Quik question about receiver setting sub distance - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By crazy8s5846
  • 1 Post By tvuong
  • 1 Post By confinoj
post #1 of 6 Old 08-22-2019, 05:05 PM - Thread Starter
Liked: 2
I run auto setup on my denon 540bt it sets my sub at 24.4 ft away, when it probably 3.5 ft it sets right be hind my sofa. Should I just leave it, or set it manually to 3or 4ft. Thanks in advace.
Dwalker112 likes this.
crazy8s5846 is offline
post #2 of 6 Old 08-22-2019, 05:14 PM
tvuong's Avatar
Quoted: 2580 Post(s)
Liked: 2307
^^ Are you using a wireless kit to connect your sub?
tvuong is offline
post #3 of 6 Old 08-22-2019, 05:31 PM - Thread Starter
Liked: 2
Yes
post #4 of 6 Old 08-22-2019, 05:35 PM
tvuong's Avatar
Liked: 2307
^^ That is why. There is a delay using a wireless kit. I would leave the distance where Aud sets.
darthray likes this.
tvuong is offline
post #5 of 6 Old 08-22-2019, 05:41 PM - Thread Starter
Liked: 2
Thanks alot for the quik reply.
post #6 of 6 Old 08-22-2019, 05:43 PM
confinoj's Avatar
Quoted: 1232 Post(s)
Liked: 1054
Agree. Definitely leave it. Audyssey is usually accurate with distance settings. Distance to sub calculated by AVR is always longer than measured distance. If wired there is usually a several ms delay from the amp. Wireless adapters add variable delays but typically in the range of 15-25ms. 1ms translates to about 1ft.
LG OLED65C7P (Chad B Calibrated) | Denon X4300H | Tivo Roamio OTA | Nvidia Shield | ATV 4K | Oppo UDP-203 | Plex server
5.2.4 | Front Klipsch RP-160M x2 | Center Klipsch RP-450C | Surrounds Klipsch RP-150M x2 | Atmos Klipsch RP-140SA x 4 | Subs SVS PC-4000 x 2
confinoj is online now
