Worth adding a 2nd subwoofer? - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 2 Post By sassuki
  • 1 Post By bobknavs
  • 1 Post By Ed Mullen
  • 1 Post By darthray
post #1 of 18 Old 08-05-2019, 01:36 PM - Thread Starter
Quoted: 21 Post(s)
Liked: 4
My setup:
Center: Klipsch 250c
Left/Right: Klipsch 260f
Surrounds: Klipsch 250s
Atmos: Klipsch 140SA
Sub: SVS PC-2000
A/V: Denon x3400h
I have my setup downstairs with room dimensions 23'7"w x 14'4"l x 6'9"h. This is my first home theater setup and I gradually pieced everything together and am considering adding a 2nd subwoofer. I originally tried the HSU VTF-2 Mk5 and the bass was rather weak. I changed over to the SVS PC2000 and the bass sounds great and there's more of that "oomph" feeling I'm looking for but it still feels a bit subdued during lfe moments (such as the famous Jurassic Park moment). I have a concrete floor with tile over it and plaster walls so I know I'm not going to get room shaking sound no matter what but that's not what I'm looking for. I'd just like have a bit more of that oomph feeling with the lfe (although not to the effect it feels like a shotgun blast to the chest).
I have calibrated the speakers, set the crossovers, and tried nearfield positioning the subwoofer. I have a throw rug in front of the speakers (I sit around 10 feet from the speakers). I'm thinking that it's the room size that is the problem. Would a 2nd SVS PC2000 would help with my problem?
Havfan is offline
post #2 of 18 Old 08-05-2019, 04:48 PM
phatfreeza's Avatar
Quoted: 66 Post(s)
Liked: 48
adding a second sub is probably not going to help you out too much in your specific case. Might I suggest reading up on a BOSS platform or maybe get some crowson motion actuators. adding a second sub usually helps even out the bass frequencies unless you colocate them, which in that case will give you roughly 6db more output.
My HT: 7.3.4 Denon x4300h + denon stereo amp, Hsu HB1-MK2(6), HC1-MK2, Pioneer SP-T22A-LR(4), dual Rythmik fv25hp, b1200d, 65" LG OLEDB7A, xbone s, ps4 pro.
Classroom HT: 7.2.2 Onkyo TX-NR747, JBL L5 (LR), HSU HC-1 MK2(C), Pioneer SP-T22A-LR(2), Pioneer SP-C22 (2-Surrounds), svs pb12+/2, svs pc13, Epson Powerlite 99WH
phatfreeza is offline
post #3 of 18 Old 08-05-2019, 05:26 PM
sassuki's Avatar
Quoted: 86 Post(s)
Liked: 194
I love to reference this diagram when talking about subwoofer tactical feel. The type of “oomph” you’re going for may require slightly different approaches. Especially when considering the effect your specific room has on certain frequencies.
Maybe it will help you determine where to focus your LFE efforts.
dpc716 and MRAYB like this.
sassuki is offline
post #4 of 18 Old 08-05-2019, 09:59 PM
bobknavs's Avatar
Quoted: 2198 Post(s)
Liked: 1571
Adding a second PC2000 may improve the uniformity of the bass in the room.
It also increases the potential volume by 6dB. (Not the 3dB you might expect.)
It may be worth a try, even if you won't get a lot of seismics.
darthray likes this.
bobknavs is offline
post #5 of 18 Old 08-07-2019, 09:53 AM
Ed Mullen's Avatar
Quoted: 313 Post(s)
Liked: 744
Are you running the subwoofer level hotter than the initial level match set by Audyssey in the Denon 3400?
If yes - how much gain did you add (either at the subwoofer itself or in the Denon)?
When you listen to action/sci-fi Blu-ray movies, what is the typical master volume setting on the Denon?
mthomas47 likes this.
Ed Mullen
Director - Technology and Customer Service
SVS
"What We Do In Life, Echoes In Eternity"
Ed Mullen is offline
post #6 of 18 Old 08-07-2019, 01:07 PM
dpc716's Avatar
Quoted: 134 Post(s)
Liked: 189
That is quite the diagram. I've never seen anything representing this before. Now I know why I'm not getting any shoulder girdle OOMPH with my HT system, it doesn't go down that low. The 50-100 hz effect on the chest cavity is often mentioned and most easily felt.
dpc716 is offline
post #7 of 18 Old 08-07-2019, 06:09 PM
darthray's Avatar
Quoted: 2137 Post(s)
Liked: 3058
@Havfan
For more in you chest feeling, a second sub will definitely help.
Also you could try this;
III-C: Cascading Crossovers:
For feeling in the chairs, you can add some TT since you have a concrete floor;
Shakers - Simple/Cheap Hookup - Visual Guide
Darth
darthray is offline
post #8 of 18 Old 08-07-2019, 06:25 PM
m0j0's Avatar
Quoted: 509 Post(s)
Liked: 448
You could try a 2nd sub near field, such as behind or next to your seating position. However, as @phatfreeza suggested, you would be wise to look into a BOSS mini riser. They really are amazing in terms of tactile bass at very low cost. Just search for the hideaway theater thread.
m0j0 is offline
post #9 of 18 Old 08-08-2019, 07:19 AM
AVS ***** Member
mthomas47's Avatar
Quoted: 5424 Post(s)
Liked: 10209
Originally Posted by Havfan View Post
My setup:
Sub: SVS PC-2000
A/V: Denon x3400h
Hi,
Ed Mullen asked a couple of important questions which don't seem to have been answered, unless you have communicated privately with him. You do have a fairly large room size, but if you have tried the PC2000 nearfield, that should have helped with respect to both increased SPL and increased tactile response (TR). You are correct that you aren't going to get nearly as much low-bass TR on concrete as you could on a suspended wood floor. But, that doesn't mean you aren't going to get any at all, especially with a nearfield arrangement.
Adding a second PC2000 could definitely be helpful, as would upgrading to an even more powerful subwoofer with lower extension, such as a PC4000. But, before doing either of those things, I think you should return to Ed's questions. How much are you turning up the volume on your subwoofer after the Audyssey calibration?
It is important to understand that the goal of your automated calibration and room EQ process is to make all of the channels in your system, including the subwoofer, play at the same volume level, as measured at the MLP. After the calibration, however, you can increase the volume of the subwoofer as much as you like. The best way to do that is explained in Section II of the Guide linked in my signature. The Cliff Notes at the very beginning of the Guide will give you a quick summary of that process.
At some point of course, as you turn up the subwoofer volume, you will run out of headroom and the sub will stop getting any louder and may also make some unpleasant noises. But, nothing in your post suggests you have gotten to that point yet. So, try turning up the volume in your sub, preferably by using the gain control on the sub itself, and see what happens.
Especially considering your room size, you may very well benefit from adding another sub, or even better, from upgrading to a more powerful model with lower extension. The PC4000 would be a good choice for that. But, you will still have to increase your subwoofer volume (post-calibration) to take advantage of the extra power, whether you have one sub or ten subs, so start by turning up your sub gain and see what you think.
Mike
Edit: The BOSS platform, which was suggested earlier, could also be helpful for low-bass TR. But, start by maximizing what you have to discover what its limitations are.
GUIDE TO SUBWOOFER CALIBRATION AND BASS PREFERENCES
* The Guide linked above is a comprehensive guide to Audio & HT systems, including:
Speaker placements & Room treatments; HT calibration & Room EQ; Room gain; Bass
Preferences; Subwoofer Buyer's Guide: Sealed/ported; ID subs; Subwoofer placement.
mthomas47 is offline
post #10 of 18 Old 08-08-2019, 08:36 AM - Thread Starter
Quoted: 21 Post(s)
Liked: 4
I haven't touched the physical volume level on the sub since the Audyssey set up. During setup it was telling me my sub volume was too loud so I turned it down just enough to proceed. I usually listen to Blu-rays around 62-65 on my Denon.
Havfan is offline
post #11 of 18 Old 08-08-2019, 08:40 AM
HarleyRider's Avatar
Quoted: 143 Post(s)
Liked: 99
My opinion, there is no substitution for cone size if you're looking for that visceral, feel it in your chest impact. I feel you need 15" minimum. Adding a second 12" will help smooth out the bass response throughout the room and increase overall SPL, but still may not give you the SPL at the lower Hz that you can feel, regardless of what the specs say on paper. As an example, I'm using a Dynamo 1100x 12" along with a DefTech SuperCube I 10" up in the front of the room. The DefTech, on paper, is spec'd down to 13Hz. Hogwash. It's not even close. It certainly can't pressurize the room down that low. The bass is good using those two subs together, but I'm still missing that low-end rumble and oomph. So last night I added back my old Velodyne 15" in the back of the room. Rated down to 15Hz on paper, not as low as the DefTech, but no comparison in actual performance. Yep, that's what I was missing. Bigger cones move bigger air.
Pre/Pro: Anthem AVR 60 | 5.2.4 Config: MartinLogan ElectroMotion ESL X FL/FR, ESL C Center, Motion LX16 Surrounds, Motion 4i Atmos | Subs: Velodyne DD-15, Martin Logan Dynamo 1100x | Amplification: Emotiva XPA-3 Gen 1 FL/C/FR, Emotiva A-700 Surrounds and Atmos
Dedicated ARC Genesis Thread
HarleyRider is offline
post #12 of 18 Old 08-09-2019, 08:14 AM
Dave Ol's Avatar
Quoted: 100 Post(s)
Liked: 481
As Mike stated, you should really try bumping up the sub volume. Many of us run our subs 5-10 db hot. That is, 5-10 db higher than the rest of your speakers (or at least the mains). If you have an SPL meter, use the pink noise on your AVR and measure your sub volume as you raise it to the desired db level you want over your mains. There may even be an app that you can download that turns your phone into an SPL meter. It makes a tremendous difference, especially at low listening levels. For myself, I run my PSA TV36 ipal (dual 18 inch drivers) around 7 db hot. Try this first and see what you think.
Dave Ol is offline
post #13 of 18 Old 08-09-2019, 10:20 AM
Ed Mullen's Avatar
Quoted: 313 Post(s)
Liked: 744
Since the subwoofer is still level matched per Audyssey and you are listening at 17-20 dB below reference level (which is 82 dB on your master volume) - you have some dynamic headroom left in the subwoofer.
Increase the subwoofer volume in the AVR under the manual set-up section. Best practices is 2-4 dB hot - but you can add more unless the subwoofer starts to complain on demanding passages.
Ed Mullen
SVS
post #14 of 18 Old 08-09-2019, 04:44 PM - Thread Starter
Quoted: 21 Post(s)
Liked: 4
Thanks for the help. I'm new to home theater so I was concerned about damaging my speakers (or worse my hearing) by playing it too loud. I didn't know if the master volume on the denon corresponded with the decibel level or was just an arbitrary number so I just played it at what's comfortable for me (although it still gets pretty loud at 65). I'll play around with the sub settings this weekend. Should I let the physical volume dial on my sub alone and only make adjustments only via my a/v receiver?
Havfan is offline
post #15 of 18 Old 08-10-2019, 06:59 AM
Ed Mullen's Avatar
Quoted: 313 Post(s)
Liked: 744
With Audyssey equipped AVRs, I generally recommend adding gain from the subwoofer channel level under the main set-up menu.
There are interrelated Audyssey functions like Dynamic EQ, MultEQ XT32 Reference, Dynamic Volume (if enabled) and also internal gain stages which are affected with the subwoofer channel level is changed within the AVR. In my experience, adjusting the sub level within the AVR results in better sound quality and integration than adding gain external to Audyssey at the subwoofer.
I do still recommend setting the gain at the subwoofer as high as possible while still staying within the green subwoofer SPL window during the XT32 subwoofer level match step. This will typically be 77-78 dB, and will result in a slightly more negative subwoofer trim value after Audyssey set-up is finished.
Ed Mullen
SVS
post #16 of 18 Old 08-10-2019, 03:06 PM
Rysa4's Avatar
Quoted: 34 Post(s)
Liked: 114
Thank you. Succinct. Straightforward. Practical. And very useful.
Rysa4 is offline
post #17 of 18 Old 08-16-2019, 10:50 AM - Thread Starter
Quoted: 21 Post(s)
Liked: 4
Thanks for all the help. I had the subwoofer gain at the max Audyssey allowed during setup so I didn't touch the knob. Audyssey set the subwoofer level at -3.5 db. I upped it 3.5 db and that made a difference. My Denon allowed me to boost the subwoofer level either under manual setup >>levels or audio >> subwoofer level adjust. Does it matter which one I use? I used the subwoofer level adjust setting.
So far I listened to the atmos tracks on Captain Marvel and Netflix's Wu Assassins. I did notice the difference with Captain Marvel but I know Disney's atmos tracks can sometimes be weak. I noticed the difference a lot more on Wu Assassins and could really feel the bass during many of the scenes. I may end up tweaking it a bit but what you suggested did solve my problem. I only have one row of seating (a couch) and the bass seems consistent across all seats so I don't think a 2nd sub would do anything for me. I didn't notice any issues with localization either even when I turned it up past my normal listening levels.
Havfan is offline
post #18 of 18 Old 08-16-2019, 07:05 PM
Viper5121's Avatar
Quoted: 50 Post(s)
Liked: 37
Adding a second PC2000 would absolutely be your best bet for the money. It would more than double overall performance since that’s just how it works with two identical subs. Probably like 2.5 times your current performance.
My Home Theater System:
* 2 Klipsch Cornwall III speakers + 1 Klipsch Heresy III speaker
* 1 Paradigm Defiance X15 subwoofer (adding one more X15 soon)
* 1 Anthem AVM 60 Preamplifier/Processor + 1 Monoprice Monolith 5
* 1 LG C8 65" OLED 4K HDR Dolby Atmos Smart TV
Viper5121 is offline
