Sub-woofer SVS PB 1000 quiet - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 2 Post By jamiebosco
  • 2 Post By prepa
post #1 of 8 Old 08-14-2019, 02:21 AM - Thread Starter
Liked: 2
Hi All,
Have been reading forum for long time and now posting first time.
Decided to move from soundbar to proper speakers setup so recently I got pair of KEF Q350 speaker and yesterday I received sub SVS PB-1000.
I'm using DENON AVR-X2500H to connect everything.
Sub is connected to no 1 sub-woofer on AVR with RCA cable to LFE conection on sub.
Low pass filter to LFE.
Phase control to 0 degrees.
Gain to between at 12 o’clock
Run Audissey and got some results where speakers were set to large and sub level is set on -6,5 Hz
Manually changed speakers to small
Set crossover to 80hz
LPA to LFE set to 120 Hz - default
Subwoofer mode set to LFE
With all adjustments I'm not getting almost any bass... Can it be faulty unit or I can change some settings ,that I did not find in forum previous discussions, in AVR to make it work.
Sub crawl is impossible to do since lack of space and sub has to be in fixed position near tv so OK I will not get optimal sub sound but I should get at least some of thump from that PB 1000. Room size iz 5.5 x 4.5 meters.
prepa is offline
post #2 of 8 Old 08-14-2019, 02:40 AM
Quoted: 46 Post(s)
You might need a second PB-1000 as you might have some mighty nulls in your frequency response curve if you were to measure it...
Do it all or don't do it at all.
yodog is online now
post #3 of 8 Old 08-14-2019, 03:20 AM
jamiebosco's Avatar
Quoted: 714 Post(s)
Liked: 1711
I would re-run Audyssey with the gain around 2-3 o'clock, aiming for a Subwoofer trim between -10 and -11.5 (not -12) and then manually increase the subwoofer trim to around -6dB in the Speaker Level menu
Make sure Dynamic Volume is OFF, as well as LFC
doni01 and indebtbassfreak like this.
TV: Panasonic P65ST60 AVR: Denon 4311ci Speakers: PSA MTM-210C (Centre), PSA MTM-210 (Left & Right), PSA MT-110 (Surrounds) Subwoofers: Dual Seaton SubMersives
jamiebosco is offline
post #4 of 8 Old 08-14-2019, 03:28 AM
wadennis's Avatar
Quoted: 105 Post(s)
Originally Posted by prepa View Post
Hi All,
I have a Denon 4300 & recently added a pb1000. This was the instructions from SVS. It made a huge difference.
Lets start with the subwoofer:
Set the Volume to 2 pm.
Set the Low Pass Filter to LFE (all the way to the right)
Set the Phase to 0 (all the way to the left)
On the Receiver please go into manual settings and make the following setting changes as needed:
Set all speakers to small.
Set the level of your subwoofer to -5 dB
Set the crossover for all your speakers to 80 Hz
Let the LPF to LFE and LFE to 120 Hz (in the bass menu)
In the audio menu, locate Auddyssey and make sure Dynamic EQ is on with a Reference level of 0 and Dynamic Volume is off.
wadennis is offline
post #5 of 8 Old 08-15-2019, 04:53 AM
Ed Mullen's Avatar
Quoted: 316 Post(s)
Liked: 748
The bass management settings in the AVR 2500 look fine after your changes.
If you are getting virtually no bass - check the upstream sources to ensure they are sending the AVR-2500 a bitstream DD 5.1 signal. Sometimes the default audio output configurations of the upstream sources are set to 2-channel PCM (to work with a direct connection to the HDTV).
If you want to make sure the PB-1000 itself if operating normally, connect your smart phone directly to the subwoofer with a headphone mini-jack to RCA adapter. Turn-up the smart phone volume all the way, set the PB-1000 low pass to 100 Hz (temporarily for this test) and the gain to 12 o'clock and then play a bassy song. The subwoofer should kick out some pretty strong bass even at 12 o'clock and by 2 o'clock should be quite loud.
If the subwoofer passes this test and kicks out some decent bass, we can continue to focus on the upstream sources.
Ed Mullen
Director - Technology and Customer Service
SVS
"What We Do In Life, Echoes In Eternity"
Ed Mullen is offline
post #6 of 8 Old 08-15-2019, 11:56 AM - Thread Starter
Liked: 2
Followed your instructions and now I can hear it as it should be. It seems that Dynamic volume in Auddyssey setup was creating low sound problem.
Upped volume to 2 and level to -5 and now windows are rattling :-) Tested with Kraftwerk and Blade Runner 2049 and it is night and day difference.
jamiebosco and wadennis like this.
prepa is offline
post #7 of 8 Old 08-15-2019, 12:18 PM - Thread Starter
Liked: 2
HI, thanks for answer. As I replayed in post before after turning off Dynamic volume in Auddyssey bass came strong. For source i used flac albums on USB attached to AVR and for video Blu Ray of Blade Runner 2049 and Dunkirk from Netflix app on LG B7 TV.
Volume is now on 2 o'clock and I increased level from -6,5 to -5
I will definitely test PB-1000 with smartphone and headphones to be sure since its my first proper sub-woofer, but bass is strong and really clear.
prepa is offline
post #8 of 8 Old 08-15-2019, 12:51 PM
Ed Mullen's Avatar
Quoted: 316 Post(s)
Liked: 748
If the bass is now strong/clear - then there is no need to check the subwoofer itself - this was definitely a set-up issue where you just needed to add some gain to the subwoofer channel and also disable DV.
Glad to see it's thumping good now.
Ed Mullen
SVS
