just throwin this out there... - AVS Forum | Home Theater Discussions And Reviews
 8Likes
  • 4 Post By mthomas47
  • 4 Post By Mark Seaton
post #1 of 10 Old 08-12-2019, 10:00 AM - Thread Starter
lefthandluke's Avatar
Quoted: 170 Post(s)
Liked: 324
long ago when I performed the "sub crawl" I found one of the primo locations to be where I now have them placed. when I run audyssey, I set the gain on both subs to 80-81 db individually, then run both as one from a single sub out. this sets the subs gain knobs at 9 o'clock. audyssey on my Marantz av8801 then sets subs to -12, which I bump 6db so i'm at -6. all sounds great!!
as most here are aware, Mike Thomas has written an excellent guide to subwoofer setup. he states two things that have me wondering if my setup could be improved even more...
1 when audyssey sets my subs to -12, they actually could be even lower (-16 for example, which in this case a 6db bump would only be actually taking them to -10)
2 Mike and others agree that the gain on the sub amp should be set higher to maximize the subs potential...setting so that audyssey sets subs at -9 to -11.5 then to bump 6db to -3 to -5.5 or so.
so then, contrary to my prior thinking, would it be advantageous to move the subs to a LESS primo spot so points 1 and 2 are addressed? my room is 24x14x8 and is NOT sealed.
does this make any sense or should I quit thinkin so much
at the zenith of his nadir...
lefthandluke is offline
post #2 of 10 Old 08-12-2019, 10:39 AM
ratbuddy's Avatar
Quoted: 776 Post(s)
Liked: 1035
Audyssey giving -12 is no good, it's true. I'd just lower the gain on the subs until you land on at least -11.5, then continue as you have been. You don't need to move the subs to accomplish that
ratbuddy is online now
post #3 of 10 Old 08-12-2019, 10:42 AM
AVS ***** Member
mthomas47's Avatar
Quoted: 5429 Post(s)
Liked: 10225
Hi Luke,
Thanks for the compliment! My first thought was whether it was thinking or drinking so much?
I assume from what you said that you have the two subs stacked. Is that correct? If so, I am curious whether you have also tried separating the subwoofers, perhaps on opposing walls? If you like your current subwoofer location, with the subs mutually-coupling, there is probably nothing wrong with the procedure you have described. Do you have REW, and have you measured your frequency response with both subs together versus separated? I'm guessing not, but I thought I would ask anyway.
As far as increasing the gain control on the subs, the advantage in using the subwoofer gain to produce more of the voltage going to the subs really only comes in if you are pushing your subs a little harder than you are. It sounds to me as if you have abundant headroom available to you.
As far as whether it is okay to be at -12, when you might really need to be at -16 if the trim settings went that low, that is sort of a numbers game in this case. I would always prefer to start at -11.5, so that I know where I am with respect to how low the trim levels can go, but I don't know whether it needs to be an ironclad rule. Since you are already at 9:00 on the gain dials, I'm not sure that you can lower the gain enough to get to -11.5 in trim level anyway, with the way that your subs are currently wired.
Separating the two subs into separate sub outs, and setting them to a little less than 80db individually, might allow you to reach -11.5 in trim without having to go much lower than 9:00 in gain, but I'm not sure. You could try it if you are really curious.
As far as adding +6db to your trim is concerned, I think that the +6 would still be a 6db increase in either case, regardless of your starting point. You could always use your SPL meter, if you have one, to do a before-and-after measurement of the subs, with the same content. That would tell you whether your trim adjustment were actually netting you 6db or not. But again, I'm not really sure it would matter. After all, I assume you are just adding the amount of subwoofer boost that sounds appropriate to you. So, does it really matter whether you are adding 3db, or 6db, or some other number? I could see it mattering if you were concerned about sufficient headroom, but that clearly isn't an issue in this case.
What I would not do is to move both of the subs to a less suitable spot in the room, simply to hit -11.5 trim levels. I would definitely experiment to see if separating the subs, by moving one of them to another good location, gave me better overall sound (or measurements). And, since you have dual sub outs in your AVR, I might try recalibrating the subs with separate sub outs, just to see what that would do to my gain/trim levels, with them where they are now. But, if the subs are in the best spot in the room, and you like running them stacked, then I wouldn't change that part for the reasons you describe.
I hope this helps!
Mike
GUIDE TO SUBWOOFER CALIBRATION AND BASS PREFERENCES
* The Guide linked above is a comprehensive guide to Audio & HT systems, including:
Speaker placements & Room treatments; HT calibration & Room EQ; Room gain; Bass
Preferences; Subwoofer Buyer's Guide: Sealed/ported; ID subs; Subwoofer placement.
mthomas47 is online now
post #4 of 10 Old 08-12-2019, 10:46 AM
kelly.mcaloney's Avatar
Quoted: 225 Post(s)
Liked: 277
C
kelly.mcaloney is offline
post #5 of 10 Old 08-12-2019, 11:05 AM - Thread Starter
Quoted: 170 Post(s)
Liked: 324
yes that's true...but doing so I would leave the subs gain at about 8 o'clock which brings point 2 into play even more so...
post #6 of 10 Old 08-12-2019, 11:22 AM - Thread Starter
Quoted: 170 Post(s)
Liked: 324
Mike
thanks Mike. subs aren't stacked but they are on the same wall approx. 4ft apart and 3-4 ft from side walls. I remember Mark Seaton recommending if both subs are located on the same wall to run both as one sub from a single sub out...
post #7 of 10 Old 08-12-2019, 12:12 PM
imureh's Avatar
Quoted: 2753 Post(s)
Liked: 3348
Slight correction to the Mark Seaton statement. Its not about the being on the same wall but more about being equidistant from the MLP in order to what he says. I have mine set up that way. Now making then equidistant may indeed result them being on the same wall.
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is online now
post #8 of 10 Old 08-12-2019, 02:04 PM
Mark Seaton's Avatar
Quoted: 909 Post(s)
Liked: 2541
"Same wall, same signal" is correct 98% of the time if that is the front or rear wall. Most often I suggest routing the same signal to a group of subs if they are at the similar front to back distance in the room for a mostly rectangular room. This would include 2 subs symmetrically on the side walls. While someone might find a very specific case where some other setting helps with a sub say at the center of the front wall and the corner, I would only make such a change if I could measure a tangible benefit. Unless your seating area is dramatically closer to one side of the room than the other (left-right), it's the placement of the subs vs the length dimension that will matter most so far as delay applied.
I wouldn't worry about the sub gain being set low if the receiver is well into the -dB range. Try setting the subs to 78-80dB initially, and see if you get a number other than -12dB. If you have REW you can use an HDMI connection to check the levels with Audyssey in the loop.
Mark Seaton
Seaton Sound, Inc.
"Make no little plans; they have no magic to stir men's blood..." Daniel H. Burnham
Mark Seaton is offline
post #9 of 10 Old 08-12-2019, 04:48 PM
MIX_MASTER_ICE's Avatar
Quoted: 2639 Post(s)
Liked: 2453
All subwoofer amp gain structure are different. For example, HSU amps don't require as much gain applied, while a Monolith amp will require much more gain on the dial. If you had Audyssey run calibration and it came back with say -10 on the sub, then the gain on the sub is plenty high and the receiver is actually dialing the output back to compensate and blend better with with speakers.
Subs>RBH I-12e, I-12. HSU VTF-15H mk2. Monolith THX 12(x2)/THX 10(x2). XTZ 1X12. SVS PB-1000(x2). Speakers>JBL Studio 270/235c/230/225c, Arena 130/125c. Sony CS3/CS8/CS5. QA 3020i/3090Ci, 2020i/2000c. Monolith Cinema 5bs. Polk RTiA1/CSiA4. Other Audio>Sony MDR-Z7m2, XB900n, MDR-V6, XB700, XB32, XB31, XB22. Sennheiser HD58X, HD4.50, PC37X. SIVGA SV004. HyperX Cloud PS4. TB Stealth300. LG FH6, RK8, RK7, PK5, PH4. HK Onyx Studio4(x2).
MIX_MASTER_ICE is online now
post #10 of 10 Old 08-14-2019, 05:19 PM - Thread Starter
Quoted: 170 Post(s)
Liked: 324
thatsa good point...I remember basshead stating that moving his sub amp gain from 8 o'clock to 9 resulted in a 3db boost...9 to 10 another 3db etc.
I guess what I could do is, for example, set my subs gain at 8 o'clock, get a reading of 75-77db, then audyssey would set my subs at -11.5...from there I could bump the subs gain knobs from 8 to 10, resulting (in theory) in a 6db boost.
what I NEED to do is quit bumpin my gums and take this weekend to measure and apply...
on the other hand, both Mike and Mark say my subs gains are set within acceptable parameters, so maybe I was readin too much into Mikes original statement as i'm not lacking headroom...
