AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Subwoofers, Bass, and Transducers (https://www.avsforum.com/forum/113-subwoofers-bass-transducers/)
-   -   building a subwoofer with a passive radiator (https://www.avsforum.com/forum/113-subwoofers-bass-transducers/3091390-building-subwoofer-passive-radiator.html)
DiscoMike 09-17-2019 04:41 PM
Cana subwoofer be built with an active subwoofer as the motor to be used with passive radiators on each side in a sealed box?
I love the sound of passive radiators. It gives layers and layers of Bass which an active aub cannot do on it's own. I want to use it in a seperate enclosure from the bookshelf speakers that I have.
Hells, I am even thinking of adding a couple of woofers to the project.
Gorilla Killa 09-17-2019 05:19 PM
Enclosures with PR's act as ported. You can use a small box, no ports or resonance issues. You HAVE to use a driver with a motor to push the PR's.
DiscoMike 09-18-2019 09:01 AM
Thanks for the info. I have a couple of active subwoofer drivers I plan to use. I am figuring two pasaives on opposite sides with one active sub in each cabinet (I plan to make 2 cabinet's since I have two sub drivers) with the active sub connecting to an amp. The cross-over will be a dsp.
Any thoughts on bracing and cabinet dimensions since it will be a closed cabinet? I know, I have to look at this more on the web for further info.
I figure it would be interesting to find out if anyone haa personal experience using a pr/sub cabinet design.
Gorilla Killa 09-19-2019 03:04 AM
You need to download WinISD and you can model it. The link below is a cliff notes of sorts. Doing it will give you a better understanding which you seem to want. I don't have any personal experience wit PR subs.
http://audiojudgement.com/how-to-tune-passive-radiator/
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
