Paradigm Defiance X15 . . . - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 08-29-2019, 01:00 PM - Thread Starter
NMG
NMG's Avatar
Quoted: 36 Post(s)
Liked: 39
Hi all,
I've read all of the reviews that I can find for this sub, but I was wondering if anyone here on the forum is running one in their setup?
I'm getting the upgrade bug and I'm thinking that would be my biggest bang for buck upgrade. The other option I was considering was adding 2 Atmos height channels to my existing 5.1 setup. I'll do that eventually as well, but I can't help but imagine that the sub would be a more significant move right now.
I'm currently running an Anthem MRX 720 with B&W speakers and an older Paradigm Studio Sub 12. The Sub 12 has a high excursion driver and is a sealed design, carrying a 1,700 watt amp, and is said to play down to 16Hz. It's a pretty compact sub. Contrast that to the Defiance which is a big ported design with a 900 watt amp. The reviews for this sub seem impressive, and I'm sure that it would give me considerably more output especially for movies. I also listen to allot of music so that's a consideration as well.
My system is in a basement that is roughly 12 wide x 20 deep with 8 foot ceilings. Seating position is near the middle of the room and I have lots of room behind me for the bigger box, which is also where the Sub 12 is situated. Not much room along the sides of the room or up front the way everything is currently laid out.
I've also considered other brands like SVS, HSU and Rythmik, but I live in Canada and by the time I pay shipping and exchange, I think the cost of the ID brands could be a prohibitive factor. I haven't priced the Defiance yet, but I'm sure I could get it under MSRP ($1,850 Canadian or roughly $1,400 US) and our money tends to go a bit further when buying Canadian products.
Any thoughts or suggestions would be greatly appreciated!
NMG is offline
post #2 of 19 Old 08-29-2019, 01:27 PM
Kini62's Avatar
Quoted: 2716 Post(s)
Liked: 2527
Originally Posted by NMG View Post
Hi all,
Did you read the review at audioholics? It would be a substantial upgrade over your existing sub.
Def Tech SC8000
Onkyo RZ820
Roku Ultra, Apple TV, Sharp 70" Quattron
Kini62 is offline
post #3 of 19 Old 08-29-2019, 02:08 PM
ratbuddy's Avatar
Quoted: 833 Post(s)
Liked: 1146
You could do much worse than the X15. It's not as good an absolute value as some ID subs, but it performs very well and has the convenience of a phone app and room correction. If you can get it for ~20% off MSRP, I think it's a great move for you.
ratbuddy is offline
post #4 of 19 Old 08-29-2019, 10:40 PM
indebtbassfreak's Avatar
Quoted: 1432 Post(s)
Liked: 2737
I think it will be a nice upgrade,,,,,, even more so if you move your MLP from the "middle" of your room's long wall if you are able. Try the first third or second third (approx) and you should get a much nicer bass response (sub location been optimal). If you are experienced in measuring "REW",,,, this will help confirm,,, although your Anthem should also give you measurements. Enjoy!!
-Marantz SR-8012
-Yamaha BD-A1060
-Funk 21.0LX Master/Slave combo 4800 watts RMS/9600watts (peak)-
-Chane A-2.4 L/C/R
-Chane A-1.4 side/rear surrounds.
indebtbassfreak is offline
post #5 of 19 Old 08-30-2019, 04:58 AM - Thread Starter
NMG
NMG's Avatar
Quoted: 36 Post(s)
Liked: 39
Thanks all, I'll stop by some local shops to check out pricing, etc.
indebtbassfreak, unfortunately, my MLP is about as far back as I can go and still be able to have a reasonably configured 5.1 setup. I've got a wall on the left side of the room that shoots off at about a 45 agree angle before leading to the staircase, so mounting a surround speaker is virtually impossible on that side. The other wall has a window, so same dilemma.
The 5.1 setup is laid out pretty optimally for the room right now, and 5.1.2 will be easy to accommodate when I go there.
The MRX has done an incredible job of integrating the Sub 12, and bass response is miles ahead of what it was before I made that upgrade. Based on the charts it produced, my response is reasonably flat down to the low/mid 20s before falling off. Volume isn't really an issue, but more extension would be nice especially for HT. If I was only focused on music, I think the Sub 12 would do the job just fine.
NMG is offline
post #6 of 19 Old 08-30-2019, 09:45 AM
VooBass's Avatar
I’m considering the X-15, too, as a second sub. I have a SVS PB4000 now. The PB4000 is awesome for foundation-crumbling subterranean bass but it’s not as strong in the higher chest-slam region that the X-15 seems to excel in. Together they be magic.
VooBass is offline
post #7 of 19 Old 08-30-2019, 01:53 PM
Banner23's Avatar
Quoted: 50 Post(s)
I will be buying a new sub and the X-15 is one that I am looking at. The above post mentions the PB4000 having more low end output, I was wondering how often do those sounds happen in a movie ? The X15 is great in the mid bass area, and that happens a lot, if you only hear a few minutes of very low bass in a movie, I think the X15 would be better.
Banner23 is offline
post #8 of 19 Old 08-30-2019, 02:09 PM
Kini62's Avatar
Liked: 2527
That it is, but it's not like a sub such as the PB4000 doesn't have any mid bass. In order to experience the substantial output of the X-15 over what the PB4000 has you'll be listening at around 115db or more. How often does that happen? For some, probably too much and they're losing their hearing.
Def Tech SC8000
Onkyo RZ820
Kini62 is offline
post #9 of 19 Old 08-30-2019, 02:15 PM
Quoted: 13 Post(s)
Liked: 1
I would also be looking at the psa v1510 and psa v1811.
rmontero1701 is offline
post #10 of 19 Old 08-30-2019, 04:46 PM - Thread Starter
NMG
NMG's Avatar
Quoted: 36 Post(s)
Liked: 39
One thing that is complicating my decision is the amplifier specs for some of the subs.
The amp in my Sub 12 is said to have a 1,700 watt amp (3,600 watt peak) and I'm running it along with all of my other gear on the same room circuit. I've had no issues. That said, I also know that I don't listen at levels that will max it out. I don't expect that my listening habits will change with a new sub. Like I said, I'm mainly looking for more extension. More thump won't hurt, but I'm not looking to rattle dishes out of the cupboards upstairs, LOL.
So when I look at a sub like the Defiance 15, it's rated at 900 watts (1,800 peak), so I know it should be no problem at all. Less powerful than my current sub. Same situation as something like the PSA V1510 or V1811 which is rated at 960 watts (2,100 peak). If I look at something like the SVS PB-4000, it's showing 1,200 watts (5,000 peak).
At what point are guys running dedicated lines for their subs? When running duals or more? Those PSA subs look very interesting, especially the V1811 which actually has a smaller footprint than the Defiance 15. I almost have to wonder if I'd be using less power to move a big woofer in a ported box to levels that are acceptable in room, than I am asking a 12 inch driver in a sealed box to do the same. I can't imagine ever needing more than a single given my room size, and if I'm going to do it, I may as well do it right and find a sub that will last me years without wondering if I made the right choice.
So much to consider!
NMG is offline
post #11 of 19 Old 08-30-2019, 05:05 PM
Liked: 2737
These "max" watt bursts are just that,,,, millisecond burst "if" pushed to the limit with the right source material. My subs have at 4800 watt rms/9600 watt peak rating and my house is flexing with 4/5 amp draw,,,,,, anr their sealed subs. Unless your drawing a consistent 3000 watts (not likely) in your situation a 15a AC will be fine. To "claim more than 4X the RMS as peak is extreme imo but even if valid is millisecond peaks which a standard ac should handle just fine as they can accommodate large peaks for several seconds without blowing fuses.
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
post #12 of 19 Old 08-30-2019, 09:43 PM
VooBass's Avatar
This may be extreme overkill but I have 3 new 20 amp lines being installed in a couple weeks. I talked to SVS and was told my PB4000 would be even happier on a dedicated 20 amp line. So, when I do get a second PB4000, it seems reasonable to have 2 lines, each line also powering 300 watt amps in my DefTech towers. Then, based on the example of Denon’s new 13 channel receiver having higher power ratings on a 20 amp circuit, it would seem next gen 13 channel+ Atmos systems would also be better served by their own 20 amp circuit.
VooBass is offline
post #13 of 19 Old 08-31-2019, 06:19 AM
ratbuddy's Avatar
Quoted: 833 Post(s)
Liked: 1146
I think I could technically run both of my subs on one 20 amp line, but I had a dedicated 20 put in for each sub just so there's no chance of popping a breaker, since the box is in a location I can't easily access. Everything else (receiver, PC, consoles) is on a third dedicated 20 amp line. It didn't cost too much to run them, so why not?
ratbuddy is offline
post #14 of 19 Old 09-01-2019, 06:46 PM - Thread Starter
NMG
NMG's Avatar
Quoted: 36 Post(s)
Liked: 39
Sorry for the late replies, and thanks for the info. That's definitely helpful!
I actually decided to upgrade to 5.1.2 this weekend so I finished that project up and gave it a test run tonight. Very happy I did it. Also paid particular attention to bass performance while watching Godzilla King of the Monsters, and I have to admit that the current setup still puts a smile on my face. I still want to upgrade my sub, but I'm going to do a little more reading and figure out what I want to do before dropping the coin.
NMG is offline
post #15 of 19 Old 09-10-2019, 07:27 AM
Banner23's Avatar
Quoted: 50 Post(s)
Hi, I am thinking about buying this subwoofer, also looking at the SVS SB16. The X15 has the built-in ARC room correction/EQ, a lot of subs I have looked at don't have this. Do you consider this to be an important feature ?
thanks
Banner23 is offline
post #16 of 19 Old 09-10-2019, 07:59 AM
ratbuddy's Avatar
Quoted: 833 Post(s)
Liked: 1146
thanks
I think it's mostly useful for people using the sub in a system without existing room correction. If you have a good receiver or some other means of room correction, the built-in ARC becomes far less useful. If you're putting the sub in a system with just a stereo integrated or separates, then the ARC on the sub becomes something you might want.
ratbuddy is offline
post #17 of 19 Old 09-14-2019, 10:00 AM
Banner23's Avatar
Quoted: 50 Post(s)
I am looking for a new subwoofer and the X15 is one that I am thinking about getting. I know this sub is large so I went the store to see it in person to get an idea of the size. When seeing it in person, it really is huge, it looked like you could use it for an end table. I still might buy it, the other sub I am looking at is the SVS SB16.
I have a couple of questions, first, has anyone been able to compare both of these subs together ? Second is about the size, for those who bought it, do you find it being to big for the room, that when you walk into the room that's the first thing you notice ? My home theater is setup in the family room and I am concern how it will look in it.
Banner23 is offline
post #18 of 19 Old 09-14-2019, 10:52 AM
Ryan Statz's Avatar
Quoted: 372 Post(s)
Liked: 152
Run. Run as far away as fast as you can, and don't look behind you...
I've had the bug for over two months, now, and I can't seem to crawl out of that hole. I have one more component to get, and that should be it for (hopefully) a long time.
And I hear you on the Canadian thing - I face that same problem, too. If only our dollar was on par...
Home Theatre: Onkyo TX-NR747 | Polk Audio RTi A3 Front L/R | Polk Audio CSi A6 Centre | Polk Audio RTi A1 Surround L/R | Elac S10EQ Subwoofer | Sony XBR55X900E | PlayStation 4 Pro | Xbox One S
Music: Cambridge Audio AXR100 | Stanton T.62 | Cambridge Audio AXC35 | KEF Q150 x 2 (upcoming) | Subwoofer TBD
Ryan Statz is online now
post #19 of 19 Old Yesterday, 01:30 PM
Liked: 0
Hi! Just a question:I have a pc with windows 7 pro, connected to the x15 via USB port.X15 is recognized, but drivers failed to install...
I wanted to tune Arc precisely with my PC.Arc configuration with an android phone does not work for me, no audible differences.
Paradigm installed me a new amp card but problem was not resolved.
Do you face same problem? I think it's a windows corrupted problem(I have to install a few divers, like graphic cards drivers manually) but x15 drivers are installed Automatically by the subWoofer.. Paradigm drivers are unavailable to download on the net...
I have Arc by my pw link and I can't live without it, difference is huge with it, no more rough bass, very useful in my small room.
Anyway, it's a great subwoofer, as good in music as in movies.bass is clean and tight.max volume used by me is 70db but you can go to 100 dB without distortion!.If Arc is the same as in Pw link, it's a perfect bang for your buck.
The only problem is it's Huge and corners are too sharp(beware if you have children! ) , I have a few scratches on my legs lol
batfunk2 is offline
