Ideas to get duct tape residue off duratex - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 1 Post By imrf
  • 1 Post By Ryan Statz
  • 1 Post By RayGuy
post #1 of 11 Old 09-08-2019, 06:27 PM - Thread Starter
jsb75's Avatar
Quoted: 350 Post(s)
Liked: 88
Got a older hsu sub with the duratex finish, and the guy used duct tape all over it to tape cardboard over the speaker to move it. Any idea how to get the tape residue off?
jsb75 is offline
post #2 of 11 Old 09-08-2019, 06:29 PM - Thread Starter
jsb75's Avatar
Quoted: 350 Post(s)
Liked: 88
Was going to try goof off, but afraid it might eat the duratex as well
jsb75 is offline
post #3 of 11 Old 09-08-2019, 06:31 PM - Thread Starter
jsb75's Avatar
Quoted: 350 Post(s)
Liked: 88
Was going to try goof off, but afraid it might eat the duratex as well. Tried dang near every over the counter cleaner, and nothing takes it off
jsb75 is offline
post #4 of 11 Old 09-08-2019, 06:52 PM
imrf's Avatar
Quoted: 213 Post(s)
Liked: 143
WD40 gets glue off everything but I can’t promise it won’t remove any duratex. You could try it in a small inconspicuous spot and see. I’ve used it on my vehicles and it didn’t eat the clearcoat or paint.
darthray likes this.
imrf is offline
post #5 of 11 Old 09-08-2019, 09:29 PM
Ryan Statz's Avatar
Quoted: 372 Post(s)
Liked: 152
What I use to get tape residue off of things is actually other tape - packing tape or masking tape. I do it by making a tape loop (sticky side out), and lightly tap the surface with enough pressure to make contact to stick to the surface, and quickly lift the tape up - the tape should grab onto the residue, and lift it off of the surface. It takes a few times to get it to lift off sometimes. Not knowing what kind of surface duratex is, do it in an inconspicuous spot first.
It's gentle enough, and doesn't use any chemicals that could eat away at the finish.
Leon! likes this.
Home Theatre: Onkyo TX-NR747 | Polk Audio RTi A3 Front L/R | Polk Audio CSi A6 Centre | Polk Audio RTi A1 Surround L/R | Elac S10EQ Subwoofer | Sony XBR55X900E | PlayStation 4 Pro | Xbox One S
Music: Cambridge Audio AXR100 | Stanton T.62 | Cambridge Audio AXC35 | KEF Q150 x 2 (upcoming) | Subwoofer TBD
Ryan Statz is online now
post #6 of 11 Old 09-08-2019, 09:57 PM
bobknavs's Avatar
Quoted: 2274 Post(s)
Liked: 1615
A semi-odd suggestion: mayonnaise.
I believe that it's the vegetable oil that does the work. The emulsifier just keeps it from running.
I have used it to remove the residue from the stickers that auto dealers put on new cars they've sold. (I always peel them off. I don't care to advertise where I bought my car.)
I can't swear that it won't attack Duratex, but I know of no gentler solvent that would be of any use.
Thanks to my friend Vicki for the original suggestion.
bobknavs is offline
post #7 of 11 Old 09-08-2019, 10:16 PM
Ryan Statz's Avatar
Quoted: 372 Post(s)
Liked: 152
Leon! likes this.
post #8 of 11 Old 09-09-2019, 04:26 PM - Thread Starter
jsb75's Avatar
Quoted: 350 Post(s)
Liked: 88
Thanks for the replies. Will give some off the suggestions a shot
jsb75 is offline
post #9 of 11 Old 09-09-2019, 04:56 PM
MRAYB's Avatar
Quoted: 252 Post(s)
Liked: 520
Goo-Gone, citrus based. NOT Goof. I think my lawnmower would run off that stuff.
MRAYB is online now
post #10 of 11 Old 09-09-2019, 05:27 PM
Leon!'s Avatar
Quoted: 289 Post(s)
Liked: 147
You're gonna need more duratex.
Leon! is offline
post #11 of 11 Old 09-11-2019, 01:05 PM
RayGuy's Avatar
Quoted: 2810 Post(s)
Liked: 2582
Second Goo Gone.
MRAYB likes this.
It's a VIRTUAL channel unless stated otherwise.
RayGuy is online now
