18 to 24 second mark. Check it out guys ...it's some EPIC CHEEK SHAKING TR!!!!
If that's not some crazy awesome Tactile Response right there, then I don't know what is
^^^^ Obviously, these clips show a ton of TR, but if this is too much for some, it can be tuned in for whatever level of TR one desires (from super subtle across the board, to just straight up ridiculous).
Are there any guides for HoverEZe?
Yes, the HeZe Guide guide can be found
HERE
Should I go with a Cone Down (CD), Cone Up (CU), or even a Dual Opposed (DO) HoverEZe?
As the name indicates, CD is with the cone of the driver mounted facing down and magnet up, the opposite for CU, and then drivers mounted top and bottom with their cones facing each other in a DO config. Which one you choose to go with, will probably be determined by how much room you have under your seating, and / or how high you are willing to sit up off of the floor.
Cone Down is very good and is how it started out (and what most use), but Cone Up does improve the efficiency of the HoverEZe, by having less weight to move you and your seating, as the drivers “and” platform that houses them are not part of the weight with this config. Lighter = more efficient. Also, at least in my opinion, I think that the drivers firing up into the piece of plywood that the seating is sitting on, makes a bit of a difference as well.
The drawback to a Cone Up config (at least for most, unless you do some sort of a NallehFold design (air pressure from the drivers not under the seating, but channeled to up underneath the seat)), is that the drivers need to go under your seating, plus the tubes and plywood sheet on top of that (that the seating sits on), can add up pretty quick, but is worth it if you can live with this. I actually don’t mind sitting up a little higher in my HT room, so it works well for me for example.
Then there is Dual Opposed. IF one has enough room under their seating to fit the magnets for the upper drivers that are facing down into the Cone Up Drivers, then this can work great, like what m0j0 does with the DO HoverEZe for example.
A reply I made to a CD and CU question within the thread that you may find useful as well, can be found
HERE.
What is the latest and greatest version of HoverEZe?
ATM, I’d say definitely the Cone Up or Dual Opposed version. To take it even further, some of us run multiple CU HeZe's in a stacked config for the ultimate of what HoverEZe has to offer. As an example, a few of us are running 3 HeZes on one seat's platform, as a Cone Up HeZe (as a base platform that the seat sits on), then an additional CU HeZeUnderButt (HUB - that goes right under the actual seat cushion itself), as well as a 3rd HeZe on the SeatBack (referred to as HeZeBack).
For a row of seats, should I do one big riser, or go with single seat platforms for HoverEZe?
It depends. As with everything, there are pros and cons to each. The latest trend tends to be single seat platforms, for various reasons. Here’s a list of reasons (in no order), that may appeal to some, to go with single platforms vs one big platform.
1). Lighter and easier to build and move into position etc (or tweak if one is into experimenting etc, as it’s easier to work with as well).
2). If the person in the seat next to you shifts their weight in the seat etc, the motion won’t affect your seat since it's on a different platform.
3). Depending how all single platform HoverEZes are setup and wired, it can give separate control for intensity, and even curves, for each seat.
What are the best or most common / popular amps for HoverEZe?
The most common may not be the absolute best, but work very well for most of us. The most common are definitely the iNuke amps and may be the best bang for the buck. The iNuke NU (the older versions before they redesigned them), the NX version (redesigned NU), in the 1000, 3000, or 6000 series work fantastic. Also, they are available in the DSP version as well, that include a “D” in the model #, such as NX6000D for example. Most use a miniDSP to set up their HoverEZe instead of the DSP in the amp, but if there is a need to limit the watts to your drivers, then you'll need the DSP version of the amp.
What fans are recommended to replace the noisy stock fans on the iNuke amps and are there any guides?
A popular choice is the Noctua NF-A8 FLX 80mm and can be found
HERE There is a pretty good guide on how to do the fan mod
HERE
What is the best way to wire drivers for my HoverEZe?
Most drivers ran in a HoverEZe config will handle their RMS max watts rating no problem, with the very small sealed “Hover Columns” that are created within the tube enclosures. One of the most common questions seems to be, “how do I wire 4x 4ohm JBL 12” drivers on my 3000 or 6000 iNuke amp?". The RMS rating on one channel of an iNuke6000 (or a bridged 3000) is about 1200w RMS at 4ohm. Max RMS wattage on the common JBL driver that is used in HoverEZe is around 250-300w, so it works perfectly running 4x 4ohm drivers wired in series / parallel for a 4ohm load. The following wiring diagram shows how to do this …
I am unsure about how to wire 4 JBL GX-1200s to one channel of my Behringer NX6000. I understand I should wire them in series, as illustrated in this diagram. Both the positive and negative wires from the amplifier are plugged into the same positive or negative terminal for 2 different drivers. I have normal 16-gauge speaker wire with 2 wires per end. How does one connect the same wire to 2 different drivers, as shown in the linked diagram? Is it done by using a wire nut or SpeakOn terminal to attach multiple wires together?
A great explanation that can be found in this post
HERE (thanks m0j0!)
What are the best drivers for HoverEZe?
12” to 18” drivers seem to be the most common choice and work fantastic in a HoverEZe, but smaller or even larger drivers can be used. The JBL CS1214 / GX1200 (same driver, just different dust cover), which are 12” drivers, are the most common for HoverEZE, but a list of drivers that could be amazing as well, with equal or even better specs to the JBL can be found
HERE . The link is also in the
"Useful Links" section in the post under
Drivers for HoverEZe. Driver list Courtesy of Nallah (Thanks!!)
Is there something magical about the 12” JBL driver that so many are using for HoverEZe?
The 12" JBL drivers just seem to work so well in a HoverEZe. There are other drivers that can work great too or even better, but these do the trick phenomenally well for TR at all frequencies in a HeZe or HeZeBack, wire well with their ohms (especially 4 per channel on the super popular iNuke 6k or bridged 3K amps for example), and are reasonably priced (although they can be real cheap on sale day. Unfortunately the big JBL sales are not as common these days, but still do happen from time to time for $29). Still, they can sometimes be found for around $50 here and there (eBay, etc).
Where and when are the sales on the super popular 12” JBL drivers used for HoverEZe?
Best Buy will usually have sales on Black Friday, but can happen at other times as well. Keep and eye on this thread
HERE (link needs activated after I track it down), as someone in there will usually post about it.
12” vs 15” vs 18” (or even the smaller 6”, 8”, or 10”) drivers in a HoverEZe, what is better and what should I go with?
12” drivers in a HoverEZe are the most popular, but bigger drivers, if you don’t mind “usually having to pay more for them”, and most importantly, whether or not one can make the bigger drivers fit without interference (under your seating or wherever it’s located, since mounting depth is usually quite a bit more the bigger the drivers get, compared to 12” drivers) can be great. Smaller drivers under 12”, like the 10s, 8s, or even 6s etc, can work well for locations under your seat cushion area (HeZeButt or maybe even in some HeZeBacks) for example, where there may not be much room to work with.
What tubes should I use on HoverEZe?
Lots of different tubes have been used with success, but here is a list of the most common ones …
FAT Tubes
Maxxis FAT (26” and 27.5”)
Mongoose FAT (20” to 27”)
Various brands of other FAT tubes (16" and up) FeNIX 16x3" etc
Normal Sized Tubes
BELL (all sizes …12” and up)
Goodyear (all sizes …12’ and up)
** For a list with links to some of these, check out the
“Useful Links” section under
Tubes for HoverEZe.
What size tube would fit around two 12” drivers side by side in a HoverEze?
A Maxxis FAT 26” or 27.5” works great for this.
How much PSI should I run in my tubes for HoverEZe?
This will vary with tube type, type of HoverEZe platform, number of drivers, weight of the seating, as well as weight & number of HeZe riders, etc. Usually anywhere from 2-5 lbs per tube works pretty well and is a good starting point. Longeze has put together a guide on how to figure what will probably be best (or a great place to start), if you want to get really specific and more scientific about it. Here's a post down below about it from our very own expert and Hover Designer, “Longeze”:
What follows is a crude approximation method to find an initial inflation value. While not technically correct, for most people it will work well enough to bring their systems nearly into balance, for best performance:
1st Weigh the moving part of your platform including your seat(s) & usual riders. Use a couple scales & add the values.
2nd Find the total planar surface area for ALL your tubes. To find that, use the calculator linked below. To use it, if you have a 16" tube for example, try entering values of "1" for "r"(the radius of your tube body), & "8" for "R"(the overall radius from the center to the outside of your entire tube. Take the "Area" result, divide that by 2, & multiply that value times the number of tubes you have, to get your total planar tube surface area. Torus Calculator at Calculator Alligator
What we're doing is finding out how much area the tube surface area becomes once it's inflated and squished 1/2 flat by your weight.
3rd Now you know the total sq in of the tubes, so divide the Wt in #1 by area in #2.
4th Now you know the PSI (pounds per square inch) being applied to your tubes from the force of gravity by your platform. If you inflate your tubes to that same PSI value, you'll be bringing the forces of the system into balance to create a "neutrally buoyant" platform, which is the best place to start. You can go firmer or softer from there, but that was the initial theoretical ideal, and the objective for the HoverEzE design.
The "ideal" is around 1 to 1, ie 1psi load to be balanced by 1 psi in your tubes. That's why guys seem to like the feel around that value.
What you DON'T want, is to end up with a platform loading value that's way out of wack, like >5psi or 0.25psi or even less. IF your value is too high, then you need to add one or more tubes & recalculate, until you find the # and size of tubes that brings things back into balance - within reason. Conversely, if the psi # was on the low side, you'd want to remove some tubes or make them smaller.
As Sbuger says: "Find what feels the best!"
Can I stack tubes for HoverEZe?
Yes, this works great for a little different feel and more excursion if one wants that. There are a few of us that stack tubes with great success.
What is the best way to have air control / access for the Tubes of Hover in a HoverEZe?
Extension hoses and various fittings can be used to make adjusting and / or maintaining air pressure within your tubes easy. Nalleh and
DesertDog have a list of parts and guides on how they did this on their HoverEZe systems. Nalleh's guide can be found
HERE and DesertDog's guide
HERE. More parts can be found
HERE (Thanks LongeZe!) The links to these, as well a more links with parts, can be found in this post under the
"Useful Links" section under
Air Extensions for HoverEZe Tubes:
Do the Tubes of Hover need to be sealed in a HoverEZe?
Yes, and the better the seal, the better it will work. Think of it as an air pump. If there is a leak, it's not going to be as efficient.
What is the best way to seal the Tubes of Hover?
Most use double sided sticky tape to create the seal between the tubes and plywood, thin piece of wood, acrylic discs, painters plastic, or whatever is being used.
Is there a recommended sealant (rather than using double sided tape) for sealing your tubes to your HoverEZe platform (and other surfaces like painters plastic, disc, etc)?
DesertDog has had great success with Dynaflex White Premium Elastomeric Exterior/Interior Window, Door and Trim Sealant. A link to his post about it can be found
HERE (Thanks DesertDog!)
Does the HoverDisc mod for sealing the tubes in a cone down HoverEze affect performance compared to using say, painters plastic?
m0j0 has tried both and and said he didn’t think it performed any better or worse than painters plastic, but it's durable, quiet, and reusable, so that for him are its main selling points. Here is a little extra detail from one of his posts on HoverDisc ...
"HoverDisc is basically acrylic or plexiglass used to seal the bottom of the tube in a Hover setup. There are other types of material that can be used for the same purpose, with painters plastic being a popular, low cost option. There doesn't seem to be any performance difference with the sealing materials tested, so the point was that the main advantage to using plexiglass/acrylic is that it is re-usable and doesn't make any noise (where with plastic you might get some occasional sounds coming from the plastic itself during movement)."
Is HoverDisc targeted towards a carpeted floor? Or is it useful for hard floors too?
From several posters, it seems to benefit all floor types, carpet, hardwood, tile, etc.
Can the HoverEZe Tubes be sealed to carpet?
If your carpet and pad are decently thick, it can make a pretty good seal, but can still leak and not be quite as efficient, so it's still recommended to use one of the other methods.
I am worried about the tubes of Hover not being able to support the full weight of my big riser and seating loaded with people. Will the tubes support it?
A few of us have had MASSIVE HoverEze platforms loaded with several heavy drivers (including 18” drivers), plus 3-4 seats loaded on it, with an overall weight of easily over 1000lbs and has never been a problem. The air filled tubes will hold a LOT of weight with no problem.
What curves should I use on my HoverEZe?
Curves are very important on the HoverEZe, but the best curve for someone on their rig could be dependent on a number of variables, including type of HoverEZe, content (movie or music), whether or not one uses BEQ on their movies, etc, and most importantly, personal preference for the best balanced feel you can get across the frequency band, or band that the HeZe is ran in. A great place to start is with aron7awol’s 6db oct TR curves
HERE. You can also try curves that various members in this thread use as well. Links to Aaron's, as well as the others, can be found in the
"TR Curves Section" in this post. Ultimately, it’ll come down to what feels best to you on YOUR own rig, but will be a great place to start. You'll just have to experiment with it.
HERE is another link that might help with that.
Do I need to implement a HPF (High Pass Filter / Low Cut Off) on a HoverEZe?
No need for a HPF on a HoverEZe. The low end extension is one of the best qualities of a HoverEZe and we don’t want to limit it in any way. In fact, it’s encouraged to even apply a Low Shelf filter to help level out the low end rolloff that most amps have, plus adding extra LS (Low Shelf) filters on top of that for even more low end extension is common practice.
What is the purpose of using a REW measurement on a HoverEze?
There are a couple reasons actually. One is that HoverEze can generate a fair bit of SPL (
see next 2 FAQs below this one for more on HoverEze SPL), depending on many variables (room size, level and curves that are ran on the HoverEze, etc). This can be measured with a REW sweep + mic, just like a normal subwoofer. The other reason is that a REW sweep (with a VibSensor instead of a mic) can also be used to measure TR.
Do you need to reduce levels on your “normal subs” after installing a HoverEze?
Since HoverEze can produce SPL (a little to a lot, depending on many variables)
**See next question below for more on this topic, it is highly likely that levels of your normal subs will have to be altered, at least somewhat, to accommodate the SPL being generated by the HoverEze, to keep your nice FR. A more in-depth post on this can be found
HERE
Does HoverEZe produce SPL?
Yes, but how much just depends on levels and curves ran to achieve desired TR results, as well as room size, room nodes, etc. On my particular system and room, I get crazy SPL down to under 5hz from the HoverEZe, but that is specific to me. In fact, below 25hz, I don’t even really need my normal / traditional subs to contribute (although I still sometimes have them do that a little bit), as I pretty much have all I need with the levels and crazy rising house curve that I run on my HoverEZe’s to get what I want out of it TR wise. Now, above 25hz, I do use my normal subs to help fill in. I have heard of others that get a lot of SPL from their HoverEZe’s as well, but the majority seem to not get a ton of SPL from theirs. So, like I was saying, it just depends, some will get just a little bit of SPL, while others like me, get LOTS of SPL down to 5hz or so.
How high will my HoverEZe platform be?
Depending on what type of platform you go with (Cone Up or Cone Down, and what size of drivers and their mounting depth), as well as your tubes (size of tubes and stacked or not) will determine the height of your “actual” HoverEZe platform. Also to be noted and needs to be taken into consideration, is how much space is available under your particular seats, to clear the magnets of the drivers etc, if running a Cone Down HoverEZe.
Should I use just Tubes alone on the HoverEZe, or should I use some form of Isolators in addition?
In most cases, if you can, use tubes only, as the tubes are your “springs” for the HoverEZe. Iso’s limit travel and change your spring rate. When using Tubes of Hover only, try to make sure the tubes reach close to the outside edges of your platform on all sides the best your can, to help with stabilization. But if one must use iso's in addition to the Tubes of Hover to help with stabilization, they can be used with either the rubber isolators like the Hi-Fi Hudsons, actual springs, or pressure-less tennis balls. Some folks will still put on Hudson Hi-Fi isolators (that don’t touch the ground) just for safety measures, just incase they have a tube blowout. I don’t think I’ve ever heard of that happening yet though.
Does HoverEze feel wobbly, like climbing onto a waterbed?
HoverEze can feel wobbly, especially when getting on and off of the platform / into and out of your seating. How wobbly, will depend on how you have it setup with tube positioning, size of your platform, and if you are using extra isolators such as pressure-less tennis balls or springs in addition, etc (which is usually only recommended in "most" cases if you need extra stability, as it can limit TR travel / excursion).
What is the difference between HoverEZe and BOSS?
HoverEZe is an entirely different beast compared to BOSS. The HoverEZe generates its TR movement pneumatically from air pressure from the drivers that are sealed within the Tubes of Hover “column enclosures” (between driver and solid surface), whereas the BOSS uses the driver’s moving mass for TR movement and is Open Baffle, making it more "shaker like", as the names implies from the BOSS acronym (Baffle Open Sub Shaker).
Would 4x 12” drivers for HoverEze on one single seat recliner be overkill?
No such thing as overkill in this thread
. Seriously though, IMO, no it is not overkill. 4x 12” JBL drivers for one seat (especially in a Cone Up Config) can be insanely good for stability, balance, and overall power (allowing you to dial in basically whatever TR you want across the frequency band). Plus, 4 of them are perfect to be powered by 1 channel of an iNuke 6000 or a bridged 3000 in a series / parallel config for 4 ohm.
Do I need a miniDSP for my HoverEZe?
A miniDSP is not an absolute “must” to run a HoverEZE, but it is HIGHLY RECOMMENDED to tune it to one's preferences (curves for the slope of the TR across the frequency band from a combo of HPF (High Pass Frequency) roll off, LSs (Low Shelf) or HSs (High Shelf), Peak Filters, etc), and to get the most out of it, as well as being able to apply BEQ (Bass EQ) for filtered movies to restore the ULF that’s been filtered out on a large majority of them below 25-30hz.
Are there any recommended MiniDSP compressor settings for HoverEze?
Courtesy of m0j0, he shares his settings
HERE
What should my "Filter / crossover" and Parametric EQ" settings be in the iNuke 1000D / 3000D / 6000D if I'm using a MiniDSP 2x4HD for PEQ and crossover? Should the INuke's PEQ and filter be bypassed since I'm using MiniDSP?
Yes, bypass all “crossover / filters etc” settings in the amp, and just use the miniDSP. You can, and what most of us do in the iNuke DSP version of the amp (since the phase is backwards on these amps), is invert the phase and save it, that way it’s done. You could do it in the miniDSP, but is best to just set it in the amp, that way it’s done and correct from the get go, then you can flip it in the miniDSP it if it needs to be inverted when tuning.
Can I use two miniDSP 2x4HDs for more outputs?
Yes, and there is an excellent guide from Desert Dog for setting up two of them
HERE (link also in the
Signal/Tuning, etc)
How do you align a HoverEze with a regular subwoofer?
Negative Delay (ND) will probably be your best bet for aligning TR between the two, so that they combine constructively and feel synced. FR between the two needs to be kept in mind as well.
**Refer to the question below for an extensive explanation on Negative Delay.
What is Negative Delay (ND) and why do I need it?
This topic seems to confuse a lot of folks, but is not too bad once you can get your head wrapped around what is going on with it. Basically, Negative Delay means a device firing before another device (i.e: your Crowson MAs firing before your subwoofers), and works well to help time align group delay between the two, so as to help you feel it at the same time that you hear it, as well as combine TR movement constructively between the two as well. One would think that a TR device would need to fire later than a subwoofer to be in sync, since a TR device like the MAs, Buttkickers, etc are directly connected to your seat, whereas the sub’s TR is not directly coupled and is transferred acoustically, but seems to be the opposite, from what many of us have found. The way this is accomplished is to set whatever TR device you want more Negative Delay on (Crowson MAs vs Subwoofers for example), is to set the distance to a greater value in your AVR for the MAs vs the subs.
For more in depth information on this from a post within the thread, check out this post
HERE For another great post for understanding ND and applying it, check out this post (courtesy of Nalleh)
HERE
Has anyone used test tones from say ...5hz to 60hz and calibrated your tactile transducer (or HoverEze), leveling any highs out and increasing lows?
Yes, this can be done with a VibSensor + REW frequency sweep, test tones, White Noise 0-50hz, and even a movie clip that has been graphed out, to compare the VS reading, to get as close as possible to the response, or even create a rising TR curve, and of course, see if you have any big peaks and / or dips in the TR response from the sweep or white noise.
The TR and VibSensor threads are pretty big, but there are some examples of this spread throughout both.
Another thing to keep in mind about TR peaks and dips from your TR devices, is that room correction could be causing some of this, if you don’t take measures to give your TR devices an untouched signal.
I tested the HoverEze with a 15hz test tone and i can feel the vibration. I tried it with 10hz and the vibration is very weak. I only have a single seat recliner and space for 1 driver. Would changing the driver to a better one solve the problem?
It may help if your driver is not very capable, but depending on what amp you are running, if you are not running an amp roll off fix on it (to keep the low end from dropping off so much), this could help a lot. For example, the DSP iNukes need a LS @ 10hz/+4.4db/0.5Q filter applied in the minDSP to correct the rolloff down to 5hz or so. This should definitely help, to keep the 15hz and 10hz feeling more "even" in intensity level. This becomes more important as you drop under 10hz, and is why a lot of us run a House Curve / Slope (like a 6db/oct slope), and/ or even more LS low end lifts added to that, to try to keep all frequencies feeling more even in intensity as the frequencies go lower.
Aarons’s post is a good place to start for amp roll-offs, as well as curves
HERE
What is a HoverEZeBack (or HeZeBack)?
It’s a driver mounted to your seatback, with a tube that seals it, working like a normal Cone Up HoverEZe that’s under your seat, just mounted on the seatback instead, firing directly into your back. These work fantastic in combination with a normal style HoverEZe under the seating. Some run the HeZeBack with no tube and just in open baffle, in which case would be called a BossBack, as BOSS is open baffle. Some also run it with the drivers firing directly into the padding that is up against the back of the seat, simi-sealing it. Depending on how well it seals itself with body weight and the padding itself, or even with a tube and no padding covering it, it can be referred to as more of a DI (Direct Injection) approach, bringing more PV (Particle Velocity).
Are there any build guides for HeZeBack?
These are becoming more popular all the time and for good reason, as they are amazing and a heck of an addition to the traditional way of running HoverEZe under the seating and compliment each other VERY well for a more complete TR experience. The HeZeBack has been done probably 4-5 different ways; sealed internally within the seatback cavity itself (with or without a tube), or even externally on the outside of the seatback with a tube, or as open baffle, which would then be called a BossBack. Here are a few links to builds that have been done along the way in the thread to give you an idea:
HeZeBack builds for normal style HT type seats:
SBuger:
HERE is a post with the 3 different versions that I’ve tried.
Nalleh:
HERE
m0j0:
HERE
Mangrove Jack:
HERE - DI (Direct Injection) HeZeBack.
Magly:
HERE
LastButNotLeast:
HERE
Carp:
HERE
GeoJustGeo:
HERE
** There are more as well spread throughout the thread.
HeZeBack for DIY seat builds as well:
**Coming soon …need to track them down and activate the links.
SBuger: HERE
Mangrove Jack: HERE
m0j0: HERE
Magly: HERE
Russell Burrows: HERE
Can I retain the same volume on the HoverEze, regardless of the volume of the volume of the main speakers and subwoofers?
This can be done with an Oppo Bluray player for example, via its analog subout (which doesn’t affect the HDMI to the AVR). A more in-depth post about it can be found
HERE
Can I run Buttkickers with my HoverEZe?
Yes, many of us run BK LFEs (or some run the Advance version) in addition to our HoverEZes, and can work very well together if set up to do so, with correct phase, levels etc.
What is the best way / location to mount Buttkickers?
Opinions may vary, but from my experience with BK LFEs, I’ve found that directly mounted towards the back of the seat, or even behind the seating as Canti-Levered works fantastic, as well as directly mounted to the seatback itself for a more "direct feel" to your body's core area. A combo of both can work amazingly well too, if one is inclined to do so
. BK’s can also be mounted on just the risers themselves (traditional risers or HoverEZe risers) for a little different feel as well. Some like this approach.
How do I keep my Buttkickers from bottoming out?
Well for starters, don’t turn them up to the point that they start bottoming out LOL. But, if you need them turned up that much, there are other ways to help keep this from happening or even completely eliminate it. IME, BK LFEs are most likely to bottom out under 10hz when pushed really hard. So if one doesn’t want to do the “Bottomless BK mod” (
see next FAQ under this one), one can set a Negative LS (Low Shelf) filter to roll off under 10hz to varying degrees, or use a BK amp (or combination), which has more rolloff under 10hz within the amp itself, compared to an Inuke amp for example.
Are there any mods for Buttkickers?
Yes, there is one called the “Bottomless Buttkicker Mod” that can be found
HERE &
HERE (links to this also found in the
“Useful Links” under
Buttkicker LFE Mods).
Can Buttkickers be Re-Lubed?
Yes they can, and there is a excellent guide (courtesy of Nalleh):
HERE (link to this, as well as greases, also found in the
Re-Lubing Buttkickers).
Is there much difference between the Buttkicker LFE and Concert versions?
A graph showing the slightly different frequency response between the two can be found
HERE (Thanks Nalleh!)
How much power do the Buttkicker LFEs really need? Can they run with less than the minimum recommended 400 watts and are they that much better at the max of 1500hz?
It’s probably best to stay in the recommend 400-1500hz watt range if possible, but I have ran up to 3 and 4 of them on a single Buttkicker BKA-1000 amp (the way it was shown in the BK manual), for very low watts a piece, and had VERY good results. Also, at one point Magly was running 6 BK LFEs on a single channel of an inuke6K (yes six!!
), and he said they still had enough power to bottom out, and worked fantastic!! In both of these cases, his and mine, watts per each were probably down close to low 100s, way below what is recommended, yet they still performed amazingly well. As good as somewhere in between 400-1500w a piece? ... IDK, maybe maybe not. With what I experienced and what he said about it, probably good enough to get what is needed from them once the gain is turned up enough. I say, give'm more watts if you have the watts available, but if you don't, they will still KICK YOUR BUTT
Can I run my Aura shakers with my HoverEZe?
Yes, just as you can run Buttkickers or any other TR device with HoverEze. As with BKs or any other TR device, they will need to be tuned to work their best with the HoverEZe (phase, levels, etc)
Should I do VNF (Very Near Field) subs behind the seating or HoverEZe?
Both have their place and can be awesome. As far as RAW and AMAZING TR power goes at all frequencies, and especially the single digits, HoverEZe will slaughter VNF subs. That said, VNF subs can be amazing as well in their own way (I ran them for years before I went with a HeZeBack, and still run one in addition). While the VNF is not directly coupled to the seat (even if the driver of the sub or MBM (Mid Bass Module) is within a 1/2” or so of the seatback’s outer surface (which you will want, for to be most effective)), it’s probably more comparable to the HeZeBack or BossBack (although not as effective IMO) vs the normal config style of HoverEZe under the seating. Still great though and has its place, especially if one can not run a HeZeBack.
Should subs that are placed behind the seating (VNF (Very Near Field)) be flattened out for SPL / FR for the best tactile response?
The answer just depends, but in general, if possible, for TR purposes, it will probably be best to have it measure flat, from a close mic reading anyway (~1” away from middle of driver cone for example), not from a reading at the MLP (Main Listening Position), where the room will start coming into play. An more in-depth post on this can be found
HERE and
HERE
Not quite as frequently asked, but important questions that should at least be addressed and included IMO
What TR devices are considered to be the best in order?
Opinions will vary I’m sure, but for me, I’d say they all have their pros and cons and can deliver the goods in their own way. A lot of times, multiple different TR devices can be combined to work super well together, bringing the best of what all have to offer. Many of us do exactly this. But, from what I’ve experienced from using a lot of different TR devices over the years, here is the order that I would rank them, and what I’d go for first.
1. HoverEZe (Cone Down, Cone Up, or Dual Opposed).
2. HoverEZeSeatBack (some sort of sealed version). If not this, then a VNF sub positioned as close as possible with driver firing directly into seatback to help with mid bass TR to the chest cavity and overall slam to the core area of the body).
3. Buttkicker LFEs (mounted to the seating wherever you can get them, but rear of seating or seatback being the best).
4. Crowson MAs (if you don’t have a HoverEZe). Probably #1 on the list for single digit TR if one doesn’t run a HoverEZe.
5. Original BOSS (open baffle) - If not running HoverEze (which is way better for full band across the band TR), some may argue that it needs to be in the number one position, above MAs and BKs.
6. Although I’ve never experienced Aura's or MQB-1 shakers, I’m sure they would fall somewhere in this area and be great in their own way as well.
What seating is the best for HoverEZe or TR in general?
This one may be highly subjective for what feels best, as seating can have a HUGE impact on the way the TR actually feels and transfers vibration and shake into the body. But form a performance standpoint, usually the lighter the better, as well as harder and / or less padding and springs. One may have to compromise for the best combo of comfort, size, TR performance, and overall feel. Seats range from large couches and sectionals, to single HT style seats, all the way to DIY seats that some members have started making for themselves to try to get around some of the limitations that traditional seats can have when it comes to mounting TR devices etc and getting the most feel possible from them.
How important are Baseline Curves and BEQ for HoverEZe?
In my opinion, BOTH are VERY VERY VERY important! Curves can bring out the absolute best in your HoverEZe across the frequency range that you want to run it in, as well as allow you to also tailor what feels best in those frequencies ranges to best suit your personal preferences (that may be strongly influenced by the variables that we all have to work with, like seating type, HoverEZe type, levels that we like from our TR, etc, for movies and music). Also, BEQ (BassEQ) for movies is just as important IMO (once you have your baseline curves setup for your HoverEZe), to make them full band, restoring the filtered frequencies (usually under 30hz on a LOT of movies), making them more like the native five star full band movies like “The Incredible Hulk” for example, that are strong all the way down to 1hz. The combo of the two will allow one to get the very best experience that HoverEZe has to offer on movie soundtracks.
Full Range HeZe Tuning Learn how to get the most full band feel out of your HeZe setup.
How much TR do you really need and / or how much is too much?
Well, this obviously will vary (and maybe by A LOT) from one individual to another. On AVS forum, the range basically goes from 0 to 100 LOL. Some guys will go as far as not wanting any TR at all and think that those that want even a little bit of it are nuts, all the way to some of us that seem like we can NEVER get enough, to of course, those that can land anywhere in-between the two extremes. Basically, it all just comes down to personal preference. There are so many amazing ways TR can be had these days, with a little research and effort to try some (or all) of the ways of getting it, we can find how much we desire and in what ways and frequencies.
Have you guys lost your minds and gone completely mad with TR in this thread?
Some of us may have entered into that territory a long time ago
…..and continue to get further and further into crazyland, always pushing the boundaries for more and / or better feeling TR. That is a big part of what this thread is all about (for a few of us anyway), but hopefully there can be something for everyone, to achieve what they are after and further their knowledge of all things TR
TR Curves - Gear & Settings used by various users from the thread:
Thanks for the great idea m0j0!! Like he said, this can be a great reference for each of us to be able to compare what others are using and would also be a great resource for newer folks who are just getting things figured out with their own systems. Anyone who wants to contribute, just make a post and I’ll link to it. That way if you make changes, add gear or whatever, you can keep it up to date.
Click on the links below for each members name to take you to their post of TR equipment and settings:
Luis Gabriel Gerena's TR Gear and Settings
Kevnmin's TR Gear and Settings
m0j0's TR Gear and Settings
Magly's TR Gear and Settings
Nalleh's TR Gear and Settings
SBuger's TR Gear and Settings
Also, here is a link to each member's
Total Gain Structure
Aaron's TR Curves - Awesome post for 6 to 24/oct TR Curves to use on your TR devices, plus amp roll fixes etc from our BEQ and Curve Ninja Aaron!!
Increase Single Digit TR - Want even more Single Digit TR? Well, here you go (Thank you Nalleh!!). He has put together some Low Shelf biquads that you can copy and paste into a filter spot of your miniDSP, to increase single digit performance.
TR Journey / Story from various members of the thread:
Read the Journeys / Stories of some of our favorite TR junkies from the thread. Learn where they got their start and where they are now. Create a post of your stories guys, with pics, vids and whatever else you want to include and I'll put a link to it down below: (Please let me know if you posted yours and I didnt get a link to it!)
m0j0’s TR Journey / Story
Nalleh’s TR Journey / Story
SBuger’s TR Journey / Story
Useful Links - Tape and Tubes for HoverEZe, BK Mods, Drivers, etc:
Signal/Tuning, etc
Why we want a flat unaltered signal to our TR devices and how do we get it (Thanks Nalleh!):
Why
How
Understanding and Applying Negative Delay
Guide to setting up 2 miniDSP 2x4HD's for all your subs and TR gear (thanks DesertDog!!)
Measure the Signal from the miniDSP 2x4HD with REW (thanks 3ll3d00d!!)
Re-Lubing Buttkickers:
White Lithium Grease
Silicone Grease
Nalleh's BK LFE How-to Re-Lubing Guide
Buttkicker LFE Mods:
m0j0’s BBKs (Bottomless Buttkickers)
m0j0's Red Rider Rubber Bands
Buttkicker Soundproofing:
SOOMMJ 20mm Soundproof Padding that helps cut noise on the BK LFEs
Nalleh’s DIY Solution
Nalleh's complete parts list for external air control for Tubes of Hover
More Valve Extenders
DesertDog's Awesome Air Extension Solution
More parts (courtesy of Longeze)
Isolators and Springs:
Springs (that m0j0 uses)
Pressure-less Tennis Balls
Hudson 2.5” Hi-Fi Isolators
Drivers for HoverEZe:
A list of various drivers (with specs etc) for HoverEZe
Tubes for HoverEZe that many of us use
Goodyear Heavy: (Smaller sized)
Steerling (16" explosion proof - smaller than Goodyear)
BELL Standard (Smaller sized but still really FAT vs the Goodyears ...similar to Maxxis Fats size when aired up more)
Lineament (16" x 3" w/ bent valve stem)
Maxxis FAT
VEE Tire FAT (20” x 4”)
Mongoose FAT
MONSTER (The ones m0j0 used at one point)
Other Fat Tubes that Nalleh Found
Yet even more FAT tubes (16" and up)
Double Sided Tape for Tubes of Hover:
Tesa
XFasten Extra Sticky
Nano Gel
Drivers / Devices and their Rankings:
Drivers & TR Device Rankings (Spreadsheet from Aaron)
** Please let me know if anyone wants me to add more to the list. That's all I could think of and/or could find for now. I'm sure there is more great stuff that would be very helpful to have a link!!
Sub Positioning and TR Devices Overview:
Ok, so I wanted to share some of my thoughts and impressions on what I like most (strengths etc) about each of the different TR components that I run in my system and am familiar with. There are TR components that I’ve never tried but have heard very good things about, like the Auras and Clarks, but only have experience with the BK LFEs, Crowson MAs and HoverEZe And of course, the VNF, NF and FF Subs.
All working together as one, pulling from each of their strengths, is where the real magic is at. They can all be great on their own when set up well, but combing can give a great synergy effect for some amazing feeling TR for a "best of all worlds kind of thing". Of course, like anything else, they need to be optimized to work together to get the most out of them all and feel right, like positioning, timing, phase, levels and so on.
So with that said, I’ll list what I like best about each of them and will show some photos for each as a visual example as well (a lot of them will be from my setup since I have a bunch of pics that are easy for me to get to, but I'll include some from others as well (I'll include their name above their photos). I'll start with the subs first, then move on to the main TR gear. Just to be clear, these are just my opinions and what I’ve found messing with them all in a couple differ setups over the years.. By no means do I claim to know it all! I feel like I never stop learning in this awesome hobby!! So, YMMV depending on the variables you have to work with, but I’m betting a lot of this will apply to you and your rig more often than not.
** More pics and updated additions coming soon ...
SUBS & POSITIONING:
The Far Field sub (FF):
The FF sub gives the least amount of TR but almost a must IMO to get the best full sound, as well as that full bass feel with weight (and pressure as well in the right room).
Example of a FF 18” sealed sub sub up front behind the screen:
The Near Field sub (NF):
The NF sub is not to be confused with the Very Near Field sub (VNF ...I’ll talk about that next). I feel that the NF sub is kind of a combo of the FF sub and VNF sub. It gives some real nice TR, more than the FF sub, but still not nearly as much as the VNF sub. But, it still sounds more like the FF sub with that weight and fuller sound, usually with extra TR, which is nice!
Example of a NF 18” sealed sub on the left side wall (plus a CantiLevered BK LFE and VNF behind the seat:
The Very Near Field sub (VNF):
The VNF sub (at least by my definition) is the driver cone at least about 3” or closer to your seatback. The closer the better. With every inch farther away, you lose TR and that overall slam feel from it fast. The main issue (at least in my findings), is that the Bass sound can sound a lot thinner and not nearly as full compared to other subs farther away in room. Also, it has less weight and pressure as well, even if the VNF sub has a real similar looking FR to the NF and FF sub. But, where it shines and what its true purpose is, is bringing on the FEEL. And not not just the shake/TR feel, but that aggressive feeling bass that you can feel within your body as well from the pressure (mostly from Particle Velocity). MBMs (Mid Bass Modules) can work great placed VNF too, for greater chest punch and TR within the chest cavity (I've included a pic of an MBM stacked behind the MLP seat, chest high, in a pic down below (7 pics down) from my previous TR setup down in the living room)
Examples of VNF 18” sealed subs with drivers facing into each seatback:
This shot shows a little CantiLevered BK LFEs and one of the 12" JBLs in the Subwoofer Riser I was running at the time as well:
Example of Nalleh’s Killer VNF array (that include down firing SLAPS) behind his seating:
The combo of just the subs:
(VNF + NF + FF) or (VNF + FF) or (VNF + NF) or (NF + FF) are all good and can work well. Of course I’m biased and think the first one (VNF + NF + FF) is the best if one can make it happen But, I understand that it’s not practical in most rooms and setups.
Examples of VNF + NF
Example of FF + NF + VNF subs (as well as a VNF Mid Bass Module stacked chest high behind the middle MLP seat) in my previous setup downstairs. This setup has a lot more space than my current dedicated room and is a lot easier to show all sub positions:
With the combo (IME) you can achieve an amazing and seamless blend of great sounding, full feeling bass with nice weight and pressure, plus that awesome Tactile and aggressive feel to go with it. This alone can be pretty amazing, especially if on a suspended floor. Plus, the amount of TR and feel, fullness of sound, weight and pressure (if in a nice sized room for pressure) can be tailored to one’s preferences by adjusting the levels etc of the VNF, NF and FF in relation to one another. Easier said than done? Maybe, but is not that bad once you start messing with it all and it gets easier once you get a little experience under your belt just from messing with it all.
Ok, with that as the bread and butter (or backbone of your system's bass), on to the real fun stuff to add the icing and really bring it home for even better feeling TR and perception of that big awesome feeling powerful Bass.
TR DEVICES:
HoverEZe:
What can I say about HoverEZe, this thing is amazing and can dish out some SERIOUS Single Digit TR Madness!!! IMO, nothing can beat it in this area ATM. It can just wobble and shake you silly in the singles if you want it to with some good settings, AND it can do it with ease. For me (and a lot of others), it's been a total game changer into the single digit TR world (especially with BEQ). HUUUUUGE upgrade to the original open baffle BOSS and is VERY worth adding tubes of hover if one is already running the original BOSS. It's fantastic across the board as well. I love mine ran full range with the tubes of hover addition with a rising house curve on it. Also, the HoverEZe can bring a pretty significant amount of SPL, in addition to your subs. In some cases, or at least in mine in a small room, with 3x 18" drivers and 6x JBL 12" drivers, they give me all the SPL I need (without my other normal subs) all the way down deep into the single digits (basically flat with a bit of a rising house curve down to 5hz), giving great sounding full bass, kind of like the combo of FF+NF+VNF that I described up above. Thanks so much, Longeze, for the HoverEZe!!!
** The HoverEZe can be ran under the seating, and/or as HoverEZeCantiLevered behind the seating, or even as a HoverEZeSeatBack
Examples of my MegaHoverEZe (HoverEZe + HoverEZeCantiLevered):
Example of Magly’s MegaHoverEZe:
Example of m0j0’s SuperMegaHoverEZe with BK MMAs on the outside edges (Named the Death Star, I LOVE that name!!):
Example of DesertDogs HoverEZeSac + VNF’s (with SLAPS like Nalleh's):
Example of Tvuong’s:
Example of subacabra's CantiLevered HoverEZe with those awesome new Stereo Integrity Drivers behind the seating:
HoverEZBack (HeZeBack if sealed, or BossBack if not sealed):
The driver in the seatback is awesome as well!!! With a driver attached to your seatback, this thing can pound and bring amazing detail, TR, and chest punch. It's similar to the VNF sub, and maybe even better in some ways. It can be ran as an open baffle version or a sealed version for a different effect and SPL, as well as lower TR in hz & FR capability. One can still run VNF subs in addition (Nalleh does, for example, in his killer TR rig), but having enough room may become an issue for some folks without some planning and creative positioning, if you run other TR gear behind the seating that takes up space. Also, getting the VNF super close to your seatback will probably suffer a little as well, since the JBL driver (or whatever driver you choose) is attached to your seatback. Still, I'm sure it will add PV, SPL, and TR if you are looking for even more. In my setup, it replaced the VNF subs (the 18's were converted to CantiLevered HoverEZe duty instead). Thanks, LastButNotLeast!! I believe you were the first to try out and implement a driver in your seatback!!!
Example:
MegaBack (MB):
You can also run a Buttkicker LFE on the seatback (referred to as a MBK) as well, in addition to the JBL driver on the seatback. This thing can pound and is a lethal combo to driver with BOTH attached to the seatback!!
Examples (JBL 12” Driver + Buttkicker LFE):
Strapped to the seatbacks and ready to be attached to my seats:
Buttkickers LFE (BK LFE):
Oh man, these things in their wheelhouse of power region (that 12-30hz area), especially when multiples of them are ran together, are just unbeatable for raw brutality that can shake your fillings loose. Nothing can match them in this area IMO!! Added to the mix, they can take your already excellent TR system up a few notches or more and give an even better over the top awesome feeling. I NEVER want to be without these in my system, no matter whatever else I’m running!!
** BK LFEs can be mounted CantiLevered behind the seating, under the seating, or to the seatback itself. A combo of mountings locations can be pretty lethal feeling.
Example of Nalleh’s CantiLevered BK LFEs mounted to the back of the seat (Plus VNFs + 18" CantiLevered HoverEZe):
Example of BK LFEs mounted CantiLevered on the seat behind the armrests with some pretty good extension for TR power:
Example of BK LFEs mounted to the inner seat frame before I moved them to Cantilevered position. You can also see the VNF driver up super close and pointed ino the seat, along with a JBL 12" driver in the Subwoofer Riser that I was running at the time:
Example of BK LFEs mounted to seatbacks as MBKs:
Crowson Motion Actuators (MA):
These things are just amazing as well. When it comes to singles digit TR, these things are awesome, only second to HoverEZe, and are amazing across the range. So I run these in the mix as well and they really add extra Pizzazz and awesomeness to the TR
Example of Crowson MAs on top of a Subwoofer Riser (with VNF & NF subs in position):
Mega Motion Actuators (MMA):
These are still new, but a few members are making their own Mega Motion Actuators by using BK LFEs or a sub driver. Early impressions have been great so far!!! Thanks, Aaron, for coming up with this concept and designing the first one!!!
Example of Aaron's MMA first run Prototype: Link to his first post about it
HERE
Example of BK MMA’s on the outside edges of m0j0’s SuperMegaHoverEZe:
So, what do you get when you combine all this stuff together? Massive Overkill???? Hahahaha, yeah probably, but IMO/E, when all dialed in together and fine tuned, you get a no compromise, check all the boxes, best of all worlds TR and Bass Super System that can ROCK YOUR WORLD!!!!
A few shots of my TR rig with all gear combined:
And a shot of Nalleh’s insane TR Rig (the CantiLevered BK LFE’s and drivers on the seats are not even shown here). OH MY!!!:
And one more, a shot of Magly's insane TR rig as well (and sporting those Bottomless BK LFEs mounted CantiLevered in there too
YES, Me, Nalleh, and Magly have went a bit NUTZ with the TR in our rigs, but hey, this is AVSforum and is what sometimes happens around here right!!!?? LOL I can say with certainty though, that we, as well as the others who have done similar with their setups in this thread, DO ENJOY THE HELL OUT OF IT!!!
Having a very capable full band TR rig can make watching movies a total blast and give an EPIC EXPERIENCE on the ones with really good bass tracks, which seems to be a lot these days with BEQ!!!
But I know running all that gear together is probably impractical for most and may not even be desired if it was. It is most definitely taking things to the extreme. I just used my system (and the others) as an example to show what is possible if desired. It’s probably not for everyone (or may not be their cup of tea I should say) . Even though I LOVE it, it may be way too over the top for some and not enjoyable.
The cool thing is, any small combo of the TR components and methods I described up above can make an amazing feeling super capable TR and Bass system. You can pretty much put together whatever you want, you just have to decide how much TR and bass you really need and want. I will say this though, IMO it’s almost impossible to have too much ULF single digit TR firepower (at least before the HoverEZe came along). With a MegaHoverEZe, when really pushed, it can come close or actually can be too much sometimes, if not careful LOL), especially with all the full band movie tracks now with BEQ!!! I know I keep mentioning BEQ a lot, but it really is THAT good and is such a game changer for movie watching if you love ULF TR and have a capable system to deliver it.
Alright, that’s about it for now. If anyone has anything they want to add to that with their impressions and/or other components as well, or even a different view on it all, feel free.
Movie Clip “Time Stamps” - For some Killer BASS and TR scenes:
I think it might be awesome to start compiling a list of movie clips with Time Stamps that have some of the
COOLEST and/or most
INSANE and/or just
FUN, or even
UNIQUE Bass and Tactile Response you’ve experienced. Thanks for the fantastic idea Tony (tvuong)!! Like he said, it can be a great place to give readers an idea of what we are talking about when we are discussing all this TR and Bass stuff, as well as a go-to place for some of the best Bass and TR clips if you’re looking for some (for demo or otherwise
And whatever the bass frequency range is cool by me. ULF, LF, MB or a Time Stamp with a combo of all. Just whatever scenes make you go OMG that was so insane and cool!!!!
With or without BEQ, but I have a feeling the majority will be with BEQ, as it just maximizes the bass in these movies to Full Band like the Native 5 - Star Monsters.
Anyone who is game and wants to contribute, make a post (or posts as you come across these awesome clips over time) with the Timestamps for each movie and descriptions/impressions of them, or whatever info you want to include. I will do my best to keep this post updated with the list of Timestamps for each movie, along with a link to your original post for the Timestamp(s), the lowdown and details on it, as well as the PVA and Heatmap for a visual (if it's available from the BEQ thread). Please include this in your post if you will.
Cool, bring on the best BASS and TR movie Time Stamps you know of
Alita: Battle Angle (UHD Atmos) -
Link to Time Stamp Details, Impressions, PVA & Heatmap Graphs
10:45 – 11:30 - Alita saves dog from Giant Bot in the street.
18:05 – 20:00 – Rollerball.
21:15 – 31:30 - Street fight.
50:15 – 52:30 – Underwater Ship.
1:04:50 – 1:10:00 – The Underground Battle.
1:48:18 – 1:49:10 – Last Battle with the Big Dude.
Another Life (Netflix Streaming - UHD Atmos) -
1:40 to 2:38 – Intro
36:21 to 37:27 Confrontation on the Ship (ULF Ongoing Extravaganza!)
Aquaman (UHD Atmos) -
6:11 – Explosion of House Sidewall
6:19 – MidBass Drop That Hits the Chest
7:12 – Dude Get Jacked with Spear!
*** LOTS of Highlight/Detail Time Stamps within each of these TS's below (check main post in Link)
9:10 to 11:35 – The Aquarium
47:00 to 50:10 - First Battle Underwater in Old Sunken Ship
1:08:24 to 1:08:44 – Inside the Whale
1:50:18 to 1:51:38 - Fighting the Sea Monster!
Atomic Blond (UHD DTX:X) -
11:07 – Two in One
1:10:09 to 1:10:12 Bass Drop (can really be felt in the chest cavity)
1:10:55 to 1:18:55 Fight Scene in the Stairwell & Room
1:18:55 to 1:19:15 In the Car (check the post for lots of TS highlights and details within this TS)
Edge of Tomorrow (UHD Atmos) -
** Note: This one is in the same post as Moonfall, so just scroll down past that for EOT.
027:00 to 30:00’ish - 2nd Repeat Into Battle
1:29:00 to 1:43:00ish - Ending Battles
Hobbs & Shaw (UHD Atmos) -
Opening Scene – Stealing the Virus.
0:32:00 - Kidnapping Hattie.
0:34:00 - Elevator Lands!
0:38:50 - Under The Trailer.
0:57:10 - Flamethrower!
1:15:20 - Flamethrower 2
1:18 and onwards >> - Bomb Goes Off !
1:22:10>50 - Building Collapses !!!!!!!
1:47:55 - Helicopter Fishing.
1:50:50 - Nitrous Hit.
1:52:00 - Landmines.
IT (UHD Atmos) -
19:30 – 20:30 Visions at the Meat House
27:40-28:18 Under the Library
35:00 – 35:30 Mean Teen in the Tunnel
49:00 – 50:20 In front of the Old House
1:19:36 – 1:19:53 Upstairs in the Old House
1:49:10 – 1:49:20 MEGA ULF Wobble within the Tunnel Scene
1:48:41 – 1:50:20 Underground Tunnel Scene
John Wick (UHD Atmos) -
24:00 - 25:00 - Concrete Sledgehammer
46:00 – 54:40 – Famous Club Fighting/Shooting
John Wick 2 (UHD Atmos) -
57:50 – 1:01:45 – Tunnel Shootout.
John Wick 3 (UHD Atmos) -
1:38:05 – 1:53:40 – Last Big Shootout and Fight.
1:44:07 – Two Shots Fired Upward
Live Free or Die Hard (DTS-MA 5.1) -
11:00 - 17:33 - Apartment Gun Fight.
The Martian (UHD Atmos - Extended) -
0:10:10 – 0:15:30 Wakes Up
1:04:30 – 1:05:10 Explosion I HAB
2:04:30 – 2:06:50 Launch MAV
2:16:60 Blowing the VAL
MIB: International (UHD Atmos) -
40:30 – 44:00 – Street Fight with the Twins
1:03:13 – 1:05:40 – Hover Cycle in the City
1:07:20 – 1:07:55 – The GUN!
1:26:21 – 1:28:00 – Earthquake and More Twins.
Moonfall (UHD Atmos) -
0 to 5:49 - Intro
33’ish minute mark - Water Gurgle
1:01:30 to 1:03:30 - Shuttle Take Off
1:10:47 to 1:11:32 - Here It Comes
1:30:30 to 1:32:30 - The Chase
1:10:00 to ~1:57:00 - The Moon and Its Devastation
** Also of note: there are some timestamps within these timestamps too (listed out in the main post for this)
Mortal Kombat (UHD Atmos) -
00:10 to around 12:00 - The Big fight intro
2:50 to 3:30 - Sub-Zero entering the house
20:36 to 21:30 - Sub-Zero shows up in town
1:13:05 to 1:16:18 - Fight with the 4 armed Giant
1:28:12 to 1:35:41 - Ending Battle with Sub-Zero
Overlord (UHD Atmos) –
Link to Time Stamp Details, Impressions, PVA & Heatmap Graphs.
More Impressions
7 minute mark, soon as you hear the buzzer
Some killer stuff before as well!!! (~1 minute mark & then starts about 5:00 to around 12:00)
Shazam! (UHD Atmos) -
1:39:40 – 1:56:00 – Showdown at the Carnival (20 minutes of Insane Bass and TR)
1:41:01 – 1:42:47 – Monster Confrontation & Slow-Mo Carnival Gun Shot.
Spiderman: Far From Home (UHD Atmos) -
19:30 to 25:00 – The Water Giant
1:17:40 to 1:21:00 – The Illusion
1:31:00 to ~1:48:00 – Ending Battle (check the post for lots of TS highlights and details)
Total Recall (TrueHD 5.1) -
02:00 - Opening scene where he dreams.
28:00 - Arrested at Recall office,
41:00 - First hand-phone call.
50:40 - Busted arriving at the Colony with the face mask.
1.38:20 Breaking free from Coohagens guards.
1:40:30 Starts the chopper.
1:45:00 Overtaken by police.
1:55:00 Bombs go off and the Fall is dropping.
Venom (UHD Atmos) -
53:27 – 58:25 – Street Chase
Wonder Woman (UHD Atmos) -
0:14:00 - First time using the bracelets!
1:14:00 - and on >>
1:20:30 - Sniper at clocktower.
2:04:30 -2:06:00 - Ares final attack on Diana
X-Men: Dark Phoenix (UHD Atmos) -
Intro to 2:30 – Intro
6:46 to 7:32 - Shuttle Launch
9:28 to 10:00 The Exit
10:46 to 49 - Mega Blast Past
14:37 to 15:38 - Jean and the Impact
28:58 to 31:40 – Cerebro (ULF Single Digit Wobble Fest)
38:00 to 1:40:01 – A Ride To The Past (check the post for lots of TS highlights and details within this TS)
43:10 – Jean unleashes on Raven
43:40 Jean Takes Off
1:14:17 to 1:14:37 Part of the Ending Battles
1:23:17 – Train Passing
Also, here is a list of Movies with BEQ that Nalleh put together that contain strong 1hz frequencies
HERE
