2nd sub or single larger one? - AVS Forum | Home Theater Discussions And Reviews
 9Likes
  • 1 Post By torii
  • 2 Post By confinoj
  • 1 Post By confinoj
  • 1 Post By WLDock
  • 4 Post By Ed Mullen
post #1 of 17 Old 08-28-2019, 04:24 AM - Thread Starter
mr645's Avatar
Quoted: 29 Post(s)
Currently using a single SVS SB-2000. It's in the corner behind the right main speaker. I can add a second one but it would have to be either right next to the 1st one or on top of it. I don't really have a space to put a second sub on the left or by the listening area. So am I better off getting a single SB-3000 or larger?
mr645 is offline
post #2 of 17 Old 08-28-2019, 05:18 AM
WLDock's Avatar
Quoted: 189 Post(s)
Liked: 217
Another of the same would be cheaper and will offer a dB gain placed on top or next to the other. Are you choosing sealed due to space constraints and/or sound quality?
Maybe something like a single HSU ULS-15 or Rythmik Audio F15HP, or F18 is what you are after?
Sent from my Pixel 3a using Tapatalk
HDTV - Sharp AQUOS LC-70LE600U 70" | AVR- Anthem MRX 300 | Media Player - Fire TV Box 2nd Gen | Blu-Ray/Media/Gaming - PS3-320GB / Xbox One
Speakers - Main - Boston Acoustics Lynnfield VR965 | Center - Boston Acoustics Lynnfield VR920 | Rear - Artison Portrait LRS
| Sub - DIY Stereo Integrity HT 15 | Sub Amp - O Audio BASH 500
WLDock is offline
post #3 of 17 Old 08-28-2019, 07:44 AM - Thread Starter
mr645's Avatar
Quoted: 29 Post(s)
I chose a sealed sub mainly for music listening. Happy with the sub now but some movies have a crazy amount of LFE which is driving the sub to it's limits from time to time
mr645 is offline
post #4 of 17 Old 08-28-2019, 07:57 AM
torii's Avatar
Quoted: 4133 Post(s)
Liked: 2420
the big ported subs can be a game changer if you can fit them
WLDock likes this.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300 LG oled c9 77
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS, Audioengine A2+
Subs: Rythmik FV25HP, Rythmik FV15HP, Velodyne HGS 12, Velodyne VA1512
torii is offline
post #5 of 17 Old 08-28-2019, 08:15 AM
WLDock's Avatar
Quoted: 189 Post(s)
Liked: 217
I agree with the above. I would see who has the best sale this weekend on a ported 15" that has port tuning. This way you can have the big low bass for movies and the tightness for music. The 15" will strain less than the 12" playing music as it has to work less to get loud due to the larger displacement. You can have it all and get the most for your money with the right sub selection.
Look at HSU, Monolith, Rythmik, Power Sound Audio, SVS this weekend.
WLDock is offline
post #6 of 17 Old 08-28-2019, 08:25 AM
confinoj's Avatar
Quoted: 1367 Post(s)
Liked: 1241
Agree with the ported recommendation given that you are hitting limits on ULF for movies. If you are within a year of purchasing the SB-2000 and you can fit/afford it simplest may be trading up to the PB-3000. It can be run sealed or ported and would give you a very significant upgrade. There a few PB-3000s left in the outlet sale right now and you could save a couple hundred dollars. If not within a year and you would need to sell SB-2000 then lots of other options as well.
WLDock and darthray like this.
LG OLED65C7P (Chad B Calibrated) | Denon X4300H | HDHomeRun Quatro | Nvidia Shield Pro 2019 | ATV 4K | Oppo UDP-203 | 40TB Plex server
5.2.4 | Front Klipsch RP-160M x2 | Center Klipsch RP-450C | Surrounds Klipsch RP-150M x2 | Atmos Klipsch RP-140SA x 4 | Subs SVS PC-4000 x 2
confinoj is offline
post #7 of 17 Old 08-28-2019, 08:30 AM - Thread Starter
mr645's Avatar
Quoted: 29 Post(s)
I bought the SB-2000 from a local retailer, about 6 months ago. I don't think I can exchange it. I am thinking perhaps an SB-4000 to keep the musical quality while adding headroom for movies. I could sell the SB-2000
mr645 is offline
post #8 of 17 Old 08-28-2019, 08:39 AM
confinoj's Avatar
Liked: 1241
For well designed subs like SVS sealed and ported are both "musical". I wouldn't make a decision based on that. Yes the SB-4000 will give you more headroom but you still will have much more impact and headroom for movies from a ported sub. However that could also depend on room size. How large is your room and is it open to other areas? In a smaller room you can get enough room gain in the ULF range from sealed subs to make up for some of what is gained from a ported sub in a larger room.
darthray likes this.
confinoj is offline
post #9 of 17 Old 08-28-2019, 08:45 AM - Thread Starter
mr645's Avatar
Quoted: 29 Post(s)
The room is 12x15, 17' ceiling. Open on one end.
Sony 85" X850G, Vandersteen 2Ce Signatures as mains. 5.1 overall system. Pioneer receiver as processor and Parasound amplification. The Vandersteens reach nicely down to 30hz but movies overdrive them, hence the sub.The little SB-2000 does nicely filling in and blending with the mains. First thought was just add another SB-2000 on the left side but I have no place to put it. I have never been a fan of ported subs but never heard one of the PB models from SVS either.
mr645 is offline
post #10 of 17 Old 08-28-2019, 08:59 AM
WLDock's Avatar
Quoted: 189 Post(s)
Liked: 217
I know where you are coming from. I preferred sealed subs going all the way back to the 80's-90's during my car audio days. A sealed 15" like the HSU ULS-15 is a sub I could live with for music and movies in my current room. However, after realizing how well this old ported 10" HSU VTF2 Mk1 sub shakes my floor, ported is the way to go for larger rooms for movies.
Furthermore, the internet direct brands today are unlike some subs from yesterday and many big brand subs today. Even ported they play pretty clean. The issue that causes boomy sound is bad placement and lack of room correction. So, you own it to yourself to at some point audition something like one of the ported 15" Rythmik Audio servo controlled subs..
http://www.rythmikaudio.com/FVX15.html
http://www.rythmikaudio.com/FV15HP.html
Better yet, I hear that infinite baffle subs may be the ultimate in terms of boxless natural bass. Maybe I will try it for myself someday.
WLDock is offline
post #11 of 17 Old 08-28-2019, 10:01 AM
lemonslush's Avatar
Quoted: 986 Post(s)
Liked: 476
two 2000 will not be a loud as one 3000 looking over the DB charts. Your only getting 3 extra db with a second sub. But it will give you more coverage. I would say get a 3000 as a second sub and upgrade the 2000 later on
"we need more power" - My Wife.
Theater Build Thread - Wartooth
lemonslush is offline
post #12 of 17 Old 08-28-2019, 01:14 PM
Ed Mullen's Avatar
Quoted: 513 Post(s)
Liked: 1073
Two co-located SB-2000s will give you a 6 dB increase in SPL.
A single SB-3000 will have similar output as dual SB-2000s in the 40-80 Hz octave. In the 18-36 Hz octave, the dual SB-2000s will have a few dB more output.
Considering you already own an SB-2000 - if you are strictly looking for more headroom and dynamic output, the most economical solution is to simply add another one.
If you are looking for mainly an increase in headroom in the 18-36 Hz octave (where LFE is strong on action/sci-fi content), a PC-2000 will have 2-4X higher max output in this deep octave than a single SB-2000 without taking up much (if any) additional floor space.
mr645, darthray, WLDock and 1 others like this.
Ed Mullen
Director - Technology and Customer Service
SVS
"What We Do In Life, Echoes In Eternity"
Ed Mullen is offline
post #13 of 17 Old 08-28-2019, 04:08 PM
Kini62's Avatar
Quoted: 2854 Post(s)
Liked: 2745
Ed suggested the PC2000 I was thinking you should go for the PC4000. Same small footprint as the PC2K and your SB2K but damn, the increase in overall output would be huge.
Plus you can seal it up for music if you like how it sounds in your room that way.
Off topic, but how do you like your Sony 850G? It's one of the sets I'm looking to possibly upgrade to this Xmas. What did you come from? Black levels etc...
You can PM me if you want.
Def Tech SC8000
Onkyo RZ820
Roku Ultra, Apple TV, Sharp 70" Quattron
Kini62 is offline
post #14 of 17 Old 08-28-2019, 04:18 PM - Thread Starter
mr645's Avatar
Quoted: 29 Post(s)
So if I understand correctly, dual SB-2000 subs will perform similar to a single PC-2000, a little better in the 40-80hz range, about the same in the 18-36 hz range. 6db meaning 4 times the output. And placing them next to each other should not be a problem.
mr645 is offline
post #15 of 17 Old 08-28-2019, 06:58 PM
darthray's Avatar
Quoted: 2549 Post(s)
Liked: 4179
@mr645
Like @confinoj said in the quote above. A well designed Port sub can also sound very good, once well integrate. So my vote would be for a ported one
My suggestion would be the best single port Sub, you can afford one for now. And not using your current sub, since it is a Seal design. Been mixing Seal and Port, are a lot more difficult to integrated together.
And enjoy-it
Than if you feel like your are still missing something, just start saving for a second one.
Cheaper in the long run, to add one better sub. Than try to replace two lesser subs
Darth
darthray is offline
post #16 of 17 Old 08-29-2019, 05:32 AM
Ed Mullen's Avatar
Quoted: 513 Post(s)
Liked: 1073
Here is the rough breakdown - single SB-2000 vs. single PC-2000 with the advantage shown for the PC2K:
50-80 Hz: similar max output
40 Hz: 1.5X (about 3 dB)
32 Hz: 2X (about 6 dB)
25 Hz: 3X (about 9 dB)
20 Hz: 4X (about 12 dB)
So dual SB-2000 will achieve parity at 32 Hz and at 40 Hz and above will have a considerable advantage. But even dual SB2K will not match a single PC2K in the 20-25 Hz bandwidth.
An SPL increase of 6 dB is a doubling of the acoustic sound pressure.
Ed Mullen
SVS
post #17 of 17 Old 08-29-2019, 05:35 AM
Ed Mullen's Avatar
Quoted: 513 Post(s)
Liked: 1073
Yeah in that size room a PC4K under most conditions would have a lot left in the tank. As we like to say around the water cooler - 'headroom has a quality all its own'.
Ed Mullen
SVS
