Bass shakers off zone2/ampassign - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-09-2019, 04:59 PM - Thread Starter
mginster's Avatar
Quoted: 29 Post(s)
I have a denon 2400h and want to add bass shakers to my existing 5.1. I figured I could try to use the 2 extra outputs from zone2. I imagine this would work easily but the issue is getting it to be low pass only. I dont want them hitting for everything. I have tried to find some in line low pass filters similar to bass blockers, but am not having any luck.
mginster is offline
post #2 of 3 Old 09-09-2019, 07:01 PM
Quoted: 328 Post(s)
Liked: 961
While this could technically work, I'm not sure it is a great idea. AVRs don't have dedicated power to each channel so any power required to drive the shakers is going to take power away from the rest of the speakers. You will likely run out of amp power pretty quickly.
Electronics: Denon X4400, Vizio M65
Sub: PSA TV36-iPal
Speakers: 3 x Chane A2.4 LCR, Klipsch Quintet Surrounds
chucks0 is offline
post #3 of 3 Old 09-12-2019, 10:24 AM
sivadselim's Avatar
Quoted: 438 Post(s)
Liked: 385
One thing you might want to try is splitting the AVR's sub out (twice if you already have sub connected) and looping that back into an unused pair of L/R analog inputs (for example, 'CD') which you would then assign to Zone2. This way what you are sending to Zone2 will already be low-passed at either the AVR's speaker channel crossover settings or, for the LFE channel bass, at the LFE channel's ceiling.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
