"Upgrading" my Funk Audio 18.1 - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 53Likes
post #61 of 90 Old 09-11-2019, 08:01 AM - Thread Starter
BigCoolJesus's Avatar
Quoted: 2151 Post(s)
Liked: 1726
Originally Posted by enricoclaudio View Post
Forgot to mention in the email that if you pick the subwoofer up at your local UPS Freight Center, you will save extra $100. You would need a pickup truck or a large SUV, though.
I could do that as well. Sounds like the FV18 is the choice for me!
BigCoolJesus is offline
post #62 of 90 Old 09-11-2019, 08:17 AM - Thread Starter
Liked: 1726
And for the price they are offering I could see about picking up a second one next year with my tax return possibly
post #63 of 90 Old 09-11-2019, 08:36 AM
tvuong's Avatar
Quoted: 2583 Post(s)
Liked: 2315
^^ Excellent! I am sure you'll much prefer ported sub for your HT application. The FV18 is an outstanding sub.
tvuong is offline
post #64 of 90 Old 09-13-2019, 07:51 AM
basshead81's Avatar
Quoted: 323 Post(s)
Liked: 9205
I don't see the FV18 being a significant upgrade over the Funk 18.1 but congrats either way. Perhaps you will be able to integrate both and keep the Funk which should make for a potent setup.
That being said, I'm not sure why you didn't just go Rythmik from the get go since you have had their stuff before and they are local.
basshead81 is offline
post #65 of 90 Old 09-13-2019, 08:20 AM
imureh's Avatar
Quoted: 2813 Post(s)
Liked: 3509
Isn’t the Funk a sealed sub? From what Marc says about the driver on this model this should be a noticeable difference.
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser, 2 BK LFE
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is offline
post #66 of 90 Old 09-13-2019, 08:27 AM
indebtbassfreak's Avatar
Quoted: 1418 Post(s)
Liked: 2724
No the 18.1 is a ported 18". Its has been mentioned in the past as been close to the JTR 118's output but not deep extension.
imureh likes this.
-Marantz SR-8012
-Yamaha BD-A1060
-Funk 21.0LX Master/Slave combo 4800 watts RMS/9600watts (peak)-
-Chane A-2.4 L/C/R
-Chane A-1.4 side/rear surrounds.
indebtbassfreak is offline
post #67 of 90 Old 09-13-2019, 08:58 AM
imureh's Avatar
Liked: 3509
Got it. So then the FV18 should be a noticeable upgrade due to its deep extension.
indebtbassfreak likes this.
imureh is offline
post #68 of 90 Old 09-13-2019, 09:04 AM
Liked: 2724
Yes i believe it should be quite noticeable below 20Hz. For some reason i thought sealed were the choices the OP was interested in otherwise the FV18 paper cone would have been my 1st recommendation under $2K along with the Triax if in good condition.
CallingMrBenzo and basshead81 like this.
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
post #69 of 90 Old 09-14-2019, 06:07 AM
basshead81's Avatar
Quoted: 323 Post(s)
Liked: 9205
I emailed Nathan about the used 18.1 that was in the outlet and this was the specs.
Here are the basics;
Amplifier Features and specs;
Class D
PFC (power factor correction) switching power supply
Zero latency double precision DSP
110/220V operation
High output current capability 35amps max
Frequency response 5-45khz -3db
S/N 100 db (unbalanced); 98 db (balanced)
slew rate 30V/us
Damping factor 20-200hz >1000
800 watts @1%THD
DSP presets(we set a fixed upper limit crossover in the DSP of 200hz, so it
must be run with a "sub out" signal for the sub/system crossover)
1; No EQ, natural response of driver and enclosure, designed to match room
giant in small/average rooms, maximum overall output capability.
2; +3db low shelf for larger rooms
3; +6db low shelf for Large rooms
4; +8db low shelf for anechoic flat response to 16hz
Driver features and specs;
1.65" max p-p Excursion
over 1" linear p-p Excursion
High force compact Neodymium Motor
4" Voice coil diameter
1200 watts AES power handling
Aluminum demodulating ring
low inductance
High efficiency 98db/1watt
Dual spider
Cast aluminum frame
Weatherproof cone
Enclosure features and specs;
Baltic birch ply construction
1.5" thick front baffle
Low turbulence slot port
18.5 Hz tuning
Response to 15 Hz
20.5" wide 24" deep 27" high
So like I said before. I don't think the FV18 will be a substantial upgrade over the 18.1. The driver used in the Funk is likely in the realm of IPAL quality by the specs and efficiency. With 800watts it's likely to hit 126db above 50hz.
The FV18 does offer deeper extension but it's likely going to give up output above 20hz to the 18.1. which is why I kept saying grab the Triax because it's not going to give up anything and offer deeper extension.
post #70 of 90 Old 09-14-2019, 07:11 AM
Liked: 2724
Hi basshead81, you certainly have a lot more knowledge than myself to summarize driver specs. Knowing Funks performance in general i knew that the only likely advantage on the Rythmik would be below 20Hz. I'm pretty sure it was a post from Nathan a while back where he said the 18.1 it would have similar output to the 118. He has ordered it so i guess its moot now.
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
post #71 of 90 Old 09-15-2019, 07:59 AM
basshead81's Avatar
Quoted: 323 Post(s)
Liked: 9205
Well the 118HT has a lot of output above 16hz, so it mimics exactly what I said previously. The Cap 118 HT hits 105db @ 16hz, 110db @ 20hz, and 122db above 50hz, The 2019 cap 118HT hits 107db @ 16hz, 113db @ 20hz, and 125db above 50hz.
The 18.1 has a 98db per 1watt efficient driver. so add 3db to 98 for every time you double power up to 800watts. That puts the driver capable of 126db or so with 800 watts. It could probably produce another 2-3db if it was fed more power being it can handle 1200watts.
So even if you add 2.5 db to the FV18 numbers up top with a paper driver it's around 121-122db. The FV has more output in the 10-15hz range and it probably has a different sound signature. I am not saying it was a bad choice. The extra 5hz down low and a slight loss in upper bass output might be very worth it to the OP.
yes it is a moot point now, so this is my last post here.
post #72 of 90 Old 09-15-2019, 08:34 AM
Liked: 2724
Not to mention the OP's Funk 18.1 has the 1000 watt amp upgrade which would bump those numbers a touch higher.
CallingMrBenzo likes this.
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
post #73 of 90 Old 09-15-2019, 09:22 AM
Billy p's Avatar
Quoted: 389 Post(s)
Liked: 789
Not much thou...1k or double gives you about a 2-3db advantage throughout the frequency range...but even so.. that driver is purdy stout above 50hz...going by the unit tested at DB and reviewed by JR back a few yrs.
Ascend Acoustics: Towers, STC w RAAL & 200 SE in espresso,
54" of Panny Bliss, Anthem MRX 300, Oppo 103D,
Sub: Funk Audio 18: (Santos Rosewood)
Indian proverb: We don't inherit the earth from our ancestors but we borrow it from our children!
Billy p is offline
post #74 of 90 Old 09-15-2019, 09:57 AM
Liked: 2724
Yes i get that the extra 200 watts equates to less than a DB extra lol,, i only mentioned it as i think basshead81 didn't know of the 1000 watt amp been used to drive the sub.
Hopefully the extra output below 20Hz results in the OP's hopes and expectations,, as that was his goal. He will likely need a little playing time to adjust to the different sound signature.
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
post #75 of 90 Old 09-15-2019, 11:39 AM - Thread Starter
Liked: 1726
Didn't know this was still going on but glad as I appreciate still reading the responses. A small tempting wrench was thrown into the choice at the last minute with Nathan offering a 21" option for a very very very good price. Where would a 21" Funk have factored into the possible choices?
post #76 of 90 Old 09-15-2019, 12:01 PM
CallingMrBenzo's Avatar
Quoted: 603 Post(s)
Liked: 1310
Top choice.
sk373 likes this.
Marantz 7011- Panasonic UB-820- Xbox One X - Epson HC 5050UB *Calibrated by ChadB* - Elite Screen's 2:35:1 AT 115' - PSA MTM 110's L/C/R - Mixed Surrounds - SVS Elevations Atmos X2 - Dual PSA TV36 B&C Neo's *MiniDSP HD* Took the Red Pill BEQ
CallingMrBenzo is offline
post #77 of 90 Old 09-15-2019, 12:16 PM
jsc79's Avatar
Quoted: 400 Post(s)
Liked: 480
I think that funk 21 would be my choice.
What kind of finish? I’m curious on what the good price was. Ive always wanted to try one, but out of my budget.
Speakers: L/R Ascend Acoustics Sierra 2 - Center - Horizon w/RAAL Surrounds: Sonance VP62R SST/SUR. Vinyl:Rega Planar 3
Video: Sony XBR65X900e 65" 4K - Sony UBP-X800 Blu Ray
Power and Processing: Yamaha RXA1030 - Monolith 7X Amp - Minidsp 2X4 HD/WI-DG
jsc79 is offline
post #78 of 90 Old 09-15-2019, 12:16 PM - Thread Starter
Liked: 1726
Separate of the Funk 21" possibility, I was able to cancel my Rythmik order today before it shipped as I need to evaluate my ongoing tuition issue with my school this week, along with switch out my AVR for a step down model for extra funds and then re-evaluate where I am at. It would still be between the FV18 as a clear choice. And possibly, depending on final price, the custom offering Nathan has for me (if it is still an option on his end).
As a totally honest question, how well does a Funk 21 (new from his in-house parts and all that) fit into HT applications for deep extension and high output overall?
post #79 of 90 Old 09-15-2019, 12:18 PM - Thread Starter
Liked: 1726
When I emailed him last week no definitive price was said, he just said he thought he could offer me a 21" in my price range (back when I was thinking of stretching to $3k range).
CallingMrBenzo and jsc79 like this.
post #80 of 90 Old 09-15-2019, 12:35 PM
jamiebosco's Avatar
Quoted: 731 Post(s)
Liked: 1783
It's hard to say without knowing the specifics of the 21 on offer (amp,cabinet size etc)
But if its a sealed 21" I'd guess the Rythmik FV18 to have a few dB advantage from 25Hz and under, and the Funk 21 to have a fairly significant advantage in the 35Hz and up range
TV: Panasonic P65ST60 AVR: Denon 4311ci Speakers: PSA MTM-210C (Centre), PSA MTM-210 (Left & Right), PSA MT-110 (Surrounds) Subwoofers: Dual Seaton SubMersives
jamiebosco is online now
post #81 of 90 Old 09-15-2019, 12:40 PM
imureh's Avatar
Liked: 3509
I would still take dual 18s for the price of one 21inch.
imureh is offline
post #82 of 90 Old 09-15-2019, 12:44 PM - Thread Starter
Liked: 1726
Again, no specifics as I haven't talked to him further but he had said it would be in the size range of their 21.0 cabinet (so ~26" wide, ~24" deep, ~30" high) with a 2400w amp
post #83 of 90 Old 09-15-2019, 12:48 PM - Thread Starter
Liked: 1726
It wasn't until my new (smaller) AV stand came in this week and I put it together that I realized I can't fit duals upfront due to my fish tank. Relocating that would be...not an option lol. So at least for this room in my condo, which I will be in for the next 4 years minimum, a single sub is my limit in terms of fitting them. Behind the couch was also ruled out as a potential spot. So while I get my stupid tuition crap figured out this week, the "choices" are more clear in that whatever sub I finally get (as long as my funds are no longer in question once it is all straightened out) can only be a single regardless of price.
post #84 of 90 Old 09-15-2019, 12:56 PM
Liked: 2724
If Nathan is talking about the trade in 21.0 in Sequoia Burl then yes 2400watt amp. According to specs (in room) response is averaging about 108DB's from 20Hz to 10Hz and low 120's above that.
I have no idea (if that is the sub in question) what he is offering it to you for, but website says $6K if that's the one on his "specials" page. I do agree with Imureh that if there is room for two 18"'s i'd take that option over a singe 21". Having said that,,,, i can say my two 21.0LX subs in an "open" 2400^3 room to the rest of the small house 10,000^3 will pressurize the house enough to bend windows in multiple rooms,, so a single in a 2700^3 sealed room should do pretty well even though it doesn't have the LX driver imo. Just saying!!
I missed the "new from in house parts" part of your post. Didn't cross my mind you would be offered any version of a "new" 21" that would be anywhere near your budget. As Marc mentioned if thats the case Nathan can set you up for more ULF capability either by tweaking the driver or the larger cabinet, or a combination of both.
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
post #85 of 90 Old 09-15-2019, 02:04 PM
Marc Alexander's Avatar
Quoted: 5457 Post(s)
Liked: 4952
How well? Superbly
This is the larger cabinet that is used for the 24.0 and the 21.0L.
I just happen to own both the FV18 and dual Funk 21s in the larger cabinet. If Nathan can work within your budget the 21 is a no-brainer IMO.
This larger cabinet allows Nathan several driver options as well as 2400W or 4800W amp, all according to your needs & budget. Getting a non-veneered, black finish will save you quite a bit. It is still superior to any other ID sub's standard finish as it still utilizes the curved cabinet and rounded edges. That being said, it was worth it to me to get a veneer. It is not too much extra if he has enough surplus veneer from another project.
When Nathan has subs in the outlet (which aren't prototypes) they are usually customer trade-ins/returns. You can offer less than is listed if the original owner agrees. This is how returns (and trades) work with Funk Audio. Because everything is built custom to-order, you don't get your refund until the sub is resold via the outlet. Or you can choose to sell yourself. Which reminds me, I have a several subs I need to sell, including a pair of Funk DO12s (20x20x20 in³). BCJ, if you could fit duals in this dimension send me a PM or ask Nathan about dual 18.0Cs (20x20x20 in³). They aren't listed on the website anymore but he can still build them.
I have the 4800W (2x2400W) amp powering both 21s. The driver Nathan used for me provides the output close to the 24.0 ≤40Hz and the 21.0L ≥ 40Hz at a much lower cost than the 21.0L or 24.0.
Let me know if you have further questions.
Marc Alexander is offline
post #86 of 90 Old 09-15-2019, 02:24 PM
jsc79's Avatar
Quoted: 400 Post(s)
Liked: 480
Originally Posted by Marc Alexander View Post
How well? Superbly
Is the sound signature between the Funks and the Rythmiks(assume high damping)similar?
jsc79 is offline
post #87 of 90 Old 09-16-2019, 12:45 PM - Thread Starter
Liked: 1726
Talked with Nathan some more today. He offered me a 21.0L cabinet with some "B stock" parts (2400w amp with one bent fin and a driver with an imperfection that doesn't affect performance). Final price fits within my budget if I really stretch it and assume I can sell my current Funk. So that seems like the logical choice
sk373 likes this.
post #88 of 90 Old 09-16-2019, 01:05 PM
Liked: 2724
Call him back with your deposit ASAP!!!!!! Did you ask if he would take the 18.1 in to reduce cost more?
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
post #89 of 90 Old 09-16-2019, 01:07 PM
tvuong's Avatar
Liked: 2315
This ^^^
NOW! Tell him you want a low tuned ported 21".
CallingMrBenzo and sk373 like this.
tvuong is offline
post #90 of 90 Old 09-16-2019, 02:45 PM - Thread Starter
Liked: 1726
Well. Paid him. He said it would take about a month to put together. Time to wait.
