inuke/nx3000d buttkicker DSP/EQ settings? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-09-2019, 09:03 AM - Thread Starter
lawdogx's Avatar
Quoted: 132 Post(s)
Liked: 159
Does anyone have experience dialing in Buttkicker transducers with an inuke/NX series amp? I'm running a pair of Mini LFE's run in series off one channel of an NX3000d. I have my mind around the voltage, gain, and timing issues. My questions are about EQing the high end low ends:
On the high end I'm currently using a LPF at 45Hz with a BW12 slope. Wherever you set the LPF seems like personal taste and I'm playing with that now. Whatever it is, is there any consensus on whether you guys are running step or shallow slopes?
On the low end I'm currently just running it wide open. I've read that some folks are boosting the low end with the "inuke 20Hz workaround" and others are actually filtering it with HPF's. Has anyone played with this that can offer some insight?
SPEAKERS: 3 x DIYSG 1099's LCR; DIYSG HTM 6's and 8's surround; 4 x RSL C34E's atmos.
SUBS: 4 x UM18-22 Mini Marty's (and always building, currently working on VBSS's).
SIGNAL CHAIN: Denon X4400; Minidsp 2x4 HD; 2 x Jensen Iso Sub 2RX; 2 x NX6000d.
lawdogx is offline
post #2 of 2 Old 09-09-2019, 09:22 AM
imureh's Avatar
Quoted: 2804 Post(s)
Liked: 3478
Check out this thread
The Tactile Response Thread for BASS )
https://r.tapatalk.com/shareLink?sha...0&share_type=t
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser, 2 BK LFE
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is offline
