Measure TR - The Viberry - Page 14 - AVS Forum | Home Theater Discussions And Reviews
 229Likes
post #391 of 494 Old 11-02-2019, 03:31 PM - Thread Starter
LastButNotLeast's Avatar
Quoted: 2696 Post(s)
Liked: 2345
Weird network
From the desktop, I can run Chromium and load AVS and Yahoo.
WHILE I'M DOING THAT, the pi does NOT show up in my client list and pinging results in "Unknown host."
I can get the recorder to run perfectly.
This is maddening, and I'm running out of hair to pull out.
Michael
LastButNotLeast is offline
post #392 of 494 Old 11-02-2019, 04:44 PM
3ll3d00d's Avatar
Quoted: 2568 Post(s)
Liked: 2883
You need to look at the status of the network on the pi
3ll3d00d is offline
post #393 of 494 Old 11-02-2019, 04:44 PM
Nalleh's Avatar
Quoted: 2820 Post(s)
Liked: 3883
Sounds like it is your network ?
Dual AVR 13.1.8 SWAtmos - Atmos 13.1.8/DTS X 9.1.8/Auro 3D 13.1 - Denon AVCX8500H+AVRX7200WA - Klipsch+KEF - 6xSI18" - 12xJBL 12" w/6xSLAPS M12 downfiring VNF - 3x2 stacked Crowson MA - 4xBK-LFE Dual TR Sleds- 6xNU6K(fan&trig mod) - Minidsp 10x10HD - Oppo UDP203 - XB1X - ATV4K - Vertex2 - JVC RS600 Dreamscreen V2 120"- Philips 65OLED873.
>>>>Nalleh’s HT<<<<
Nalleh is offline
post #394 of 494 Old 11-02-2019, 05:58 PM - Thread Starter
Liked: 2345
I won't insult you by asking how to do that here, I'll look it up.
Still at the dummy level, after all.
Michael
post #395 of 494 Old 11-02-2019, 06:01 PM - Thread Starter
Liked: 2345
But it's obviously CONNECTED, apparently in stealth mode.
We'll see what I can figure out over the next few days.
I think I'll get a new SD card soon, anyway.
Michael
Nalleh likes this.
post #396 of 494 Old 11-02-2019, 10:24 PM - Thread Starter
Liked: 2345
iwgetid and iwconfig both show the correct SSID.
Listed under wlan0.
Of course, I can't take a screenshot because I'm working with the pi desktop and a keyboard.
Still nothing with ping or client table.
Michael
post #397 of 494 Old 11-03-2019, 01:55 AM
3ll3d00d's Avatar
Liked: 2883
The two most immediate things to look at are
Can the pi can reach other devices on the network and/or the outside world (ping is fine for this)
Check if it is a domain name resolution problem by using an IP
3ll3d00d is offline
post #398 of 494 Old 11-03-2019, 11:17 AM - Thread Starter
Liked: 2345
New SD card didn't make a difference.
Currently running upgrade (again), downloading, obviously, from somewhere, NOT showing up on router, ping still can't find raspberrypi.local.
Initial setup from pi found other networks. Will try ping from pi later, maybe.
This is maddening, and I'm going to give up soon. I must have burned out something on the pi.
Michael
post #399 of 494 Old 11-03-2019, 11:36 AM - Thread Starter
Liked: 2345
pi can ping the router, avg rtt about 12ms.
still can't ping the pi.
post #400 of 494 Old 11-03-2019, 12:20 PM
3ll3d00d's Avatar
Liked: 2883
as I said in my previous post, try using an IP address instead to rule domain name resolution out
3ll3d00d is offline
post #401 of 494 Old 11-03-2019, 03:44 PM - Thread Starter
Liked: 2345
Which I understood to mean ping 192.168.1.1. Which I did.
I'm going to try stretch just for grins.
Then I'll see if I can get it to work as a BT receiver again.
I really think it's just broken.
Which would really come as no surprise after all it's been through.
Michael
post #402 of 494 Old 11-03-2019, 04:13 PM
3ll3d00d's Avatar
Liked: 2883
I doubt it is broken given it can ping the router
If you have confirmed the pi can reach the router then you should be able to get the IP of the pi and ping it from your other machine.
3ll3d00d is offline
post #403 of 494 Old 11-03-2019, 04:24 PM - Thread Starter
Liked: 2345
Right. I know I should be able to. I can't.
And that will probably be the end of it.
No, it doesn't make any sense.
And stretch isn't working any differently.
So I give up.
Thanks, though.
Michael
post #404 of 494 Old 11-12-2019, 10:47 AM
Alaric's Avatar
Quoted: 106 Post(s)
Liked: 131
Someone on an AVforums boss thread pointed me at this!!! Like I *NEEDED* another project!!!
I've now got a pi zero and sensor on order.....I've got an pi3 running octoprint for a 3D print server and a few bits left over from an Uno projector (automatic toilet flusher for my cat, the cat decided no and i changed tack on that automation), though may grab case and cables later. Ex IT linux sys-admin though i'm about 20yrs from that and i've probably forgotten most of it. I know delving into my Vortexbox media server or playing with a linux crypto miner was a re-education!
I'm curious to see how my Buttkicker LFE's, Origional and Clark TSTs compare with my dual boss and dual servo15 subs. Ideally something like this should show up what each bring to the party and then be able to tune them to integrate better
looks interesting and sometimes it's just case of knowing that the projects exist that gets people interested. Then again some people don't even bother with a calibration disc (or free Disney maximizer) on a few grand projector
Sound - Marantz SR6011 (pre/atmos), Yamaha Z9, Mirage Om-6's, Om-C2's, 6x Om-R2's, 4x Nanosat (atmos), Dual Paradigim Servo 15's
Additional - MiniDSP : DDRC-88a, 2x4HD
Source -Panasonic DP-UB420, Toshiba HD-XE1, Sony SCD-XE620
Vision - Epson TW9400, eecolour Lut Box, 120" Spitfire Acoustically Transparent Screen
Alaric is offline
post #405 of 494 Old 11-12-2019, 11:38 AM - Thread Starter
Liked: 2345
I hope you mean a zero WH, otherwise you're going to need the wireless adapter and solder on a header.
Eager to have you on board.
Michael
post #406 of 494 Old 11-12-2019, 12:29 PM
Alaric's Avatar
Quoted: 106 Post(s)
Liked: 131
Michael
Ha. Yeah I went for the WH one, being lazy in my writing!
I can solder but it's not my greatest skill and so if easily avoided i will.
Sent from my HTC U11 using Tapatalk
Alaric is offline
post #407 of 494 Old 11-12-2019, 01:21 PM - Thread Starter
Liked: 2345
Which means you don't have to worry about long cables
To make sensor placement easier, do you think longer cables like this would work?
https://www.ebay.com/itm/40pcs-100cm...YAAOSwymxVJ-vj
I haven't been able to find anything longer.
Michael
post #408 of 494 Old 11-12-2019, 03:20 PM
3ll3d00d's Avatar
Liked: 2883
You will have to try it and see. I believe 1m is the outer limit for 100kbps using that sort of cable, twisted pair (e.g. network cable) can reportedly go further.
3ll3d00d is offline
post #409 of 494 Old 11-19-2019, 10:28 AM
Alaric's Avatar
Quoted: 106 Post(s)
Liked: 131
Having a quick play, still yet to get the sensor, but running through the set-up. Noticed this in one of the scripts output
pip install qvibe-recorder
Building wheels for collected packages: qvibe-recorder
Running setup.py bdist_wheel for qvibe-recorder ... error
Complete output from command /home/pi/python/qvibe/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-v8j2h14v/qvibe-recorder/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-dmtn_9ad --python-tag cp37:
/home/pi/python/qvibe/lib/python3.7/site-packages/setuptools/dist.py:475: UserWarning: Normalizing '0.0.1-alpha.1+dirty' to '0.0.1a1+dirty'
normalized_version,
usage: -c [global_opts] cmd1 [cmd1_opts] [cmd2 [cmd2_opts] ...]
or: -c --help [cmd1 cmd2 ...]
or: -c --help-commands
or: -c cmd --help
error: invalid command 'bdist_wheel'
Failed building wheel for qvibe-recorder
Alaric is offline
post #410 of 494 Old 11-19-2019, 10:47 AM - Thread Starter
Liked: 2345
Right. Not a problem. Ignore and keep on going.
Michael
Alaric likes this.
post #411 of 494 Old 11-27-2019, 05:42 AM
Alaric's Avatar
Quoted: 106 Post(s)
Liked: 131
OK.....Got her up and running last night at home. Got the sensor in the post the other day, had a few cables from my UNO build, plug and play. Put the pi in a case and the little board has notches so with a bit of double sided tape the sensor is now attached to the top of the case. Did a bit of a dual network set-up so i could get things going at work and then just plug in at home
wpa_supplicant.conf
country=UK
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
network={
ssid="SSID1"
psk="PWD1"
priority=1
id_str="home"
network={
ssid="SSID2"
psk="PWD2"
priority=2
id_str="work"
Change SSID1/2 & PWD1/2 as required
Installed joe on the PI as i never liked nano and it's been my default editor forever. It's an old wordstar clone, using ctrl-k+x for save & quit and ctrl-k+q for just quit (no save or changes) - Advantage cut and paste works - Just change nano for joe in the instructions!
$ sudo apt install joe
I use textpad (https://www.textpad.com/) as a file editor in widows. It can handle linux files and doesn't add carriage returns and the like that notepad can - Probably not needed, but it's an AWESOME text editor so well worth mentioning if you play with non standard files!
I used Win32 disk imager (https://sourceforge.net/projects/win32diskimager/) to write the card. You have to unzip the download, but i've always had good results and it's MUCH smaller than Balena and works on older Windows Platforms
Managed to get the qvibe-analyser running at home. It didn't like my Vista pc at work (Yeah, i know, i know, i do have a Win10 box to transfer over to at some point!)
The install file is fine and then says to update. The update pulls down the smaller .exe but doesn't install. Should i place that over the installed copy?
Running the small .exe one doesn't save the "Batch Size" to 25, but resets to 8 and boy does the PI not like *THAT* option
I'm still logging in to run the Pi as so far the service thing doesn't seem to work for me.....though didn't notice any user changes to that part of the instructions? Still it's pretty easy to do with Putty and not a massive hassle for Mapping what is happening and then tweaking my set-up. I mean i can't see me using it massively once done? I don't often use my colorimeters for image calibration or rew & mic that often once set-up is actually done etc?
FYI for anyone doing this.....It's a pretty simple set-up following the dummies guide. The things i've done above are alternatives or help, but can be ignore unless you hit an issue with old OS's, dual network or the cut and paste thing
LastButNotLeast likes this.
Alaric is offline
post #412 of 494 Old 11-27-2019, 06:17 AM - Thread Starter
Liked: 2345
Outstanding! Thanks for coming aboard.
I preferred NOT having the sensor attached to the case; that's why I'm curious about longer cables.
You can manually install the large update over what you have; maybe Matt can tell you why you're getting the small version, instead (though it will work perfectly well).
And, yes, you need to change it from 8 to 25 [hey, Matt, how about changing the default? ]
I had no trouble with cut and paste (once someone told me how to do it, and I added it to the guide), but alternatives are always welcome.
Now let's see some measurements!
Michael
post #413 of 494 Old 11-27-2019, 06:25 AM
Alaric's Avatar
Quoted: 106 Post(s)
Liked: 131
It is a good idea to make a backup image of your Viberry.
(Why didn't I think of this a dozen reformats and reinstalls ago? ):
https://thepihut.com/blogs/raspberry...ry-pis-sd-card
Michael
Just thinking about this one.....and the ease of use for people setting all this up.
Couldn't we create a back-up of a working pi zero, with all the software and bits on a lite version, standard username/pass. I mean all the network conf is done at the beginning after flashing on a pc/mac!
So build board, Flash sd, network conf and AWAY it goes ???
A simple Viberry distro so to speak
You wouldn't really have to touch SSH and all the commands and stuff apart from updates. And to be fair it wouldn't be hard to get a script that checked for updates on start up anyway ???
OK. Network security with the pi being default, but it's not like the machine is going to be on ALL the time and it'll be on a private network anyway, so apart from an lucky opportunist snooper the risk is very minimal?
Have I missed something?
Alaric is offline
post #414 of 494 Old 11-27-2019, 07:27 AM - Thread Starter
Liked: 2345
The problem is the network setup. If you're doing it headless, it needs to be done BEFORE it's on the pi.
I guess you can do what you suggest with the full version, boot to the desktop (with keyboard and monitor) and set it up from there.
This is easier.
Michael
post #415 of 494 Old 11-27-2019, 09:36 AM
Alaric's Avatar
Quoted: 106 Post(s)
Liked: 131
This is easier.
Michael
Does it *HAVE* to be before ???
I mean if I make a back-up of my card, write it to a new card, can i not just drop a new wpa_supplicant.conf file on the SD card and it'll boot to that network ???
or have I missed something and that file can only be dropped on to new flash of the PI os ???
Alaric is offline
post #416 of 494 Old 11-27-2019, 09:46 AM - Thread Starter
Liked: 2345
I have no idea (still a Dummy, remember? ).
Anyone?
post #417 of 494 Old 11-27-2019, 12:56 PM
3ll3d00d's Avatar
Liked: 2883
You can put wpa_supplicant.conf in /boot but then it isn't an image anymore so the benefit isn't obvious to me given how few steps are involved in using a vanilla image.
3ll3d00d is offline
post #418 of 494 Old 11-27-2019, 01:08 PM - Thread Starter
Liked: 2345
Because that would be the ONLY thing someone would have to do.
Download the image (which would probably be a torrent), write the modified wpa_ file, put it in the pi, DONE.
No real need to update anything on the pi once it's working.
Not that there's a tremendous demand for this, but it would save some time and effort.
Maybe.
Thoughts from anyone else?
Michael
Alaric likes this.
post #419 of 494 Old 11-27-2019, 06:28 PM
Foundation42's Avatar
Quoted: 106 Post(s)
Liked: 119
Maybe.
Michael
I'm not familiar with the details enough to weigh in too much, but the simpler to set up the better.
Foundation42 is offline
post #420 of 494 Old 11-30-2019, 02:36 PM - Thread Starter
Liked: 2345
Back in business!
Problem turnout out to be the ROUTER!
Next step is to improve the autorun.
Michael
Nalleh likes this.
