Suggestions for HT sub - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By eljaycanuck
post #1 of 13 Old 09-20-2019, 05:45 PM - Thread Starter
Quoted: 13 Post(s)
Liked: 2
Hey all,
Working on a new basement HT. Size is 20’ wide x 15’ Deep x 7’ high open to rest of basement (approx. 600sqft.).
Denon 4400 Avr
Silver ticket in wall/ceiling speakers 7.?.4
50% sports fibre
25% gaming
25% movies
Need recommendations for subwoofers. Budget is 1.5k Canadian.
All recommendations welcome. I’m thinking either;
1. Dual svs pb 1000
2. Dual monolith 10”
3. Single svs pb 2000
4. Single monolith 12”
5. Dual vft 2 mk5
6. Single vft 3 mk5
Very torn.....Help!!!
Rick Lajeunesse is offline
post #2 of 13 Old 09-21-2019, 05:30 PM
eljaycanuck's Avatar
Quoted: 1894 Post(s)
Liked: 2662
Concrete floor, 4200+ cu.ft. I'd start with the VTF-3 or Monolith 12" and double up when additional funds become available.
eljaycanuck is offline
post #3 of 13 Old 09-22-2019, 05:13 AM - Thread Starter
Quoted: 13 Post(s)
Liked: 2
Thanks. Just to clarify, the HT room is partially open (blocked by a 42” high seating bar wall). There is a 5 foot wide full opening. Does your recommendation remain the same?
post #4 of 13 Old 09-22-2019, 06:00 AM
Liked: 2662
Yes. The biggest factor (IMO) is that you're on concrete. Buy two "lesser" subs now and you may find yourself trying to sell both in order to upgrade. Buy one more-powerful sub now and:
- if you're satisfied with its performance, you're done;
- if you feel you need more, simply add another when additional funds become available.
post #5 of 13 Old 09-23-2019, 10:18 AM
Writer & Reviewer
JimWilson's Avatar
Quoted: 2218 Post(s)
Liked: 3366
Post # 2? Some things never change...
You're correct; large space + concrete = significant subwoofer(s). The sports viewing will likely be OK, but movies and games would go lacking unless there was sufficient output and depth potential available.
If you take yourself too seriously expect me to do the exact opposite...
JimWilson is offline
post #6 of 13 Old 09-23-2019, 10:23 AM
Liked: 2662
Sometimes I'm PN2 but you are always the (J)man!
JimWilson likes this.
post #7 of 13 Old 09-23-2019, 03:41 PM - Thread Starter
Quoted: 13 Post(s)
Liked: 2
Ok. Being from Canada, HSU doesn’t really work for warranty. I wish it did.
So switching gears, and after some pricing research. I can swing either one monolith 12 or two pb 2000. Either of these two options can be fixed with free shipping in Canada.
post #8 of 13 Old 09-23-2019, 05:03 PM
Enovare's Avatar
Liked: 7
Dual PB2000 You can not go wrong!
Enovare is offline
post #9 of 13 Old 09-23-2019, 05:33 PM
Liked: 2662
... after some pricing research. I can swing either one monolith 12 or two pb 2000. Either of these two options can be fixed with free shipping in Canada.
A pair of PB-2000s will have plenty of output and solid sub-20Hz extension. And they come with SVS' top-notch customer support. The Monolith 12" is reportedly better but I'm not sure it's worth the $337 premium up here ($1416 for a Mono 12" vs. $1079 for a PB-2000).
post #10 of 13 Old 09-23-2019, 05:47 PM
Writer & Reviewer
JimWilson's Avatar
Liked: 3366
Add another yes vote for dual PB 2000's.
post #11 of 13 Old 09-23-2019, 05:55 PM - Thread Starter
Quoted: 13 Post(s)
Liked: 2
Thanks for the replies....dual pb 2000 it is. As these are my 1st good subs, is there a setup procedure outlining sub settings? Hopefully something geared towards my Denon avr 4400?
post #12 of 13 Old 09-23-2019, 06:17 PM
Writer & Reviewer
JimWilson's Avatar
Liked: 3366
Check out the calibration thread. There is no question you could have that the guide doesn't cover.
post #13 of 13 Old 09-23-2019, 06:26 PM - Thread Starter
Quoted: 13 Post(s)
Liked: 2
Thanks Jim....you guys are great!
